[General] Quiz Authoritative SAP - Free C_S4EWM_2023 Test Questions
103
【General】 Quiz Authoritative SAP - Free C_S4EWM_2023 Test Questions
Posted at 2/21/2026 10:37:05      View:102 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ActualTestsQuiz C_S4EWM_2023 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1QODihTlkaKA0Jmb8T38aJx4KMiubKtRK
With the development of society, SAP industry has been tremendously popular. And more and more people join SAP C_S4EWM_2023 certification exam and want to get SAP certificate that make them go further in their career. This time you should be thought of ActualTestsQuiz website that is good helper of your exam. ActualTestsQuiz powerful exam dumps is experiences and results summarized by C_S4EWM_2023 experts in the past years, standing upon the shoulder of predecessors, it will let you further access to success.
We stick to the principle "Credit management first and first class service". While purchasing our C_S4EWM_2023 exma questions, not only you have no need to worry about the quality of our C_S4EWM_2023 exam materials quality but also our service is satisfying on the C_S4EWM_2023 study guide. We promise buyers “Pass Guaranteed” and we only offer the latest C_S4EWM_2023 Training Materials. If you would like to choose safely high passing rate of C_S4EWM_2023 exam torrent materials, our C_S4EWM_2023 learning guide will be the first choice for you.
SAP C_S4EWM_2023 Reliable Exam Answers | C_S4EWM_2023 Latest ExamOften candidates fail the C_S4EWM_2023 exam due to the fact that they do not know the tactics of attempting the SAP Certified Associate - SAP S/4HANA Cloud Private Edition, Extended Warehouse Management (C_S4EWM_2023) exam in an ideal way. The decisive part is often effective time management. Some SAP C_S4EWM_2023 Exam Questions demand more attention than others, which disturbs the time allotted to each topic. The best way to counter them is to use an updated C_S4EWM_2023 Dumps.
SAP Certified Associate - SAP S/4HANA Cloud Private Edition, Extended Warehouse Management Sample Questions (Q30-Q35):NEW QUESTION # 30
Which fields in the warehouse process type are used to determine warehouse order creation rules (WOCR)?
  • A. Activity
  • B. Storage process
  • C. WOCR activity area
  • D. Process type determination indicator
Comprehensive and Detailed In-Depth Explanation:
Warehouse order creation rules (WOCR) in SAP EWM are determined by fields in the warehouse process type. Option B ("WOCR activity area") is correct as it links the process type to a specific area for task grouping, and option C ("Activity") is correct because it specifies the task type (e.g., PICK), both set in SPRO: SCM Extended Warehouse Management > Cross-Process Settings > Warehouse Task > Define Warehouse Process Type. Option A (Storage process) and option D (determination indicator) influence other processes, not WOCR directly.
NEW QUESTION # 31
Your customer wants to implement the material flow system (MFS) to control conveyors and the automated high rack storage are a. Which standard options do you have to communicate with the programmable logic controllers (PLC)? Note: There are 2 correct answers to this question.
  • A. Directly integrate to the PLC using ABAP Push Channels
  • B. Send an IDoc through a Post Processing Framework action to the PLC
  • C. Use the ALE interface to send an IDoc to a 3rd party software
  • D. Use an RFC adaptor (e.g., SAP Plant Connectivity)
The Material Flow System (MFS) in SAP EWM integrates with PLCs for automation. Option B ("Directly integrate to the PLC using ABAP Push Channels") is correct as it enables real-time communication via WebSockets, configured in SPRO: SCM Extended Warehouse Management > Material Flow System > Communication. Option D ("Use an RFC adaptor (e.g., SAP Plant Connectivity)") is correct because SAP Plant Connectivity (PCo) uses RFC to connect EWM to PLCs. Option A (ALE/IDoc) and option C (PPF/IDoc) are not standard for direct PLC communication; they're more suited for system-to-system data exchange.
NEW QUESTION # 32
Which options are available in the packing profile that is assigned to the warehouse order creation rule? Note:
There are 3 correct answers to this question.
  • A. Limit the number of items to be packed in the pick handling unit.
  • B. Consider length, width, and height.
  • C. Create items in the outbound delivery for the packaging material.
  • D. Use a simple algorithm, a complex algorithm, or a BAdl.
  • E. Skip a warehouse task that no longer fits into the pick handling unit.
Answer: B,D,E
The packing profile assigned to the warehouse order creation rule determines how items are packed into handling units. Key options include:
* A. Consider Length, Width, and Height:
* Ensures that the dimensions of goods are considered for optimized packing into handling units.
* C. Use a Simple Algorithm, a Complex Algorithm, or a BAdI:
* Packing logic can be defined using simple or complex algorithms, or custom implementations via a BAdI (Business Add-In).
* D. Skip a Warehouse Task That No Longer Fits Into the Pick Handling Unit:
* Allows the system to skip tasks when items exceed the capacity of the handling unit.
Incorrect Options:
* B: Creating items for packaging materials in the outbound delivery is not a standard packing profile feature.
* E: Limiting the number of items packed is typically managed via capacity constraints, not packing profiles.
* SAP Help Portal: Packing Profile in Warehouse Order Creation
* SAP EWM Documentation: Packing Profile Customization
NEW QUESTION # 33
What can a mobile user do when working with semi-system-guided processing?
  • A. Select the handling unit to be processed
  • B. Create ad hoc warehouse tasks
  • C. Select the batch to be processed
  • D. Select the warehouse order to be processed
Semi-system-guided processing in SAP EWM (via RF, e.g., /SCWM/RFUI) provides flexibility. Option A ("Select the warehouse order to be processed") is correct as users can choose from a list of orders, configured in SPRO: SCM Extended Warehouse Management > Mobile Data Entry > Define Semi-System-Guided Processing. Options B, C, and D are either system-driven or not standard in this mode.
NEW QUESTION # 34
Which physical inventory procedure is storage-bin-specific only? Note: There are 2 correct answers to this question.
  • A. Ad hoc physical inventory procedure
  • B. Low stock physical inventory procedure
  • C. Periodic physical inventory procedure
  • D. Zero stock physical inventory procedure
Storage Bin-Specific Physical Inventory Procedures
* Low Stock (A): Triggered when stock in a bin falls below a predefined threshold.
* Zero Stock (B): Conducted when a bin is expected to be empty, ensuring no discrepancies.
Excluded Options
* C (Periodic): Applies to storage bins or sections but is not bin-specific.
* D (Ad Hoc): Can be applied to multiple bins but is not restricted to specific bins.
SAP S/4HANA Cloud Private Edition Reference
* Refer to Physical Inventory Procedures in SAP EWM for setup details.
NEW QUESTION # 35
With C_S4EWM_2023 test guide, you only need a small bag to hold everything you need to learn. In order to make the learning time of the students more flexible, C_S4EWM_2023 exam materials specially launched APP, PDF, and PC three modes. With the APP mode, you can download all the learning information to your mobile phone. In this way, whether you are in the subway, on the road, or even shopping, you can take out your mobile phone for review. C_S4EWM_2023 study braindumps also offer a PDF mode that allows you to print the data onto paper so that you can take notes as you like and help you to memorize your knowledge. At the same time, regardless of which mode you use, C_S4EWM_2023 test guide will never limit your download times and the number of concurrent users. For the same information, you can use it as many times as you want, and even use together with your friends.
C_S4EWM_2023 Reliable Exam Answers: https://www.actualtestsquiz.com/C_S4EWM_2023-test-torrent.html
So the clients can enjoy more benefits after they buy our C_S4EWM_2023 study materials, SAP Free C_S4EWM_2023 Test Questions Only a coward will give in to his fate, SAP Free C_S4EWM_2023 Test Questions Once you have any doubt or advice about our product & service you can talk with us via online system or email any time, Everyone wants to seek for the best valid and efficient way to prepare for the C_S4EWM_2023 actual test.
From the following dialog box, select the rsLogin recordset, Deleting a Song from Your iPod, So the clients can enjoy more benefits after they buy our C_S4EWM_2023 study materials.
Only a coward will give in to his fate, Once C_S4EWM_2023 you have any doubt or advice about our product & service you can talk with us via online system or email any time, Everyone wants to seek for the best valid and efficient way to prepare for the C_S4EWM_2023 actual test.
Pass Guaranteed Quiz SAP - Useful C_S4EWM_2023 - Free SAP Certified Associate - SAP S/4HANA Cloud Private Edition, Extended Warehouse Management Test QuestionsWhen it comes to our time-tested C_S4EWM_2023 latest practice dumps, for one thing, we have a professional team contains a lot of experts who have devoted themselves to the research and development of our C_S4EWM_2023 exam guide, thus we feel confident enough under the intensely competitive market.
