[General] Actual Juniper JN0-224 Exam Question For Quick Success
88
General Actual Juniper JN0-224 Exam Question For Quick Success
Posted at 2/21/2026 11:50:32      View117 | Replies0        Print      Only Author   [Copy Link] 1#
Choosing our JN0-224 exam quiz will be a wise decision that you make, because this decision may have a great impact in your future development. Having the certificate may be something you have always dreamed of, because it can prove that you have certain strength. Our JN0-224 exam questions can provide you with services with pretty quality and help you obtain a certificate. Our JN0-224 Learning Materials are made after many years of practical efforts and their quality can withstand the test of practice. And you will obtain the JN0-224 certification just for our JN0-224 study guide.
Juniper JN0-224 Exam Syllabus Topics:
  • Data Serialization: This domain addresses YAML and JSON formats used for structured data representation and exchange in network automation workflows.
  • Python
  • PyEZ: This domain examines Python programming with PyEZ library for Junos automation, including JSNAPy, Jinja2 templates, RPC calls, exception handling, and device configuration management.
  • Junos Automation Stack and DevOps Concepts: This domain covers fundamental automation tools, frameworks, APIs, and DevOps culture applicable to Junos platform operations and network management.
  • NETCONF
  • XML API: This domain focuses on XML syntax, XPath expressions, NETCONF protocol, and XML API functionality for programmatic device configuration and communication.
Topic 5
  • Rest API: This domain covers Junos REST API implementation, REST API Explorer tool, and cURL usage for HTTP-based device management and configuration.
JN0-224 Latest Test Answers | JN0-224 Mock ExamWith the most scientific content and professional materials JN0-224 preparation materials are indispensable helps for your success. Such a valuable acquisition priced reasonably of our JN0-224 study guide is offered before your eyes, you can feel assured to take good advantage of. And we give some discounts from time to time on our JN0-224 Exam Questions for promoting. If you come to visit our website more times, you will buy our JN0-224 practice engine at a more favorable price.
Juniper Automation and DevOps, Associate (JNCIA-DevOps) Sample Questions (Q48-Q53):NEW QUESTION # 48
Which two statements are correct about the Junos REST API Explorer? (Choose two.)
  • A. The REST API Explorer supports multiple RPC calls.
  • B. The REST API Explorer returns data only in XML format.
  • C. The REST API Explorer is enabled by default on all Junos devices.
  • D. The REST API Explorer supports both GET and POST calls.
The Junos REST API Explorer provides an interactive environment to explore and execute REST API calls. The correct statements are:
Supports GET and POST Calls (C): The REST API Explorer allows users to make both GET and POST requests, enabling retrieval and submission of data to the Junos device.
Supports Multiple RPC Calls (D): The REST API Explorer can execute multiple RPC (Remote Procedure Call) commands, allowing a wide range of operations to be performed directly through the interface.
Option A is incorrect because the REST API Explorer is not enabled by default; it must be enabled manually. Option B is incorrect because the REST API Explorer returns data in both XML and JSON formats, not just XML.
Junos REST API Explorer Documentation: Provides details on the supported operations and how to use the Explorer for different types of requests.
Juniper Networks Documentation: Covers the setup and usage of the REST API Explorer.
NEW QUESTION # 49
You must use Junos PyEZ to configure unique IP addresses on individual machines.
Which two features will permit this requirement? (Choose). Ian SCP module
  • A. an SCP module
  • B. a BSON data file
  • C. a YAML data file
  • D. a Jinja2 template
To configure unique IP addresses on individual machines using Junos PyEZ, you can use the following features:
YAML Data File (C): YAML files are used to store configuration data in a human-readable format. They are often used in combination with Jinja2 templates to provide the data necessary for template rendering.
Jinja2 Template (D): Jinja2 is a templating engine for Python that allows you to create dynamic templates. When used with Junos PyEZ, a Jinja2 template can be filled with data (such as IP addresses from a YAML file) to generate configuration snippets that are applied to different devices.
Options A (SCP module) and B (BSON data file) are not typically used with Junos PyEZ for this purpose.
Junos PyEZ Documentation: Discusses the use of YAML files and Jinja2 templates for generating configurations.
Jinja2 Templating Documentation: Provides details on how to create and use templates in Python scripts.
NEW QUESTION # 50
Which two statements about Junos automation are correct? (Choose two.)
  • A. The Junos REST API client is on-box.
  • B. The Junos REST API client is off-box.
  • C. Junos automation does not allow for device provisioning throuqh the console port.
  • D. Junos automation allows for device provisioning through the console port.
A). The Junos REST API client is on-box:
The Junos REST API is on-box, meaning it is hosted directly on the Junos OS device. This allows you to interact with the device through RESTful API calls without needing an external client to act as an intermediary. With the on-box REST API, users can manage and automate configuration and operational tasks directly from the Junos device itself using HTTP/HTTPS protocols. This simplifies automation and remote management since the API server is embedded within the device.
Key Automation Capabilities of On-box REST API:
Supports configuration, monitoring, and operational commands.
Allows for direct device interaction via tools like curl, or through custom-built automation scripts.
C . Junos automation allows for device provisioning through the console port:
Junos automation does indeed allow for device provisioning through the console port, especially in the context of Zero Touch Provisioning (ZTP). When network interfaces are not initially configured, or when remote access is not possible, devices can be provisioned via the console port. This method is commonly used during the initial setup process, enabling administrators to deploy configurations even without network access. ZTP automates initial configurations, including system setup and software installation, which can be triggered via the console.
Key Advantages of Console-based Provisioning:
Useful in environments where network interfaces are unavailable or not yet configured.
Essential for the initial bootstrapping of devices in remote locations.
Why the Other Options Are Incorrect:
B . Junos automation does not allow for device provisioning through the console port: This statement is incorrect because Junos automation does allow for provisioning via the console port, particularly during initial device setups.
D . The Junos REST API client is off-box: This is incorrect because the REST API client can be directly on the Junos device, providing local API functionality (on-box).
Juniper Automation in DevOps Context: Junos automation, especially with on-box REST API and console-based provisioning, enhances the flexibility and accessibility of device management in DevOps environments. These capabilities simplify remote configuration, monitoring, and device setup even in cases where direct network access is unavailable.
NEW QUESTION # 51
Which two statements about NETCONF are true? (Choose two.)
  • A. It uses the messages layer to lock the configuration of a Junos device.
  • B. It uses the messages layer to commit the configuration of a Junos device.
  • C. It uses the operations layer to commit the configuration of a Junos device.
  • D. It uses the operations layer to lock the configuration of a Junos device.
NETCONF (Network Configuration Protocol) operates through different layers, with the operations layer being particularly important for managing configurations:
Operations Layer (A & D): This layer is responsible for actions like locking and committing the configuration on a Junos device. The lock operation prevents other sessions from modifying the configuration, and the commit operation applies the configuration changes to the device.
Options B and C are incorrect because the messages layer handles the communication aspects, such as exchanging data between the client and server, not performing configuration operations like locking and committing.
IETF RFC 6241 (NETCONF): Describes the protocol layers and their functions, with a focus on the operations layer.
Juniper Networks NETCONF Documentation: Provides insights into how NETCONF operations are managed in Junos
NEW QUESTION # 52
You are asked to write an on-box script that will be triggered when a specific interface on a Junos device goes down.
Which type of on-box script should you use to accomplish this task?
  • A. operation
  • B. SNMP
  • C. event
  • D. commit
An event script is used to automate responses to system events in Junos, such as an interface going down. These scripts are triggered automatically when a specified event occurs, making them suitable for tasks like monitoring interface status and executing actions when the status changes.
Option B (event) is correct because event scripts are designed for reacting to system events like an interface going down.
Option A (commit) is used for configuration changes, Option C (operation) is used for operational tasks, and Option D (SNMP) is not applicable in this context.
Supporting Reference:
Juniper Networks Event Scripts Documentation: Details how event scripts are used to automate responses to specific system events in Junos
NEW QUESTION # 53
Maybe there are so many candidates think the JN0-224 exam is difficult to pass that they be beaten by it. But now, you dont worry about that anymore, because we will provide you an excellent exam material. Our JN0-224 exam materials are very useful for you and can help you score a high mark in the test. It also boosts the function of timing and the function to simulate the exam so you can improve your speed to answer and get full preparation for the test. Trust us that our JN0-224 Exam Torrent can help you pass the exam and find an ideal job. If you have any question about the content of our JN0-224 exam materials, our customer service will give you satisfied answers online.
JN0-224 Latest Test Answers: https://www.testsimulate.com/JN0-224-study-materials.html
