1z0-1080-25 PDF} - 1z0-1080-25d
Posted at 2/21/2026 12:03:48
View125
Replies0
혱һ£ԏ녴惦dNewDumps 1z0-1080-25ԇ}棺https://drive.google.com/open?id=1wSvZg8J777iLcy4HZxZArpvFvNF9Ua4y
ĉʲNy㲻IһWҫijɾ͆϶İɡNҪԼ呟ԼITИIй㣬ͨ^ʲN팍FԼĉأУITJԇK@JCYԼˮʵһNʽFڣOracle1z0-1080-25ԇһdzܚgӭĿԇNҲõ@ԇJCYNsoӰɣNewDumpsԎ㣬ԲÓġ
@Oracle 1z0-1080-25JĆNewDumpsWվṩõČWYϣHͨ^1z0-1080-25ԇ߀ڶ̕rgȫ@õijɿ҂ѽܶĿͨ^1z0-1080-25ԇ@ȡC@һyõęCFڣُIOracle 1z0-1080-25}֮]յ҂]ԼrdُI1z0-1080-25}첢L@ӿȫ˽ԔĿԇԇ}Լ𰸡
¸µ1z0-1080-25 PDF}YԇIcI1z0-1080-25Oracle Planning 2025 Implementation ProfessionalNewDumpsһܞܶOracle 1z0-1080-25JCԇITИIIʿṩPoYρõOracle 1z0-1080-25JCCľWվNewDumpsṩČWYNewDumpsYҵSИI͌I֪RоĵģƷ|ǺܺãٶҲdz졣K҂ṩľ}ǺĿԇ}ĿܽӽģһӵġxNewDumps100%_ͨ^ĵһ΅ӵyȱ^ߵČIPIOracle 1z0-1080-25JCԇ
Oracle 1z0-1080-25 ԇV| } | | | } 1 | - Creating System Reports: This section of the exam measures the skills of a Planning Administrator and focuses on system-generated reports that provide insights into application activity.
| | } 2 | - Design forms and dashboards: This section of the exam measures the skills of an EPM Consultant and covers designing planning input forms and visual dashboards to support decision-making.
| | } 3 | - Set Up Planning Security: This section of the exam measures the skills of a Planning Administrator and includes provisioning user roles and assigning appropriate access rights across Planning artifacts and data.
| | } 4 | - Explain the benefits of using Groovy Rules: This section of the exam measures the skills of an EPM Consultant and explains how Groovy scripting enhances rule flexibility and performance.
| | } 5 | - Create and manage navigation flows: This section of the exam measures the skills of an EPM Consultant and involves organizing navigation flows to simplify user interaction in Planning.
| | } 6 | - Import and export data into Planning: This section of the exam measures the skills of a Planning Administrator and covers the process of moving planning data into and out of the system.
| | } 7 | - Import and export metadata into Planning: This section of the exam measures the skills of a Planning Administrator and involves understanding how to bring metadata in and out of Planning applications.
| | } 8 | - Create and run data integrations: This section of the exam measures the skills of an EPM Consultant and involves building data integration flows between different data sources and Planning.
| | } 9 | - Set up Planning and FreeForm Applications: This section of the exam measures the skills of a Planning Administrator and involves setting up Planning applications, including FreeForm apps, to support flexible planning and modeling needs.
| | } 10 | - Report on Planning Data: This section of the exam measures the skills of a Planning Administrator and focuses on generating reports to analyze and present Planning data effectively.
| | } 11 | - Introduction to Planning Modules: This section of the exam measures the skills of an EPM Consultant and introduces the available Planning modules, their integration, and use cases.
| | } 12 | - Map data across applications: This section of the exam measures the skills of an EPM Consultant and includes how to map and align data structures between Planning and other connected applications.
| | } 13 | - Describe Planning features: This section of the exam measures the skills of an EPM Consultant and focuses on recognizing key Planning features that help organizations manage and analyze financial data efficiently.
| | } 14 | - Build validation rules: This section of the exam measures the skills of an EPM Consultant and includes creating rules that validate data entry in forms.
| | } 15 | - Manage Metadata and Data: This section of the exam measures the skills of a Planning Administrator and covers methods for loading and maintaining metadata and data in Planning.
| | } 16 | - Set up valid and invalid intersections and cell-level security: This section of the exam measures the skills of an EPM Consultant and focuses on defining valid data intersections and applying security controls to limit data access at the cell level.
| | } 17 | - Identify metadata and data load options: This section of the exam measures the skills of a Planning Administrator and introduces options available for importing and managing metadata and data within the system.
| | } 18 | - Report on EPM data: This section of the exam measures the skills of a Planning Administrator and covers using reporting tools to analyze data stored in EPM applications.
| | } 19 | - Assign access permissions to artifacts and cells in Planning: This section of the exam measures the skills of a Planning Administrator and involves granting permissions to users for accessing specific Planning objects and data.
| | } 20 | - Manage Rules: This section of the exam measures the skills of an EPM Consultant and covers designing and managing business logic using rules and rulesets to automate calculations.
| | } 21 | - Describe Planning modules: This section of the exam measures the skills of an EPM Consultant and includes identifying different modules like Financials, Workforce, Projects, and Capital.
| | } 22 | - This section of the exam measures the skills of a Planning Administrator and includes understanding how standard and custom dimensions are used, and how dimension hierarchies affect planning structure and outcomes.
| | } 23 | - Provision users and groups. This section of the exam measures the skills of a Planning Administrator and covers how to manage user access by assigning them to appropriate roles and groups.
| | } 24 | - Explain required and user-defined dimensions; how dimension hierarchies impact Planning
| | } 25 | - Manage Forms, Dashboards, and Navigation Flows: This section of the exam measures the skills of an EPM Consultant and includes creating interactive forms and dashboards and setting up navigation flows for a better user experience.
| | } 26 | - Set up and run data maps: This section of the exam measures the skills of a Planning Administrator and focuses on configuring and executing data maps to move data across plan types or applications.
| | } 27 | - Create Reports: This section of the exam measures the skills of a Planning Administrator and involves creating reports that summarize planning activities and outcomes.
| | } 28 | - Planning Overview: This section of the exam measures the skills of an EPM Consultant and covers the general features of Planning. It includes how Planning works, its core capabilities, and how it fits into enterprise performance management.
µ Oracle Enterprise Planning and Budgeting Cloud Service 1z0-1080-25 Mԇ} (Q113-Q118):} #113
You want to copy data between two Planning instances. Which three tasks must you complete so you can copy the data?
- A. Define an EPM Connection to the target instance.
- B. Associate the data map with a form.
- C. Define an EPM Connection to the source instance.
- D. Enable cross-POD mapping on the Smart Push card.
- E. Define a data map with Remote Cube as the target.
𰸣A,B,E
} #114
You want to Input data into Financials. For Financials, there is a predefined navigation flow with cards listed for both Revenue and Expenses. What is the sequence of the cards for Revenue and Expenses?
- A. Overview, Driver and Trend Based, Rolling Forecast, Direct Entry, Income Statement
- B. Assumptions, Direct Input, Driver and/or Trend Based, High Level Overview, Detailed Overview, Summary
- C. Assumptions, Allocations, Detailed Bottom Up, Strategic Top-Down, Direct Input, Overview, Summary
- D. Overview, Assumptions, Allocations, Detailed Bottom-Up, Driver and/or Trend based. Direct Input
𰸣A
}f
In Oracle Planning 2024, Financials provides a predefined navigation flow for entering data, organized into cards that guide users through the planning process for Revenue and Expenses. The navigation flow is designed to streamline data input and analysis, starting with high-level views and moving into detailed entry methods. According to the Oracle documentation, the default sequence of cards for Revenue and Expenses in Financials is: Overview, followed by Driver and Trend Based, Rolling Forecast, Direct Entry, and concluding with Income Statement.
* Overview: Provides a high-level summary of financial data, setting the context for planning.
* Driver and Trend Based: Allows users to input data based on drivers (e.g., units sold) or trends (e.g., historical patterns), a key method for revenue and expense planning.
* Rolling Forecast: Enables continuous forecasting over a defined period, integrating with driver-based inputs.
* Direct Entry: Permits manual data input for specific accounts or line items, offering flexibility.
* Income Statement: Consolidates all inputs into a financial statement view for review.
Option A accurately reflects this sequence as outlined in the Oracle Planning 2024 predefined navigation flow for Financials. Option B includes irrelevant cards like "Allocations" and "Strategic Top-Down," which are not part of the default Financials Revenue and Expenses flow. Option C introduces "High Level Overview" and
"Detailed Overview," which are not standard card names in this context. Option D includes "Allocations" and
"Detailed Bottom-Up," which are more aligned with custom flows or other modules, not the default Financials sequence.
This sequence is part of the out-of-the-box Financials navigation flow, ensuring users follow a logical progression from overview to detailed input and final reporting.
Oracle Planning 2024 Implementation Study Guide: "Working with Navigation Flows in Financials" (docs.
oracle.com, Published 2024-09-10).
Oracle EPM Cloud Documentation: "Planning Revenue and Expenses in Financials" (docs.oracle.com, Published 2023-11-15, updated for 2024).
} #115
You must assign a Planning user with a Cloud EPM predefined role that allows them to create and administer Planning or Planning Modules and service components. This role should also allow them to grant permissions to other users.
Which of the following predefined role must you assign this Planning user?
- A. System Administrator
- B. Service Administrator
- C. Approvals Administrator
- D. Identity Role Administrator
𰸣B
}f
In Oracle Planning 2024, predefined roles in Cloud EPM determine user permissions. The requirement is for a role that allows a Planning user to create and administer Planning or Planning Modules and service components, as well as grant permissions to other users. Among the options:
* A. System Administrator: Incorrect. This role exists in some Oracle systems but is not a Cloud EPM predefined role specific to Planning. It's too broad and not aligned with EPM terminology.
* B. Approvals Administrator: Incorrect. This role manages approval processes (e.g., workflows) but does not include creating/administering applications or granting permissions beyond approvals.
* C. Identity Role Administrator: Incorrect. While this role manages identity and access (e.g., assigning roles), it does not allow creating or administering Planning applications or service components.
* D. Service Administrator: Correct. The Service Administrator role in Cloud EPM allows users to create and manage Planning applications, configure modules and service components (e.g., forms, rules), and assign permissions to other users via access control.
The Service Administrator role is the highest-level predefined role in Oracle EPM Cloud for Planning, encompassing application management and user permission assignments, making it the correct choice.
Oracle Planning 2024 Implementation Study Guide: "Predefined Roles in Cloud EPM" (docs.oracle.com, Published 2024-08-25).
Oracle EPM Cloud Documentation: "Managing Users and Roles" (docs.oracle.com, Published 2023-10-30, updated for 2024).
} #116
Which three application types can you create and edit Groovy Rules?
- A. Hybrid
- B. Module (Enterprise)
- C. Custom
- D. FreeForm
- E. Reports
𰸣B,C,D
} #117
Which three are required when enabling Flexible Account Mapping in Workface?
- A. Enable Flexible Account Mapping only when you bring your own chart of accounts in Financials.
- B. Enable Financials and the Financials Expense planning option to enable this feature.
- C. For Mapping Level, specify whether the mapping should be done at the Global level (the same mapping for every entity) or at the Entity level.
- D. Map Salary and Merit from Workface to the same account in Financials and Projects.
- E. Specify whether Mapping Drivers should be based on Grade or on Defaults for the application.
𰸣B,C,E
} #118
QُINewDumpsOracle1z0-1080-25Ŀ}֮ǰ㌢һMIJԇ}ԇã@һ֪NewDumpsOracle1z0-1080-25ԇӖYϵƷ|ϣNewDumpsOracle1z0-1080-25ԇYʹx
1z0-1080-25d: https://www.newdumpspdf.com/1z0-1080-25-exam-new-dumps.html
- |1z0-1080-25 PDF}죬µČWYώpͨ^1z0-1080-25ԇ 🚇 ⮆ tw.fast2test.com ⮄µģ 1z0-1080-25 }1z0-1080-25}YԴ
- ֵه1z0-1080-25 PDF}YԇеIȹ̺ͿԇJCOracle Oracle Planning 2025 Implementation Professional 🥭 ➤ [url]www.newdumpspdf.com ⮘✔ 1z0-1080-25 ️✔️ԫ@ȡMd1z0-1080-25JCԇ[/url]
- Pass-Sure 1z0-1080-25 PDF}YԇеIȹ̺1z0-1080-25Oracle Planning 2025 Implementation Professional 🏨 _ [url]www.vcesoft.com K⏩ 1z0-1080-25 ⏪ԫ@ȡMd1z0-1080-25ԇYӍ[/url]
- ]1z0-1080-25 PDF}죬Oracle Oracle Enterprise Planning and Budgeting Cloud ServiceJC1z0-1080-25ԇ}ṩMd ✴ ڣ [url]www.newdumpspdf.com 1z0-1080-25 K@ȡMd1z0-1080-25ԇ[/url]
- 1z0-1080-25} 🛑 1z0-1080-25d 👤 1z0-1080-25}YԴ 🚧 tw.fast2test.com ➥ 1z0-1080-25 🡄p@ȡMd1z0-1080-25ԇYӍ
- ֵه1z0-1080-25 PDF}YԇеIȹ̺ͿԇJCOracle Oracle Planning 2025 Implementation Professional ⏬ }uWַ⇛ [url]www.newdumpspdf.com ⇚_K 1z0-1080-25 Md1z0-1080-25}[/url]
- 1z0-1080-25 PDF}ͨ^Oracle Planning 2025 Implementation Professionalԇ 🕷 _ [url]www.pdfexamdumps.com K➤ 1z0-1080-25 ⮘ԫ@ȡMd1z0-1080-25ԇĵ[/url]
- [url=http://carriagetoursofsavannah.com/?s=1z0-1080-25%e8%80%83%e9%a1%8c%e8%b3%87%e6%ba%90%20%f0%9f%9b%a3%201z0-1080-25%e6%9b%b4%e6%96%b0%20%f0%9f%8e%ae%201z0-1080-25%e9%a1%8c%e5%ba%ab%e6%9c%80%e6%96%b0%e8%b3%87%e8%a8%8a%20%f0%9f%95%a1%20%e4%be%86%e8%87%aa%e7%b6%b2%e7%ab%99%e2%8f%a9%20www.newdumpspdf.com%20%e2%8f%aa%e6%89%93%e9%96%8b%e4%b8%a6%e6%90%9c%e7%b4%a2[%201z0-1080-25%20]%e5%85%8d%e8%b2%bb%e4%b8%8b%e8%bc%891z0-1080-25%e9%a1%8c%e5%ba%ab%e6%9c%80%e6%96%b0%e8%b3%87%e8%a8%8a]1z0-1080-25}YԴ 🛣 1z0-1080-25 🎮 1z0-1080-25}YӍ 🕡 ԾWվ⏩ www.newdumpspdf.com ⏪_K[ 1z0-1080-25 ]Md1z0-1080-25}YӍ[/url]
- 1z0-1080-25}YӍ 🐼 1z0-1080-25 🃏 1z0-1080-25ԇYӍ 🦇 ⇛ [url]www.pdfexamdumps.com ⇚WվdM▛ 1z0-1080-25 ▟}ռ1z0-1080-25d[/url]
- Md1z0-1080-25} 🔛 1z0-1080-25}YӍ 🤱 1z0-1080-25Wָ 🤣 [url]www.newdumpspdf.com Wվ 1z0-1080-25 KMd1z0-1080-25}[/url]
- 1z0-1080-25ԇY 🏉 1z0-1080-25ԇĵ 🙌 1z0-1080-25}YӍ 🛤 ▷ [url]www.pdfexamdumps.com ◁µģ 1z0-1080-25 }1z0-1080-25JCԇ[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, my.anewstart.au, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
Google DriveMdµNewDumps 1z0-1080-25 PDF濼ԇ}죺https://drive.google.com/open?id=1wSvZg8J777iLcy4HZxZArpvFvNF9Ua4y
