[General] Free PDF Quiz 2026 Marvelous Oracle 1z0-076 100% Exam Coverage
108
General Free PDF Quiz 2026 Marvelous Oracle 1z0-076 100% Exam Coverage
Posted at 2/21/2026 13:09:46      View139 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Oracle 1z0-076 dumps are available on Google Drive shared by TestPassKing: https://drive.google.com/open?id=1aLFw7_dRiLDd3akpsxqEmUsjuYM7Y_GI
Oracle Database 19c: Data Guard Administration (1z0-076) PDF dumps are the third and most convenient format of the Oracle Database 19c: Data Guard Administration (1z0-076) PDF questions prep material. This format is perfect for busy test takers who prefer to study for the Oracle Database 19c: Data Guard Administration (1z0-076) exam on the go. Questions bank in the TestPassKing Oracle 1z0-076 Pdf Dumps is accessible via all smart devices. We also update Oracle Database 19c: Data Guard Administration (1z0-076) PDF questions regularly to ensure they match with the new content of the 1z0-076 exam.
We have been developing our 1z0-076 practice engine for many years. We have no doubt about our quality of the 1z0-076 exam braindumps. Our experience is definitely what you need. And especially our professional experts have been devoting in this field for over ten years. I believe no one can know the 1z0-076 training guide than them. To combine many factors, 1z0-076 real exam must be your best choice.
Practice Test Oracle 1z0-076 Fee - 1z0-076 Exam Testking1z0-076 practice material contains questions & answers together with explanations. You can do your 1z0-076 study plan according to your actual test condition. If your time is limited, you can remember the questions and answers for the 1z0-076 preparation. While, if your time is enough for well preparation, you can study and analyze the answers with the help of the 1z0-076 Exam explanations. No matter in which way you study for the Oracle certification, our 1z0-076 valid pdf dumps will ensure you 100% pass.
Oracle 1z0-076 Exam Syllabus Topics:
  • Performing Role Transitions: Here, the concept of database roles is explained, along with the steps for performing switchovers, failovers, and maintaining physical standby sessions during role transitions.
  • Patching and Upgrading Databases in a Data Guard Configuration: This section provides guidance on patching and upgrading databases in a Data Guard environment, along with performance optimization techniques and monitoring considerations.
  • Oracle Data Guard Broker Basics: An overview of the Data Guard broker, its architecture, components, benefits, and configurations, is provided here. It serves as an introduction to the tool used for managing Data Guard configurations.
Topic 6
  • Monitoring a Data Guard Broker Configuration: The topic covers the use of Enterprise Manager and DGMGRL to monitor Data Guard configurations and explains the various data protection modes available.
Topic 7
  • Creating a Data Guard Broker Configuration: This section delves into the practical aspects of creating and managing a Data Guard broker configuration, including command-line and Enterprise Manager approaches.
Topic 8
  • Creating a Logical Standby Database: This topic guides users through the process of creating and managing a logical standby database, including SQL Apply filtering.
Topic 9
  • Enhanced Client Connectivity in a Data Guard Environment: This topic focuses on enhancing client connectivity in a Data Guard setup and implementing failover procedures for seamless client redirection. It also covers application continuity to ensure uninterrupted operations during role transitions.
Topic 10
  • Oracle Data Guard Basics: This topic covers the essential architecture and concepts of Oracle Data Guard. It includes sub-topics such as the physical and logical standby database comparison, benefits of Data Guard, and its integration with multi-tenant databases.
Topic 11
  • Using Flashback Database in a Data Guard Configuration: This topic covers the configuration and advantages of using Flashback Database in a Data Guard setup, as well as the process of enabling fast-start failover for seamless role changes.
Topic 12
  • Backup and Recovery Considerations in an Oracle Data Guard Configuration: In this topic, Backup and recovery procedures in a Data Guard configuration are discussed, including RMAN backups, offloading to physical standby, and network-based recovery.
Oracle Database 19c: Data Guard Administration Sample Questions (Q84-Q89):NEW QUESTION # 84
You created the PRODSBY1 physical standby database for the PROD primary database using gql and RMAN.
You are planning to create a Data Guard Broker configuration. You execute the command:
Which three statements are true regarding the execution of the command?
  • A. The command will execute successfully only if Oracle Net connectivity to the PROD and PRODSBYl database instances are defined on the primary host.
  • B. The Data Guard Broker configuration files is automatically created in the destinations specified by the DG_BROKER_CONFIG_FILEn initialization parameters on the primary database.
  • C. The PRODSBY1 standby database is automatically added to the configuration if DG_BROKER_START is TRUE for PRODSBYl.
  • D. The command will execute successfully only if Oracle Net connectivity to the PROD database instance is defined on the primary host.
  • E. The command will execute successfully only if the DG_BROKER_START initialization parameter is set to TRUE for the PROD database instance.
  • F. The PRODSBYI standby database is automatically added to the configuration if Oracle Net connectivity to the PRODSBYl database instance is defined on the primary host.
Answer: B,D,E
The command executed (CREATE CONFIGURATION 'DGConfig' AS PRIMARY DATABASE IS ' PROD' CONNECT IDENTIFIER IS PROD;) is used to create a Data Guard Broker configuration named
'DGConfig'. The successful execution of this command depends on several conditions:
* A: The DG_BROKER_START parameter must be set to TRUE on the primary database to start the Data Guard Broker processes. Without the broker processes running, the configuration cannot be created.
* D: Oracle Net connectivity to the PROD database instance must be established on the primary host. This is because the Data Guard Broker requires network accessibility to communicate with the primary database and manage the configuration.
* E: When the configuration is created, the Data Guard Broker configuration files are indeed automatically created in the locations specified by the DG_BROKER_CONFIG_FILEn parameters on the primary database.
It's important to note that the command will not automatically add the PRODSBY1 standby database to the configuration (thus B and C are not correct), and there is no requirement for the standby database to have Oracle Net connectivity defined on the primary host for the execution of this command (making F incorrect as well).
References: This information can be validated in Oracle's Data Guard Broker documentation, which outlines the requirements for setting up and managing a Data Guard configuration using the Data Guard Broker.
NEW QUESTION # 85
Active Data Guard (ADG) databases are widely used to offload reporting or ad hoc query-only jobs from the primary database. Reporting workload profile is different from the primary database and often requires tuning.
Which tool is used to tune SQL workloads running on an ADG database?
  • A. In-Memory Active Session History (ASH)
  • B. Automatic Diagnostic Database Monitor (ADDM)
  • C. SQL Tuning Advisor
  • D. Automatic Workload Repository (AWR)
  • E. Standby Statspack
AWR collects, processes, and maintains performance statistics for problem detection and self-tuning purposes.
In an Active Data Guard environment, where the physical standby database can be used for read-only workloads, AWR can be instrumental in identifying performance bottlenecks and areas for optimization. It provides detailed reports that include wait events, time model statistics, and active session history, making it an invaluable tool for tuning SQL queries and overall database performance in an ADG setup.
NEW QUESTION # 86
Which two statements are true regarding asynchronous redo transport in a Data Guard
  • A. This transport mode satisfies the minimum requirements for Maximum Performance data protection mode.
  • B. Real-time query performance on a physical standby database improves for current read requests when using this transport mode.
  • C. This transport mode satisfies the minimum requirements for Maximum Availability data protection mode.
  • D. A transaction can commit without waiting for redo to be sent to any standby database in the data guard configuration.
  • E. The performance of SQL apply on a logical standby database always improves when using this transport mode.
Asynchronous redo transport is a method where the primary database does not wait for an acknowledgment from the standby database before committing transactions, which helps in minimizing the impact on the primary database's performance (B). This transport mode is associated with the Maximum Performance data protection mode, which prioritizes performance over synchronicity of data between the primary and standby databases (C). While it provides a level of data protection, there could be some data loss in the event of a primary database failure because redo data may not have been transmitted to the standby database at the time of the failure.
Oracle Data Guard Concepts and Administration documentation provides detailed explanations of different redo transport modes and their implications on data protection and performance. Asynchronous transport mode's behavior and association with Maximum Performance mode are outlined explicitly.
NEW QUESTION # 87
Your Data Guard environment consists of these components and settings:
A primary database supporting an OLTP workload
A remote physical standby database
Real-time query is enabled
The redo transport mode is set to SYNC
The protection mode is set to Maximum Availability
Which two statements are true regarding the DelayMins database property for the standby database?
  • A. It can only be enabled for a configuration in Maximum Performance mode.
  • B. It enables you to bypass the default network timeout interval specified for the standby redo transport destination.
  • C. It specifies a delay before the primary ships redo to the standby destination having DelayMins set.
  • D. It can only be enabled for a configuration in Maximum Availability mode.
  • E. It allows logical corruptions on the primary to be recovered by using the physical standby database.
  • F. It allows user errors on the primary to be recovered by using the physical standby database.
Answer: E,F
NEW QUESTION # 88
Which THREE statements are true........ open in real time query mode, which becomes a new.
  • A. User sessions can be retained.
  • B. Sessions that are using database links
  • C. Sessions that have long running queries can be retained.
  • D. All sessions are disconnected and all
  • E. All current buffers can be retained.
  • F. User sessions and Current Buffers are maintained by default.
Answer: A,D,E
When a physical standby database is opened in real-time query mode, which may be referred to as real-time apply when using Active Data Guard, certain operations can disrupt ongoing sessions. However, with features like Application Continuity and the proper configuration of initialization parameters such as STANDBY_DB_PRESERVE_STATES, user sessions and current buffers may be preserved during role transitions such as a switchover or failover. Specifically, the STANDBY_DB_PRESERVE_STATES parameter can be set to preserve none, all, or only user sessions during such transitions. This ensures that in-flight transactions are not lost and that users do not experience disruptions during the role transitions of a physical standby database.
Reference
Oracle Database Licensing Information User Manual
Oracle Data Guard Broker User Manual
NEW QUESTION # 89
Our 1z0-076 exam questions are of high quality and efficient. We provide the client with the latest materials so that the client can follow the newest trends in theory and practice it so thus the client can pass the exam easily. Dont be hesitated and take action immediately! The study materials what we provide is to boost pass rate and hit rate, you only need little time to prepare and review, and then you can pass the 1z0-076 Exam. It costs you little time and energy, and you can download the software freely and try out the product before you buy it.
Practice Test 1z0-076 Fee: https://www.testpassking.com/1z0-076-exam-testking-pass.html
Posted at 2/23/2026 12:43:48        Only Author  2#
Analytics-Con-201Salesforce Certified CRM Analytics and Einstein Discovery ConsultantSalesforceһJ^ԇYȤơ⤷SalesforceJ^ԇY˺ϸ񤷤ITIˤȤƤ˚ݤäƤΤǡޤޤयˤAnalytics-Con-201ԇYꤷzǡAnalytics-Con-201ԇYϺgǤϤʤơrgȥͥ륮`ä⤷ʤФʤޤ
