[Hardware] AP-219 Exam Study Guide - Advanced AP-219 Testing Engine
69
Hardware AP-219 Exam Study Guide - Advanced AP-219 Testing Engine
Posted at 2/21/2026 15:05:24      View137 | Replies0        Print      Only Author   [Copy Link] 1#
Everyone has a utopian dream in own heart. Dreams of imaginary make people feel disheartened. In fact, as long as you take the right approach, everything is possible. You can pass the Salesforce AP-219 Exam easily. Why? Because you have ExamcollectionPass's Salesforce AP-219 exam training materials. ExamcollectionPass's Salesforce AP-219 exam training materials are the best training materials for IT certification. It is famous for the most comprehensive and updated by the highest rate. It also can save time and effort. With it, you will pass the exam easily. If you pass the exam, you will have the self-confidence, with the confidence you will succeed.
Salesforce AP-219 Exam Syllabus Topics:
  • Order Management Basics: Foundation of Order Management within Salesforce ecosystem, platform architecture, integration capabilities with third-party systems, and native Salesforce functionality.
  • Advanced Topics: Troubleshooting configuration issues, diagnosing system integration problems, and resolving deployment obstacles.
  • Deployment and Debugging: Deployment options, lifecycle management, building processes with pre-configured data, and understanding supporting objects and system runtime.
  • Data Model: Core objects (Order, Order Summary, Fulfillment Orders, Return Orders), B2C Commerce integrations, and tracing data flow including custom attributes.
Topic 5
  • Process Automation and Integrations: Configuring end-to-end Order Management processes and external system integrations using declarative tools and clicks-based configuration.
Pass Guaranteed Quiz Salesforce - AP-219 - Trustable Salesforce Order Management Administrator Accredited Professional Exam Study GuideSalesforce AP-219 Practice Material is from our company which made these AP-219 practice materials with accountability. And AP-219 Training Materials are efficient products. What is more, Salesforce AP-219 Exam Prep is appropriate and respectable practice material.
Salesforce Order Management Administrator Accredited Professional Sample Questions (Q29-Q34):NEW QUESTION # 29
Once the administrator hasactivated the integration between B2C Commerce and Order Management, orders being placed by customers will be sent to Order Management if the order status is set to which two values?
  • A. New
  • B. Active
  • C. Drafted
  • D. Open
  • E. Created
Once the administrator has activated the integration between B2C Commerce and Order Management, orders being placed by customers will be sent to Order Management if the order status is set to Active or New. These are the two order statuses that indicate that an orderhas been created or confirmed by a customer, and that it needs to be processed by Order Management. Verified Reference:https://help.salesforce.com/s/ar ... _api.htm&type=5
NEW QUESTION # 30
Which two process exceptions are available out of the box in order
management? (Choose 2)
  • A. Inventory check exception
  • B. Find location fault
  • C. Unable to capture payment
  • D. Navigate invoice amount
NEW QUESTION # 31
How can an administrator quickly examine the relationships between several objects?
  • A. Download it from the Partner Community
  • B. Goto SchemaBuilder and check the boxes next to the objectnames
  • C. File a support case asking for a data relationship diagram
  • D. Generate an Entity Relationship Diagram by going to Data in Setup
The best way for an administrator to quickly examine the relationships between several objects is to go to Schema Builder and check the boxes next to the object names. Schema Builder is a tool that allows administrators to view and modify the data model of their org in a graphical interface. Schema Builder shows the objects and fields in the org, as well as the relationships between them. The administrator can use Schema Builder to select the objects that they want to examine, and see how they are connected to each other. Verified Reference:https://help.salesforce.com/s/ar ... lder.htm&type=5
NEW QUESTION # 32
Which object is used to createan invoice?
  • A. Order Summary
  • B. Shipment
  • C. Order
  • D. Fulfillment Order
The Order Summary object is used to create an invoice. An invoice is a document that requests payment from a customer for an order. An invoice can include one or more fulfillment orders and one or more credit memos. A fulfillment order is a record that represents a part of an order that is fulfilled by a specific location. A credit memo is a record that represents a partial or full refund for an order or a fulfillment order. To create an invoice, an administrator can use the Create Invoice Apex action in a flow. The Create Invoice Apex action requires the Order Summary ID as an input parameter and creates an Invoice record associated with the Order Summary record. Reference: Order Management Objects, [Create Invoice Apex Action]
NEW QUESTION # 33
Which three objects need to be utilized when creating orders using the composite API?
  • A. Contact
  • B. Order Summary
  • C. Product
  • D. Account
  • E. Pricebook Entry
Answer: A,D,E
The PricebookEntry, Contact, and Account objects are required when creating orders using the composite API. The composite API is a REST API that allows creating multiple records in one request. To create an order using the composite API, an administrator needs to provide the following information:
The Account ID of the customer who placed the order
The Contact ID of the customer who placed the order
The Pricebook Entry IDs of the products that are ordered
The quantity and unit price of each product
The order status andcurrency Reference: [Create Orders Using Composite API], [Composite Resources]
NEW QUESTION # 34
Our professional experts have compiled the AP-219 exam questions carefully and skillfully to let all of our worthy customers understand so that even an average candidate can learn the simplified information on the syllabus contents and grasp it to ace exam by the first attempt. It is the easiest track that can lead you to your ultimate destination with our AP-219 Practice Engine. And as our pass rate of the AP-219 learning guide is high as 98% to 100%, you will pass the exam for sure.
Advanced AP-219 Testing Engine: https://www.examcollectionpass.com/Salesforce/AP-219-practice-exam-dumps.html
