[General] Latest CRT-211 Dumps Sheet - Study CRT-211 Materials
90
【General】 Latest CRT-211 Dumps Sheet - Study CRT-211 Materials
Posted at 2/21/2026 16:29:46      View:81 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Salesforce CRT-211 dumps are available on Google Drive shared by Actual4test: https://drive.google.com/open?id=1jnHTrqPU3ufznAtr1zFuwsj3Gq6IzYiI
Actual4test Certification Preparation for Advanced Administrator (CRT-211) practice test has real Certification Preparation for Advanced Administrator (CRT-211) exam questions. You can change the difficulty of these questions, which will help you determine what areas appertain to more study before taking your Salesforce CRT-211 Exam Dumps. Here we listed some of the most important benefits you can get from using our Salesforce CRT-211 practice questions.
The CRT-211 exam is a comprehensive assessment of an administrator's advanced knowledge of Salesforce. It is intended for those who have already earned the Salesforce Certified Administrator certification and have at least two years of experience working with the platform. CRT-211 Exam covers a range of topics, including advanced security and access, data management, analytics, automation, and collaboration. Passing the CRT-211 exam demonstrates that an administrator has the expertise to manage complex Salesforce environments.
​​​Salesforce CRT-211 Exam Questions in Convenient PDF FormatActual4test CRT-211 exam certification training materials is not only the foundation for you to success, but also can help you play a more effective role in the IT industry. With efforts for years, the passing rate of Actual4test CRT-211 Certification Exam has reached as high as 100%. If you failed CRT-211 exam with our CRT-211 exam dumps, we will give a full refund unconditionally
Salesforce Certification Preparation for Advanced Administrator Sample Questions (Q146-Q151):NEW QUESTION # 146
Northern Trail Outfitters (NTO) has a private sharing model for records containing a customer's credit Information. These records should be visible to a sales rep's manager but hidden from their colleagues.
How should an administrator adjust NTO's sharing model to ensure the correct amount of confidentiality?
  • A. Use validation rules targeting the logged-in user.
  • B. Create sharing rules for each manager based on the record owner.
  • C. Add View All access for the object via the managers profile.
  • D. Grant access using hierarchies via the sharing settings.
To ensure that sales reps' managers can view records containing customer's credit information but their colleagues cannot, NTO should grant access using hierarchies via the sharing settings. This option allows users above another user in the role hierarchy to have access to records owned by or shared with users below them in the hierarchy. References: https://help.salesforce.com/s/ar ... ring.htm&type=5
NEW QUESTION # 147
Cloud Kicks needs to automate several updates to lead records and update unrelated records. Select changes should happen every time a record is created or updated, Put other changes should only happen when the record is updated.
Which two options should the administrator use to automate these updates?
Choose 2 answers
  • A. Use "formula evaluates to true" workflow rule with the ISCHANCEO function to make changes when the record Is updated.
  • B. Create a flow that runs when a record is created or updated.
  • C. Create a Process Builder that runs when a record is changed.
  • D. Use a Decision element with the "Only if the record that triggered the flow to run is updated to meet the condition requirements" option.
Process Builder and Flow Builder are tools that allow administrators to automate business processes in Salesforce without writing code. Process Builder and Flow Builder can perform actions such as creating records, updating fields, sending emails, posting to Chatter, invoking Apex classes, calling flows, etc.
To automate several updates to lead records and update unrelated records at Cloud Kicks, an administrator can use two options:
* B) Create a Process Builder that runs when a record is changed
Process Builder is a tool that allows administrators to create processes that consist of criteria nodes and action groups. Criteria nodes define the conditions that trigger the process and action groups define the actions that the process performs. Processes can run when a record is created or when a record is created or edited.
By creating a Process Builder that runs when a record is changed, an administrator can automate updates to lead records based on certain criteria and perform actions such as updating fields, sending emails, posting to Chatter, invoking Apex classes, calling flows, etc. References: https://help.salesforce.com/s/articleView?id=sf.
process_overview.htm&type=5 https://help.salesforce.com/s/ar ... ess_considerations.
htm&type=5
* C) Create a flow that runs when a record is created or updated
Flow Builder is a tool that allows administrators to create flows that consist of elements such as screens, assignments, decisions, loops, etc. Elements define the logic and user interface of the flow. Flows can run in different ways such as when a user clicks a button, when a record is updated by Process Builder, when an event occurs in the system (such as record creation), etc.
NEW QUESTION # 148
Universal containers uses Salesforce to track job positions and applicants. Applicants can apply for multiple positions and positions will have multiple applicants. The company wants to ensure that if an applicant is deleted, all associations between the applicant and the position(s) that he or she has applied for are deleted.
How can this be accomplished?
  • A. Create a master detail relationship between applicants and positions with applicants as the master.
  • B. Create a lookup relationship between applicants and positions with applicants as the parent.
  • C. Create a custom object between applicants and positions with lookup fields on the junction to both the objects.
  • D. Create a many -to- many relationships using junction object with both positions and applicants as masters.
NEW QUESTION # 149
When using Collaborative Forecasts, what information can a sales representative access from the Forecasts tab? Choose 2 answers
  • A. Forecast amount for each opportunity stage
  • B. Forecast amount for other representatives on their team
  • C. Opportunities that make up each forecast amount
  • D. Forecast amount for each forecast category
NEW QUESTION # 150
A new administrator at Cloud Kicks has reported that they are unable to use outbound change sets as requested.
What permission should be reviewed to determine if it is missing from the administrator user or profile?
  • A. API Enabled
  • B. Modify Metadata Through Metadata API Functions
  • C. Create and Upload Change Sets
  • D. Deploy Change Sets
To use outbound change sets, a user needs to have the Create and Upload Change Sets permission on their profile or permission set. This permission allows users to create change sets in a sandbox or Developer Edition organization and upload them to another organization. References: https://help.salesforce.com/s
/articleView?id=sf.changesets_create_upload_perm.htm&type=5
NEW QUESTION # 151
If you are still troubled for the Salesforce CRT-211 Certification Exam, then select the Actual4test's training materials please. Actual4test's Salesforce CRT-211 exam training materials is the best training materials, this is not doubt. Select it will be your best choice. It can guarantee you 100% pass the exam. Come on, you will be the next best IT experts.
Study CRT-211 Materials: https://www.actual4test.com/CRT-211_examcollection.html
BTW, DOWNLOAD part of Actual4test CRT-211 dumps from Cloud Storage: https://drive.google.com/open?id=1jnHTrqPU3ufznAtr1zFuwsj3Gq6IzYiI
