[General] Customizable PDF Questions for Improved Success in Salesforce Integration-Archit
90
General Customizable PDF Questions for Improved Success in Salesforce Integration-Archit
Posted at 2/21/2026 17:21:00      View227 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free & New Integration-Architect dumps are available on Google Drive shared by SureTorrent: https://drive.google.com/open?id=1SLy8rnmk2h0PHpSeNqJSCWgpDsq8waZk
Most of our clients found our Integration-Architect exam questions and answers amazing. All they learned from SureTorrent is that the Salesforce Integration-Architect practice test questions were accurately similar to the actual questions they faced on their Salesforce Certified Integration Architect exam. It made them utterly confident to go through the whole process of the Salesforce Certified Integration Architect.Feel free to compare our quality of Salesforce Integration-Architect Exam Questions dumps with other courses. Nothing can help people pass their Salesforce Integration-Architect certification exam more than we do. Even people who were on their first time taking Salesforce Target Integration-Architect certification can pass their Salesforce Certified Integration Architect exam with SureTorrent's help.
Salesforce Integration-Architect Certification Exam covers a wide range of topics, including integration patterns, data modeling, security, and performance optimization. Integration-Architect exam is divided into two parts: a multiple-choice section and a scenario-based section. The multiple-choice section tests your knowledge of Salesforce integration concepts and best practices, while the scenario-based section evaluates your ability to apply these concepts to real-world scenarios.
Salesforce Integration-Architect Exam covers a wide range of topics, including integration architecture, data integration, enterprise messaging, API integration, and security. Integration-Architect Exam also tests your ability to design and implement complex integration solutions that meet business requirements and adhere to best practices. With this certification, you can demonstrate your expertise in Salesforce integration and differentiate yourself in the job market as a highly skilled and experienced integration architect.
Online Integration-Architect Lab Simulation - Integration-Architect New Study QuestionsIf you want to pass a high percentage of the Salesforce Integration-Architect Exam, you should consider studying for the actual exam. These practice tests are designed to help you prepare for the exam and ensure you know the syllabus content. It will also help you improve your time management skills, as these tests are designed like an actual exam. Moreover, they will help you learn to answer all questions in the time allowed.
Salesforce Integration-Architect certification is a valuable asset for any Salesforce professional looking to advance their career. Salesforce Certified Integration Architect certification demonstrates that you have the knowledge and skills required to design and implement complex integrations with the Salesforce platform. It also helps you stand out in a crowded job market and increases your earning potential. With the Salesforce Integration-Architect Certification, you can position yourself as a trusted advisor and expert in Salesforce Integration.
Salesforce Certified Integration Architect Sample Questions (Q65-Q70):NEW QUESTION # 65
Northern Trail Outfitters (NTO) uses a custom mobile app to interact with their customers.
One of the features of the app are Salesforce Chatter Feeds. NTO wants to automatically post a Chatter item to Twitter whenever the post includes the #thanksNTO hashtag.
Which API should an Integration Architect use to meet this requirement?
  • A. REST API
  • B. Streaming API
  • C. Connect REST API
  • D. Apex REST
NEW QUESTION # 66
Universal Containers (UC) is currently managing a custom monolithic web service that runs on an on-premise server. This monolithic web service is responsible for Point-to-Point (P2P) integrations between Salesforce and a legacy billing application, a cloud-based ERP, and a data lake. UC has found that the tight interdependencies are causing failures. What should an integration architect recommend to decouple the systems and improve performance?
  • A. Move the custom monolithic web service from on-premise to a cloud provider.
  • B. Leverage modular design by breaking up the web service into smaller pieces for a microservice architecture.
  • C. Use the Salesforce Bulk API when integrating back into Salesforce.
The primary architectural flaw in UC's current landscape is the reliance on a monolithic P2P integration layer. In such designs, any failure in one integration thread or a surge in volume for one system can monopolize resources (CPU, memory, threads), causing the entire service-and thus all other integrations-to fail. This lack of isolation leads to the "tight interdependencies" described.
To effectively decouple these systems, the architect should recommend a Microservices Architecture. By breaking the monolithic service into smaller, independent, and modular components, each integration (Billing, ERP, Data Lake) becomes its own isolated service. This approach provides several key architectural benefits:
* Isolation of Failure: If the connection to the legacy billing application fails or times out, it no longer impacts the ERP or Data Lake integrations.
* Independent Scalability: If the Data Lake integration requires high throughput, that specific microservice can be scaled horizontally without wasting resources on the others.
* Technology Agility: Each microservice can be updated or patched independently, allowing for faster maintenance cycles.
Furthermore, moving a "monolithic" service to the cloud (Option B) is simply a "lift and shift" that preserves the underlying fragility. While the Bulk API (Option A) is excellent for high-volume data loading, it does not solve the fundamental problem of system interdependency and orchestration failure. Transitioning to a modular, service-oriented design allows UC to implement modern integration patterns, such as asynchronous queuing between the microservices, which significantly improves the overall resilience and performance of the Salesforce-to-back-office landscape.
NEW QUESTION # 67
Which two system constraint questions should be considered when designing an integration to send orders from Salesforce to a fulfillment system?
Choose 2 answers
  • A. What latency is acceptable for orders to reach the fulfillment system?
  • B. Can the fulfillment system implement a contract-first Outbound Messaging interface?
  • C. Can the fulfillment system participate in idempotent design to avoid duplicate orders?
  • D. Which system will validate order shipping addresses?
NEW QUESTION # 68
Northern Trail Outfitters is seeking to improve the performance and security of outboundintegrations from Salesforce to on-premise servers.
What should the Architect consider before recommending a solution?
  • A. Considerations for using Deterministic Encryption
  • B. External gateway products in use
  • C. A Default gateway restrictions
  • D. ShieldPlatform Encryption Limitations
Option A is correct because external gateway products in use can affect the performance and security of outbound integrations from Salesforce to on-premise servers. External gateway products are software or hardwaredevices that act as intermediaries between Salesforce and the on-premise servers, such as firewalls, proxies, load balancers, or VPNs. They can have different configurations, features, and limitations that can impact the speed, reliability, and security ofthe data transmission. For example, some external gateway products may require authentication, encryption, or compression of the data, which can add overhead and latency to the integration. Some external gateway products may also have bandwidth or throughput limits, which can affect the scalability and availability of the integration. Therefore, the architect should consider the external gateway products in use before recommending a solution.
Option B is incorrect because a default gateway restriction is not a factor that can affect the performance and security of outbound integrations from Salesforce to on-premise servers. A default gateway restriction is a feature that allows administrators to restrict outbound requests from Salesforce to a specific IP address or domain name. This can help prevent unauthorized or malicious requests from Salesforce to external systems.
However, this feature does not affect the performance or security of the outbound requests themselves, as it only acts as a filter for the destination of the requests.
Option C is incorrect because considerations for using deterministic encryption are not relevant for outbound integrations from Salesforce to on-premise servers. Deterministic encryption is a type of encryption that produces thesame ciphertext for the same plaintext input. This can help preserve some functionality and performance of encrypted data in Salesforce, such as filtering, sorting, and indexing. However, deterministic encryption is not applicable for outbound integrations from Salesforce to on-premise servers, as it is only supported for custom fields and not for standard fields or attachments. Moreover, deterministic encryption does not affect the security of the data transmission itself, as it only encrypts the data atrest in Salesforce.
Option D is incorrect because Shield Platform Encryption limitations are not relevant for outbound integrations from Salesforce to on-premise servers. Shield Platform Encryption is a feature that allows administrators to encrypt sensitive data at rest in Salesforce using AES 256-bitencryption. This can help protect data from unauthorized access or theft. However, Shield Platform Encryption limitations are not relevant for outbound integrations from Salesforce to on-premise servers, as they only affect the functionality and performance of encrypted data in Salesforce, such as searching, reporting, or validation rules. Shield Platform Encryption does not affect the security of the data transmission itself, as it only encrypts the data at rest in Salesforce.
References: Salesforce Integration Patterns and Practices : Salesforce Integration Guide : Restrict Outbound Requests with a Default Gateway : Deterministic Encryption : Shield Platform Encryption Considerations :
Shield PlatformEncryption : Shield Platform Encryption Architecture
NEW QUESTION # 69
Universal Containers (UC) owns a variety of cloud-based applications, including Salesforce, alongside several on premise applications. The on-premise applications are protected behind a corporate network with limited outside access to external systems.
UC would like to expose data from the on-premise applications to Salesforce for a more unified user experience. The data should be accessible from Salesforce in real-time.
Which two actions should be recommended to fulfill this system requirement?
Choose 2 answers
  • A. Develop custom APIs on the company's network that are invokable by Salesforce.
  • B. Develop an application in Heroku that connects to the on-premise database via an ODBC string and VPC connection.
  • C. Run a batch job with an ETL tool from an on-premise server to move data to Salesforce.
  • D. Deploy MuleSoft to the on-premise network and design externally facing APIs to expose the data.
NEW QUESTION # 70
Online Integration-Architect Lab Simulation: https://www.suretorrent.com/Integration-Architect-exam-guide-torrent.html
What's more, part of that SureTorrent Integration-Architect dumps now are free: https://drive.google.com/open?id=1SLy8rnmk2h0PHpSeNqJSCWgpDsq8waZk
Posted at 4/20/2026 13:17:16        Only Author  2#
Huawei H13-624_V5.5인증시험은 전문적인 관련지식을 테스트하는 인증시험입니다. Pass4Test는 여러분이Huawei H13-624_V5.5인증시험을 통과할 수 잇도록 도와주는 사이트입니다. 많은 분들이 많은 시간과 돈을 들여 혹은 여러 학원 등을 다니면서Huawei H13-624_V5.5인증시험패스에 노력을 다합니다. 하지만 우리ass4Test에서는 20시간 좌우만 투자하면 무조건Huawei H13-624_V5.5시험을 패스할 수 있도록 도와드립니다.
