[General] ActualPDF Offers Valid and Real Fire-Inspector-II 67 - Fire Inspector II Exam Ex
78
General ActualPDF Offers Valid and Real Fire-Inspector-II 67 - Fire Inspector II Exam Ex
Posted at 2/21/2026 17:33:50      View165 | Replies1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of ActualPDF Fire-Inspector-II dumps from Cloud Storage: https://drive.google.com/open?id=1b2KWadHXjIFg26rtDYFQWY46d-WTYD8H
The second form is 67 - Fire Inspector II Exam (Fire-Inspector-II) web-based practice test which can be accessed through online browsing. The Fire-Inspector-II web-based practice test is supported by browsers like Firefox, Microsoft Edge, International Code Council Chrome, and Safari. You don't need to install any plugins or software to attempt the Fire-Inspector-II web-based practice test. This online International Code Council Fire-Inspector-II exam is also compatible with all operating systems.
As a working person, the International Code Council Fire-Inspector-II practice exam will be a great help because you are left with little time to prepare for the International Code Council Fire-Inspector-II certification exam which you cannot waste to make time for the International Code Council Fire-Inspector-II Exam Questions. You can find yourself sitting in your dream office and enjoying the new opportunity.
Valid Fire-Inspector-II Exam Objectives | Certification Fire-Inspector-II Exam DumpsDesktop and web-based Fire-Inspector-II practice exams are available at ActualPDF for thorough preparation. Going through these International Code Council Fire-Inspector-II mock exams boosts your learning and reduces mistakes in the International Code Council Fire-Inspector-II Test Preparation. Customization features of International Code Council Fire-Inspector-II practice tests allow you to change the settings of the Fire-Inspector-II test sessions.
International Code Council 67 - Fire Inspector II Exam Sample Questions (Q32-Q37):NEW QUESTION # 32
Battery-charging areas for industrial trucks shall be protected with portable fire extinguishers which have a minimum rating of:
  • A. 40-B:C
  • B. 2-A:10-B:C
  • C. 3-A:40-B:C
  • D. 4-A:20-B:C
Battery-charging areas for industrial trucks (such as forklifts) present a fire hazard due to the potential for flammable hydrogen gas buildup and electrical malfunctions. To mitigate this risk, portable fire extinguishers with a minimum rating of 40-B:C are required.
Reference to Fire Inspector Documentation:
1. 2021 International Fire Code (IFC) - Section 309.5 (Fire Extinguishers for Battery-Charging Areas) IFC 309.5 states that battery-charging areas must have a portable fire extinguisher with a minimum rating of
40-B:C to handle potential electrical and flammable liquid fires.
The B rating covers flammable liquid fires (such as battery electrolyte leaks), while the C rating ensures it is safe for electrical fires.
2. NFPA 10 - Standard for Portable Fire Extinguishers (2022 Edition)
NFPA 10, Table 6.3.1.1 outlines that industrial battery-charging areas must have at least one extinguisher rated 40-B:C.
This ensures adequate fire suppression capability for both electrical and flammable liquid hazards.
Detailed Explanation of Answer Choices:
Option A (Incorrect): 4-A:20-B:C includes a higher A-rating (for ordinary combustibles), but 20-B:C is below the required 40-B:C.
Option B (Incorrect): 3-A:40-B:C exceeds the B:C requirements but adds an unnecessary A-rating, which is not specified in the code.
Option C (Incorrect): 2-A:10-B:C is insufficient, as it does not meet the 40-B:C minimum requirement.
Option D (Correct): 40-B:C is the correct and minimum required rating per IFC 309.5 and NFPA 10.
Thus, the correct and verified answer is: D. 40-B:C.
NEW QUESTION # 33
Quantities of flammable liquid storage in a control area of an Industrial Occupancy may be doubled when:
  • A. permission is granted by the chief.
  • B. the building is protected with automatic sprinklers.
  • C. the control area is provided with exhaust ventilation in accordance with fire code requirements.
  • D. the control area exceeds 50,000 sq. ft.
Flammable Liquid Storage Limits in Control Areas
According to the International Fire Code (IFC) 2021, Section 5003.1.1 and Table 5003.1.1(1), the allowable quantity of flammable liquids stored in a control area can be doubled if the building is equipped with an automatic sprinkler system that complies with NFPA 13.
2. Why Automatic Sprinklers Allow Increased Storage
A sprinkler system significantly reduces fire risk by suppressing flames early, thus allowing greater quantities of hazardous materials to be safely stored.
IFC and NFPA 30 (Flammable and Combustible Liquids Code) specify that sprinkler-protected buildings can have up to twice the standard storage limits.
3. Verification of Other Options
Option A (permission is granted by the chief) - Incorrect, as storage limits are regulated by the fire code, not discretionary approval from the fire chief.
Option B (the control area exceeds 50,000 sq. ft.) - Incorrect, as floor area does not automatically allow for increased storage unless fire protection systems are in place.
Option D (the control area is provided with exhaust ventilation) - Incorrect, because ventilation is required for hazardous material control but does not impact storage limits like sprinklers do.
Reference Sources:
International Fire Code (IFC) 2021 - Section 5003.1.1 & Table 5003.1.1(1) (Control Area Storage Limits for Flammable Liquids) NFPA 30: Flammable and Combustible Liquids Code (Sprinkler-Adjusted Storage Quantities) ICC Fire Inspector II Study Guide (2021) Thus, the correct and verified answer is: C. the building is protected with automatic sprinklers. #
NEW QUESTION # 34
Which of the following situations requires securing of an operational permit from the code official prior to commencing the related activity?
  • A. Storing 85,000 bd. ft. of lumber.
  • B. Organic coating production facility producing 2 gallons per day.
  • C. Fruit ripening operations using carbon dioxide gas.
  • D. Inside storage of 100 cu. ft. of baled cotton.
IFC Section 105.6 lists activities requiring operational permits. For A, lumber storage exceeding 100,000 board feet (bd. ft.) indoors or outdoors requires a permit (Section 105.6.28, Lumber Yards), but local thresholds may be lower-85,000 bd. ft. is close to this limit and likely exceeds typical exempt amounts, triggering a permit in many jurisdictions. For B, IFC Table 3206.2 allows small quantities of combustible commodities like baled cotton (100 cu. ft. is minimal) without a permit unless part of a larger high-piled storage operation. For C, fruit ripening with CO2 (Section 105.6.13) requires a permit only for specific flammable gases, not CO2 alone, which is nonflammable. For D, organic coating production (Section
105.6.33) requires a permit only above 1 gallon per day, but 2 gallons is still small-scale and context- dependent-lumber storage is the clearer permit trigger here. Thus, A is the best answer.
Reference: IFC 2021, Section 105.6 (Required Operational Permits), Section 3206.2 (High-Piled Storage).
NEW QUESTION # 35
Hazardous occupancies involved in the manufacturing of organic coatings:
  • A. require both manual and automatic fire alarm systems.
  • B. require only a manual fire alarm system.
  • C. do not require a fire alarm system.
  • D. require only an automatic fire alarm system.
Hazardous occupancies involved in organic coatings manufacturing are classified as Group H-2 or H-3 occupancies under the 2021 IFC. These facilities involve highly flammable materials, requiring both manual and automatic fire alarm systems for safety.
IFC 2021, Section 415.7 - Organic Coatings Manufacturing:
Requires that automatic fire alarm and manual fire alarm systems be installed due to the high risk of fire and explosion in these facilities.
IFC 907.2.4 - Fire Alarm Systems for Group H Occupancies:
Specifies that Group H (high-hazard) occupancies must have both manual and automatic fire alarm systems.
The automatic fire alarm system ensures immediate detection, while the manual system allows for human activation in case of emergencies.
Why Other Options Are Incorrect?
A). Do not require a fire alarm system.
Incorrect, as all high-hazard occupancies require fire alarm systems.
B). Require only a manual fire alarm system.
Incorrect, as automatic detection is also required due to high fire risk.
C). Require only an automatic fire alarm system.
Incorrect, as manual activation is necessary for early intervention.
# Correct answer: D. Require both manual and automatic fire alarm systems.
NEW QUESTION # 36
The minimum allowable distance to a public traffic route for storage of 1,750 lb. of Class 1.3 explosives is
___ ft.
  • A. 0
  • B. 1
  • C. 2
  • D. 3
Reference to Explosive Storage Regulations:
The International Fire Code (IFC 2021), Section 5604 and NFPA 495 (Explosive Materials Code) regulate the storage distances for Class 1.3 explosives (which include low explosives such as propellants and display fireworks).
Table 5604.5.2(3) of the IFC provides minimum separation distances between explosives storage and public traffic routes based on the weight of the explosives.
Determining the Correct Distance:
According to IFC Table 5604.5.2(3), for 1,750 lb. of Class 1.3 explosives, the minimum separation distance from a public traffic route is 115 feet.
Clarification of Incorrect Answer Choices:
A: 50 ft. # Incorrect
50 feet is too close and does not meet the safety requirements for explosive storage.
B: 75 ft. # Incorrect
75 feet is insufficient based on IFC and NFPA separation tables.
D: 150 ft. # Incorrect
While more distance is safer, the minimum requirement is 115 feet, making 150 feet unnecessary per code.
Conclusion:
The correct and verified answer is C (115 feet) based on IFC Table 5604.5.2(3) and NFPA 495 requirements for Class 1.3 explosives storage near public traffic routes.
NEW QUESTION # 37
All people dream to become social elite. However, less people can take the initiative. If you spend less time on playing computer games and spend more time on improving yourself, you are bound to escape from poverty. Maybe our Fire-Inspector-II real dump could give your some help. Our company concentrates on relieving your pressure of preparing the Fire-Inspector-II Exam. Getting the certificate equals to embrace a promising future and good career development. Perhaps you have heard about our Fire-Inspector-II exam question from your friends or news. Why not has a brave attempt? You will certainly benefit from your wise choice.
Valid Fire-Inspector-II Exam Objectives: https://www.actualpdf.com/Fire-Inspector-II_exam-dumps.html
International Code Council Fire-Inspector-II Exam Collection Especially in the workplace of today, a variety of training materials and tools always makes you confused and waste time to test its quality, Order your Fire-Inspector-II Dumps now to Avail 25% EXTRA Discount on the Fire-Inspector-II Exam Dumps learning material and get your dream certification, Under the help of the real Fire-Inspector-II test simulation, you can have a good command of key points which are more likely to be tested in the real test.
There are fewer books about this part of the process, but Fire-Inspector-II Tom Holman's Sound For Film and Television is a great place to start, You won't need many Pages in your blog.
Especially in the workplace of today, a variety Valid Fire-Inspector-II Test Voucher of training materials and tools always makes you confused and waste time to test its quality, Order your Fire-Inspector-II Dumps now to Avail 25% EXTRA Discount on the Fire-Inspector-II Exam Dumps learning material and get your dream certification.
100% Pass Fire-Inspector-II - 67 - Fire Inspector II Exam CHigh Pass-Rate Exam CollectionUnder the help of the real Fire-Inspector-II test simulation, you can have a good command of key points which are more likely to be tested in the real test, With our 67 - Fire Inspector II Exam (Fire-Inspector-II) study material, you'll be able to make the most of your time to ace the test.
Our Fire-Inspector-II study materials are selected strictly based on the real Fire-Inspector-II exam and refer to the exam papers in the past years.
2026 Latest ActualPDF Fire-Inspector-II PDF Dumps and Fire-Inspector-II Exam Engine Free Share: https://drive.google.com/open?id=1b2KWadHXjIFg26rtDYFQWY46d-WTYD8H
Posted at 3/7/2026 17:28:56        Only Author  2#
Your article is truly awe-inspiring, thank you for sharing! Latest test Comm-Dev-101 braindumps has outstanding content, and I hope it helps you, at no cost.
