Test 220-1102 Free - Reliable 220-1102 Test Braindumps
109
Posted at 2/21/2026 18:59:32      View:116 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 CompTIA 220-1102 dumps are available on Google Drive shared by PrepAwayTest: https://drive.google.com/open?id=1O6cWG4xSxE-L1O5pnkgS7_LNZEncVYAj
The CompTIA A+ Certification Exam: Core 2 (220-1102) is available in three easy-to-use forms. The first one is 220-1102 dumps PDF format. It is printable and portable. You can print 220-1102 questions PDF or access them via your smartphones, tablets, and laptops. The PDF format can be used anywhere and is essential for students who like to learn on the go.
It is similar to the 220-1102 desktop-based software, with all the elements of the desktop practice exam. This mock exam can be accessed from any browser and does not require installation. The CompTIA 220-1102 questions in the mock test are the same as those in the real exam. And candidates will be able to take the web-based CompTIA 220-1102 Practice Test immediately through any operating system and browsers.
Reliable CompTIA 220-1102 Test Braindumps | 220-1102 Latest Exam ForumOur 220-1102 study material is the most popular examination question bank for candidates. 220-1102 study material has helped thousands of candidates successfully pass the exam and has been praised by all users since it was appearance. 220-1102 study material has the most authoritative test counseling platform, and each topic in 220-1102 Study Materials is carefully written by experts who are engaged in researching in the field of professional qualification exams all the year round.
The 220-1102 Exam is ideal for IT professionals who are interested in pursuing a career in technical support, help desk support, or field service technician roles. It is also beneficial for individuals who are looking to expand their knowledge and skills in the IT field. CompTIA A+ certification is recognized by major companies such as Dell, HP, and Intel, making it a valuable credential for those seeking employment in the IT industry.
CompTIA A+ Certification Exam: Core 2 Sample Questions (Q426-Q431):NEW QUESTION # 426
A technician is troubleshooting a lack of outgoing audio on a third-party Windows 10 VoIP application, The PC uses a USB microphone connected to a powered hub. The technician verifies the microphone works on the PC using Voice Recorder. Which of the following should the technician do to solve the issue?
  • A. Delete the microphone from Device Manager and scan for new hardware,
  • B. Enable the microphone under Windows Privacy settings to allow desktop applications to access it.
  • C. Remove the microphone from the USB hub and plug it directly into a USB port on the PC.
  • D. Replace the USB microphone with one that uses a traditional 3.5mm plug.
In Windows 10, there are privacy settings that control access to certain devices, such as microphones, cameras, and other input devices. If the microphone is not enabled under these privacy settings, the VoIP application may not have access to it, causing a lack of outgoing audio.
The technician can go to the Windows 10 Settings menu, select the Privacy submenu, and under App permissions, select Microphone. The technician should then turn on the toggle switch for the VoIP application to allow it to access the microphone.
Removing the microphone from the USB hub and plugging it directly into a USB port on the PC may or may not solve the issue, as the issue could be related to the privacy settings. Deleting the microphone from Device Manager and scanning for new hardware may also not solve the issue, as the issue could be related to the privacy settings. Replacing the USB microphone with one that uses a traditional 3.5mm plug is not recommended, as it would require purchasing a new microphone and may not solve the issue.
NEW QUESTION # 427
A user is setting up backups on a workstation. The user wants to ensure that the restore process is as simple as possible. Which of the following backup types should the user select?
  • A. Full
  • B. Synthetic
  • C. Differential
  • D. Incremental
Full backup is the best option to ensure that the restore process is as simple as possible. A full backup is a backup type that copies all the data from the source to the destination, regardless of whether the data has changed or not. A full backup provides the most complete and consistent backup of the data, and it allows the user to restore the data from a single backup set without relying on any previous or subsequent backups.
Incremental, differential, and synthetic backups are not as simple as full backups for restoring data. An incremental backup is a backup type that copies only the data that has changed since the last backup, whether it was full or incremental. An incremental backup requires less time and space than a full backup, but it also requires multiple backup sets to restore the data completely. A differential backup is a backup type that copies only the data that has changed since the last full backup. A differential backup requires more time and space than an incremental backup, but it also requires fewer backup sets to restore the data than an incremental backup. A synthetic backup is a backup type that combines a full backup with one or more incremental or differential backups to create a consolidated backup set. A synthetic backup requires less time and bandwidth than a full backup, but it also requires more processing power and storage space than an incremental or differential backup. References:
Official CompTIA learning resources CompTIA A+ Core 1 and Core 2, page 15 CompTIA A+ Core 1 (220-1101) and Core 2 (220-1102) Cert Guide, page 458
NEW QUESTION # 428
A systems administrator finds that a Windows client machine with an address of 169.254.124.24 is unable to access network resources. Which of the following should the administrator do to establish connectivity?
  • A. Reinstall the NIC device driver.
  • B. Disable the Windows firewall.
  • C. Assign a static IP.
  • D. Reconfigure DNS settings.
Reference: CompTIA A+ Certification Core 2 220-1102, Objective 2.1 (IP Configuration and Troubleshooting).
NEW QUESTION # 429
A technician is trying to connect to a user's laptop in order to securely install updates. Given the following information about the laptop:
Which of the following should the technician do to connect via RDP?
  • A. Change the subnet mask on the user's laptop.
  • B. Change the IP address on the user's laptop.
  • C. Open port 3389 on the Windows firewall.
  • D. Confirm the user can ping the default gateway.
In order to connect to a user's laptop via RDP, the technician should open port 3389 on the Windows firewall. This is because RDP uses port 3389 for communication12. The other options are not necessary or relevant for establishing an RDP connection.
Confirming the user can ping the default gateway is not required for RDP, as it only tests the network connectivity between the user's laptop and the router. RDP works over the internet, so the technician should be able to ping the user's laptop directly using its IP address3.
Changing the IP address on the user's laptop is not needed for RDP, as long as the IP address is valid and not conflicting with another device on the network. The user's laptop has a valid IP address of 192.168.0.45, which belongs to the same subnet as the gateway (192.168.0.1) and the subnet mask (255.255.255.0)4.
Changing the subnet mask on the user's laptop is not required for RDP, as long as the subnet mask matches the network configuration. The user's laptop has a correct subnet mask of 255.255.255.0, which defines a network with 254 possible hosts4.
1: [What is RDP and How Does It Work? - CompTIA] 2: CompTIA A+ Certification Exam Core 2 Objectives - CompTIA 3: [Ping (networking utility) - Wikipedia] 4: [IP address - Wikipedia] : What is RDP and How Does It Work? - CompTIA : CompTIA A+ Certification Exam Core 2 Objectives - CompTIA : Ping (networking utility) - Wikipedia) : IP address - Wikipedia
NEW QUESTION # 430
A Windows user recently replaced a computer The user can access the public internet on the computer; however, an internal site at https7/companyintranet.com:8888 is no longer loading. Which of the following should a technician adjust to resolve the issue?
  • A. Firewall settings
  • B. Antivirus settings
  • C. DHCP settings
  • D. IP address settings
  • E. Default gateway settings
The technician should adjust the firewall settings to resolve the issue of not being able to access an internal site at https://companyintranet.com:8888. The firewall settings control how the firewall filters and allows network traffic based on rules and policies. The firewall settings may be blocking or preventing the access to the internal site by mistake or by default, especially if the site uses a non-standard port number such as 8888. The technician should check and modify the firewall settings to allow the access to the internal site or its port number. Default gateway settings determine how a computer connects to other networks or the internet.
Default gateway settings are not likely to cause the issue of not being able to access an internal site if the user can access the public internet. DHCP settings determine how a computer obtains its IP address and other network configuration parameters automatically from a DHCP server. DHCP settings are not likely to cause the issue of not being able to access an internal site if the user can access other network resources. IP address settings determine how a computer identifies itself and communicates with other devices on a network. IP address settings are not likely to cause the issue of not being able to access an internal site if the user can access other network resources. Antivirus settings control how the antivirus software scans and protects the computer from malware and threats. Antivirus settings are less likely to cause the issue of not being able to access an internal site than firewall settings, unless the antivirus software has its own firewall feature that may interfere with the network traffic. References: CompTIA A+ Core 2 (220-1002) Certification Exam Objectives Version 4.0, Domain 1.6
NEW QUESTION # 431
A calm judgment is worth more than a thousand hasty discussions. I know that when you choose which our220-1102 exam materials to buy, it will be very tangled up. This is a responsible performance for you. But you can't casually make a choice because of tangle. And our 220-1102 Study Materials won't let you regret. You can just free download the demos of the 220-1102 practice guide to have a check our quality.
Reliable 220-1102 Test Braindumps: https://www.prepawaytest.com/CompTIA/220-1102-practice-exam-dumps.html
2026 Latest PrepAwayTest 220-1102 PDF Dumps and 220-1102 Exam Engine Free Share: https://drive.google.com/open?id=1O6cWG4xSxE-L1O5pnkgS7_LNZEncVYAj
