Test 1Z0-083 Questions & 1Z0-083 Latest Practice Materials
Posted at 2/21/2026 19:01:09
View134
Replies1
P.S. Free & New 1Z0-083 dumps are available on Google Drive shared by Prep4cram: https://drive.google.com/open?id=1PmMQvasdijy4gFQw3t0ny-hKfwqJSGO8
1Z0-083 test questions have so many advantages that basically meet all the requirements of the user. If you have good comments or suggestions during the trial period, you can also give us feedback in a timely manner. Our study materials will give you a benefit as Thanks, we do it all for the benefits of the user. 1Z0-083 study materials look forward to your joining in. We have full confidence to ensure that you will have an enjoyable study experience with our 1Z0-083 Certification guide, which are designed to arouse your interest and help you pass the exam more easily. You will have a better understanding after reading the following advantages.
Oracle 1Z0-083 Exam is intended for database administrators, database architects, and other IT professionals who are responsible for managing, monitoring, and maintaining Oracle database systems. 1Z0-083 exam is also suitable for candidates who have completed the Oracle Database Administration I certification and wish to further enhance their skills and knowledge in Oracle database administration.
Pass Guaranteed Oracle - Efficient Test 1Z0-083 QuestionsPrep4cram offers updated and real Oracle 1Z0-083 Exam Dumps for Oracle Database Administration II (1Z0-083) test takers who want to prepare quickly for the 1Z0-083 examination. These actual 1Z0-083 exam questions have been compiled by a team of professionals after a thorough analysis of past papers and current content of the 1Z0-083 test. If students prepare with these valid 1Z0-083 questions, they will surely become capable of clearing the 1Z0-083 examination within a few days.
Oracle 1Z1-083 is an exam designed for professionals who wish to demonstrate their knowledge and expertise in database administration. 1Z0-083 exam is a part of the Oracle Certified Database Administrator (OCDA) certification program and is considered an important step towards becoming an Oracle Certified Master. 1Z0-083 Exam aims to test the candidate's ability to manage and administer an Oracle database, including installation, configuration, backup and recovery, and performance tuning.
Oracle Database Administration II Sample Questions (Q150-Q155):NEW QUESTION # 150
RMAN is connected to a target database instance and an auxilary instance. You execute 3625the command: RMAN> DUPLICATE TARGET DATABASE TO dupdb FROM ACTIVE DATABASE SECTION SIZE 1G; What is the outcome?
- A. RMAN uses the push method to transfer image copies
- B. RMAN uses the push method to transfer backup sets
- C. RMAN uses the pull method to restore files using backup sets
- D. RMAN uses the pull method to restore files using image copies
NEW QUESTION # 151
In a recent Automatic Workload Repository (AWR) report for your database, you notice a high number of buffer busy waits. The database consists of locally managed tablespaces with free list managed segments. On further investigation, you f ind that buffer busy waits is caused by contention on data blocks. Which option would you consider first to decrease the wait event immediately?
- A. Decreasing PCTUSED
- B. Increasing the number of DBWN process
- C. Using Automatic Segment Space Management (ASSM)
- D. Decreasing PCTFREE
- E. Increasing db_buffer_cache based on t he V$DB_CACHE_ADVICE recommendation
NEW QUESTION # 152
Which two are true about flashback features in Oracle Database 19c and later releases?
- A. Flashback logs are monitored and proactively deleted when beyond the retention period defined in db_flashback_retention_target before there is space pressure.
- B. Flashback logs are monitored and proactively deleted when beyond the retention period defined in DB_flashback_retention_TARGET only after there is space pressure
- C. Flashback logs are monitored for being older than the retention period defined in db_flashback_retention_target and can be deleted by an administrator written event trigger.
- D. Flashback logs are automatically purged whenever the value
Of DB_FLASHBACK_RETENTION_TARGET is changed. - E. Flashback logs are automatically purged when db_flashback_retention_target is set lower than the time they have already been retained.
NEW QUESTION # 153
Which three are true about monitoring waits for sessions and services? (Choose three.)
- A. V$SESSION_WAIT and V$SESSION both contain details of the event on which a session is currently waiting.
- B. V$SESSION_EVENT displays all waits for all past and existing sessions if the wait has occurred at least once for a session.
- C. V$SESSION_WAIT and V$SESSION both contain details of the event on which a non-waiting session last waited.
- D. V$SERVICE_EVENT displays all waits for all services if the wait has occurred at least once for a service.
- E. V$SESSION_WAIT_CLASS displays waits broken down by wait class only for waiting sessions.
- F. V$SESSION_EVENT displays all waits for all past sessions if the wait has occurred at least once for a session.
Answer: C,E,F
NEW QUESTION # 154
Which two are true about Oracle Grid Infrastructure for a Standalone Server? (Choose two.)
- A. It requires Oracle Automatic Storage Management (ASM) components to be installed separately.
- B. The CSS daemon runs from the Grid Infrastructure home.
- C. It supports volume management, file system, and automatic restart capabilities.
- D. It can manage database resources on the server where it is installed or on a different server.
- E. It must be installed before the Oracle database software is installed.
Oracle Grid Infrastructure for a standalone server includes Oracle Restart and Oracle Automatic Storage Management.
If you install Oracle Grid Infrastructure for a standalone server and then create your database, then the database is automatically added to the Oracle Restart configuration. Oracle Restart automatically restarts the database when required.
If you install Oracle Grid Infrastructure for a standalone server on a host computer on which a database already exists, then you must manually add the database, the listener, the Oracle ASM instance, and other components to the Oracle Restart configuration before you are able to configure automatic database restarts.
NEW QUESTION # 155
1Z0-083 Latest Practice Materials: https://www.prep4cram.com/1Z0-083_exam-questions.html
- 1Z0-083 Trustworthy Exam Torrent 🦚 1Z0-083 Exam Experience 🌤 1Z0-083 Exam Quick Prep 🍏 Copy URL [url]www.dumpsmaterials.com open and search for 1Z0-083 to download for free 😧Latest 1Z0-083 Test Dumps[/url]
- Test 1Z0-083 Questions - Oracle Oracle Database Administration II - High Pass-Rate 1Z0-083 Latest Practice Materials 🍁 The page for free download of { 1Z0-083 } on [ [url]www.pdfvce.com ] will open immediately 🛫1Z0-083 Dumps Collection[/url]
- 1Z0-083 Dumps Collection 🏮 Trustworthy 1Z0-083 Practice 🥂 1Z0-083 Latest Torrent 🐄 Download ➡ 1Z0-083 ️⬅️ for free by simply searching on ➠ [url]www.practicevce.com 🠰 🙅1Z0-083 Dumps Collection[/url]
- Quiz Marvelous Oracle - 1Z0-083 - Test Oracle Database Administration II Questions 🏳 Download [ 1Z0-083 ] for free by simply entering [url]www.pdfvce.com website 🚏1Z0-083 Interactive EBook[/url]
- Latest 1Z0-083 Test Prep 🕡 Trustworthy 1Z0-083 Practice 🔚 Trustworthy 1Z0-083 Exam Torrent 😡 Open ▛ [url]www.examcollectionpass.com ▟ and search for ➤ 1Z0-083 ⮘ to download exam materials for free 👎1Z0-083 Latest Test Labs[/url]
- 1Z0-083 Dumps Collection 🔄 1Z0-083 Latest Test Labs 💌 1Z0-083 Training Questions 🌛 Open ⏩ [url]www.pdfvce.com ⏪ and search for ⮆ 1Z0-083 ⮄ to download exam materials for free 🚹1Z0-083 Trustworthy Exam Torrent[/url]
- Latest 1Z0-083 Test Prep 🥅 Exam 1Z0-083 Dumps ❕ 1Z0-083 New Dumps Book 🏉 The page for free download of 1Z0-083 on ▛ [url]www.examdiscuss.com ▟ will open immediately 🦠1Z0-083 Learning Engine[/url]
- 1Z0-083 Learning Engine 🚨 1Z0-083 Exam Quick Prep 🏙 New 1Z0-083 Mock Exam ✳ Immediately open [url]www.pdfvce.com and search for 1Z0-083 to obtain a free download 😒1Z0-083 Exam Quick Prep[/url]
- 100% Pass Quiz Pass-Sure Oracle - Test 1Z0-083 Questions 🙃 The page for free download of 1Z0-083 on ☀ [url]www.exam4labs.com ️☀️ will open immediately 🦖Valid 1Z0-083 Test Preparation[/url]
- Quiz Marvelous Oracle - 1Z0-083 - Test Oracle Database Administration II Questions 🟠 Download ☀ 1Z0-083 ️☀️ for free by simply searching on ➽ [url]www.pdfvce.com 🢪 🧆1Z0-083 Learning Engine[/url]
- Free demo of the 1Z0-083 exam product ☃ Search on ▛ [url]www.validtorrent.com ▟ for [ 1Z0-083 ] to obtain exam materials for free download 🍈Latest 1Z0-083 Test Dumps[/url]
- bbs.t-firefly.com, appos-wp.edalytics.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BONUS!!! Download part of Prep4cram 1Z0-083 dumps for free: https://drive.google.com/open?id=1PmMQvasdijy4gFQw3t0ny-hKfwqJSGO8
