Free PDF F5 - F5CAB4 - Authoritative Exam BIG-IP Administration Control Plane Ad
108
Posted at 2/22/2026 00:24:58      View116 | Replies0        Print      Only Author   [Copy Link] 1#
The F5CAB4 web-based practice questions carry the above-mentioned notable features of the desktop-based software. This version of Pass4guide's F5CAB4 practice questions works on Mac, Linux, Android, iOS, and Windows. Our customer does not need troubling plugins or software installations to attempt the web-based F5CAB4 Practice Questions. Another benefit is that our F5CAB4 online mock test can be taken via all browsers, including Chrome, MS Edge, Internet Explorer, Safari, Opera, and Firefox.
F5 F5CAB4 Exam Syllabus Topics:
  • Apply procedural concepts required to manage the state of a high availability pair: This domain covers controlling and monitoring failover states in high availability pairs, including forcing standby
  • offline modes, reporting failover status, and verifying device trust.
  • List which log files could be used to find events and
  • or hardware issues: This section teaches identification of key log files (
  • var
  • log
  • ltm, secure, audit), understanding event severity levels, and interpreting log messages.
  • Explain config sync: This section focuses on configuration synchronization procedures, identifying sync errors, determining sync necessity, checking sync status, and comparing configuration timestamps.
  • Apply procedural concepts required to create, manage, and restore a UCS archive: This domain covers UCS backup and restore procedures, understanding backup use cases, proper storage practices, and UCS file contents including private keys.
Topic 5
  • Given a scenario, determine device upgrade eligibility: This domain covers determining appropriate timing for software and platform upgrades and strategies to minimize downtime during upgrades.
Topic 6
  • Given a scenario, interpret Service status: This section teaches interpreting service states, analyzing netstat output, and determining whether services are listening on specific ports.
Topic 7
  • Explain authentication methods: This section focuses on user management including creating
  • modifying users, configuring remote authentication providers, and implementing group-based access control.
Topic 8
  • Identify and report current device status: This domain covers monitoring BIG-IP operational status through LCD panels, dashboards, Network Map, GUI
  • TMSH commands, and checking high availability states.
Latest Exam F5CAB4 Cram Review Help You to Get Acquainted with Real F5CAB4 Exam SimulationLike the real exam, Pass4guide F5 F5CAB4 Exam Dumps not only contain all questions that may appear in the actual exam, also the SOFT version of the dumps comprehensively simulates the real exam. With Pass4guide real questions and answers, when you take the exam, you can handle it with ease and get high marks.
F5 BIG-IP Administration Control Plane Administration Sample Questions (Q51-Q56):NEW QUESTION # 51
A BIG-IP Administrator must determine if a Virtual Address is configured to fail over to the standby member of a device group. In which area of the Configuration Utility can this be confirmed?
  • A. Device Management > Traffic Groups
  • B. Device Management > Devices
  • C. Local Traffic > Virtual Servers
  • D. Device Management > Overview
Comprehensive and Detailed Explanation From BIG-IP Administration Control Plane Administration documents: To re27port the current status of high availability for specific traffic, an administrator must verify the Traffic Group association28. In the Configuration Utility, Virtual Server properties include the Virtual Address settings where the 'Traffic Group' is assigned29292929. If the Virtual Address is assigned to a floating traffic group (like traffic-group-1), it is configured to fail over to the standby member30303030.
NEW QUESTION # 52
Users are unable to reach an application. The BIG-IP Administrator checks the Configuration Utility and observes that the Virtual Server has a red diamond in front of the status.
What is causing this issue? (Choose one answer)
  • A. The Virtual Server is disabled
  • B. All pool members have been disabled
  • C. The Virtual Server is receiving HTTPS traffic over an HTTP virtual
  • D. All pool members are down
In the BIG-IP Configuration Utility, status icons provide immediate health information. A red diamond specifically indicates that the object itself is administratively disabled. When a virtual server is disabled, BIG-IP will not accept or process traffic for that virtual server, regardless of pool or node state.
* If all pool members were down, the virtual server would typically show a yellow triangle (available but no resources).
* If all pool members were disabled, the virtual server would usually still be enabled but unavailable due to pool status, not shown as a red diamond.
* Protocol mismatch (HTTPS sent to HTTP) does not change the administrative status icon of the virtual server.
Therefore, the red diamond clearly indicates the virtual server is disabled, making D the correct answer.
NEW QUESTION # 53
Administrative user accounts have been defined on the remote LDAP server and are unable to log in to the BIG-IP device.
Which log file should the BIG-IP Administrator check to find the related messages? (Choose one answer)
  • A. /var/log/user.log
  • B. /var/log/messages
  • C. /var/log/ltm
  • D. /var/log/secure
When BIG-IP is configured to use remote authentication (such as LDAP), all authentication and authorization attempts-including successes and failures-are logged to /var/log/secure.
For LDAP-based administrative login issues, /var/log/secure contains:
* LDAP authentication failures
* PAM authentication errors
* Authorization and access-denied messages
* Details explaining why a remote user could not log in
* /var/log/user.log is not a standard BIG-IP log file for authentication.
* /var/log/ltm logs traffic management events, not user authentication.
* /var/log/messages contains general system messages but not detailed authentication failure information.
Therefore, the correct log file to troubleshoot LDAP administrative login failures is /var/log/secure.
NEW QUESTION # 54
A BIG-IP Administrator is unable to connect to the management interface via HTTPS. What is a possible reason for this issue?
  • A. The IP address of the device used to access the management interface is NOT included in the "P Allow" list in the Configuration Utility.
  • B. The IP address of the device used to access the management interface is NOT included in the "httpd Allow" list in the CLI.
  • C. The port lockdown setting is configured to Allow None.
  • D. An incorrect management route is specified.
Comprehensive and Detailed Explanation From BIG-IP Administration Control Plane Administration documents: Management connectivity is protected by an allowed access list for the httpd daemon. Unlike TMM data ports which use 'Port Lockdown' settings, the management port's access is controlled by a specific 'Allow' list323232. If an administrator's IP is not explicitly included in this list, the Control Plane will reject HTTPS connection attempts to the management utility33.
NEW QUESTION # 55
A BIG-IP device sends out the following SNMP trap: big-ipo.f5.com - bigipExternalLinkChange Link: 1.0 is DOWN. Where in the BIG-IP Configuration utility should the BIG-IP Administrator verify the current status of Link 1.0?
  • A. Statistics > Performance > System
  • B. System > Platform
  • C. Network > Interfaces > Interface List
  • D. Network > Trunks > Trunk List
Comprehensive and Detailed Explan13ation From BIG-IP Administration Control Plane Administration documents: Monitoring the physical status of the device is critical for reporting device health. In F5 nomenclature, "1.0", "1.1", etc., represent physical hardware interfaces. To verify if a physical link is up or down as reported by the Control Plane's SNMP agent, the administrator must check the Interface List located under Network > Interfaces
NEW QUESTION # 56
Consistent practice with it relieves exam stress and boosts self-confidence. The web-based F5CAB4 practice exam does not require additional software installation. All operating systems also support this BIG-IP Administration Control Plane Administration (F5CAB4) practice test. We update our BIG-IP Administration Control Plane Administration (F5CAB4) pdf format regularly so keep calm because you will always get updated BIG-IP Administration Control Plane Administration (F5CAB4) questions.
F5CAB4 Valid Study Guide: https://www.pass4guide.com/F5CAB4-exam-guide-torrent.html
