最新ACP-620試題 - ACP-620熱門題庫
Posted at 2/22/2026 02:09:45
P.S. Fast2test在Google Drive上分享了免費的、最新的ACP-620考試題庫:https://drive.google.com/open?id=10ZYwzfo8c5xM_18hNbzROhCn8ZlKFaVK
作為一位 ATLASSIAN ACP-620 考生而言,作好充分的準備可以幫助您通過考試。首先您必須去當地考試中心咨詢相關考試信息,然后挑選最新的 ACP-620 考試題庫,因為擁有了最新的 ACP-620 考試題庫可以有利的提高通過考試的機率。使用Fast2test 的題庫可以節省您寶貴的時間,保證你順利通過 ACP-620 考試。既能幫您節省時間,又可以順利幫助您通過考試,這將是您的最佳選擇。
通過ATLASSIAN ACP-620 認證考試的方法有很多種,花大量時間和精力來復習ATLASSIAN ACP-620 認證考試相關的專業知識是一種方法,通過少量時間和金錢選擇使用Fast2test的針對性訓練和練習題也是一種方法。
ACP-620熱門題庫,ACP-620題庫多年以來,Fast2test一直致力於為廣大參加IT認證考試的考生們提供最優秀並且最值得信賴的參考資料。關於IT認證考試的出題,Fast2test有著豐富的經驗。而且,Fast2test已經幫助過無數的考生,並得到了大家的信賴和表揚。所以,不要懷疑Fast2test的ACP-620考古題的品質了。這絕對是一個可以保證你通過ACP-620考試的資料。Fast2test向你保證考不過就全額退款。有了這個保證,你完全沒有必要再猶豫到底要不要買這個考古題了。错过了它将是你很大的损失。
最新的 Jira Administrator ACP-620 免費考試真題 (Q53-Q58):問題 #53
Which of the following are true about the Jira permission? (Choose three.)
- A. You need 'Manage Sprints' permission to complete your sprint.
- B. You need 'Fix Version' permission to set the 'Fix version' field.
- C. You need 'Resolve Issues' permission to set the 'Fix version' field.
- D. You need the Jira Core application access to create a new sprint.
- E. You need 'Move Issues' permission to move the issue's status to another status.
- F. You need 'Resolve Issues' permission to reopen resolved issues.
答案:A,C,F
問題 #54
Which of the following are true about managing a Jira board? (Choose three.) Board administrators can change the board filter even though they are not the owner of the saved filter.
- A. The number of Epics in the backlog would not be affected by the Board Filter.
- B. Versions in the backlog will only show issues that match with the Board Filter.
- C. Board Filter allows users to hide issues from the Jira board without changing the number of issues in their report.
- D. Board Sub-Filter allows users to hide issues from the Jira board without changing the number of issues in their report.
- E. As a Jira administrator, they can create a new status from the Jira board.
答案:B,D,E
問題 #55
You need to write a JQL query that returns all issues without the label "discard".
Identify the JQL statement that returns the correct results.
- A. labels not in (discard, NULL)
- B. labels != discard OR labels is EMPTY
- C. label!- discard
- D. labels in (discard, EMPTY)
- E. labels != discard
答案:B
解題說明:
This JQL correctly returns all issues that do not have the label "discard", including those where the labels field is empty. Without theOR labels is EMPTYclause, issues with no labels would be excluded.
問題 #56
The UX team uses a custom issue type named Design in your team-managed project.
You want them to start entering the number of days spent and remaining on each of their issues.
What field must you add to the Design issue type?
- A. Time tracking
- B. Estimation Statistic
- C. Date Time Picker
- D. Time stamp
- E. Date
答案:A
解題說明:
The Time tracking field is required to allow users to enter the number of days (or time) spent and the remaining estimate on issues. Adding this field to theDesignissue type enables tracking of effort in terms of logged and remaining time.
問題 #57
Nick found his Human Resource (HR) Jira project is using an incorrect project key. He then changed the project key from "HT" to "HR" and also renamed the project.
If Nick exported, then imported this project, which of the following is false?
- A. All answers are correct.
- B. Users can create a new project using the previous project key.
- C. Users can access issues of the imported project from the Jira macro in Confluence.
- D. Users can access issues of the imported project using the old project key.
- E. Jira will remove all previous project keys.
答案:A
問題 #58
Fast2test擁有一個由龐大的ATLASSIAN行業精英組成的團隊。他們都在ATLASSIAN行業中有很高的權威。他們利用專業的知識和經驗不斷地為準備參加ACP-620相關認證考試的人提供培訓材料。Fast2test提供的考試練習題和答案準確率很高,可以100%保證你ACP-620考試一次性成功,而且還免費為你提供一年的更新服務。
ACP-620熱門題庫: https://tw.fast2test.com/ACP-620-premium-file.html
ATLASSIAN 最新ACP-620試題 有很多人因為沒有充分的時間準備考試從而放棄了參加IT認證考試,它是你通過ACP-620考試的保障,ATLASSIAN 最新ACP-620試題 就是因為自己始終處在一個非常枯燥的境地中,ATLASSIAN 最新ACP-620試題 取得這個考試的認證資格對想晉升的人們來說是最好的,也是最可以看到效果的選擇,我們都知道,大量的練習ACP-620問題集有助於提高我們的解題能力,能夠拓寬我們的知識面,ATLASSIAN ACP-620熱門題庫認證:專業提供ATLASSIAN ACP-620熱門題庫認證題庫、ATLASSIAN ACP-620熱門題庫題庫下載 Fast2test ACP-620熱門題庫提供最新ATLASSIAN ACP-620 熱門題庫題庫,覆蓋全面的ATLASSIAN ACP-620熱門題庫題庫,將助您輕松掌握知識,順利通過考試認證,有了Fast2test ATLASSIAN的ACP-620考試認證培訓資料你可以理清你淩亂的思緒,讓你為考試而煩躁不安。
東華和峨嵋兩派的五名弟子聽後,無不臉色大變,總古至今南蠻的地區總是資源缺乏,虎視眈眈我們的綿薄之地,有很多人因為沒有充分的時間準備考試從而放棄了參加IT認證考試,它是你通過ACP-620考試的保障,就是因為自己始終處在一個非常枯燥的境地中。
全面覆蓋的最新ACP-620試題 |高通過率的考試材料|最好的ACP-620熱門題庫取得這個考試的認證資格對想晉升的人們來說是最好的,也是最可以看到效果的選擇,我們都知道,大量的練習ACP-620問題集有助於提高我們的解題能力,能夠拓寬我們的知識面。
- 高質量的最新ACP-620試題,全面覆蓋ACP-620考試知識點 💏 立即到《 tw.fast2test.com 》上搜索【 ACP-620 】以獲取免費下載ACP-620真題材料
- ACP-620考題資源 🗻 ACP-620考題資源 📀 ACP-620認證資料 ⏳ 進入☀ [url]www.newdumpspdf.com ️☀️搜尋▶ ACP-620 ◀免費下載ACP-620學習資料[/url]
- 有效的最新ACP-620試題和資格考試的領導者和有口皆碑的ACP-620:Managing Jira Cloud Projects ✔️ 「 tw.fast2test.com 」最新( ACP-620 )問題集合ACP-620最新考證
- ACP-620最新考證 🌎 ACP-620認證資料 💂 ACP-620真題材料 🎄 《 [url]www.newdumpspdf.com 》上搜索⏩ ACP-620 ⏪輕鬆獲取免費下載新版ACP-620題庫[/url]
- 快速下載的ATLASSIAN 最新ACP-620試題是行業領先材料&熱門的ACP-620:Managing Jira Cloud Projects 😷 打開➤ [url]www.newdumpspdf.com ⮘搜尋{ ACP-620 }以免費下載考試資料ACP-620認證考試解析[/url]
- ACP-620考古題介紹 🔧 ACP-620證照信息 🤖 ACP-620最新考證 🧷 打開【 [url]www.newdumpspdf.com 】搜尋➥ ACP-620 🡄以免費下載考試資料ACP-620考古題介紹[/url]
- 最有效的最新ACP-620試題,由ATLASSIAN權威專家撰寫 🙄 ▛ [url]www.newdumpspdf.com ▟上的《 ACP-620 》免費下載只需搜尋ACP-620考題資源[/url]
- ACP-620學習指南 🧵 ACP-620考試指南 🩸 ACP-620考古題介紹 😍 在{ [url]www.newdumpspdf.com }網站上免費搜索▶ ACP-620 ◀題庫ACP-620软件版[/url]
- 高效的ATLASSIAN 最新ACP-620試題&完美的[url]www.newdumpspdf.com - 資格考試的領先提供商 🎿 到➤ www.newdumpspdf.com ⮘搜尋【 ACP-620 】以獲取免費下載考試資料ACP-620認證資料[/url]
- ACP-620考試大綱 ✉ ACP-620認證考試解析 🕥 ACP-620測試題庫 👟 打開網站⮆ [url]www.newdumpspdf.com ⮄搜索➥ ACP-620 🡄免費下載ACP-620熱門證照[/url]
- 有效的最新ACP-620試題和資格考試的領導者和有口皆碑的ACP-620:Managing Jira Cloud Projects 🧦 免費下載☀ ACP-620 ️☀️只需在▷ [url]www.kaoguti.com ◁上搜索ACP-620認證資料[/url]
- try.drmsobhy.net, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, campus.academiamentesana.com, tutor.appdeeboktor.com, owners111.com, videodakenh.com, www.stes.tyc.edu.tw, Disposable vapes
