Hardware
Test PDI Questions Pdf, 100% PDI Correct Answers
Posted at 2/22/2026 05:19:06
View149
Replies1
2026 Latest Dumpkiller PDI PDF Dumps and PDI Exam Engine Free Share: https://drive.google.com/open?id=1-AU-YjkqkQTkWq5rzYkEYdZvrO4znOFm
Our PDI study prep has inspired millions of exam candidates to pursuit their dreams and motivated them to learn more high-efficiently. Many customers get manifest improvement. PDI simulating exam will inspire your potential. And you will be more successful with the help of our PDI training guide. Just imagine that when you have the certification, you will have a lot of opportunities to come to the bigger companies and get a higher salary.
Platform Developer I (PDI) ExamPlatform Developer I (PDI) Exam is related to Salesforce Certified Platform Developer I Certification. This exam validates the Candidate knowledge and skills in building custom applications on the Lightning Platform. It also deals with the ability of the Lightning Platform to develop custom business logic and interfaces to extend Salesforce using Apex and Visualforce.
Salesforce PDI, or Platform Developer I, is a certification exam designed to test an individual's proficiency in Salesforce development. PDI Exam evaluates a candidates ability to create custom objects, formula fields, and workflow rules while applying best practices and accommodating platform limits. Passing the exam demonstrates the candidate's knowledge of the Salesforce platform and their ability to develop simple yet robust solutions that meet client requirements.
100% Salesforce PDI Correct Answers, PDI Pdf DumpsThe whole payment process on our PDI exam braindumps only lasts a few seconds as long as there has money in your credit card. Then our system will soon deal with your orders according to the sequence of payment. Usually, you will receive the PDI Study Materials no more than five minutes. Then you can begin your new learning journey of our PDI praparation questions. All in all, our payment system and delivery system are highly efficient.
Salesforce Platform Developer I (PDI) Sample Questions (Q67-Q72):NEW QUESTION # 67
Which action causes a before trigger to fire by default for Accounts?
- A. Converting Leads to Contact accounts
- B. Updating addresses using the Mass Address update tool
- C. Renaming or replacing picklist
- D. Importing data using the Data Loader and the Bulk API
NEW QUESTION # 68
A developer considers the following snippet of code:
Based on this code, what is the value of x?
NEW QUESTION # 69
A company wants to create an employee rating program that allows employees to rate each other. An employees average rating must be displayed on the employee record. Employees must be able to create rating records, but are not allowed to create employee records. Which two actions should a developer take to accomplish this task?
- A. Create a master-detail relationship between the Rating and Employee objects.
- B. Create a lookup relationship between the Rating and Employee object.
- C. Create a roll-up summary field on the Employee and use AVG to calculate the average rating score.
- D. Create a trigger on the Rating object than updates a field on the Employee object.
NEW QUESTION # 70
Which two are best practices when it comes to Aura component and application event handling?
Choose 2 answers
- A. Try to use application events as opposed to component events.
- B. Use component events to communicate actions that should be handled at the application level.
- C. Handle low-level events in the event handler and re-fire them as higher-level events.
- D. Reuse the event logic in a component bundle, by putting the fogic in the helper.
Option C: Handle low-level events in the event handler and re-fire them as higher-level events.
True.
It's a best practice to encapsulate lower-level events and re-emit them as higher-level, application-specific events to decouple components and simplify event handling.
Placing reusable logic in the helper aids in maintaining clean code and promotes reusability across the component's controller and renderer.
Best practice recommends using component events when possible.
Application events should be used sparingly due to their performance impact and broader scope.
Component events are designed for parent-child communication.
For application-level communication, application events are appropriate.
Lightning Components Best Practices
Option D: Reuse the event logic in a component bundle, by putting the logic in the helper.
True.
Helper Functions
Option A: Try to use application events as opposed to component events.
False.
Component Events vs. Application Events
Option B: Use component events to communicate actions that should be handled at the application level.
False.
Event Communication Patterns
Conclusion:
The best practices are C and D.
NEW QUESTION # 71
A developer has the following class and trigger code:
public class InsuranceRates { public static final Decimal smokerCharge = 0.01; } trigger ContactTrigger on Contact (before insert) { InsuranceRates rates = new InsuranceRates(); Decimal baseCost = XXX; } Which code segment should a developer insert at the XXX to set the baseCost variable to the value of the class variable smokerCharge?
- A. ContactTrigger.InsuranceRates.smokerCharge
- B. Rates.getSmokerCharge()
- C. InsuranceRates.smokerCharge
- D. Rates.smokerCharge
NEW QUESTION # 72
The PDI Exam softwares user-friendly interface is made to uproot potential problems. Once you will try the demo of PDI exam questions, you will be well- acquainted with the software and its related features. Also PDI exam comes with various self-assessment features like timed exam, randomization questions, and multiple questions types, test history and score etc. Which means it enables you to customize the question type and you may practice random questions in order to enhance your skills and expertise. You may keep attempting the same questions many a time also.
100% PDI Correct Answers: https://www.dumpkiller.com/PDI_braindumps.html
- PDI Latest Exam Materials 💌 Exam PDI Collection 📐 Latest PDI Braindumps 🎹 Download ➤ PDI ⮘ for free by simply entering ▶ [url]www.prepawaypdf.com ◀ website 💭Latest PDI Braindumps[/url]
- PDI Exam Review 🪕 New PDI Test Labs 📂 PDI Labs 🏥 ☀ [url]www.pdfvce.com ️☀️ is best website to obtain ⇛ PDI ⇚ for free download 🍝
DI Reliable Braindumps Free[/url] - Excellent Test PDI Questions Pdf Covers the Entire Syllabus of PDI 🐫 Easily obtain ☀ PDI ️☀️ for free download through { [url]www.prepawayexam.com } 🔓Exam PDI Dumps[/url]
- PDI Reliable Braindumps Free 🍵 Study PDI Plan ⏺ Valid PDI Test Book 🦄 Search for ⇛ PDI ⇚ and download exam materials for free through [url]www.pdfvce.com 🙄Exam PDI Dumps[/url]
- Newest Salesforce Test PDI Questions Pdf offer you accurate 100% Correct Answers | Platform Developer I (PDI) 🍞 Easily obtain ☀ PDI ️☀️ for free download through ✔ [url]www.exam4labs.com ️✔️ 🏎Exam PDI PDF[/url]
- Test PDI Questions Pdf - Quiz First-grade Salesforce 100% PDI Correct Answers 🐏 Download ➠ PDI 🠰 for free by simply entering ⇛ [url]www.pdfvce.com ⇚ website 📯Exam PDI PDF[/url]
- Latest PDI Braindumps 🐫 PDI 100% Exam Coverage 🥘 New PDI Test Labs ✔ Search for ⇛ PDI ⇚ on { [url]www.testkingpass.com } immediately to obtain a free download ➿Valid PDI Exam Sims[/url]
- Valid PDI Exam Sims 🛣 PDI Labs 🎐 Hot PDI Questions 🦁 Immediately open { [url]www.pdfvce.com } and search for ➽ PDI 🢪 to obtain a free download 🗳Exam PDI PDF[/url]
- Exam PDI PDF 🕥 PDI Test Testking 🕕 Valid PDI Exam Sims 🦂 Open ➤ [url]www.vce4dumps.com ⮘ enter ▷ PDI ◁ and obtain a free download 🐖Latest PDI Braindumps[/url]
- New PDI Test Labs 🍯 PDI Valid Test Tips 🤎 PDI Reliable Braindumps Free 🦃 The page for free download of ⮆ PDI ⮄ on [url]www.pdfvce.com will open immediately 🐾Hot PDI Questions[/url]
- PDI: Your Partner in Salesforce PDI Exam Preparation with Free Demos and Updates 🥌 Search for ✔ PDI ️✔️ on ➽ [url]www.vce4dumps.com 🢪 immediately to obtain a free download 🚖
DI Exam Review[/url] - www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, videodakenh.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BTW, DOWNLOAD part of Dumpkiller PDI dumps from Cloud Storage: https://drive.google.com/open?id=1-AU-YjkqkQTkWq5rzYkEYdZvrO4znOFm
