F5CAB4 Reliable Test Vce & F5CAB4 Testking Learning Materials
105
Posted at 2/22/2026 06:20:47      View:89 | Replies:0        Print      Only Author   [Copy Link] 1#
If you download our study materials successfully, you can print our study materials on pages by the PDF version of our F5CAB4 exam torrent. We believe these special functions of the PDF version will be very useful for you to prepare for your exam. We hope that you will like the PDF version of our F5CAB4 question torrent. If you try to get the BIG-IP Administration Control Plane Administration certification that you will find there are so many chances wait for you. You can get a better job; you can get more salary. But if you are trouble with the difficult of BIG-IP Administration Control Plane Administration exam, you can consider choose our F5CAB4 Exam Questions to improve your knowledge to pass BIG-IP Administration Control Plane Administration exam, which is your testimony of competence.
F5 F5CAB4 Exam Syllabus Topics:
  • Identify configured system services: This domain covers verifying proper configuration of essential services including DNS, NTP, SNMP, and syslog.
  • Explain config sync: This section focuses on configuration synchronization procedures, identifying sync errors, determining sync necessity, checking sync status, and comparing configuration timestamps.
  • Identify and report current device status: This domain covers monitoring BIG-IP operational status through LCD panels, dashboards, Network Map, GUI
  • TMSH commands, and checking high availability states.
  • List which log files could be used to find events and
  • or hardware issues: This section teaches identification of key log files (
  • var
  • log
  • ltm, secure, audit), understanding event severity levels, and interpreting log messages.
Topic 5
  • Explain authentication methods: This section focuses on user management including creating
  • modifying users, configuring remote authentication providers, and implementing group-based access control.
Topic 6
  • Apply procedural concepts required to manage the state of a high availability pair: This domain covers controlling and monitoring failover states in high availability pairs, including forcing standby
  • offline modes, reporting failover status, and verifying device trust.
Topic 7
  • Identify management connectivity configurations: This section focuses on understanding management access configurations, including management IP addresses, port lockdown settings, remote connectivity verification, and troubleshooting access issues.
Topic 8
  • Given a scenario, determine device upgrade eligibility: This domain covers determining appropriate timing for software and platform upgrades and strategies to minimize downtime during upgrades.
Latest updated F5CAB4 Reliable Test Vce | Easy To Study and Pass Exam at first attempt & Hot F5 BIG-IP Administration Control Plane AdministrationBIG-IP Administration Control Plane Administration Practice exams of Prep4sureExam i.e. desktop software and web-based are customizable and you can attempt them for multiple times. These practice exam save progress report of each attempt so you can assess it to find and overcome mistakes. As mentioned earlier, these BIG-IP Administration Control Plane Administration (F5CAB4) practice exams can be customized according to your requirements. You can change their time and numbers of BIG-IP Administration Control Plane Administration (F5CAB4) dumps questions as you want.
F5 BIG-IP Administration Control Plane Administration Sample Questions (Q19-Q24):NEW QUESTION # 19
An organization is performing a major release upgrade to its BIG-IP system. The system is under medium load and has enough disk space to perform the upgrade.
Which pre-upgrade task is disruptive to regular system performance and should be performed during a maintenance window? (Choose one answer)
  • A. Create a QKView
  • B. Generate a UCS
  • C. Reactivate the license
  • D. tmsh save sys config
Reactivating a BIG-IP license is a traffic-disruptive operation. During the license reactivation process, the BIG-IP system performs a configuration reload, which results in a temporary interruption of all traffic processing. Because traffic handling is affected, F5 explicitly recommends scheduling license updates during a maintenance window.
This behavior is documented in F5 Knowledge Base articles, which state that license reactivation impacts traffic and must be planned accordingly during upgrades or system changes.
The other options are not considered disruptive:
* Creating a QKView is primarily a diagnostic task and does not interrupt traffic.
* Running tmsh save sys config only saves the running configuration to disk.
* Generating a UCS is resource-intensive but does not reload configuration or interrupt traffic processing.
NEW QUESTION # 20
The BIG-IP Administrator has modified an iRule on one device of an HA pair. The BIG-IP Administrator notices there is NO traffic on the BIG-IP device in which they are logged into. What should the BIG-IP Administrator do to verify if the iRule works correctly?
  • A. Push configuration from this device to the group and start to monitor traffic on this device
  • B. Log in to the other device in the cluster, pull configuration to it, and start to monitor traffic on that device
  • C. Log in to the other device in the cluster, push configuration from it, and start to monitor traffic on that device
  • D. Pull configuration to this device to the cluster and start to monitor traffic on this device
Comprehensive and Detailed Explanation From BIG-IP Administration Control Plane Adminis44tration documents: In a45n Active/Standby HA pair, application traffic only flows through the Active device. If an administrator makes a change on the Standby device (which has no traffic), they must synchronize the configuration to the Active device to test it. The procedural step is to log into the Active device and "pull" the configuration from the Standby device (or push from Standby) so the Active device can process traffic using the new iRule
NEW QUESTION # 21
A BIG-IP Administrator needs to restore a UCS file to an F5 device using the Configuration Utility. Which section of the Configuration Utility should the BIG-IP Administrator access to perform this task?
  • A. System > Configuration
  • B. Local Traffic > Virtual Servers
  • C. System > Archives
  • D. Local Traffic > Policies
Managing the state of a device often involves restoring configuration backups known as User Configuration Set (UCS) files These archives contain the full system configuration, including licenses and SSL certificates.
The Control Plane provides a dedicated management area for these files under System > Archives, where administrators can upload, create, and restore configuration snapshots
NEW QUESTION # 22
A BIG-IP Administrator needs to export system configuration for migration purposes. Which file type should be used?
  • A. QKView
  • B. UCS
  • C. ISO
  • D. SCF
In F5 TMOS, a User Configuration Set (UCS) is the standard archive format used for backing up and migrating a complete system configuration .
* Composition: A UCS file contains all necessary configuration data, including system-specific files, license information, SSL certificates, private keys, and local user accounts.
* Procedural Use: When migrating to new hardware or performing an RMA replacement, the UCS file is the primary tool used to restore the entire Control Plane state to the new device.
* Restoration: It can be managed through the Configuration Utility under System > Archives or via the CLI using the tmsh load /sys ucs command The correct location to restrict management access to specific subnets is D. System > Platform1.
NEW QUESTION # 23
A BIG-IP Administrator needs to load a UCS file but must exclude the license file.
How should the administrator perform this task? (Choose one answer)
  • A. From the CLI with command tmsh load /sys ucs <ucs filename> no-license
  • B. From the GUI, select the UCS file, uncheck the license box, and click Restore
  • C. From the CLI with command tmsh load /sys ucs <ucs filename>
  • D. From the GUI, select the UCS file and click Restore
When restoring a User Configuration Set (UCS) file, BIG-IP allows administrators to selectively exclude the license during the restore process. From the CLI, this is accomplished using the no-license option with the tmsh load /sys ucs command.
The command:
restores:
* System configuration
* Certificates and keys
* Device and traffic objects
while explicitly excluding the license file, which is required when:
* Migrating configurations between devices
* Restoring to hardware with a different license
* Avoiding license conflicts or overwrites
* A does not provide the option to exclude the license.
* B restores the UCS including the license, which does not meet the requirement.
* D is incorrect because the BIG-IP GUI does not provide a checkbox to exclude the license during UCS restore.
Therefore, the correct and supported method is C.
NEW QUESTION # 24
If you want to constantly improve yourself and realize your value, if you are not satisfied with your current state of work, if you still spend a lot of time studying and waiting for F5CAB4 qualification examination, then you need our F5CAB4 material, which can help solve all of the above problems. I can guarantee that our study materials will be your best choice. Our F5CAB4 Study Materials have three different versions, including the PDF version, the software version and the online version, to meet the different needs, our products have many advantages, I will introduce you to the main characteristics of our F5CAB4 research materials.
F5CAB4 Testking Learning Materials: https://www.prep4sureexam.com/F5CAB4-dumps-torrent.html
