[General] Microsoft MS-102 New Dumps Book & Dumps MS-102 Discount
103
General Microsoft MS-102 New Dumps Book & Dumps MS-102 Discount
Posted at 2/22/2026 08:00:11      View122 | Replies1        Print      Only Author   [Copy Link] 1#
What's more, part of that ActualCollection MS-102 dumps now are free: https://drive.google.com/open?id=1IuBZ846ynU-E536EMQDGyYsmhezxr_DL
ActualCollection presents its Microsoft 365 Administrator (MS-102) exam product at an affordable price as we know that applicants desire to save money. To gain all these benefits you need to enroll in the Microsoft 365 Administrator EXAM and put all your efforts to pass the challenging Microsoft 365 Administrator (MS-102) exam easily. In addition, you can test specs of the Microsoft 365 Administrator practice material before buying by trying a free demo. These incredible features make ActualCollection prep material the best option to succeed in the Microsoft MS-102 examination. Therefore, don't wait. Order Now !!!
Microsoft MS-102 Exam Syllabus Topics:
  • Implement and manage Microsoft Entra identity and access: In this topic, questions about Microsoft Entra tenant appear. Moreover, it delves into implementation and management of authentication and secure access.
  • Deploy and manage a Microsoft 365 tenant: Management of roles in Microsoft 365 and management of users and groups are discussion points of this topic. It also focuses on implementing and managing a Microsoft 365 tenant.
  • Manage compliance by using Microsoft Purview: Implementation of Microsoft Purview information protection and data lifecycle management is discussed in this topic. Moreover, questions about implementing Microsoft Purview data loss prevention (DLP) also appear.
  • Manage security and threats by using Microsoft Defender XDR: This topic discusses how to use Microsoft Defender portal to manage security reports and alerts. It also focuses on usage of Microsoft Defender for Office 365 to implement and manage email and collaboration protection. Lastly, it discusses the usage of Microsoft Defender for Endpoint for the implementation and management of endpoint protection.
Dumps MS-102 Discount & MS-102 Valid Test FormatThe MS-102 Test Guide is written by lots of past materials rigorous analyses. The language of our study materials are easy to be understood, only with strict study, we write the latest and the specialized study materials. We want to provide you with the best service and hope you can be satisfied. It boosts your confidence for real exam and will help you remember the exam questions and answers that you will take part in. You may analyze the merits of each version carefully before you purchase our Microsoft 365 Administrator guide torrent and choose the best one.
Microsoft 365 Administrator Sample Questions (Q538-Q543):NEW QUESTION # 538
You have an Azure AD tenant that contains the users shown in the following table.
You enable self-service password reset for all users. You set Number of methods required to reset to 1, and you set Methods available to users to Security questions only.
What information must be configured for each user before the user can perform a self-service password reset?
To answer, select the appropriate options in the answer area.
NEW QUESTION # 539
You have a Microsoft 365 E5 subscription that uses Microsoft intune. The subscription contains the resources shown in the following table.
User1 is the owner of Device1.
You add Microsoft 365 Apps Windows 10 and later app types to Intune as shown in the following table.
On Thursday, you review the results of the app deployments.
NEW QUESTION # 540
HOTSPOT
You have an Azure AD tenant named contoso.com that contains the users shown in the following table.
Multi-factor authentication (MFA) is configured to use 131.107.5.0/24 as trusted IPs.
The tenant contains the named locations shown in the following table.
You create a conditional access policy that has the following configurations:
* Users or workload identities assignments: All users
* Cloud apps or actions assignment: App1
* Conditions: Include all trusted locations
* Grant access: Require multi-factor authentication
Box 1: Yes
131.107.50.10 is in a Trusted Location so the conditional access policy applies. The policy requires MFA.
However, User1's MFA status is disabled. The MFA requirement in the conditional access policy will override the user's MFA status of disabled. Therefore, User1 must use MFA.
Box 2: Yes.
131.107.20.15 is in a Trusted Location so the conditional access policy applies. The policy requires MFA so User2 must use MFA.
Box 3: No.
IP not from Trusted Location so Policy does not apply, Subnet 131.107.5.5 is not in the range of 131.107.50.0
/24
https://docs.microsoft.com/en-us ... /location-condition
NEW QUESTION # 541
You have a Microsoft 365 tenant.
Company policy requires that all Windows 10 devices meet the following minimum requirements:
Require complex passwords.
Require the encryption of data storage devices.
Have Microsoft Defender Antivirus real-time protection enabled.
You need to prevent devices that do not meet the requirements from accessing resources in the tenant.
Which two components should you create? Each correct answer presents part of the solution.
  • A. a configuration policy
  • B. a conditional access policy
  • C. a configuration profile
  • D. a compliance policy
  • E. a security baseline profile
https://docs.microsoft.com/en-us ... pliance-get-started
NEW QUESTION # 542
Your company uses a legacy on-premises LDAP directory that contains 100 users.
The company purchases a Microsoft 365 subscription.
You need to import the 100 users into Microsoft 365 by using the Microsoft 365 admin center.
Which type of file should you use and which properties are required? To answer, select the appropriate options in the answer area.
https://learn.microsoft.com/en-u ... rs-at-the-same-time
NEW QUESTION # 543
We have the MS-102 Questions and answers with high accuracy and timely update. Our professional team checks MS-102 answers and questions carefully with their professional knowledge. We also have the latest information about the exam center, and will update the version according to the new requirements. Pass guarantee and money back guarantee are also our principles, and if you have any questions, you can also consult the service stuff.
Dumps MS-102 Discount: https://www.actualcollection.com/MS-102-exam-questions.html
BTW, DOWNLOAD part of ActualCollection MS-102 dumps from Cloud Storage: https://drive.google.com/open?id=1IuBZ846ynU-E536EMQDGyYsmhezxr_DL
Posted at 2/22/2026 19:30:21        Only Author  2#
It was a real eye-opener. Free New AP-201 exam study guide resources for your exam prep. Best of luck to everyone!
