HP HPE7-A06 Latest Torrent - HPE7-A06 Latest Test Testking
Posted at 2/22/2026 08:34:33
View117
Replies0
BONUS!!! Download part of PDF4Test HPE7-A06 dumps for free: https://drive.google.com/open?id=1bLw-bKAT9tsv1gLlCNSNMBFViRbPZpMf
Are you on the way to pass the HPE7-A06 exam? Our HPE7-A06 exam questions will be the best choice for you. And if you still feel uncertain about the content, wondering whether it is the exact HPE7-A06 exam material that you want, you can free download the demo to check it out. You will be quite surprised by the convenience to have an overview just by clicking into the link, and you can experience all kinds of HPE7-A06 versions.
Our company has always been following the trend of the HPE7-A06 certification. Our research and development team not only study what questions will come up in the exam, but also design powerful study tools like HPE7-A06 exam simulation software. This Software version of our HPE7-A06 learning quesions are famous for its simulating function of the real exam, which can give the candidates a chance to experience the real exam before they really come to it.
Excellent HPE7-A06 Latest Torrent | HPE7-A06 100% Free Latest Test TestkingBy gathering, analyzing, filing essential contents into our HPE7-A06 training quiz, they have helped more than 98 percent of exam candidates pass the HPE7-A06 exam effortlessly and efficiently. You can find all messages you want to learn related with the exam in our HPE7-A06 Practice Engine. Any changes taking place in the environment and forecasting in the next HPE7-A06 exam will be compiled earlier by them. About necessary or difficult questions, they left relevant information for you.
HPE Campus Access Switching Expert Written Exam Sample Questions (Q11-Q16):NEW QUESTION # 11
A customer hassot a requirement for VLAN 151 to be an isolated VLAN. A colleague has copied and pasted a partialconfiguration, but you do not achieve the desired outcome. This is the code that was added:
What should be added to the configuration before this code to achieve the desired result?
The customer requires VLAN 151 to be configured as an isolated Private VLAN. A partial configuration was added, but the desired outcome wasn't achieved. We need to determine which configuration snippet should be addedbeforethe (unspecified) partial configuration to correctly set up the Private VLAN structure.
* Private VLAN Configuration Fundamentals:
* APrimary VLANmust be defined. This VLAN carries traffic between promiscuous ports and ports in associated secondary VLANs.
* Secondary VLANs(either isolated or community) are associated with the primary VLAN.
* Ports are then mapped to either the primary VLAN (promiscuous ports, typically router/firewall connections) or a secondary VLAN (host ports). Isolated ports within thesameisolated VLAN cannot communicate with each other.
* Analyzing the Options (Assuming VLAN 15 is the intended Primary):
* A)
vlan 15
private-vlan primary
vsx-sync
This correctly defines VLAN 15 as the Primary Private VLAN. The vsx-sync command ensures this configuration is synchronized across a VSX pair (relevant if applicable). This is the necessary prerequisite before defining VLAN 151 as an isolated secondary VLAN and associating it with VLAN 15.
* B)isolated-vlan primary is incorrect syntax. The command is private-vlan primary.
* C)primary-vlan isolated 151 is incorrect syntax for defining either the primary or secondary VLAN type/association within the primary VLAN context.
* D)private-vlan isolated 151 within the vlan 15 context is incorrect syntax. The private-vlan isolated command belongs under the configuration of the secondary VLAN (VLAN 151 in this case).
* Conclusion:Before configuring VLAN 151 as private-vlan isolated and associating it, the primary VLAN must be defined. Option A correctly shows the command (private-vlan primary) under the intended primary VLAN's configuration (vlan 15) to establish it as the primary VLAN.
References:AOS-CX Security Guide (Private VLAN configuration steps and commands). This relates to the
"Switching" (19%) and "Security" (10%) objectives.
NEW QUESTION # 12
In the given example AGG-SW1 and AGG-SW2 use CX 8325 in VSX and Edge-1 with CX 6200F.
You want to avoid sub-optimal pathing and ISL traffic for the VSX and upstream routers R1 and R2.
What is the HPE Aruba Networking recommended solution for the SVIs on the VSX switches connected to R1 and R2?
- A. Configure the VSX SVI using the active-forwarding.
- B. Configure the VSX SVI using the active-gateway.
- C. Configure the VSX SVI using the VRRP virtual-ip.
- D. Configure the VSX SVI using the unicast IP.
In an AOS-CX VSX design, using active-gateway for SVIs ensures both VSX peers respond with the same virtual IP and virtual MAC. This avoids asymmetric routing, sub-optimal pathing, and prevents unnecessary ISL traffic between VSX peers. It is the HPE Aruba Networking recommended best practice for SVIs connected to upstream routers like R1 and R2.
NEW QUESTION # 13
Refer to the exhibit which illustrates the current configuration of Router-1.
Clients of VLAN 10 require access to services hosted in the 10.1.100.0/24subnet. This 'equites one 01 more routes to be added to Rculer-1 that do not currently exist.
Which script would install a route from 10.2.10.0/24 to 10.1.100.0/24 on Router-1? A return path is not required as part of this answer.
- A. there is no solution as Core-1 is not part of VRF service
- B. ip route 0.0.0.0/0 10.255.101.11 vrf service
ip route 10.255.101.0/24 1/1/1 vrf IoT-Medical
ip route 10.1.100.0/24 10.255.101.11 vrf IoT-Medical - C. ip route 0.0.0.0/0 10.255.101.11 vrf service
ip route 10.1.100.0/24 1/1/1:10.255.101.11 vrf IoT-Medical - D. ip route 0.0.0.0/0 10.255.101.11 vrf service
ip route 10.1.100.0/24 1/1/1 vrf IoT-Medical
The goal is to add a static route on Router-1 to allow clients in VLAN 10 (subnet 10.2.10.0/24, presumably in VRF 'IoT-Medical' based on options) to reach services in the 10.1.100.0/24 subnet. The exhibit indicates interface 1/1/1 (IP 10.255.101.10/24) is in VRF 'service', and the likely next hop towards the destination is Core-1 at 10.255.101.11 (also implied to be reachable via VRF 'service'). This requires adding a route in the source VRF ('IoT-Medical') pointing towards the destination via the next hop in the 'service' VRF.
* Static Route Syntax (with VRF):ip route <destination_prefix> <next-hop-ip> [vrf <source-vrf>]
* Analysis of Options:
* A: Claims Core-1 isn't in VRF 'service', contradicting the likely setup.
* B: Uses unusual interface:ip syntax (1/1/1:10.255.101.11). Defines the route in VRF 'IoT- Medical'.
* C: Uses interface 1/1/1 as the next hop. This is less specific than using the IP address and relies on the interface being point-to-point or having proxy ARP enabled. Defines the route in VRF
'IoT-Medical'.
* D: ip route 10.1.100.0/24 10.255.101.11 vrf IoT-Medical. This uses the standard syntax to define a static route for the destination 10.1.100.0/24 via the next-hop IP 10.255.101.11 within the context of the IoT-Medical VRF. The successful function of this route depends on inter-VRF routing (route leaking) being configured between 'IoT-Medical' and 'service' VRFs, but the command itself correctly defines the desired static route.
* Conclusion:Option D provides the correct and standard command syntax to configure the required static route within the specified source VRF ('IoT-Medical').
References:AOS-CX IP Routing Guide (Static Routes), AOS-CX VRF Configuration Guide (Inter-VRF Routing). This relates to the "Routing" (16%) and "Connectivity" (9%) objectives.
NEW QUESTION # 14
VSX cluster is already configured. Your task is to validate a correct configuration for the Edge-1 switch that is connected to a CCTV provider that will install its switching infrastructure. The CCTV switches do not support STP.
What needs to be configured on the Edge-1 switch ports connecting to CCTV-SW1 and CCTV- SW2 to prevent loop problems with the existing setup with automatic recovery features?
- A. configure spanning-tree and TN-guard timeout for CCTV switch ports
- B. configure spanning-tree with udld for CCTV switch ports
- C. configure spanning-tree with bpdu-guard timeout values for CCTV switch ports
- D. configure lag with lacp fallback for CCTV switch ports
Since the CCTV switches don't run STP, Edge-1 should protect itself from potential loops by enabling STP on those ports and using BPDU-guard with an automatic timeout/recovery. If a looped switch starts sending BPDUs, the port is error-disabled, then automatically recovers after the timeout.
NEW QUESTION # 15
Following HPE Aruba Networking best practice, dick where you implement loop protection.
NEW QUESTION # 16
Nowadays, we live so busy every day. Especially for some businessmen who want to pass the HPE7-A06 exam and get related certification, time is vital importance for them, they may dont have enough time to prepare for their exam. Some of them may give it up. But our HPE7-A06 guide tests can solve these problems perfectly, because our study materials only need little hours can be grasped. Once you use our HPE7-A06 Latest Dumps, you will save a lot of time. High effectiveness is our great advantage. After twenty to thirty hours practice, you are ready to take the real HPE7-A06 exam torrent. The results will never let you down. You just need to wait for obtaining the certificate.
HPE7-A06 Latest Test Testking: https://www.pdf4test.com/HPE7-A06-dump-torrent.html
In short, HPE7-A06 exam dump possesses all factors of the best product, HP HPE7-A06 Latest Torrent All your efforts will have great rewards, HP HPE7-A06 Latest Torrent Part of excellent candidates will get a wonderful passing score, PDF4Test HPE7-A06 Latest Test Testking has come up with this new style format in which you can easily track the records of your previous progress, Therefore, with PDF4Test HPE7-A06 Latest Test Testking, you can relax and go ahead on your way to successful future.
Flash requires the parameters of the `
