[General] 100% Pass Quiz 2026 Professional Salesforce CRT-450: Salesforce Certified Platfo
95
General 100% Pass Quiz 2026 Professional Salesforce CRT-450: Salesforce Certified Platfo
Posted at 2/22/2026 09:44:10      View131 | Replies0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of TestkingPass CRT-450 dumps from Cloud Storage: https://drive.google.com/open?id=1dgzV_mOyyNJ61AD35mXn2DHDEzQj7Sa6
The Salesforce Certified Platform Developer I (CRT-450) exam questions can help you gain the high-in-demand skills and credentials you need to pursue a rewarding career. To do this you just need to pass the Salesforce Certified Platform Developer I (CRT-450) certification exam which is not easy to crack. You have to put in some extra effort, and time and prepare thoroughly to pass the Salesforce CRT-450 Exam. For the quick, complete, and comprehensive Salesforce Certified Platform Developer I (CRT-450) exam dumps preparation you can get help from top-notch and easy-to-use CRT-450 Questions.
If you free download the demos of the CRT-450 exam questions, I believe you have a deeper understanding of our products, and we must also trust our CRT-450 learning quiz. Our products can provide you with the high efficiency and high quality you need. Selecting our study materials is your rightful assistant with internationally recognized CRT-450 Certification. What are you waiting for? Quickly use our CRT-450 study materials.
CRT-450 Updated Test Cram, CRT-450 Exam BookWe try our best to renovate and update our Salesforce CRT-450 study materials in order to help you fill the knowledge gap during your learning process, thus increasing your confidence and success rate. At the same time, Salesforce CRT-450 Preparation baindumps can keep pace with the digitized world by providing timely application. You will never fell disappointed with our CRT-450 exam quiz.
Salesforce Certified Platform Developer I Sample Questions (Q71-Q76):NEW QUESTION # 71
A Visualforce page has a standard controller for an object that has a lookup relationship to a parent object. How can a developer display data from the parent record on the page?
  • A. By adding a second standard controller to the page for the parent record.
  • B. By using SOQL on the Visualforce page to query for data from the parent record.
  • C. By using a roll-up formula field on the child record to include data from the parent record.
  • D. By using merge field syntax to retrieve data from the parent record.
NEW QUESTION # 72
Which annotation should a developer use on an Apex method to make it available to be wired to a property in a Lightning web component?
  • A. @AureEnabled
  • B. @AureEnabled (cacheable=true)
  • C. @RemoteAction(|cacheable=true)
  • D. @RemoteAction
NEW QUESTION # 73
A user selects a value from a multi-select picklist. How is this selected value represented in Apex?
  • A. As a list< String > with one element
  • B. As a string ending with a comma
  • C. As a string
  • D. As a set< string > with one element
NEW QUESTION # 74
A custom Visualforce controller calls the ApexPages,addMessage () method, but no messages are rendering on the page.
Which component should be added to the Visualforce page to display the message?
  • A. <apex: pageMessage severity="info''/>
  • B. <Apex: message for='' info''/>
  • C. <apex: pageMessages />
  • D. <Apex: facet name='' message''/>
NEW QUESTION # 75
developer created this Apex trigger that calls MyClass .myStaticMethod:
trigger myTrigger on Contact(before insert) ( MyClass.myStaticMethod(trigger.new, trigger.oldMap); } The developer creates a test class with a test method that calls MyClass.mystaticMethod, resulting in 81% overall code coverage. What happens when the developer tries to deploy the trigger and two classes to production, assuming no other code exist?
  • A. The deployment fails because no assertions were made in the test method.
  • B. The deployment passes because both classes and the trigger were included in the deployment.
  • C. The deployment fails because the Apex trigger has no code coverage.
  • D. The deployment passes because the Apex code has required (>75%) code coverage.
NEW QUESTION # 76
Our online test engine and windows software of the CRT-450 test answers will let your experience the flexible learning style. Apart from basic knowledge, we have made use of the newest technology to enrich your study of the CRT-450 exam study materials. Online learning platform is different from traditional learning methods. One of the great advantages is that you will soon get a feedback after you finish the exercises. So you are able to adjust your learning plan of the CRT-450 Guide test flexibly. We hope that our new design can make study more interesting and colorful. You also can send us good suggestions about developing the study material.
CRT-450 Updated Test Cram: https://www.testkingpass.com/CRT-450-testking-dumps.html
Our product CRT-450 test guide delivers more important information with fewer questions and answers, in order to easy and efficient learning, Salesforce CRT-450 Exam Dump Once you get the certification you may have a higher position and salary, What is more, our CRT-450 study guide offers free updates for one year and owns increasing supporters, Welcome to the Salesforce CRT-450 Salesforce Certified Platform Developer I!
Although modern machines tend to have huge memory capacity, it is CRT-450 always possible that the free store will be exhausted, It's slightly longer, though, due to material new in the second edition.
Pass Guaranteed Salesforce - CRT-450 - High Hit-Rate Salesforce Certified Platform Developer I Exam DumpOur product CRT-450 Test Guide delivers more important information with fewer questions and answers, in order to easy and efficient learning, Once you get the certification you may have a higher position and salary.
What is more, our CRT-450 study guide offers free updates for one year and owns increasing supporters, Welcome to the Salesforce CRT-450 Salesforce Certified Platform Developer I, What you need to do is send your score report to our support, we will refund after confirmation.
2026 Latest TestkingPass CRT-450 PDF Dumps and CRT-450 Exam Engine Free Share: https://drive.google.com/open?id=1dgzV_mOyyNJ61AD35mXn2DHDEzQj7Sa6
