4A0-D01最新題庫 - 4A0-D01試題
Posted at 2/22/2026 11:18:07
此外,這些VCESoft 4A0-D01考試題庫的部分內容現在是免費的:https://drive.google.com/open?id=1tjVMSgWMtZEmVxwQ2fPl2NvU6Y8ImjLi
VCESoft的4A0-D01考古題是你準備4A0-D01認證考試時最不能缺少的資料。這個資料的價值等同於其他一切的與考試相關的參考書。這種說法並不誇張。只要你用了它你就會發現,這一切都是真的。
Nokia 4A0-D01 考試大綱:| 主題 | 簡介 | | 主題 1 | - SR Linux Logging, Monitoring, and Filtering: This section of the exam measures skills of a Data Center Network Engineer and addresses how to implement logging, monitoring, and traffic filtering in SR Linux. It explains log file usage, ACL types, CPM filtering, and packet capture filters. Configuration tasks involve applying ACLs and monitoring network activity using capture tools.
| | 主題 2 | - SR Linux User and System Management: This section of the exam measures skills of a Network Automation Specialist and includes managing user roles, TLS configurations for secure communication, and automation features like Zero-Touch Provisioning (ZTP). It covers ZTP setup, configuration processes, and common issues that may arise during deployment.
| | 主題 3 | - SR Linux Configuration and Routing: This section of the exam measures skills of a Network Automation Specialist and focuses on configuring and managing SR Linux systems. It examines the YANG-driven CLI, JSON output, environment variables, and static and dynamic routing. Learners also explore BGP, ECMP, IP-VRF, MAC-VRF, and the use of VXLAN with EVPN to implement both Layer 2 and Layer 3 overlays, including symmetric and asymmetric models.
4A0-D01試題 - 4A0-D01考試大綱隨著4A0-D01考試的變化,VCESoft已經跟新了考試問題和答案,包括一些新增的問題,通過使用更新版本的Nokia 4A0-D01考古題,您可以輕松快速的通過考試,還節約寶貴的時間。獲得4A0-D01認證之后,您的職業生涯也將開始新的輝煌時期。購買我們的Nokia 4A0-D01題庫資料可以保證考生一次性通過考試,這是值得大家信賴的題庫網站,可以幫大家減少考試成本,節約時間,是上班族需要獲取4A0-D01認證的最佳選擇。
最新的 Nokia Certified Data Center Fabric Professional 4A0-D01 免費考試真題 (Q13-Q18):問題 #13
Which of the following statements about IP-VRFs in Nokia's SR Linux is FALSE?
- A. The router maintains a distinct route table for each IP-VRF instance.
- B. Multiple servers can be connected to the same subnet in an IP-VRF.
- C. An IP-VRF is a Layer 3 network instance.
- D. Packets in an IP-VRF are forwarded based on the destination IP address.
答案:B
解題說明:
Multiple servers connected to the same subnet typically reside within the same Layer 2 domain or MAC-VRF. IP-VRFs operate at Layer 3 and segment routing and forwarding by separate routing tables, so multiple servers on the same subnet are not a function of IP-VRF.
問題 #14
How are LLDP frames advertised between two Nokia SR Linux routers?
- A. They are routed to the destination node based on the IP VRF forwarding table.
- B. They are forwarded to the destination node based on the MAC VRF table.
- C. They are forwarded to the destination node based on the MAC VRF table.
- D. They are periodically flooded to the broadcast MAC address on each interface.
答案:C
解題說明:
LLDP frames are periodically sent to a well-known multicast MAC address on each interface to discover directly connected devices.
問題 #15
Which of the following statements about the data center's leaf-spine topology (clos network) is FALSE?
- A. Each leaf router is connected to all the spine routers in the cluster.
- B. It uses ECMP to distribute traffic across duplicate links.
- C. It uses the spanning tree protocol to avoid forwarding loops.
- D. It provides a consistent path for east-west traffic.
答案:C
解題說明:
The leaf-spine (Clos) topology does not use the spanning tree protocol because it relies on equal-cost multipath (ECMP) routing to prevent loops and efficiently utilize all available paths. Spanning tree is typically avoided in modern data center fabrics to enable full bandwidth utilization.
問題 #16
Examine the exhibit. Which of the following statements is TRUE?
- A. A recursive lookup is performed to resolve 10.1.1.0 to use 10.2.1.0.
- B. The next-hop group for this static route is configured with two next-hops.
- C. A recursive lookup is performed to resolve 10.2.1.0 to use 10.1.1.0.
- D. The next-hop selected for this route will be based on the preference value configured for each next-hop.
答案:B
解題說明:
The static route shows two next-hop IP addresses (10.1.1.0 and 10.2.1.0) listed, indicating that a next-hop group with multiple next-hops is configured for load balancing or redundancy.
問題 #17
Which of the following is NOT one of the reasons why BGP is used as the routing protocol in the data center?
- A. It is a well understood and mature routing protocol.
- B. It is more efficient than link-state protocols like IS-IS and OSPF.
- C. It supports both IPv4 and IPv6.
- D. BGP neighbors automatically discover each other.
答案:B
解題說明:
BGP is not chosen because it is more efficient than link-state protocols; in fact, link-state protocols like IS-IS and OSPF generally provide faster convergence and more efficient route calculation. BGP is used in data centers mainly because it is mature, well understood, supports both IPv4 and IPv6, and offers flexible policy control.
問題 #18
VCESoft已經獲得了很多認證行業的聲譽,因為我們有很多的Nokia的4A0-D01考古題,4A0-D01學習指南,4A0-D01考古題,4A0-D01考題答案,目前在網站上作為最專業的IT認證測試供應商,我們提供完善的售後服務,我們給所有的客戶買的跟蹤服務,在你購買的一年,享受免費的升級試題服務,如果在這期間,認證測試中心Nokia的4A0-D01試題顯示修改或者別的,我們會提供免費為客戶保護,顯示Nokia的4A0-D01考試認證是由我們VCESoft的IT產品專家精心打造,有了VCESoft的Nokia的4A0-D01考試資料,相信你的明天會更好。
4A0-D01試題: https://www.vcesoft.com/4A0-D01-pdf.html
- 選擇4A0-D01最新題庫 - 擺脫Nokia Data Center Fabric Fundamentals Exam考試困境 🌤 開啟【 [url]www.vcesoft.com 】輸入▶ 4A0-D01 ◀並獲取免費下載4A0-D01考古題更新[/url]
- 4A0-D01最新題庫和認證成功保證,簡便的培訓方式和Nokia Nokia Data Center Fabric Fundamentals Exam 🚪 請在{ [url]www.newdumpspdf.com }網站上免費下載▶ 4A0-D01 ◀題庫4A0-D01考試心得[/url]
- 真實的4A0-D01最新題庫 |第一次嘗試易於學習和通過考試和權威的Nokia Nokia Data Center Fabric Fundamentals Exam 🏙 來自網站⇛ [url]www.newdumpspdf.com ⇚打開並搜索⇛ 4A0-D01 ⇚免費下載4A0-D01最新考題[/url]
- 免費獲得最新的4A0-D01考試題庫試題和答案 - 是最新和最完整的Nokia Data Center Fabric Fundamentals Exam - 4A0-D01題庫質料 😌 在《 [url]www.newdumpspdf.com 》網站下載免費「 4A0-D01 」題庫收集4A0-D01測試題庫[/url]
- Nokia 4A0-D01最新題庫和[url]www.testpdf.net - 認證考試材料的領導者 🔕 複製網址⮆ www.testpdf.net ⮄打開並搜索➤ 4A0-D01 ⮘免費下載4A0-D01新版題庫上線[/url]
- 4A0-D01考古題更新 ➖ 4A0-D01題庫 🔸 4A0-D01考試題庫 🕊 在⇛ [url]www.newdumpspdf.com ⇚網站上查找【 4A0-D01 】的最新題庫4A0-D01下載[/url]
- 高效率地使用我們可靠的4A0-D01最新題庫:Nokia Data Center Fabric Fundamentals Exam,Nokia 4A0-D01考試很容易通過 🧼 ▛ [url]www.newdumpspdf.com ▟網站搜索➽ 4A0-D01 🢪並免費下載4A0-D01考試心得[/url]
- 高質量的4A0-D01最新題庫和資格考試中的領先供應平臺&有效的4A0-D01:Nokia Data Center Fabric Fundamentals Exam 🌵 透過▶ [url]www.newdumpspdf.com ◀搜索➽ 4A0-D01 🢪免費下載考試資料新版4A0-D01考古題[/url]
- 高質量的4A0-D01最新題庫和資格考試中的領先供應平臺&有效的4A0-D01:Nokia Data Center Fabric Fundamentals Exam 🙇 開啟➽ [url]www.newdumpspdf.com 🢪輸入➡ 4A0-D01 ️⬅️並獲取免費下載4A0-D01證照信息[/url]
- 4A0-D01下載 🎹 新版4A0-D01考古題 😆 4A0-D01考試心得 🧘 ⇛ [url]www.newdumpspdf.com ⇚提供免費▷ 4A0-D01 ◁問題收集4A0-D01 PDF題庫[/url]
- 最新4A0-D01試題 🖊 4A0-D01考試心得 🔫 4A0-D01證照信息 🌎 ➽ [url]www.newdumpspdf.com 🢪網站搜索⇛ 4A0-D01 ⇚並免費下載4A0-D01 PDF題庫[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, asmtechnolabs.com, www.stes.tyc.edu.tw, www.nfcnova.com, www.stes.tyc.edu.tw, Disposable vapes
