[Hardware] Download Oracle 1Z0-1042-25 Real Dumps And Get Free Updates
96
Hardware Download Oracle 1Z0-1042-25 Real Dumps And Get Free Updates
Posted at 2/22/2026 12:32:09      View151 | Replies0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of DumpsFree 1Z0-1042-25 dumps from Cloud Storage: https://drive.google.com/open?id=1QP-rIe1A5XEEcLZfOXVEwbS6hIBKB1bT
Using the 1Z0-1042-25 Study Materials, you will find that you can grasp the knowledge what you need in the exam in a short time. Because users only need to spend little hours on the 1Z0-1042-25 study materials, our learning materials will help users to learn all the difficulties of the test site, to help users pass the qualifying examination and obtain the qualification certificate. If you think that time is important to you, try our learning materials and it will save you a lot of time.
Oracle 1Z0-1042-25 Exam Syllabus Topics:
  • Getting Started with OIC Integrations: This section of the exam measures the skills of Integration Specialists and Cloud Engineers in understanding the foundational components of Oracle Integration Cloud (OIC). It covers key integration concepts, how integrations work, and web services fundamentals such as WSDL, SOAP, REST, and JSON. The focus is on building a strong understanding of OICs integration capabilities.
  • Creating Scheduled Integrations: This domain measures the skills of Automation Engineers and Cloud Administrators in defining integration schedules and converting scheduled integrations to app-driven ones. It also includes using scheduled parameters to automate workflows efficiently.
  • Creating Orchestrated Integrations: This section tests the knowledge of Orchestration Developers and Business Process Analysts in managing orchestrated integrations within OIC. It includes using lookups, data mappers, and custom JavaScript libraries, configuring orchestration flow actions, implementing file handling options, and leveraging the fault-handling framework to manage errors effectively.
  • Testing, Monitoring, and Troubleshooting Integrations: This section assesses the abilities of Support Engineers and Integration Administrators in managing integration lifecycles. It includes activating and deactivating integrations, testing REST-triggered integrations, importing and exporting integrations, as well as monitoring and troubleshooting integration instances to ensure smooth operations.
Topic 5
  • Using OIC Connections & Adapters: This section evaluates the expertise of Integration Developers and Solution Architects in creating and configuring OIC connections. It includes setting up trigger and invoke connections, understanding the role of the Connectivity Agent, and effectively using adapters to connect cloud and on-premises applications seamlessly.
Efficient 1Z0-1042-25 Test Questions Pdf | Amazing Pass Rate For 1Z0-1042-25 Exam | Professional 1Z0-1042-25: Oracle Cloud Infrastructure 2025 Application Integration ProfessionalDo you need the 1Z0-1042-25 certification? You may still hesitate. In fact, 1Z0-1042-25 certification has proved its important effect in many aspects of your life. 1Z0-1042-25 certification will definitely keep you competitive in your current position and considered jewels on your resume. The person who get certified by 1Z0-1042-25 certification will be proved to be dedicated, committed and have a strong knowledge base. If you are considering becoming a certified professional about Oracle test, now is the time. Oracle 1Z0-1042-25 Exam Practice torrent is the best valid study material for the preparation of 1Z0-1042-25 actual test. With the good 1Z0-1042-25 latest study pdf, you can get your certification at your first try.
Oracle Cloud Infrastructure 2025 Application Integration Professional Sample Questions (Q48-Q53):NEW QUESTION # 48
You need to create a scheduled orchestration integration that is based on an existing app-driven orchestration using the same display name. Which statement is valid for this use case?
  • A. You can create the new integration by using the same display name but with a different identifier.
  • B. You can create the new integration as a different major version of the existing one.
  • C. You cannot create another integration that uses the same name.
  • D. You can clone the existing integration and specify it to use the scheduled orchestration pattern.
OIC allows pattern changes:
B:True-cloning an app-driven integration and switching to scheduled pattern is supported, retaining the name.
A:False-versioning doesn't change the pattern.
C:False-same names are allowed with different identifiers.
NEW QUESTION # 49
When defining the frequency for scheduled orchestration style integration runs, you can choose either Basic or the Advanced option. Which expression format is used for defining advanced scheduled runs?
  • A. YAML
  • B. cron
  • C. Groovy
  • D. iCal
OIC provides two scheduling options: Basic (simple intervals) and Advanced (complex patterns). For Advanced scheduling, OIC uses theiCal (Internet Calendaring)format, a standard for defining recurring events.
Option A:iCal supports expressions like FREQ=DAILY;BYDAY=MO-FR, ideal for precise scheduling.
Option B:Cron is common in UNIX systems but not used in OIC.
Option C:YAML is a data serialization format, not for scheduling.
NEW QUESTION # 50
In Oracle Integration (OIC) you can notify users by email with hourly or daily reports about system status as well as service alerts. Which is NOT an alert type that can be configured in thesenotification emails?
  • A. One or more connectivity agents are unavailable.
  • B. Failed instances exceeding a specified percentage.
  • C. Certificates that are set to expire within seven days.
  • D. The email quota has exceeded the threshold.
Notifications:
C:False-not a standard alert.
NEW QUESTION # 51
There are use cases in which you need to perform an advanced XSLT task that you cannot perform in the Oracle Integration Cloud (OIC) data mapper. To perform the advanced mapping tasks, you decide to use an external XSLT mapper and then import the .xsl file back to your integration.
Which is NOT a valid consideration when handling this use case?
  • A. The exported archive file can include a map file that is largely complete in content or a map file that is empty of content.
  • B. Once the advanced mapping is complete, you must import the entire integration that contains the updated .xsl files.
  • C. The exported archive must be imported into an Oracle Service Bus project in JDeveloper.
  • D. You must export the entire integration that contains one or more .xsl files.
There is no need to import the archive into an Oracle Service Bus project. The focus is on modifying the XSLT mapping in OIC.
NEW QUESTION # 52
Which operation is NOT supported by an Oracle Integration (OIC) Connection resource configured with the FTP Adapter?
  • A. Read File in Segments
  • B. List Files
  • C. Read File
  • D. Delete File
  • E. Write File
FTP Adapter:
E:False-Trigger role only, not standard Invoke.
NEW QUESTION # 53
The questions of our 1Z0-1042-25 guide questions are related to the latest and basic knowledge. Whats more, our 1Z0-1042-25 learning materials are committed to grasp the most knowledgeable points with the fewest problems. So 20-30 hours of study is enough for you to deal with the exam. When you get a 1Z0-1042-25 certificate, you will be more competitive than others, so you can get a promotion and your wages will also rise your future will be controlled by yourselves.
1Z0-1042-25 Flexible Testing Engine: https://www.dumpsfree.com/1Z0-1042-25-valid-exam.html
What's more, part of that DumpsFree 1Z0-1042-25 dumps now are free: https://drive.google.com/open?id=1QP-rIe1A5XEEcLZfOXVEwbS6hIBKB1bT
