[General] 完璧な300-740資格認証攻略 &合格スムーズ300-740トレーニング資料 |有効的な300-740資格難易度
135
【General】 完璧な300-740資格認証攻略 &合格スムーズ300-740トレーニング資料 |有効的な300-740資格難易度
Posted at 2/22/2026 14:21:25      View:79 | Replies:0        Print      Only Author   [Copy Link] 1#
2026年Jpshikenの最新300-740 PDFダンプおよび300-740試験エンジンの無料共有:https://drive.google.com/open?id=1NeRsTQvPbHsL_4ayz3l8T3hgR-50gVDZ
大量の時間と金銭をかかるのに比べて、正しい仕方は肝心なことです。もしあなたはCisco 300-740試験に準備しているなら、あんたのための整理される備考資料はあなたにとって最善のオプションです。我々の目標はあなたに試験にうまく合格させることです。弊社の誠意を信じてもらいたいし、Cisco 300-740試験2成功するのを祈って願います。
Cisco 300-740 認定試験の出題範囲:
トピック出題範囲
トピック 1
  • Threat Response: This section of the exam measures skills of Incident Response Engineers and focuses on responding to threats through automation and data analysis. It covers how to act based on telemetry and audit reports, manage user or application compromises, and implement response steps such as containment, reporting, remediation, and reinstating services securely.
トピック 2
  • Cloud Security Architecture: This section of the exam measures the skills of Cloud Security Architects and covers the fundamental components of the Cisco Security Reference Architecture. It introduces the role of threat intelligence in identifying and mitigating risks, the use of security operations tools for monitoring and response, and the mechanisms of user and device protection. It also includes strategies for securing cloud and on-premise networks, as well as safeguarding applications, workloads, and data across environments.
トピック 3
  • Industry Security Frameworks: This section of the exam measures the skills of Cybersecurity Governance Professionals and introduces major industry frameworks such as NIST, CISA, and DISA. These frameworks guide best practices and compliance in designing secure systems and managing cloud environments responsibly.
トピック 4
  • Application and Data Security This section of the exam measures skills of Cloud Security Analysts and explores how to defend applications and data from cyber threats. It introduces the MITRE ATT&CK framework, explains cloud attack patterns, and discusses mitigation strategies. Additionally, it covers web application firewall functions, lateral movement prevention, microsegmentation, and creating policies for secure application connectivity in multicloud environments.
トピック 5
  • User and Device Security: This section of the exam measures skills of Identity and Access Management Engineers and deals with authentication and access control for users and devices. It covers how to use identity certificates, enforce multifactor authentication, define endpoint posture policies, and configure single sign-on (SSO) and OIDC protocols. The section also includes the use of SAML to establish trust between devices and applications.
トピック 6
  • Visibility and Assurance: This section of the exam measures skills of Security Operations Center (SOC) Analysts and focuses on monitoring, diagnostics, and compliance. It explains the Cisco XDR solution, discusses visibility automation, and describes tools for traffic analysis and log management. The section also involves diagnosing application access issues, validating telemetry for behavior analysis, and verifying user access with tools like firewall logs, Duo, and Cisco Secure Workload.
トピック 7
  • Network and Cloud Security:This section of the exam measures skills of Network Security Engineers and covers policy design for secure access to cloud and SaaS applications. It outlines techniques like URL filtering, app control, blocking specific protocols, and using firewalls and reverse proxies. The section also addresses security controls for remote users, including VPN-based and application-based access methods, as well as policy enforcement at the network edge.
300-740トレーニング資料 & 300-740資格難易度人生はさまざまな試しがある、人生の頂点にかからないけど、刺激のない生活に変化をもたらします。あなたは我々社の提供する質高いCisco 300-740問題集を使用して、試験に参加します。もし無事に300-740試験に合格したら、あなたはもっと自信になって、更なる勇気でやりたいことをしています。
Cisco Designing and Implementing Secure Cloud Access for Users and Endpoints 認定 300-740 試験問題 (Q61-Q66):質問 # 61
Which of the following best describes multifactor authentication (MFA)?
  • A. Authentication that requires only a user name
  • B. Authentication that relies solely on biometrics
  • C. Authentication using a single factor like a password
  • D. Authentication that requires two or more verification factors
質問 # 62
Refer to the exhibit. An engineer must implement a remote access VPN solution that provides user and device verification. The company uses Active Directory for user authentication and ID certificates for device identity. Users are currently able to connect using only a valid username and password, even if their computer is missing the required certificate.
Which command from the Cisco ASA tunnel-group completes the requirement of verifying device identity in addition to user identity?
  • A. authentication aaa certificate
  • B. webvpn authorize-device
  • C. authentication mfa
  • D. ldap-attribute-map PolicyAllow
To enforce both user-based and device-based authentication on Cisco ASA, the tunnel group must include the command: authentication aaa certificate. This configuration requires that both a valid username/password (authenticated via AAA, such as Active Directory) and a trusted certificate (device identity) are present before allowing VPN access. Without this directive, only username/password credentials are validated, which leads to the scenario described in the question.
Reference: Designing and Implementing Secure Cloud Access for Users and Endpoints (SCAZT), Section 2:
User and Device Security, Pages 40-44.
質問 # 63
An engineer is configuring multifactor authentication using Duo. The implementation must use Duo Authentication Proxy and the Active Directory as an identity source. The company uses Azure and a local Active Directory. Which configuration is needed to meet the requirement?
  • A. Configure the Identity Source as "SAML" on the Single Sign-On tab in the Duo Admin Panel, and configure the forwarding proxy as "local" for the Identity Source.
  • B. Configure the Identity Source as "SAML" on the Single Sign-On tab, and configure the authentication proxy with the "[cloud]" section.
  • C. Configure the Identity Source as "Active Directory" on the Single Sign-On tab in the Duo Admin Panel, and configure the permit list to "Local database".
  • D. Configure the Identity Source as "Active Directory" on the Single Sign-On tab, and configure the authentication proxy with the "[sso]" section.
When integrating Duo Authentication Proxy with Active Directory for multifactor authentication (MFA), you must:
Configure the Identity Source in the Duo Admin Panel as Active Directory (not SAML), since it's using the Authentication Proxy.
Configure the authentication proxy settings in the [sso] section to communicate with both AD and the Duo cloud.
This setup allows Active Directory to be the primary identity store while Duo provides the second authentication factor.
User and Device Security, Pages 40-45
質問 # 64
Converged multicloud policy ensures:
  • A. Consistent security policies across all cloud environments
  • B. Decreased reliance on cloud security
  • C. Increased complexity in security management
  • D. Separate policies for each cloud environment
質問 # 65
A web application firewall (WAF) protects against DDoS attacks by:
  • A. Decreasing the security settings to allow all traffic
  • B. Physically disconnecting the server during an attack
  • C. Analyzing and filtering incoming traffic to identify and block malicious requests
  • D. Ignoring signs of an attack to maintain website functionality
質問 # 66
今の社会では、高い効率の仕方を慣れんでいます。あなたはCiscoの300-740資格認定のために、他人より多くの時間をかかるんですか?Jpshikenの300-740問題集を紹介させてください。300-740は専門家たちが長年の経験で研究分析した勉強資料です。受験生のあなたを助けて時間とお金を節約したり、300-740試験に速く合格すると保証します。
300-740トレーニング資料: https://www.jpshiken.com/300-740_shiken.html
無料でクラウドストレージから最新のJpshiken 300-740 PDFダンプをダウンロードする:https://drive.google.com/open?id=1NeRsTQvPbHsL_4ayz3l8T3hgR-50gVDZ
