[General] NSE4_FGT_AD-7.6 Exam Tips - NSE4_FGT_AD-7.6 Valid Test Materials
117
【General】 NSE4_FGT_AD-7.6 Exam Tips - NSE4_FGT_AD-7.6 Valid Test Materials
Posted at 2/22/2026 14:27:37      View:127 | Replies:0        Print      Only Author   [Copy Link] 1#
The Fortinet job market has become so competitive and challenging. To stay competitive in the market as an experienced Fortinet professional you have to upgrade your skills and knowledge with the Fortinet NSE 4 - FortiOS 7.6 Administrator (NSE4_FGT_AD-7.6) certification exam. With the Fortinet NSE4_FGT_AD-7.6 exam dumps you can easily prove your skills and upgrade your knowledge. To do this you just need to enroll in the Fortinet NSE 4 - FortiOS 7.6 Administrator (NSE4_FGT_AD-7.6) certification exam and put all your efforts to pass this challenging NSE4_FGT_AD-7.6 exam with good scores. However, you should keep in mind that to get success in the NSE4_FGT_AD-7.6 certification exam is not a simple and easy task.
Fortinet NSE4_FGT_AD-7.6 Exam Syllabus Topics:
  • Content Inspection: This domain addresses inspecting encrypted traffic using certificates, understanding inspection modes and web filtering, configuring application control, deploying antivirus scanning modes, and implementing IPS for threat protection.
  • VPN: This domain focuses on implementing meshed or partially redundant IPsec VPN topologies for secure connections.
  • Deployment and System Configuration: This domain covers initial FortiGate setup, logging configuration and troubleshooting, FGCP HA cluster configuration, resource and connectivity diagnostics, FortiGate cloud deployments (CNF and VM), and FortiSASE administration with user onboarding.
  • Firewall Policies and Authentication: This domain focuses on creating firewall policies, configuring SNAT and DNAT for address translation, implementing various authentication methods, and deploying FSSO for user identification.
Topic 5
  • Routing: This domain covers configuring static routes for packet forwarding and implementing SD-WAN to load balance traffic across multiple WAN links.
NSE4_FGT_AD-7.6 Valid Test Materials, Composite Test NSE4_FGT_AD-7.6 PriceNSE4_FGT_AD-7.6 training materials are compiled by experienced experts, and therefore they cover most knowledge points of the exam, and you can also improve your ability in the process of learning. NSE4_FGT_AD-7.6 exam dumps not only contain quality but also contain certain quantity, and they will be enough for you to pass the exam and get the certificate. In addition, we are pass guarantee and money back guarantee if you fail to pass the exam. We offer you free update for365 days after you purchase the NSE4_FGT_AD-7.6 traing materials.
Fortinet NSE 4 - FortiOS 7.6 Administrator Sample Questions (Q78-Q83):NEW QUESTION # 78
Refer to the exhibit, which shows an SD-WAN zone configuration on the FortiGate GUI.
Based on the exhibit, which statement is true?
  • A. The virtual-wan-link and overlay zones can be deleted.
  • B. The Underlay zone contains no member.
  • C. port2 and port3 are not assigned to a zone.
  • D. The Underlay zone is the zone by default.
The Underlay zone is the default SD-WAN zone, typically representing the physical interfaces in the SD-WAN configuration before overlay or virtual links are added.
NEW QUESTION # 79
Refer to the exhibit, which shows a partial configuration from the remote authentication server.
Why does the FortiGate administrator need this configuration?
  • A. To authenticate only the Training user group.
  • B. To set up a RADIUS server Secret.
  • C. To authenticate Any FortiGate user groups.
  • D. To authenticate and match the Training OU on the RADIUS server.
The Fortinet-Group-Name attribute is used to restrict authentication to users who belong specifically to the "Training" user group on the RADIUS server.
NEW QUESTION # 80
Refer to the exhibits. An administrator has observed the performance status outputs on an HA cluster for 55 seconds.
Which FortiGate is the primary?
  • A. HQ-NGFW-2 with the parameter memory-failover-threshold setting
  • B. HQ-NGFW-2 with the parameter priority setting
  • C. HQ-NGFW-1 with the parameter override setting
  • D. HQ-NGFW-1 with the parameter memory-failover-flip-timeout setting
The configured memory failover threshold is 70%, and FW-1 is running at 90%. The monitored period is set to 50 seconds, while the question states that the admin observed the output for 55 seconds. This means FW-1 has remained above the 70% threshold for more than the configured monitoring period, while the memory usage on FW-2 is below 70%.
NEW QUESTION # 81
Refer to the exhibit, which shows the IPS sensor configuration.
If traffic matches this IPS sensor, which two actions is the sensor expected to take? (Choose two.)
  • A. The sensor will reset all connections that match these signatures.
  • B. The sensor will block all attacks aimed at Windows servers.
  • C. The sensor will allow attackers matching the Microsoft.Windows.iSCSI.Target.DoS signature.
  • D. The sensor will gather a packet log for all matched traffic.
The sensor will allow attackers matching the Microsoft.Windows.iSCSITarget.DoS signature.
The action for this specific signature is set to Monitor, which means FortiGate will only detect and log the activity but will not block or reset the session.
The general Windows filter is configured with the Block action, so any traffic matching Windows- related attack signatures will be blocked.
NEW QUESTION # 82
The exhibits show a diagram of a FortiGate device connected to the network, as well as the IP pool configuration and firewall policy objects.
The WAN (port1) interface has the IP address 10.200.1.1/24.
The LAN (port3) interface has the IP address 10.0.1.254/24.
Which IP address will be used to source NAT (SNAT) the traffic, if the user on Local-Client (10.0.1.10) pings the IP address of Remote-FortiGate (10.200.3.1)?
  • A. 10.200.1.1
  • B. 10.200.1.99
  • C. 10.200.1.49
  • D. 10.200.1.149
All_TCP doesn't include ICMP. So you would match rule ID 2, in which uses IP Poop remote 1.
NEW QUESTION # 83
With the increasing marketization, the NSE4_FGT_AD-7.6 study guide experience marketing has been praised by the consumer market. Attract users interested in product marketing to know just the first step, the most important is to be designed to allow the user to try before buying the NSE4_FGT_AD-7.6 study training materials, so we provide free pre-sale experience to help users to better understand our NSE4_FGT_AD-7.6 Exam Questions. The user only needs to submit his E-mail address and apply for free trial online, and our system will soon send free demonstration research materials of NSE4_FGT_AD-7.6 latest questions to download.
NSE4_FGT_AD-7.6 Valid Test Materials: https://www.dumpsking.com/NSE4_FGT_AD-7.6-testking-dumps.html
