[General] NCP-US-6.5 Test Registration, Pass NCP-US-6.5 Rate
118
【General】 NCP-US-6.5 Test Registration, Pass NCP-US-6.5 Rate
Posted at 2/22/2026 16:44:59      View:98 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that ExamBoosts NCP-US-6.5 dumps now are free: https://drive.google.com/open?id=17W5rbV99db7jCnBQtAoZOYG8aemiGQ4S
With more than thousands of satisfied applicants in multiple countries, we guarantee that you will clear the Nutanix NCP-US-6.5 exam as quickly as possible by using our product. In this way, Exams.SOlutions save you time and money. In addition to all these excellent offers, in any case despite properly studying with NCP-US-6.5 Practice Test material.
Nutanix NCP-US-6.5 Exam Syllabus Topics:
  • Analyze and Monitor Nutanix Unified Storage
  • Describe the use of Data Lens for data security
  • Configure Nutanix Files with advanced features
  • Determine the appropriate method to ensure data availability
  • recoverability
  • Utilize File Analytics for data security
  • Troubleshoot Nutanix Unified Storage
  • Configure Nutanix Volumes
  • Troubleshoot issues related to Nutanix Objects
  • Troubleshoot issues related to Nutanix Volumes
Topic 5
  • Given a scenario, configure shares, buckets, and
  • or Volume Groups
  • Troubleshoot a failed upgrade for Files
  • Objects
Topic 6
  • Configure and Utilize Nutanix Unified Storage
  • Identify the steps to deploy Nutanix Objects
Nutanix NCP-US-6.5 Exam | NCP-US-6.5 Test Registration - Full Refund if Failing NCP-US-6.5: Nutanix Certified Professional - Unified Storage (NCP-US) v6.5 ExamTherefore, you must stay informed as per these changes to save time, money, and mental peace. As was already discussed, ExamBoosts satisfies the needs of Nutanix Certified Professional - Unified Storage (NCP-US) v6.5 (NCP-US-6.5) exam candidates. The customer will receive updates of Nutanix Certified Professional - Unified Storage (NCP-US) v6.5 (NCP-US-6.5) real dumps for up to 365 days after buying the product. Our offers don't stop here. If our customers want to evaluate the Nutanix Certified Professional - Unified Storage (NCP-US) v6.5 (NCP-US-6.5) exam dumps before paying us, they can download a free demo as well.
Nutanix Certified Professional - Unified Storage (NCP-US) v6.5 Sample Questions (Q72-Q77):NEW QUESTION # 72
The Administrator needs to review the following graphs, as displayed in the exhibit.
* Storage Used
* Open Connections
* Number of Files
* Top Shares by Current Capacity
* Top Shares by current Connections
Where should the administrator complete this action?
  • A. Files Console Dashboard View
  • B. Files Console Data Management View
  • C. Files Console Share View
  • D. Files Console Monitoring View
The Files Console Dashboard View provides an overview of the Files cluster performance and usage, including the following graphs:
Storage Used: Shows the total storage used by the Files cluster, including data, metadata, and snapshots.
Open Connections: Shows the number of active SMB and NFS connections to the Files cluster.
Number of Files: Shows the number of files stored in the Files cluster, excluding snapshots.
Top Shares by Current Capacity: Shows the top five shares by current capacity usage in the Files cluster.
Top Shares by Current Connections: Shows the top five shares by current connection count in the Files cluster2. Reference: Nutanix Files Administration Guide2
NEW QUESTION # 73
An administrator has received an alert AI60068 - ADSDuplicationIPDetected details of alert as follows:
Which error log should the administrator review to determine the related Duplicate IP address involved?
  • A. Solver.log
  • B. Minerva.nvm.log
  • C. Tcpkill.log
  • D. Minerva_cvm.log
https://portal.nutanix.com/page/ ... =kA00e000000CvHICA0
NEW QUESTION # 74
After migrating to Files for a company's user home directories, the administrator started receiving complaints that accessing certain files results in long wait times before the file is even opened or an access denied error message after four minutes. Upon further investigation, the administrator has determined that the files in question are very large audio and video files. Which two actions should the administrator take to mitigate this issue? (Choose two.)
  • A. Uncheck the "Block access to files if scan cannot be completed (recommended)" option in the ICAP settings for the Files cluster.
  • B. Add the extensions of the affected file types to the ICAP's Exclude File Types field in the ICAP settings for the Files cluster.
  • C. Enable the "Scan on Write" option and increase resources for the ICAP server.
  • D. Enable the "Scan on Read" option and decrease resources for the ICAP server.
Nutanix Files, part of Nutanix Unified Storage (NUS), is being used for user home directories, and users are experiencing delays or access denied errors when accessing large audio and video files. The issue is related to the integration with an ICAP (Internet Content Adaptation Protocol) server, which Nutanix Files uses to scan files for security (e.g., antivirus, malware detection). The delays and errors suggest that the ICAP server is struggling to scan these large files, causing timeouts or access issues.
Understanding the Issue:
* ICAP Integration: Nutanix Files can integrate with an ICAP server to scan files for threats. By default, files are scanned on read and write operations, and if a scan cannot be completed (e.g., due to timeouts), access may be blocked.
* Large Audio/Video Files: These files are typically very large (e.g., GBs in size), and scanning them can take significant time, especially if the ICAP server is under-resourced or the network latency is high.
* Four-Minute Timeout: The "access denied" error after four minutes suggests a timeout in the ICAP scan process, likely because the ICAP server cannot complete the scan within the default timeout period (often 240 seconds or 4 minutes).
* Long Wait Times: The wait times before opening files indicate that the ICAP server is scanning the files on read, causing delays for users.
Analysis of Options:
* Option A (Add the extensions of the affected file types to the ICAP's Exclude File Types field in the ICAP settings for the Files cluster): Correct. Nutanix Files allows administrators to exclude certain file types from ICAP scanning by adding their extensions (e.g., .mp4, .wav) to the "Exclude File Types" field in the ICAP settings. Large audio and video files are often safe and do not need to be scanned (e.g., they are less likely to contain malware), and excluding them prevents the ICAP server from attempting to scan them, eliminating delays and timeout errors.
* Option B (Uncheck the "Block access to files if scan cannot be completed (recommended)" option in the ICAP settings for the Files cluster): Correct. By default, Nutanix Files blocks access to files if the ICAP scan cannot be completed within the timeout period (e.g., 4 minutes), resulting in the "access denied" error. Unchecking this option allows access to files even if the scan fails or times out, mitigating the access denied issue for large files while still attempting to scan them. This is a recommended mitigation when scans are causing access issues, though it slightly reduces security by allowing access to un-scanned files.
* Option C (Enable the "Scan on Write" option and increase resources for the ICAP server):
Incorrect. The "Scan on Write" option is already enabled by default in Nutanix Files ICAP settings, as it ensures files are scanned when written to the share. Increasing resources for the ICAP server might help with scanning performance, but it does not directly address the issue of large files causing timeouts on read operations, and it requires additional infrastructure changes that may not be feasible. The issue is primarily with read access delays, not write operations.
* Option D (Enable the "Scan on Read" option and decrease resources for the ICAP server):
Incorrect. The "Scan on Read" option is also enabled by default in Nutanix Files ICAP settings, and it is the root cause of the delays-scanning large files on read causes long wait times. Decreasing resources for the ICAP server would exacerbate the issue by further slowing down scans, leading to more timeouts and errors.
Selected Actions:
* A: Excluding audio and video file extensions from ICAP scanning prevents the server from attempting to scan large files, eliminating delays and timeouts for these file types.
* B: Disabling the "Block access" option ensures that users can access files even if the ICAP scan times out, mitigating the "access denied" error after four minutes.
Why These Actions?
* Excluding File Types (A): Large audio and video files are often safe and do not need scanning, and excluding them avoids the performance bottleneck caused by the ICAP server, directly addressing the long wait times.
* Disabling Block Access (B): The four-minute timeout leading to "access denied" errors is due to the ICAP scan failing to complete. Allowing access despite scan failures ensures users can still open files, though it requires careful consideration of security risks (e.g., ensuring excluded file types are safe).
* Combining these actions provides a comprehensive solution: excluding file types prevents unnecessary scans, and disabling the block ensures access during edge cases where scans might still occur.
Exact Extract from Nutanix Documentation:
From the Nutanix Files Administration Guide (available on the Nutanix Portal):
"To mitigate performance issues with ICAP scanning for large files (e.g., audio, video), add the extensions of affected file types to the 'Exclude File Types' field in the ICAP settings for the Files cluster. Additionally, to prevent 'access denied' errors due to scan timeouts, uncheck the 'Block access to files if scan cannot be completed (recommended)' option, allowing access to files even if the scan fails."
Nutanix Files Administration Guide, Version 4.0, Section: "Configuring ICAP Settings for Files" (Nutanix Portal).
Nutanix Certified Professional - Unified Storage (NCP-US) Study Guide, Section: "Nutanix Files ICAP Integration".
NEW QUESTION # 75
Workload optimization for Files is based on which entity?
  • A. Block size
  • B. File type
  • C. FSVM quantity
  • D. Protocol
Workload optimization in Nutanix Files, part of Nutanix Unified Storage (NUS), refers to the process of tuning the Files deployment to handle specific workloads efficiently. This involves scaling resources to match the workload demands, and the primary entity for optimization is the number of File Server Virtual Machines (FSVMs).
* Option A (Protocol): Incorrect. While Nutanix Files supports multiple protocols (SMB, NFS), workload optimization is not directly based on the protocol. Protocols affect client access, but optimization focuses on resource allocation.
* Option B (File type): Incorrect. File type (e.g., text, binary) is not a factor in workload optimization for Files. Optimization focuses on infrastructure resources, not the nature of the files.
* Option C (FSVM quantity): Correct. Nutanix Files uses FSVMs to distribute file service workloads across the cluster. Workload optimization involves adjusting the number of FSVMs to handle the expected load, ensuring balanced performance and scalability. For example, adding more FSVMs can improve performance for high-concurrency workloads.
* Option D (Block size): Incorrect. Block size is relevant for block storage (e.g., Nutanix Volumes), but Nutanix Files operates at the file level, not the block level. Workload optimization in Files does not involve block size adjustments.
Why FSVM Quantity?
FSVMs are the core entities that process file operations in Nutanix Files. Optimizing for a workload (e.g., high read/write throughput, many concurrent users) typically involves scaling the number of FSVMs to distribute the load, adding compute and memory resources as needed, or adjusting FSVM placement for better performance.
"Workload optimization in Nutanix Files is achieved by adjusting the number of FSVMs in the file server. For high-performance workloads, you can scale out by adding more FSVMs to distribute the load across the cluster, ensuring optimal resource utilization and performance."
Nutanix Files Administration Guide, Version 4.0, Section: "Optimizing Nutanix Files for Workloads" (Nutanix Portal).
Nutanix Certified Professional - Unified Storage (NCP-US) Study Guide, Section: "Nutanix Files Performance Optimization".
NEW QUESTION # 76
Which port is required between a CVM or Prism Central to insights,nutanix.com for Data Lens configuration?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
Data Lens is a SaaS that provides file analytics and reporting, anomaly detection, audit trails, ransomware protection features, and tiering management for Nutanix Files. To configure Data Lens, one of the network requirements is to allow HTTPS (port 443) traffic between a CVM or Prism Central to insights.nutanix.com. This allows Data Lens to collect metadata and statistics from the FSVMs and display them in a graphical user interface. Reference: Nutanix Files Administration Guide, page 93; Nutanix Data Lens User Guide
NEW QUESTION # 77
Great concentrative progress has been made by our company, who aims at further cooperation with our candidates in the way of using our NCP-US-6.5 exam engine as their study tool. with more people joining in the NCP-US-6.5 exam army, we has become the top-raking training materials provider in the international market. In addition, we always adhere to the principle of “mutual development and benefit”, and we believe our NCP-US-6.5 practice materials can give you a timely and effective helping hand whenever you need in the process of learning.
Pass NCP-US-6.5 Rate: https://www.examboosts.com/Nutanix/NCP-US-6.5-practice-exam-dumps.html
BTW, DOWNLOAD part of ExamBoosts NCP-US-6.5 dumps from Cloud Storage: https://drive.google.com/open?id=17W5rbV99db7jCnBQtAoZOYG8aemiGQ4S
