[General] SC-100 Trustworthy Exam Content, Reliable SC-100 Exam Sample
74
【General】 SC-100 Trustworthy Exam Content, Reliable SC-100 Exam Sample
Posted at 2/22/2026 18:51:37      View:140 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Real4test SC-100 dumps for free: https://drive.google.com/open?id=1mrwk-0ZfCnJErpTXA_JTbS-qg6_XjfRJ
Our company has dedicated ourselves to develop the SC-100 latest practice materials for all candidates to pass the exam easier, also has made great achievement after more than ten years' development. As the certification has been of great value, a right SC-100 exam guide can be your strong forward momentum to help you pass the SC-100 Exam like a hot knife through butter. And our SC-100 exam questions are exactly the right one for you as our high quality of SC-100 learning guide is proved by the high pass rate of more than 98%.
The Microsoft SC-100 desktop exam simulation software works only on Windows but the web-based SC-100 practice test is compatible with all operating systems and browsers. This is also an effective format for SC-100 Test Preparation. The SC-100 PDF dumps is an easily downloadable and printable file that carries the most probable Microsoft SC-100 actual questions.
Reliable SC-100 Exam Sample | SC-100 Exam DurationWith passing rate up to 98 to 100 percent, the quality and accuracy of our SC-100 training materials are unquestionable. You may wonder their price must be equally steep. While it is not truth. On the contrary everyone can afford them easily. By researching on the frequent-tested points in the real exam, our experts have made both clear outlines and comprehensive questions into our SC-100 Exam Prep. So our SC-100 practice engine is easy for you to understand.
Microsoft SC-100 Certification Exam is a highly recognized certification in the cybersecurity industry. It offers professionals the opportunity to demonstrate their skills and knowledge in securing Microsoft environments. With proper preparation and training, candidates can successfully pass the exam and advance their careers in cybersecurity architecture.
Microsoft Cybersecurity Architect Sample Questions (Q333-Q338):NEW QUESTION # 333
You need to design a strategy for securing the SharePoint Online and Exchange Online dat a. The solution must meet the application security requirements.
Which two services should you leverage in the strategy? Each correct answer presents part of the solution. NOTE; Each correct selection is worth one point.
  • A. access reviews in Azure AD
  • B. Microsoft Defender for Cloud Apps
  • C. Microsoft Defender for Endpoint
  • D. Microsoft Defender for Cloud
  • E. Azure AD Conditional Access
https://docs.microsoft.com/en-us ... application-control
https://docs.microsoft.com/en-us ... pplication-security
NEW QUESTION # 334
You need to recommend a strategy for App Service web app connectivity. The solution must meet the landing zone requirements. What should you recommend? To answer, select the appropriate options in the answer are a. NOTE Each correct selection is worth one point.
NEW QUESTION # 335
Your company has a multi-cloud environment that contains a Microsoft 365 subscription, an Azure subscription, and Amazon Web Services (AWS) implementation. You need to recommend a security posture management solution for the following components:
* Azure loT Edge devices
* AWS EC2 instances
Which services should you include in the recommendation? To answer, select the appropriate options in the answer area. NOTE: Each correct selection is worth one point.
https://docs.microsoft.com/en-us ... ations/architecture
https://docs.microsoft.com/en-us ... pivots=env-settings
https://docs.microsoft.com/en-us ... ed-cloud-operations
NEW QUESTION # 336
Your on-premises network contains an e-commerce web app that was developed in Angular and Node.js. The web app uses a MongoDB database You plan to migrate the web app to Azure. The solution architecture team proposes the following architecture as an Azure landing zone.
You need to provide recommendations to secure the connection between the web app and the database. The solution must follow the Zero Trust model.
Solution: You recommend implementing Azure Application Gateway with Azure Web Application Firewall (WAF).
Does this meet the goal?
  • A. Yes
  • B. No
When using Azure-provided PaaS services (e.g., Azure Storage, Azure Cosmos DB, or Azure Web App, use the PrivateLink connectivity option to ensure all data exchanges are over the private IP space and the traffic never leaves the Microsoft network.
NEW QUESTION # 337
Your company is developing an invoicing application that will use Azure Active Directory (Azure AD) B2C. The application will be deployed as an App Service web app. You need to recommend a solution to the application development team to secure the application from identity related attacks. Which two configurations should you recommend? Each correct answer presents part of the solution. NOTE: Each correct selection is worth one point.
  • A. custom resource owner password credentials (ROPC) flows in Azure AD B2C
  • B. smart account lockout in Azure AD B2C
  • C. Azure AD Conditional Access integration with user flows and custom policies
  • D. access packages in Identity Governance
  • E. Azure AD workbooks to monitor risk detections
https://docs.microsoft.com/en-us ... c/threat-management
https://docs.microsoft.com/en-us ... ivots=b2c-user-flow
Topic 1, Litware, inc.
Overview
Litware, inc. is a financial services company that has main offices in New York and San Francisco. litware has 30 branch offices and remote employees across the United States. The remote employees connect to the main offices by using a VPN.
Litware has grown significantly during the last two years due to mergers and acquisitions. The acquisitions include several companies based in France.
Existing Environment
Litware has an Azure Active Directory (Azure AD) tenant that syncs with an Active Directory Domain Services (AD D%) forest named Utvvare.com and is linked to 20 Azure subscriptions. Azure AD Connect is used to implement pass-through authentication. Password hash synchronization is disabled, and password writeback is enabled. All Litware users have Microsoft 365 E5 licenses.
The environment also includes several AD DS forests, Azure AD tenants, and hundreds of Azure subscriptions that belong to the subsidiaries of Litware.
Planned Changes
Litware plans to implement the following changes:
* Create a management group hierarchy for each Azure AD tenant.
* Design a landing zone strategy to refactor the existing Azure environment of Litware and deploy all future Azure workloads.
* Implement Azure AD Application Proxy to provide secure access to internal applications that are currently accessed by using the VPN.
Business Requirements
Litware identifies the following business requirements:
* Minimize any additional on-premises infrastructure.
* Minimize the operational costs associated with administrative overhead.
Hybrid Requirements
Litware identifies the following hybrid cloud requirements:
* Enable the management of on-premises resources from Azure, including the following:
* Use Azure Policy for enforcement and compliance evaluation.
* Provide change tracking and asset inventory.
* Implement patch management.
* Provide centralized, cross-tenant subscription management without the overhead of maintaining guest accounts.
Microsoft Sentinel Requirements
Litware plans to leverage the security information and event management (SIEM) and security orchestration automated response (SOAK) capabilities of Microsoft Sentinel. The company wants to centralize Security Operations Center (SOQ by using Microsoft Sentinel.
Identity Requirements
Litware identifies the following identity requirements:
* Detect brute force attacks that directly target AD DS user accounts.
* Implement leaked credential detection in the Azure AD tenant of Litware.
* Prevent AD DS user accounts from being locked out by brute force attacks that target Azure AD user accounts.
* Implement delegated management of users and groups in the Azure AD tenant of Litware, including support for.
* The management of group properties, membership, and licensing « The management of user properties, passwords, and licensing
* The delegation of user management based on business units.
Regulatory Compliance Requirements
Litware identifies the following regulatory compliance requirements:
* insure data residency compliance when collecting logs, telemetry, and data owned by each United States- and France-based subsidiary.
* Leverage built-in Azure Policy definitions to evaluate regulatory compliance across the entire managed environment.
* Use the principle of least privilege.
Azure Landing Zone Requirements
Litware identifies the following landing zone requirements:
* Route all internet-bound traffic from landing zones through Azure Firewall in a dedicated Azure subscription.
* Provide a secure score scoped to the landing zone.
* Ensure that the Azure virtual machines in each landing zone communicate with Azure App Service web apps in the same zone over the Microsoft backbone network, rather than over public endpoints.
* Minimize the possibility of data exfiltration.
* Maximize network bandwidth.
The landing zone architecture will include the dedicated subscription, which will serve as the hub for internet and hybrid connectivity. Each landing zone will have the following characteristics:
* Be created in a dedicated subscription.
* Use a DNS namespace of litware.com.
Application Security Requirements
Litware identifies the following application security requirements:
* Identify internal applications that will support single sign-on (SSO) by using Azure AD Application Proxy.
* Monitor and control access to Microsoft SharePoint Online and Exchange Online data in real time.
NEW QUESTION # 338
As we entered into such a web world, cable network or wireless network has been widely spread. And it is easier to find an online environment to do your practices. This version of SC-100 test prep can be used on any device installed with web browsers. We specially provide a timed programming test in this online SC-100 Test Engine, and help you build up confidence in a timed exam. With limited time, you need to finish your task in SC-100 quiz guide, considering your precious time, we also suggest this version of SC-100 study guide that can help you find out your problems to pass the exam.
Reliable SC-100 Exam Sample: https://www.real4test.com/SC-100_real-exam.html
BTW, DOWNLOAD part of Real4test SC-100 dumps from Cloud Storage: https://drive.google.com/open?id=1mrwk-0ZfCnJErpTXA_JTbS-qg6_XjfRJ
