New DSA-C03 Test Simulator - DSA-C03 Exam Quiz
71
Posted at 2/22/2026 21:33:59      View:117 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New DSA-C03 dumps are available on Google Drive shared by Test4Cram: https://drive.google.com/open?id=17GFU_XeTXBcMgcuk1PEsO5NGg4Zn58LX
The Snowflake DSA-C03 desktop practice test software and web-based practice test software, both are the mock SnowPro Advanced: Data Scientist Certification Exam (DSA-C03) exam that provides you real-time DSA-C03 exam environment for quick and complete preparation. Whereas the Snowflake DSA-C03 PDF Dumps file is concerned, this file is simply a collection of real, valid, and updated SnowPro Advanced: Data Scientist Certification Exam (DSA-C03) exam questions that also help you in preparation. So choose the right "Test4Cram" exam questions format and start DSA-C03 exam preparation today. Order your DSA-C03 Dumps now to Avail 25% EXTRA Discount on the DSA-C03 Exam Dumps learning material and get your dream certification.
DSA-C03 exam training allows you to pass exams in the shortest possible time. If you do not have enough time, our DSA-C03 study material is really a good choice. In the process of your learning, our DSA-C03 study materials can also improve your efficiency. If you don't have enough time to learn, DSA-C03 Test Guide will make the best use of your spare time. The professional tailored by DSA-C03 learning question must be very suitable for you. You will have a deeper understanding of the process. Efficient use of all the time, believe me, you will realize your dreams.
Test4Cram: The Ultimate Solution for Snowflake DSA-C03 Certification Exam PreparationTest4Cram provides actual to help candidates pass on the first try, ultimately saving them time and resources. These questions are of the highest quality, ensuring success for those who use them. To achieve success, it's crucial to have access to quality Snowflake DSA-C03 Exam Dumps and to prepare for the likely questions that will appear on the exam. Test4Cram helps candidates overcome any difficulties they may face in exam preparation, with a 24/7 support team ready to assist with any issues that may arise.
Snowflake SnowPro Advanced: Data Scientist Certification Exam Sample Questions (Q94-Q99):NEW QUESTION # 94
You are working with a dataset in Snowflake containing customer reviews stored in a 'REVIEWS' table. The 'SENTIMENT SCORE column contains continuous values ranging from -1 (negative) to 1 (positive). You need to create a new column, 'SENTIMENT CATEGORY, based on the following rules: 'Negative': 'SENTIMENT SCORE < -0.5 'Neutral': -0.5 'SENTIMENT SCORE 0.5 'Positive': 'SENTIMENT SCORE > 0.5 You also want to binarize this 'SENTIMENT CATEGORY column into three separate columns: 'IS NEGATIVE, 'IS NEUTRAL', and 'IS POSITIVE. Which of the following SQL statements correctly implements both the categorization and subsequent binarization?
  • A. Option B
  • B. Option E
  • C. Option C
  • D. Option D
  • E. Option A
Options B and E are correct. Option B correctly uses a CTE to first categorize the sentiment and then perform one-hot encoding using the ' IFF function. This approach is efficient and readable. Option E correctly categorizes and implements one-hot encoding using Boolean expressions and casting them to integers (0 or 1). Option A attempts to perform the one-hot encoding in the same SELECT statement as the categorization, which will result in error. Because it is referencing a column it just defined, so it wont find it. Option C is incorrect because it uses both WHEN SENTIMENT SCORE < -0.5 THEN 'Negative' and 'WHEN SENTIMENT SCORE BETWEEN -0.5 AND 0.5 THEN 'Neutral" which could include duplicates. Option D is incorrect, because it includes 'ELSE 'Unknown" that is not needed, as it should only be three rules.
NEW QUESTION # 95
A marketing analyst is building a propensity model to predict customer response to a new product launch. The dataset contains a 'City' column with a large number of unique city names. Applying one-hot encoding to this feature would result in a very high-dimensional dataset, potentially leading to the curse of dimensionality. To mitigate this, the analyst decides to combine Label Encoding followed by binarization techniques. Which of the following statements are TRUE regarding the benefits and challenges of this combined approach in Snowflake compared to simply label encoding?
  • A. Label encoding introduces an arbitrary ordinal relationship between the cities, which may not be appropriate. Binarization alone cannot remove this artifact.
  • B. Label encoding followed by binarization will reduce the memory required to store the 'City' feature compared to one-hot encoding, and Snowflake's columnar storage optimizes storage for integer data types used in label encoding.
  • C. While label encoding itself adds an ordinal relationship, applying binarization techniques like binary encoding (converting the label to binary representation and splitting into multiple columns) after label encoding will remove the arbitrary ordinal relationship.
  • D. Binarizing a label encoded column using a simple threshold (e.g., creating a 'high_city_id' flag) addresses the curse of dimensionality by reducing the number of features to one, but it loses significant information about the individual cities.
  • E. Binarization following label encoding may enhance model performance if a specific split based on a defined threshold is meaningful for the target variable (e.g., distinguishing between cities above/below a certain average income level related to marketing success).
Answer: A,B,D,E
Option A is true because label encoding converts strings into integers, which are more memory-efficient than storing numerous one-hot encoded columns. Snowflake's columnar storage further optimizes integer storage. Option B is also true; label encoding inherently creates an ordinal relationship that might not be valid for nominal features like city names. Option C is incorrect; simple binarization (e.g., > threshold) of label encoded data doesn't remove the arbitrary ordinal relationship; more complex binarization techniques would be needed. Option D is accurate; binarization reduces dimensionality but sacrifices granularity, leading to information loss. Option E is correct because carefully chosen thresholds might correlate with the target variable and improve predictive power.
NEW QUESTION # 96
You've trained a model using Snowflake ML and want to deploy it for real-time predictions using a Snowflake UDF. To ensure minimal latency, you need to optimize the UDF's performance. Which of the following strategies and considerations are most important when creating and deploying a UDF for model inference in Snowflake to minimize latency, especially when the model is large (e.g., > 100MB)?
Select all that apply.
  • A. Use smaller warehouse size for UDF evaluation in order to reduce latency and compute costs.
  • B. Use a Snowflake Stage to store the model file and load the model within the UDF using 'snowflake.snowpark.files.SnowflakeFile' to minimize memory footprint.
  • C. Ensure the UDF code is written in Python and utilizes vectorized operations with libraries like NumPy to process data in batches efficiently.
  • D. Utilize a Snowflake external function instead of a UDF if the model requires access to resources outside of Snowflake's environment.
  • E. Store the trained model as a BLOB within the UDF code itself to avoid external dependencies.
Options A and C are the most important strategies. Option A: Vectorized operations in Python using libraries like NumPy can significantly improve the performance of UDFs, especially for large datasets. Option C: Storing the model in a Snowflake Stage and loading it within the UDF helps manage memory usage efficiently, especially when dealing with large models. Option B is not recommended as embedding large BLOB data within UDF code increases UDF size. Option D: External functions introduce additional latency due to the need to communicate with external resources. Option E is incorrect because smaller warehouses may lead to longer processing times.
NEW QUESTION # 97
A data scientist is performing exploratory data analysis on a table named 'CUSTOMER TRANSACTIONS. They need to calculate the standard deviation of transaction amounts C TRANSACTION AMOUNT) for different customer segments CCUSTOMER SEGMENT). The 'CUSTOMER SEGMENT column can contain NULL values. Which of the following SQL statements will correctly compute the standard deviation, excluding NULL transaction amounts, and handling NULL customer segments by treating them as a separate segment called 'Unknown'? Consider using Snowflake-specific functions where appropriate.
  • A. Option B
  • B. Option C
  • C. Option D
  • D. Option E
  • E. Option A
Options B and C correctly calculates the standard deviation. Option B utilizes 'NVL' , which is the equivalent of 'COALESCE or ' IFNULL', to handle NULL Customer Segment values, and 'STDDEV_SAMP' for sample standard deviation, which is generally the correct function to use when dealing with a sample of the entire population. Option C also uses 'COALESCE and utilizes the 'STDDEV POP function, which returns the population standard deviation, assuming the data represents the whole population. Option A uses IFNULL, which works, and STDDEV, which is an alias for either STDDEV SAMP or STDDEV POP. The exact behavior will depend on session variable setting. Option D also uses 'CASE WHEN' construct which works to identify Unknown segments. STDDEV is again aliased. Option E calculates the variance and not Standard deviation.
NEW QUESTION # 98
You are building a customer support chatbot using Snowflake Cortex and a large language model (LLM). You want to use prompt engineering to improve the chatbot's ability to answer complex questions about product features. You have a table PRODUCT DETAILS with columns 'feature_name', Which of the following prompts, when used with the COMPLETE function in Snowflake Cortex, is MOST likely to yield the best results for answering user questions about specific product features, assuming you are aiming for concise and accurate responses focused solely on providing the requested feature description and avoiding extraneous chatbot-like conversation?
  • A. Option B
  • B. Option C
  • C. Option D
  • D. Option E
  • E. Option A
Option C is the best prompt because it directly instructs the LLM to act as a product expert and provide only the feature description, minimizing extraneous conversation or information. Options A and B lack specific instructions, potentially leading to verbose responses. Option D includes all product details in the prompt, which might overwhelm the LLM. Option E tries to fetch a specific feature description, but the SQL is incorrect. Correct SQL will increase token usage and may not lead to a concise response.
NEW QUESTION # 99
It is worth mentioning that, the simulation test is available in our software version. With the simulation test, all of our customers will get accustomed to the DSA-C03 exam easily, and get rid of bad habits, which may influence your performance in the real DSA-C03 exam. In addition, the mode of DSA-C03 learning guide questions and answers is the most effective for you to remember the key points. During your practice process, the DSA-C03 test questions would be absorbed, which is time-saving and high-efficient.
DSA-C03 Exam Quiz: https://www.test4cram.com/DSA-C03_real-exam-dumps.html
Serving as indispensable choices on your way of achieving success especially during this DSA-C03 Exam Cram Sheet exam, more than 98 percent of candidates pass the exam with our DSA-C03 Exam Cram Sheet training guide and all of former candidates made measurable advance and improvement, We gain the reputation by DSA-C03 : SnowPro Advanced: Data Scientist Certification Exam valid exam practice and the DSA-C03 latest practice questions in turn inspire us to do even better, Snowflake New DSA-C03 Test Simulator As far as study materials are concerned, our company is the undisputed bellwether in this field.
So, we're sure it absolutely can help you pass DSA-C03 exam and get Snowflake certificate and you don't need to spend much time and energy on preparing for DSA-C03 exam.
All the questions were the same as this dump, Serving as indispensable choices on your way of achieving success especially during this DSA-C03 Exam Cram Sheet exam, more than 98 percent of candidates pass the exam with our DSA-C03 Exam Cram Sheet training guide and all of former candidates made measurable advance and improvement.
New DSA-C03 Test Simulator Free PDF | Pass-Sure DSA-C03 Exam Quiz: SnowPro Advanced: Data Scientist Certification ExamWe gain the reputation by DSA-C03 : SnowPro Advanced: Data Scientist Certification Exam valid exam practice and the DSA-C03 latest practice questions in turn inspire us to do even better, As far as study DSA-C03 materials are concerned, our company is the undisputed bellwether in this field.
We provide Snowflake DSA-C03 test dumps questions since 2010, Now there are many ways to find free Snowflake DSA-C03 braindumps pdf but it is most probably old and outdated material.
What's more, part of that Test4Cram DSA-C03 dumps now are free: https://drive.google.com/open?id=17GFU_XeTXBcMgcuk1PEsO5NGg4Zn58LX
