Valid C1000-189 Test Syllabus, Testking C1000-189 Learning Materials
73
Posted at 2/22/2026 21:58:46      View:87 | Replies:0        Print      Only Author   [Copy Link] 1#
Practicing with IBM C1000-189 Exam questions will help you to become an expert in and acquire the IBM C1000-189. IBM C1000-189 Exam Questions allow you to verify your skills as a professional. You have to pass the IBM C1000-189 to achieve the associate-level certification.
IBM C1000-189 Exam Syllabus Topics:
  • Planning: This section of the exam measures the skills of Cloud Monitoring Engineers and covers the foundational planning tasks required for successful Instana deployment. Candidates must understand the installation prerequisites, the architectural design of Instana for on-premises environments, and the platform core capabilities and use cases. It also assesses knowledge of different agent modes, supported sensors and tracers, and the distinctions between cloud service agents and serverless agents essential for scalable implementation.
  • Configuration: This section of the exam measures the skills of DevOps Administrators and evaluates their ability to configure and optimize Instana operational settings. It involves setting up business process monitoring, configuring both cloud and serverless agents, and defining agent proxy parameters. Candidates will learn to implement various technologies and sensors, manage OpenTelemetry integrations, set up smart alerts, create service naming rules, and define custom SLIs and payloads for alert channels. Managing licenses and ensuring proper configuration of alerts and notifications are also key components of this domain.
  • Security and Compliance: This section of the exam measures the skills of IT Security Analysts and focuses on the data protection and compliance aspects of Instana deployment. Candidates must describe and implement data retention policies, plan for regulatory compliance, secure APIs, manage user access, and interpret audit logs. The goal is to ensure secure system configurations that align with organizational and regulatory standards.
  • Integration: This section of the exam measures the skills of Integration Engineers and assesses their proficiency in connecting Instana with external monitoring and automation tools. Candidates must demonstrate knowledge of integrating agent-based systems such as Omegamon, ITM, and ITCAM, as well as external platforms like Prometheus and Grafana. The section also includes configuring alert channels, automation actions, and utilizing the Instana REST API to support customized workflows and data visibility.
Testking C1000-189 Learning Materials - C1000-189 Test Guide OnlineWhen you take ActualTestsQuiz IBM C1000-189 practice exams, you can know whether you are ready for the finals or not. It shows you the real picture of your hard work and how easy it will be to clear the C1000-189 exam if you are ready for it. So, don’t miss practicing the C1000-189 Mock Exams and score yourself honestly. You have all the time to try IBM C1000-189 practice exams and then be confident while appearing for the final turn.
IBM Instana Observability v1.0.277 Administrator - Professional Sample Questions (Q22-Q27):NEW QUESTION # 22
Which tool does Instana use to provide geographical data by mapping user IP addresses?
  • A. GeoLite2 database
  • B. Geo Application Service
  • C. Universal Geo database
  • D. Google Maps API
IBM Instana leverages the open-source and widely recognized GeoLite2 database for mapping user IP addresses to their approximate physical locations in synthetic and real user monitoring scenarios. The documentation details: "Instana provides geographical and location metadata based on the GeoLite2 database, which is regularly updated for improved accuracy and privacy compliance." GeoLite2 is a MaxMind-developed database providing country, city, region, and sometimes ISP-level information from IP addresses. Using an on-premise and regularly-curated geo database ensures no end-user data is ever transmitted to external or third-party web mapping services (such as Google Maps), maintaining strong data privacy and compliance for enterprise customers. Other listed tools are not native to Instana's geo lookup implementation.
NEW QUESTION # 23
At which level can AWS agent polling intervals for CloudWatch API be configured?
  • A. Account
  • B. Resource group
  • C. Service
  • D. Region
AWS monitoring through Instana involves integration with the CloudWatch API to retrieve platform and service metrics. The official IBM Instana Observability documentation affirms that polling intervals for CloudWatch can be set at the Region level. This means an administrator configures how frequently Instana's agent queries CloudWatch within each specified region independently. This level of granularity provides flexibility: for example, mission-critical regions may be monitored more frequently, while others are polled less often to reduce API costs or remain within AWS rate limits. The documentation specifies: "Instana Agents for AWS can be configured with a polling interval for CloudWatch that is set per Region to customize granularity and resource consumption." Polling cannot be set at the account, resource group, or individual service level in default configuration. Instana's region-based polling helps balance data accuracy and overhead, especially in global or multi-region deployments. If needed, changes are applied through YAML configuration or UI during AWS agent integration setup.
NEW QUESTION # 24
Which protocol is used by the Grafana Plugin for Instana to fetch data?
  • A. HTTP
  • B. gRPC
  • C. JDBC
  • D. SOP
When integrating Grafana with Instana, the plugin communicates using RESTful interactions over the HTTP protocol. IBM's integration guide clearly explains: "The Instana DataSource Plugin for Grafana communicates with the Instana backend via HTTP-based REST APIs to query metrics and event data." This ensures secure TLS-encrypted data transport and allows compatibility with Grafana's native data source management features. HTTP is chosen due to its simplicity, standardization, and suitability for web API integrations, allowing Grafana to query time-series data from Instana and automatically populate dashboards. The plugin retrieves metrics, trace-level summaries, and service health states over HTTP GET and POST requests. Other options such as gRPC are used only internally between microservices, SOP is not a standard communication protocol, and JDBC is limited to databases. The HTTP choice makes integration straightforward across networked environments, requiring only API tokens or basic authentication per Instana API access configuration.
NEW QUESTION # 25
What is the purpose of creating a custom service rule in Instana?
  • A. To set a global service name for all calls
  • B. To apply the service.name tag of the infrastructure component
  • C. To map services using existing meta-information of the infrastructure component
  • D. To create a manual service configuration
IBM Instana Observability enables users to create custom service rules to precisely associate telemetry with logical services using meta-information already present in infrastructure components. The documentation specifies: "Custom service rules enable mapping of discovered entities to meaningful service constructs, using labels, tags, or annotations present on infrastructure components." This supports the grouping and visualization of traffic/metrics for actual business workflows rather than default technical boundaries. By analyzing meta-data, such as Kubernetes labels, docker tags, or VM metadata, Instana automatically maps relevant requests and traces to the defined service names, improving observability and simplifying troubleshooting. Global service naming (A) and manual configuration (C) do not leverage infrastructure metadata and are not scalable in dynamic environments. Option D relies only on a service.name tag, missing broader meta-information mapping capabilities. The verified documentation supports answer B as the sole comprehensive approach for dynamic service discovery within Instana.
NEW QUESTION # 26
Which statement accurately describes the use of the agent key?
  • A. It is used for both downloading Instana artifacts and deploying an instance.
  • B. It is not included in the purchase email and must be obtained separately.
  • C. It is used only for deploying an instance.
  • D. It is required only for downloading the license.
The IBM Instana Observability product architecture uses a security credential called an agent key for authentication and authorization in both installation and deployment operations. The documentation explicitly affirms: "The agent key must be used for downloading Instana installation artifacts from IBM repositories as well as for deploying agents to connect to the backend." This binding ensures entitlement enforcement and integrity of data transfer. The key, distributed through official IBM entitlement channels or purchase confirmation emails, validates the customer's licensed environment. During deployment, the same key is included in configuration files or environment variables so that each agent securely authenticates to its assigned backend instance. This unified mechanism simplifies lifecycle management while maintaining strong license controls. The key is never generated manually nor limited to licensing download alone-its dual purpose makes it critical in both provisioning and operations stages.
NEW QUESTION # 27
You can use this IBM C1000-189 version on any operating system, and this software is accessible through any browser like Opera, Safari, Chrome, Firefox, and IE. You can easily assess yourself with the help of our C1000-189 practice software, as it records all your previous results for future use.
Testking C1000-189 Learning Materials: https://www.actualtestsquiz.com/C1000-189-test-torrent.html
