[General] 2V0-13.25 Study Materials Review - Pass4sure 2V0-13.25 Exam Prep
71
General 2V0-13.25 Study Materials Review - Pass4sure 2V0-13.25 Exam Prep
Posted at 2/22/2026 22:03:16      View119 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest DumpsActual 2V0-13.25 PDF Dumps and 2V0-13.25 Exam Engine Free Share: https://drive.google.com/open?id=1WolNH21vJLNX8sG23ZpFIucOJLE4XFTl
As we all know, time and tide waits for no man. If you really want to pass the 2V0-13.25 exam, you should choose our first-class 2V0-13.25 study materials. And you cannot miss the opportunities this time for as the most important and indispensable practice materials in this line, we have confidence in the quality of our 2V0-13.25 practice materials, and offer all after-sales services for your consideration and acceptance.
DumpsActual play the key role for assuring your success in Private Cloud Monitoring and Operations with 2V0-13.25 exam. We incline your interest towards professional way of learning; motivate you to execute your learned concepts in practical industry. No more exam phobia exits if you have devotedly prepared through our 2V0-13.25 Exam products, certain boost comes in your confidence level that routes you towards success pathway.
Pass Guaranteed 2026 Valid VMware 2V0-13.25 Study Materials ReviewWe offer free demo 2V0-13.25 questions answers and trial services at DumpsActual. You can always check out our 2V0-13.25 certification exam dumps questions that will help you pass the 2V0-13.25 exams. With our well-researched and well-curated exam 2V0-13.25 dumps, you can surely pass the exam in the best marks. We continuously update our products by adding latest questions in our 2V0-13.25 Pdf Files. After the date of purchase, you will receive free updates for one year. You will also be able to get discounts for 2V0-13.25 on complete packages.
VMware Cloud Foundation 9.0 Architect Sample Questions (Q34-Q39):NEW QUESTION # 34
Which Broadcom hardware features are essential for optimizing VMware Cloud Foundation's performance?
  • A. Broadcom Ethernet adapters
  • B. Broadcom RAID controllers
  • C. Broadcom GPU accelerators
  • D. Broadcom NVMe SSDs
Answer: A,B,D
Broadcom's Ethernet adapters, NVMe SSDs, and RAID controllers optimize networking, storage, and data redundancy performance in VMware Cloud Foundation.
NEW QUESTION # 35
Which VMware Cloud Foundation components are essential for automating and managing infrastructure in hybrid cloud environments?
  • A. VMware vRealize Automation
  • B. VMware vSAN
  • C. VMware vSphere
  • D. VMware NSX
VMware vRealize Automation and vSphere are key for automation and infrastructure management in hybrid cloud environments.
NEW QUESTION # 36
Which Broadcom products are used to ensure high availability in VMware Cloud Foundation environments?
  • A. Broadcom RAID controllers
  • B. Broadcom NVMe SSDs
  • C. Broadcom Fibre Channel HBAs
  • D. Broadcom Ethernet adapters
Broadcom RAID controllers and Fibre Channel HBAs enhance high availability in VMware Cloud Foundation.
NEW QUESTION # 37
An architect is designing a new VCF solution to meet the following requirements:
The solution must be deployed across two availability zones.
The physical hosts must be installed in a single rack per availability zone.
Workloads running in the cluster must be able to run on hosts in either availability zone.
The architect has decided that to meet these requirements, the solution will be deployed using the Single Instance - Multiple Availability Zones VCF Topology.
When considering the design for the network, what should the architect include in the logical design to meet these requirements?
  • A. A physical network fabric in a leaf-spine configuration with dual Cisco switches within each availability zone.
  • B. A highly available gateway that supports the failure of an entire availability zone.
  • C. A 25-GbE port on each Top of Rack (ToR) switch connected to the ESXi host uplinks.
  • D. A single NSX Overlay Transport Zone for all clusters to carry the traffic between the ESXi hosts.
The VCF 5.2 design uses a Single Instance - Multiple Availability Zones topology (e.g., stretched cluster), requiring centralized management across two AZs, hosts in one rack per AZ, and workload mobility across AZs. The logical design focuses on high-level networking architecture, not physical details.
Let's evaluate:
Option A: A physical network fabric in a leaf-spine configuration with dual Cisco switches within each availability zone A leaf-spine fabric enhances physical network scalability and redundancy, aligning with rack-based deployments. However, it's a physical design detail (switch topology), not a logical networking decision, per the VCF 5.2 Design Guide.
Option B: A highly available gateway that supports the failure of an entire availability zone A gateway (e.g., NSX Edge Tier-0) with AZ failover supports North-South traffic resilience. While valuable, it doesn't directly enable workload mobility across AZs (East-West traffic), which is the core requirement. The VCF 5.2 Networking Guide treats gateways as supplementary, not foundational for stretched clusters.
Option C: A 25-GbE port on each Top of Rack (ToR) switch connected to the ESXi host uplinks Specifying 25-GbE ports is a physical network detail (bandwidth, cabling), not a logical design element. The VCF 5.2 Design Guide relegates port speeds to physical implementation, not logical architecture.
Option D: A single NSX Overlay Transport Zone for all clusters to carry the traffic between the ESXi hosts In a stretched cluster topology, a single NSX Overlay Transport Zone enables VM mobility across AZs via overlay networks (e.g., Geneve). It ensures workloads can run on hosts in either AZ by providing a unified L2/L3 connectivity layer, managed by NSX. The VCF 5.2 Architectural Guide mandates a single Overlay TZ for stretched deployments to support vMotion and workload distribution, directly meeting the requirement.
Conclusion:
Option D is the logical design decision, enabling workload mobility across AZs in a stretched VCF topology via NSX overlay networking.
Reference: VMware Cloud Foundation 5.2 Architectural Guide (docs.vmware.com): Multi-AZ Topology and NSX Overlay.
VMware Cloud Foundation 5.2 Networking Guide (docs.vmware.com): Transport Zones in Stretched Clusters.
VMware Cloud Foundation 5.2 Design Guide (docs.vmware.com): Logical vs. Physical Design.
NEW QUESTION # 38
Which Broadcom solutions are important for ensuring high-speed network connectivity in VMware environments?
  • A. Broadcom NVMe SSD
  • B. Broadcom RAID Controller
  • D. Broadcom 25GbE Ethernet Adapter
The Broadcom 25GbE Ethernet Adapter is the key solution for ensuring high-speed network connectivity in VMware environments.
NEW QUESTION # 39
It is our consistent aim to serve our customers wholeheartedly. Our 2V0-13.25 real exam try to ensure that every customer is satisfied, which can be embodied in the convenient and quick refund process. Although the passing rate of our 2V0-13.25 training quiz is close to 100%, if you are still worried, we can give you another guarantee: if you don't pass the exam, you can get a full refund. So there is nothing to worry about, just buy our 2V0-13.25 exam questions.
Pass4sure 2V0-13.25 Exam Prep: https://www.dumpsactual.com/2V0-13.25-actualtests-dumps.html
Many candidates are under great pressure and are hard to work in daily life before real test, if so, 2V0-13.25 study guide can save you out of bad situation, The quality of our 2V0-13.25 dumps torrent is excellent and it meets international certification exam standards, The VMware Cloud Foundation 9.0 Architect (2V0-13.25) exam credential paves the way toward landing high-paying jobs or promotions in your organization, DumpsActual 2V0-13.25 questions pdf and preparation material has everything you need to pass any VMware Cloud Foundation 9.0 Architect exam without any hassle.
You may not want every entry in your table of contents 2V0-13.25 to be followed by a page number, Do not attempt to modify string literals, Many candidates are under great pressure and are hard to work in daily life before real test, if so, 2V0-13.25 Study Guide can save you out of bad situation.
Hot 2V0-13.25 Study Materials Review - Reliable 2V0-13.25 Exam Tool Guarantee Purchasing SafetyThe quality of our 2V0-13.25 dumps torrent is excellent and it meets international certification exam standards, The VMware Cloud Foundation 9.0 Architect (2V0-13.25) exam credential paves the way toward landing high-paying jobs or promotions in your organization.
DumpsActual 2V0-13.25 questions pdf and preparation material has everything you need to pass any VMware Cloud Foundation 9.0 Architect exam without any hassle, Moreover, without the needs of waiting, you can download the 2V0-13.25 study guide after paying for it immediately.
