AWS-Developer valid dumps - AWS-Developer exam simulator - AWS-Developer st
Posted at 2/22/2026 22:46:22
View132
Replies0
DOWNLOAD the newest Exam-Killer AWS-Developer PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1Vp-1FxjCNcuKsBxUgUraGy3dKgQXZhtW
We assume all the responsibilities that our practice materials may bring. They are a bunch of courteous staff waiting for offering help 24/7. You can definitely contact them when getting any questions related with our AWS-Developer practice materials. If you haplessly fail the exam, we treat it as our responsibility then give you full refund and get other version of practice material for free. That is why we win a great deal of customers around the world. Especially for those time-sensitive and busy candidates, all three versions of AWS-Developer practice materials can be chosen based on your preference. Such as app version, you can learn it using your phone everywhere without the limitation of place or time.
To sit for the AWS Certified Developer - Associate exam, candidates should have a solid understanding of at least one high-level programming language and experience with AWS services such as Amazon S3, Amazon EC2, and AWS Lambda. AWS-Developer exam consists of 65 multiple-choice and multiple-response questions that must be answered within 130 minutes. The cost of the exam is $150, and it can be taken at testing centers worldwide or online via a remote proctoring system. Passing the exam demonstrates to employers and clients that the individual has the skills and knowledge required to develop and maintain applications on the AWS platform and can help open up new career opportunities in cloud computing.
The Amazon AWS-Developer Exam consists of 65 multiple-choice and multiple-response questions that must be completed within 130 minutes. The questions are designed to test a candidate's ability to develop, deploy, and debug cloud-based applications using AWS services. AWS Certified Developer Associate Exam (DVA-C02) certification exam covers a range of topics, including AWS core services, security, deployment, and troubleshooting. Candidates must have a solid understanding of AWS Identity and Access Management (IAM), AWS Elastic Beanstalk, and AWS Elastic Compute Cloud (EC2) to pass the exam. Upon passing the exam, candidates are awarded the AWS Certified Developer - Associate certification, which is valid for two years.
Latest AWS-Developer Exam Pattern & AWS-Developer Valid Dumps PdfIt is very convenient for all people to use the AWS-Developer study materials from our company. Our study materials will help a lot of people to solve many problems if they buy our products. The online version of AWS-Developer study materials from our company is not limited to any equipment, which means you can apply our study materials to all electronic equipment, including the telephone, computer and so on. So the online version of the AWS-Developer Study Materials from our company will be very useful for you to prepare for your exam. We believe that our AWS-Developer study materials will be a good choice for you.
Amazon AWS Certified Developer Associate Exam (DVA-C02) Sample Questions (Q24-Q29):NEW QUESTION # 24
What happens when you create a topic on Amazon SNS?
- A. The topic is created, and it has the name you specified for it.
- B. This question doesn't make sense.
- C. An ARN (Amazon Resource Name) is created
- D. You can create a topic on Amazon SQS, not on Amazon SNS.
NEW QUESTION # 25
An application running on Amazon EC2 instances must access objects within an Amaon S3 busket that are encrypted using server-side encryption using AWS KMS encryption keys (SSE-KMS). The application must have access to the customer master key (CMK) to decrypt the objects.
Which combination of steps will grant the application access? (Select TWO.)
- A. Write an S3 bucket policy that grants the bucket access to the key.
- B. Write a key policy that enables IAM policies to grant access to the key.
- C. Grant access to the key in the IAM EC2 role attached to the application's EC2 instances.
- D. Grant access to the key in the S3 bucket's ACL
- E. Create a Systems Manager parameter that exposes the KMS key to the EC2 instances.
Answer: A,E
NEW QUESTION # 26
A developer is setting up Amazon API gateway for their company's products. The API will be registered developers to query and update their environments. The company wants to limit the amount of requests end users send for.bot cost and security reason management wants to offer registered the option of buying larger packages that allow for more requests.
- A. Enable Amazon CloudWatch metrics for the API Gateway stage Set up CloudWatch alarms based oft the Count metric and the ApiName, Method, Resource, and Stage dimensions to alerts when request rates pass the threshold Set the alarm action to Deny If a registered user chooses a larger package, create a user-specific alarm and adjust the values
- B. Set up a default usage plan specify values for the rate and burst capacity, and associate it with a stage If a registered user chooses a larger package, create a custom plan with the appropriate values and associate the plan with the user
- C. Enable throttling for the API Gateway stage Set a value tor both the rate and burst capacity If a registered larger package, create a stage for them, adjust the values, and share the new URL with them.
- D. Set up Amazon CloudWatch API logging in API Gateway Create a filter based on the user and requestTime fields and create an alarm on this filter Write an AWS Lambda function to analyze the values and requester information, and respond accordingly Set up the function as the target tor the alarm If a registered user chooses a larger package, update the Lambda code with the values
NEW QUESTION # 27
An application has hundreds of users. Each user may use multiple devices to access the application. The Developer wants to assign unique identifiers to these users regardless of the device they use.
Which of the following methods should be used to obtain unique identifiers?
- A. Assign IAM users and roles to the users. Use the unique IAM resource ID as the unique identifier.
- B. Create a user table in Amazon DynamoDB as key-value pairs of users and their devices. Use these keys as unique identifiers.
- C. Use IAM-generated access key IDs for the users as the unique identifier, but do not store secret keys.
- D. Implement developer-authenticated identities by using Amazon Cognito, and get credentials for these identities.
Amazon Cognito developer-authenticated identities helps authenticate, identify the user across devices.
Refer AWS documentation - Cognito Developer Authenticated Identities
Amazon Cognito supports developer authenticated identities, in addition to web identity federation through Facebook (Identity Pools), Google (Identity Pools), and Login with Amazon (Identity Pools). With developer authenticated identities, you can register and authenticate users via your own existing authentication process, while still using Amazon Cognito to synchronize user data and access AWS resources. Using developer authenticated identities involves interaction between the end user device, your backend for authentication, and Amazon Cognito.
NEW QUESTION # 28
An e-commerce site allows returning users to log in to display customized web pages. The workflow is shown in the image below:
An application is running on EC2 instances. Amazon RDS is used for the database that stores user accounts and preferences. The website freezes or is slow to load while waiting for the login step to complete. The remaining components of the site are well-optimized.
Which of the following techniques will resolve this issue? (Choose two.)
- A. Batch login requests from hundreds of users together as a single read request to the database.
- B. Use Amazon ElastiCache for MemCached to cache user data.
- C. Implement the user login page as an asynchronous Lambda function.
- D. Use an Amazon Application Load Balancer to load balance the traffic to the website.
- E. Call the database asynchronously so the code can continue executing.
Answer: B,E
NEW QUESTION # 29
Amazon AWS-Developer test braindump will be the right key to your exam success. As long as the road is right, success is near. Don't be over-anxious, wasting time is robbing oneself. Our Amazon AWS-Developer test braindump will be definitely useful for your test and 100% valid. Money Back Guaranteed!
Latest AWS-Developer Exam Pattern: https://www.exam-killer.com/AWS-Developer-valid-questions.html
- 100% Pass Quiz 2026 Amazon Useful AWS-Developer Guaranteed Success 🌌 Search for ➥ AWS-Developer 🡄 and download it for free immediately on ➤ [url]www.dumpsmaterials.com ⮘ 🎏New AWS-Developer Braindumps Sheet[/url]
- Testking AWS-Developer Exam Questions 🤠 AWS-Developer Certificate Exam 🥗 Dumps AWS-Developer Download 🚺 Immediately open ⇛ [url]www.pdfvce.com ⇚ and search for AWS-Developer to obtain a free download 🚵AWS-Developer Verified Answers[/url]
- Latest AWS-Developer - AWS Certified Developer Associate Exam (DVA-C02) Guaranteed Success 🧉 Easily obtain ⮆ AWS-Developer ⮄ for free download through ✔ [url]www.testkingpass.com ️✔️ 😖
df Demo AWS-Developer Download[/url] - AWS-Developer Latest Exam Papers 🙆 New AWS-Developer Test Dumps ➡️ AWS-Developer Reliable Exam Topics ↩ Open ▷ [url]www.pdfvce.com ◁ enter AWS-Developer and obtain a free download 🦲AWS-Developer Reliable Exam Dumps[/url]
- 100% Pass 2026 Authoritative Amazon AWS-Developer Guaranteed Success ❤ Search for ➥ AWS-Developer 🡄 and download it for free immediately on ➽ [url]www.troytecdumps.com 🢪 💬Cert AWS-Developer Exam[/url]
- AWS-Developer Guaranteed Success - Free PDF Amazon - AWS-Developer First-grade Latest Exam Pattern 🔂 Easily obtain AWS-Developer for free download through ➽ [url]www.pdfvce.com 🢪 🎡Examinations AWS-Developer Actual Questions[/url]
- AWS-Developer Reliable Exam Guide ↕ Testking AWS-Developer Exam Questions 🗯 Dumps AWS-Developer Download 🧺 Search for AWS-Developer and download it for free immediately on { [url]www.troytecdumps.com } 📱Dumps AWS-Developer Download[/url]
- 100% Pass Quiz Amazon - Professional AWS-Developer - AWS Certified Developer Associate Exam (DVA-C02) Guaranteed Success 🤿 Download ✔ AWS-Developer ️✔️ for free by simply searching on ⏩ [url]www.pdfvce.com ⏪ ⛪Cert AWS-Developer Exam[/url]
- 100% Pass 2026 Trustable AWS-Developer: AWS Certified Developer Associate Exam (DVA-C02) Guaranteed Success 🤧 ▶ [url]www.easy4engine.com ◀ is best website to obtain ☀ AWS-Developer ️☀️ for free download 🍵Examinations AWS-Developer Actual Questions[/url]
- Free PDF Quiz 2026 Amazon AWS-Developer Latest Guaranteed Success 🐻 ✔ [url]www.pdfvce.com ️✔️ is best website to obtain AWS-Developer for free download 🌊AWS-Developer Reliable Exam Guide[/url]
- Valid AWS-Developer Test Pass4sure 🙈 New AWS-Developer Test Dumps 🐶 AWS-Developer Review Guide 🟥 Go to website [url]www.examcollectionpass.com open and search for ⇛ AWS-Developer ⇚ to download for free 🛃
df Demo AWS-Developer Download[/url] - class.regaliaz.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, withshahidnaeem.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free & New AWS-Developer dumps are available on Google Drive shared by Exam-Killer: https://drive.google.com/open?id=1Vp-1FxjCNcuKsBxUgUraGy3dKgQXZhtW
