真實的156-536真題材料和資格考試中的領導者和156-536考試
94
Posted at 2/23/2026 03:40:28      View:78 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. KaoGuTi在Google Drive上分享了免費的、最新的156-536考試題庫:https://drive.google.com/open?id=1QTyTWgvEChrVIiQ1RBvsVybtphQxA0zY
在近幾年,IT世界的競爭越來越激烈,IT認證已經成為該行業的必需品,如果你想在你的職業生涯有一個很好的提升,通過KaoGuTi CheckPoint的156-536考試培訓資料這種方式來獲得微軟認證的證書是非常可行的,現在許多IT專業人士更願意增加CheckPoint的156-536考試認證對他們的憑證,我們的培訓資料涵蓋了通過CheckPoint的156-536考試認證的100%。
CheckPoint 156-536 考試大綱:
主題簡介
主題 1
  • Harmony Endpoint Management as a Service: This section targets Harmony Endpoint Security Professionals, focusing on managing endpoint security as a service. It covers the cloud-based management capabilities of Harmony Endpoint, allowing for scalable deployment and policy management.
主題 2
  • Troubleshooting: In this final section, CheckPoint Security Administrators will demonstrate their troubleshooting skills related to Harmony Endpoint. This involves identifying and resolving issues that may arise during deployment or operation of the endpoint security solution.
主題 3
  • Introduction to Harmony Endpoint: This section measures the skills of CheckPoint Security Administrators about the fundamental concepts of Harmony Endpoint. It introduces candidates to the capabilities of the Harmony Endpoint solution, which is designed to protect endpoint devices from various cyber threats.
主題 4
  • Harmony Endpoint Security Management: This section focuses on the skills of Harmony Endpoint Security Professionals and covers the management aspects of Harmony Endpoint Security. It emphasizes how to effectively configure and manage security policies across endpoint devices.
主題 5
  • Deploying Harmony Endpoint Data Security Protection: In this domain, CheckPoint Security Administrators will demonstrate their skills in deploying data security protections within Harmony Endpoint. This includes configuring data loss prevention strategies and ensuring data integrity across endpoints.
主題 6
  • Advanced Threat Prevention: CheckPoint Security Administrators will be assessed in this area, which covers advanced techniques for preventing sophisticated threats. This includes leveraging threat intelligence and proactive measures to safeguard endpoints from emerging cyber risks.
CheckPoint 156-536考試,156-536信息資訊KaoGuTi不僅可靠性強,而且服務也很好。如果你選擇了KaoGuTi但是156-536考試沒有成功,我們會100%全額退款給您。KaoGuTi還會為你提供一年的免費更新服務。
最新的 CCES 156-536 免費考試真題 (Q45-Q50):問題 #45
You are facing a lot of CPU usage and high bandwidth consumption on your Endpoint Security Server. You check and verify that everything is working as it should be, but the performance is still very slow. What can you do to decrease your bandwidth and CPU usage?
  • A. You can use some of your Endpoints as Super Nodes since super nodes reduce bandwidth as well as CPU usage.
  • B. Your company's size is not large enough to have a valid need for Endpoint Solution.
  • C. Your company needs more bandwidth. You have to increase your bandwidth by 300%.
  • D. The management High Availability sizing is not correct. You have to purchase more servers and add them to the cluster.
答案:A
問題 #46
Which solution encrypts various types of removable storage media including USB drives, backup hard drives, and SD cards?
  • A. Media Encryption and Port Protection (MEPP)
  • B. Full Recovery with Media Encryption
  • C. Full Disk Encryption and File Recovery
  • D. Endpoint's Media Encryption (ME) Software Capability
答案:D
問題 #47
What communication protocol does Harmony Endpoint management use to communicate with the management server?
  • A. CPCOM
  • B. TCP
  • C. UDP
  • D. SIC
答案:D
解題說明:
To determine the correct communication protocol used by Harmony Endpoint management to communicate with the management server, we need to clarify what "Harmony Endpoint management" refers to in the context of Check Point's Harmony Endpoint solution. The provided document, "CP_R81.
20_Harmony_Endpoint_Server_AdminGuide.pdf," offers detailed insights into the architecture and communication protocols used within this ecosystem. Let's break this down step-by-step based on the official documentation.
Step 1: Understanding "Harmony Endpoint Management"
Harmony Endpoint is Check Point's endpoint security solution, encompassing both client-side components (Endpoint Security Clients) and management-side components (SmartEndpoint console and Endpoint Security Management Server). The phrase "Harmony Endpoint management" in the question is ambiguous-it could refer to the management console (SmartEndpoint), the management server itself, or even the client-side management components communicating with the server. However, in security contexts, "management" typically implies the administrative or console component responsible for overseeing the system, which in this case aligns with the SmartEndpoint console.
The document outlines the architecture onpage 23under "Endpoint Security Architecture":
* SmartEndpoint: "A Check Point SmartConsole application to deploy, monitor and configure Endpoint Security clients and policies."
* Endpoint Security Management Server: "Includes the Endpoint Security policy management and databases. It communicates with endpoint clients to update their components, policies, and protection data."
* Endpoint Security Clients: "Application installed on end-user computers to monitor security status and enforce security policies." Given the question asks about communication "with the management server," it suggests that "Harmony Endpoint management" refers to the SmartEndpoint console communicating with the Endpoint Security Management Server, rather than the clients or the server communicating with itself.
Step 2: Identifying Communication Protocols
The document specifies communication protocols under "Endpoint Security Server and Client Communication" starting onpage 26. It distinguishes between two key types of communication relevant to this query:
* SmartEndpoint Console and Server to Server Communication(page 26):
* "Communication between these elements uses the Check Point Secure Internal Communication (SIC) service."
* "Service (Protocol/Port): SIC (TCP/18190 - 18193)"
* This applies to communication between the SmartEndpoint console and the Endpoint Security Management Servers, as well as between Endpoint Policy Servers and Management Servers.
* Client to Server Communication(page 27):
* "Most communication is over HTTPS TLSv1.2 encryption."
* "Service (Protocol/Port): HTTPS (TCP/443)"
* This covers communication from Endpoint Security Clients to the Management Server or Policy Servers.
The options provided are:
* A. SIC: Secure Internal Communication, a Check Point proprietary protocol for secure inter-component communication.
* B. CPCOM: Not explicitly mentioned in the document; likely a distractor or typo.
* C. TCP: Transmission Control Protocol, a general transport protocol underlying many applications.
* D. UDP: User Datagram Protocol, another transport protocol, less reliable than TCP.
Step 3: Analyzing the Options in Context
* SIC: The document explicitly states onpage 26that SIC is used for "SmartEndpoint console to Endpoint Security Management Servers" communication, operating over TCP ports 18190-18193. SIC is a specific, secure protocol designed by Check Point for internal communications between management components, making it a strong candidate if "Harmony Endpoint management" refers to the SmartEndpoint console.
* CPCOM: This term does not appear in the provided document. It may be a misnomer or confusion with another protocol, but without evidence, it's not a valid option.
* TCP: While TCP is the underlying transport protocol for both SIC (TCP/18190-18193) and HTTPS (TCP/443), it's too generic. The question likely seeks a specific protocol, not the transport layer.
* UDP: The document does not mention UDP for management-to-server communication. It's used in other contexts (e.g., RADIUS authentication on port 1812, page 431), but not here.
Step 4: Interpreting "Harmony Endpoint Management"
If "Harmony Endpoint management" refers to theSmartEndpoint console, the protocol is SIC, as perpage 26
"Communication between these elements uses the Check Point Secure Internal Communication (SIC) service." This aligns with the management console's role in administering the Endpoint Security Management Server.
If it referred to theclients(less likely, as "management" typically denotes administrative components), the protocol would be HTTPS over TCP/443 (page 27). However, HTTPS is not an option, and TCP alone is too broad. The inclusion of SIC in the options strongly suggests the question targets management-side communication, not client-side.
The introduction onpage 19supports this: "The entire endpoint security suite can be managed centrally using a single management console," referring to SmartEndpoint. Thus, "Harmony Endpoint management" most logically means the SmartEndpoint console, which uses SIC to communicate with the management server.
Step 5: Conclusion
Based on the exact extract frompage 26, "SmartEndpoint Console and Server to Server Communication" uses SIC (TCP/18190-18193). This matches option A. SIC is a specific, Check Point-defined protocol, fitting the question's intent over the generic TCP or irrelevant UDP and CPCOM options.
Final answer: A
"CP_R81.20_Harmony_Endpoint_Server_AdminGuide.pdf," Page 19: Introduction to Endpoint Security
"CP_R81.20_Harmony_Endpoint_Server_AdminGuide.pdf," Page 23: Endpoint Security Architecture
"CP_R81.20_Harmony_Endpoint_Server_AdminGuide.pdf," Page 26: SmartEndpoint Console and Server to Server Communication
問題 #48
How does FDE add another layer of security?
  • A. By offering encryption
  • B. By offering media encryption
  • C. By offering pre-boot protection
  • D. By offering port protection
答案:C
問題 #49
What happens to clients that fail to meet the requirements?
  • A. They receive incomplete protections
  • B. They do not receive FDE protections
  • C. They have encryption issues
  • D. They have unenforced protections
答案:B
解題說明:
The Check Point Harmony Endpoint documentation specifies that clients must fulfill all prerequisites to transition from the Deployment Phase to the Full Disk Encryption policy enforcement phase. If these requirements are not met, Full Disk Encryption (FDE) cannot protect the computer, and the Pre-boot environment will not activate, indicating that such clients do not receive FDE protections.
Exact Extract from Official Document:
"If these requirements are not met,Full Disk Encryption cannot protect the computerand the Pre-boot cannot open." Reference:Check Point Harmony Endpoint Specialist R81.20 Administration Guide, Page 250, Section:
"Installing and Deploying Full Disk Encryption."
問題 #50
所有購買 KaoGuTi 題庫學習資料網“CheckPoint 156-536 題庫學習資料”的考生,都將獲半年免費升級的售后服務,確保考生一次通過。我们網站的學習資料覆蓋了當前最新的知識點。如果你發現我們的題庫學習資料,存在重大的質量問題,一經核實,我們會無條件退換你的購買費用。事實證明,大多數考生對 CheckPoint 的 156-536 權威考試題庫學習資料充滿信任,如果你不確定,可以免費下載 156-536 考題學習資料試用版本,這樣方便你了解真實考試軟件界面,熟悉操作流程,讓 156-536 試題的質量得到保證。
156-536考試: https://www.kaoguti.com/156-536_exam-pdf.html
從Google Drive中免費下載最新的KaoGuTi 156-536 PDF版考試題庫:https://drive.google.com/open?id=1QTyTWgvEChrVIiQ1RBvsVybtphQxA0zY
Posted at 3/6/2026 01:02:39        Only Author  2#
No hesitation, this is deserving of a like. Free New practice questions C_S4PM2_2507 files questions—wishing you success in your exam!
