[General] SD-WAN-Engineer Latest Exam Camp - SD-WAN-Engineer Reliable Test Simulator
98
General SD-WAN-Engineer Latest Exam Camp - SD-WAN-Engineer Reliable Test Simulator
Posted at 2/23/2026 05:42:58      View114 | Replies0        Print      Only Author   [Copy Link] 1#
It is heartening to announce that all Actual4Cert users will be allowed to capitalize on a free Palo Alto Networks SD-WAN-Engineer exam questions demo of all three formats of the Palo Alto Networks SD-WAN-Engineer practice test. It will make them scrutinize how our formats work and what we offer them, for example, the form and pattern of Palo Alto Networks SD-WAN-Engineer Exam Dumps, and their relevant and updated answers. It is convenient for our consumers to check Actual4Cert Palo Alto Networks SD-WAN-Engineer exam questions free of charge before purchasing the Palo Alto Networks SD-WAN Engineer practice exam.
Palo Alto Networks SD-WAN-Engineer Exam Syllabus Topics:
  • Unified SASE: This domain covers Prisma SD-WAN integration with Prisma Access, ADEM configuration, IoT connectivity via Device-ID, Cloud Identity Engine integration, and User
  • Group-based policy implementation.
  • Planning and Design: This domain covers SD-WAN planning fundamentals including device selection, bandwidth and licensing planning, network assessment, data center and branch configurations, security requirements, high availability, and policy design for path, security, QoS, performance, and NAT.
  • Operations and Monitoring: This domain addresses monitoring device statistics, controller events, alerts, WAN Clarity reports, real-time network visibility tools, and SASE-related event management.
  • Deployment and Configuration: This domain focuses on Prisma SD-WAN deployment procedures, site-specific settings, configuration templates for different locations, routing protocol tuning, and VRF implementation for network segmentation.
Topic 5
  • Troubleshooting: This domain focuses on resolving connectivity, routing, forwarding, application performance, and policy issues using co-pilot data analysis and analytics for network optimization and reporting.
Pass Guaranteed Quiz Updated Palo Alto Networks - SD-WAN-Engineer - Palo Alto Networks SD-WAN Engineer Latest Exam CampThe exam time is coming, while you are not prepared well for SD-WAN-Engineer real test. Please do not be tense and worried, you can pass your SD-WAN-Engineer actual exam very simply and easily with Actual4Cert SD-WAN-Engineer free pdf dumps. With the help of Palo Alto Networks SD-WAN-Engineer free pdf practice, you can not only get high score in your actual test, but also can get more technology knowledge and be more professional.
Palo Alto Networks SD-WAN Engineer Sample Questions (Q47-Q52):NEW QUESTION # 47
When using the CloudBlade to integrate Prisma SD-WAN with Prisma Access, how does the system ensure that the IPSec tunnels between the branch ION and the Prisma Access Security Processing Node (SPN) are kept alive during periods of no user traffic?
  • A. The administrator must configure a continuous ping script on a branch PC.
  • B. The IPSec tunnel uses standard DPD (Dead Peer Detection) and the ION sends keepalives.
  • C. The CloudBlade automatically configures the ION to send Synthetic Probes (ICMP/HTTP) across the tunnel.
  • D. Prisma Access initiates the connection to the branch every 60 seconds.
Comprehensive and Detailed Explanation
The stability of VPN tunnels in the Prisma SD-WAN + Prisma Access integration relies on standard IPSec mechanisms.
Dead Peer Detection (DPD): The CloudBlade configuration automatically enables DPD on the IPSec tunnels it provisions.
Mechanism: DPD is a standard keepalive mechanism where the ION device sends periodic "R-U-THERE" messages to the Prisma Access gateway (and vice versa). If no acknowledgment is received after a specific count/timer, the ION marks the tunnel as down and attempts to re-key or switch to a backup path.
Synthetic Probes (B): While Synthetic Probes (part of ADEM or Path Quality monitoring) can be configured to measure latency/loss, the fundamental mechanism that keeps the IPSec security association (SA) active and detects link failure is DPD, not an application-layer probe.
NEW QUESTION # 48
An engineer at a managed services provider is updating an application that allows its customers to request firewall changes to also manage SD-WAN. The application will be able to make any approved changes directly to devices via API.
What is a requirement for the application to create SD-WAN interfaces?
  • A. REST API's "sdwanInterfaces" parameter on a firewall device
  • B. REST API's "sdwanInterfaceprofiles" parameter on a Panorama device
  • C. XML API's "sdwanprofiles/interfaces" parameter on a Panorama device
  • D. XML API's "InterfaceProfiles/sdwan" parameter on a firewall device
In Palo Alto Networks PAN-OS SD-WAN environments, automation and orchestration are key components for service providers managing large-scale deployments. The PAN-OS REST API provides a modern, structured way to programmatically manage configuration objects, including those required for SD-WAN functionality.
When an application is designed to push changes directly to devices (individual firewalls) rather than through a centralized template in Panorama, it must interact with the firewall's local REST API. To successfully create a virtual SD-WAN interface, the application must target the correct resource URI. In the PAN-OS API schema, the logical SD-WAN interface-which groups physical links to enable application-based path selection-is managed via the sdwanInterfaces parameter within the REST API.
It is important to distinguish between the interface itself and the profiles that support it. Option A refers to sdwanInterfaceprofiles, which are the objects used to define the characteristics of a link (such as bandwidth, link type, and monitoring frequency), but not the interface itself. Furthermore, since the scenario specifies making changes "directly to devices," the target must be the firewall rather than Panorama. While Panorama can manage these objects via templates, a direct-to-device automation workflow necessitates using the firewall's REST API endpoint. Utilizing the REST API over the legacy XML API is the recommended standard for modern integrations due to its ease of use with JSON payloads and alignment with contemporary DevSecOps practices. By using the sdwanInterfaces parameter on the firewall, the MSP application can programmatically bind physical Layer 3 interfaces to the SD-WAN fabric.
NEW QUESTION # 49
An organization has created a custom internal application definition for "Inventory_App" on the Prisma SD-WAN controller based on its destination IP address and port (L3/L4 rule). The application server IP has just changed.
After updating the custom application definition on the controller, how is this change propagated to the branch ION devices?
  • A. The administrator must manually "ush" the policy to all sites.
  • B. The change will only take effect after the daily "App-ID" scheduled update.
  • C. The controller automatically pushes the updated Application Definition (App-Def) to all ION devices immediately.
  • D. The administrator must reboot the ION devices for the new object to load.
In Prisma SD-WAN, Custom Applications are global policy objects managed centrally on the controller.
Immediate Propagation: When an administrator creates or modifies a Custom Application definition (e.g., updating the IP subnet or port for an internal app), the Prisma SD-WAN controller automatically pushes this update to all connected ION devices in the tenant.
No Manual Push: Unlike some legacy firewall management paradigms (like Panorama "Commit and Push"), the Prisma SD-WAN architecture is "intent-based" and continuously synchronized. A change to a global object like an App Definition is considered a live configuration change and is distributed immediately via the secure control channel.
No Reboot: The ION data plane updates its classification engine dynamically without interrupting traffic or requiring a reboot. This ensures that policy enforcement (steering "Inventory_App" to the correct path) remains accurate in real-time.
NEW QUESTION # 50
An administrator is configuring a BGP peer on a Data Center ION to learn routes from the core switch. The goal is to have the ION learn these prefixes and then advertise them to all remote branch sites across the SD- WAN overlay.
Which setting must be configured on the BGP Peer to ensure these learned routes are redistributed into the SD-WAN fabric?
  • A. Set the "Admin Distance" to 20.
  • B. Enable "Graceful Restart".
  • C. Set the "Scope" to "Global".
  • D. Configure a "refix List" to deny all.
In Prisma SD-WAN routing configuration, the Scope setting on a BGP Peer (or a Static Route) controls the redistribution logic for the prefixes learned from that source.
* Local Scope: If a BGP peer is configured with "Local" scope, the ION device will install the learned routes into its local routing table for its own reachability, but it will not advertise (redistribute) these routes to other ION devices via the Secure Fabric. They remain local to the site.
* Global Scope: To advertise reachability to the rest of the network, the BGP peer must be configured with "Global" scope. This tells the ION that any prefixes learned from this specific neighbor (e.g., the DC Core Switch) should be propagated across the SD-WAN overlay to remote branches. This is the critical setting for enabling branch-to-DC communication for applications hosted behind that BGP peer.
Without "Global" scope, the branches would never learn the routes to the data center subnets.
NEW QUESTION # 51
A network installer is at a remote branch site to deploy a new ION 3000 device. The device has been racked, cabled to the internet, and powered on. The installer has the "Claim Code" displayed on the email sent by the administrator.
When the administrator enters this Claim Code into the Prisma SD-WAN portal, what is the immediate status of the device before the configuration is fully pushed?
  • A. Provisioned
  • B. Claimed
  • C. Active
  • D. Online
In the Prisma SD-WAN (CloudGenix) Zero Touch Provisioning (ZTP) lifecycle, the device status transitions through specific stages that indicate its readiness and connectivity.
When an administrator enters the Claim Code (or Serial Number/Claim Code pair) into the portal, the device status immediately updates to "Claimed".
This status confirms that the portal has registered the device's unique identity and associated it with the customer's tenant. However, "Claimed" does not necessarily mean the device is fully operational or passing traffic yet. It simply signifies that the ownership is verified.
Once the physical device at the site successfully connects to the internet and reaches the Prisma SD-WAN Controller (using the call-home function), it will authenticate using its installed certificate. Upon successful authentication and the establishment of the secure control channel, the status will transition from "Claimed" to "Online".
Only after the device is "Online" can the controller push the specific site configuration (Device Shell), policies, and IP addressing required for the device to become "rovisioned" and eventually "Active" in the data path. If the device remains in the "Claimed" state for an extended period, it indicates that the hardware has not yet successfully contacted the controller, which prompts troubleshooting of the physical internet circuit or firewall rules upstream.
NEW QUESTION # 52
The passing rate of our SD-WAN-Engineer training quiz is 99% and the hit rate is also high. Our professional expert team seizes the focus of the exam and chooses the most important questions and answers which has simplified the important SD-WAN-Engineer information and follow the latest trend to make the client learn easily and efficiently. We update the SD-WAN-Engineer Study Materials frequently to let the client practice more. We provide the function to stimulate the SD-WAN-Engineer exam and the timing function of our SD-WAN-Engineer study materials to adjust your speed to answer the questions. You will pass the SD-WAN-Engineer exam easily.
SD-WAN-Engineer Reliable Test Simulator: https://www.actual4cert.com/SD-WAN-Engineer-real-questions.html
