Valid DOP-C02 Vce - Examinations DOP-C02 Actual Questions
110
Posted at 2/23/2026 06:27:03      View:116 | Replies:2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Pass4SureQuiz DOP-C02 dumps from Cloud Storage: https://drive.google.com/open?id=19L2kwruhn6z8U30y5zrpFo8hUNUZq_BA
Our DOP-C02 exam materials have plenty of advantages. For example, in order to meet the needs of different groups of people, we provide customers with three different versions of DOP-C02 actual exam, which contain the same questions and answers. They are the versions of the PDF, Software and APP online. You can choose the one which is your best suit of our DOP-C02 Study Materials according to your study habits.
Earning the AWS Certified DevOps Engineer - Professional certification can help individuals advance their careers in the field of DevOps and cloud computing. It demonstrates that they have the knowledge and skills needed to design, deploy, and manage complex applications on AWS using DevOps practices and principles.
Amazon DOP-C02 (AWS Certified DevOps Engineer - Professional) Certification Exam is an advanced-level certification designed for individuals with extensive experience in the field of DevOps. AWS Certified DevOps Engineer - Professional certification exam measures an individual's ability to manage and implement continuous delivery systems and methodologies on the AWS platform. It is a challenging exam that requires extensive knowledge of DevOps methodologies and AWS services, but it is a valuable credential for individuals who want to demonstrate their expertise in the field of DevOps.
Start Preparation with Amazon DOP-C02 Exam DumpsFor there are some problems with those still in the incubation period of strict control, thus to maintain the DOP-C02 quiz guide timely, let the user comfortable working in a better environment. You can completely trust the accuracy of our Amazon DOP-C02 Exam Questions because we will full refund if you failed exam with our training materials.
Amazon AWS Certified DevOps Engineer - Professional Sample Questions (Q174-Q179):NEW QUESTION # 174
A company wants to use AWS Systems Manager documents to bootstrap physical laptops for developers The bootstrap code Is stored in GitHub A DevOps engineer has already created a Systems Manager activation, installed the Systems Manager agent with the registration code, and installed an activation ID on all the laptops.
Which set of steps should be taken next?
  • A. Configure the Systems Manager document to use the AWS-RunShellScnpt command to copy the files from GitHub to Amazon S3, then use the aws-downloadContent plugin with a sourceType of S3
  • B. Configure the Systems Manager document to use the aws:softwarelnventory plugin and run the script from the Git repository
  • C. Configure the Systems Manager document to use the aws-configurePackage plugin with an install action and point to the Git repository
  • D. Configure the Systems Manager document to use the aws-downloadContent plugin with a sourceType of GitHub and sourcelnfo with the repository details.
Configure the Systems Manager Document to Use the aws-downloadContent Plugin with a sourceType of GitHub and sourcelnfo with the Repository Details:
The aws-downloadContent plugin can download content from various sources, including GitHub, which is necessary for bootstrapping the laptops with the code stored in the GitHub repository.
schemaVersion: '2.2'
description: "Download and run bootstrap script from GitHub"
mainSteps:
- action: aws:downloadContent
inputs:
sourceType: GitHub
sourceInfo: '{"owner":"my-org","repository":"my-repo","path":"scripts/bootstrap.sh","getOptions":"branch:main"}' destinationPath: /tmp/bootstrap.sh
- action: aws:runShellScript
inputs:
runCommand:
- chmod +x /tmp/bootstrap.sh
- /tmp/bootstrap.sh
This setup ensures that the bootstrap code is downloaded from GitHub and executed on the laptops using Systems Manager.
AWS Systems Manager aws-downloadContent Plugin
Running Commands Using Systems Manager
NEW QUESTION # 175
A company has a legacy application A DevOps engineer needs to automate the process of building the deployable artifact for the legacy application. The solution must store the deployable artifact in an existing Amazon S3 bucket for future deployments to reference Which solution will meet these requirements in the MOST operationally efficient way?
  • A. Create a custom Docker image that contains all the dependencies tor the legacy application Store the custom Docker image in a new Amazon Elastic Container Registry (Amazon ECR) repository Configure a new AWS CodeBuild project to use the custom Docker image to build the deployable artifact and to save the artifact to the S3 bucket.
  • B. Create a custom EC2 Image Builder image Install all the dependencies for the legacy application on the image Launch a new Amazon EC2 instance from the image Use the new EC2 instance to build the deployable artifact and to save the artifact to the S3 bucket.
  • C. Create an Amazon Elastic Kubernetes Service (Amazon EKS) cluster with an AWS Fargate profile that runs in multiple Availability Zones Create a custom Docker image that contains all the dependencies for the legacy application Store the custom Docker image in a new Amazon Elastic Container Registry (Amazon ECR) repository Use the custom Docker image inside the EKS cluster to build the deployable artifact and to save the artifact to the S3 bucket.
  • D. Launch a new Amazon EC2 instance Install all the dependencies (or the legacy application on the EC2 instance Use the EC2 instance to build the deployable artifact and to save the artifact to the S3 bucket.
This approach is the most operationally efficient because it leverages the benefits of containerization, such as isolation and reproducibility, as well as AWS managed services. AWS CodeBuild is a fully managed build service that can compile your source code, run tests, and produce deployable software packages. By using a custom Docker image that includes all dependencies, you can ensure that the environment in which your code is built is consistent. Using Amazon ECR to store Docker images lets you easily deploy the images to any environment. Also, you can directly upload the build artifacts to Amazon S3 from AWS CodeBuild, which is beneficial for version control and archival purposes.
NEW QUESTION # 176
A company has deployed an application in a production VPC in a single AWS account. The application is popular and is experiencing heavy usage. The company's security team wants to add additional security, such as AWS WAF, to the application deployment. However, the application's product manager is concerned about cost and does not want to approve the change unless the security team can prove that additional security is necessary.
The security team believes that some of the application's demand might come from users that have IP addresses that are on a deny list. The security team provides the deny list to a DevOps engineer. If any of the IP addresses on the deny list access the application, the security team wants to receive automated notification in near real time so that the security team can document that the application needs additional security. The DevOps engineer creates a VPC flow log for the production VPC.
Which set of additional steps should the DevOps engineer take to meet these requirements MOST cost- effectively?
  • A. Create a log group in Amazon CloudWatch Logs. Configure the VPC flow log to capture accepted traffic and to send the data to the log group. Create an Amazon CloudWatch metric filter for IP addresses on the deny list. Create a CloudWatch alarm with the metric filter as input. Set the period to 5 minutes and the datapoints to alarm to 1. Use an Amazon Simple Notification Service (Amazon SNS) topic to send alarm notices to the security team.
  • B. Create a log group in Amazon CloudWatch Logs. Create an Amazon S3 bucket to hold query results.
    Configure the VPC flow log to capture all traffic and to send the data to the log group. Deploy an Amazon Athena CloudWatch connector in AWS Lambda. Connect the connector to the log group.Configure Athena to periodically query for all accepted traffic from the IP addresses on the deny list and to store the results in the S3 bucket. Configure an S3 event notification to automatically notify the security team through an Amazon Simple Notification Service (Amazon SNS) topic when new objects are added to the S3 bucket.
  • C. Create an Amazon S3 bucket for log files. Configure the VPC flow log to capture all traffic and to send the data to the S3 bucket. Configure Amazon Athena to return all log files in the S3 bucket for IP addresses on the deny list. Configure Amazon QuickSight to accept data from Athena and to publish the data as a dashboard that the security team can access. Create a threshold alert of 1 for successful access.
    Configure the alert to automatically notify the security team as frequently as possible when the alert threshold is met.
  • D. Create an Amazon S3 bucket for log files. Configure the VPC flow log to capture accepted traffic and to send the data to the S3 bucket. Configure an Amazon OpenSearch Service cluster and domain for the log files. Create an AWS Lambda function to retrieve the logs from the S3 bucket, format the logs, and load the logs into the OpenSearch Service cluster. Schedule the Lambda function to run every 5 minutes. Configure an alert and condition in OpenSearch Service to send alerts to the security team through an Amazon Simple Notification Service (Amazon SNS) topic when access from the IP addresses on the deny list is detected.
NEW QUESTION # 177
A security team is concerned that a developer can unintentionally attach an Elastic IP address to an Amazon EC2 instance in production. No developer should be allowed to attach an Elastic IP address to an instance. The security team must be notified if any production server has an Elastic IP address at any time How can this task be automated'?
  • A. Create an AWS Config rule to check that all production instances have EC2 1AM roles that include deny associate-address permissions Verify whether there is an Elastic IP address associated with any instance, and alert the security team if an instance has an Elastic IP address associated with it.
  • B. Attach an 1AM policy to the developers' 1AM group to deny associate-address permissions Create a custom AWS Config rule to check whether an Elastic IP address is associated with any instance tagged as production, and alert the security team
  • C. Use Amazon Athena to query AWS CloudTrail logs to check for any associate-address attempts Create an AWS Lambda function to disassociate the Elastic IP address from the instance, and alert the security team.
  • D. Ensure that all 1AM groups associated with developers do not have associate-address permissions.
    Create a scheduled AWS Lambda function to check whether an Elastic IP address is associated with any instance tagged as production, and alert the secunty team if an instance has an Elastic IP address associated with it
To prevent developers from unintentionally attaching an Elastic IP address to an Amazon EC2 instance in production, the best approach is to use IAM policies and AWS Config rules. By attaching an IAM policy that denies the associate-address permission to the developers' IAM group, you ensure that developers cannot perform this action. Additionally, creating a custom AWS Config rule to check for Elastic IP addresses associated with instances tagged as production provides ongoing monitoring. If the rule detects an Elastic IP address, it can trigger an alert to notify the security team. This method is proactive and enforces the necessary permissions while also providing a mechanism for detection and notification. References: from Amazon DevOps sources
NEW QUESTION # 178
A company has a guideline that every Amazon EC2 instance must be launched from an AMI that the company's security team produces Every month the security team sends an email message with the latest approved AMIs to all the development teams.
The development teams use AWS CloudFormation to deploy their applications. When developers launch a new service they have to search their email for the latest AMIs that the security department sent. A DevOps engineer wants to automate the process that the security team uses to provide the AMI IDs to the development teams.
What is the MOST scalable solution that meets these requirements?
  • A. Direct the security team to use Amazon EC2 Image Builder to create new AMIs and to place the AMI ARNs as parameters in AWS Systems Manager Parameter Store Instruct the developers to specify a parameter of type SSM in their CloudFormation stack to obtain the most recent AMI ARNs from Parameter Store.
  • B. Direct the security team to use CloudFormation to create new versions of the AMIs and to list! the AMI ARNs in an encrypted Amazon S3 object as part of the stack's Outputs Section Instruct the developers to use a cross-stack reference to load the encrypted S3 object and obtain the most recent AMI ARNs.
  • C. Direct the security team to use Amazon EC2 Image Builder to create new AMIs and to create an Amazon Simple Notification Service (Amazon SNS) topic so that every development team can receive notifications. When the development teams receive a notification instruct them to write an AWS Lambda function that will update their CloudFormation stack with the most recent AMI ARNs.
  • D. Direct the security team to use a CloudFormation stack to create an AWS CodePipeline pipeline that builds new AMIs and places the latest AMI ARNs in an encrypted Amazon S3 object as part of the pipeline output Instruct the developers to use a cross-stack reference within their own CloudFormation template to obtain the S3 object location and the most recent AMI ARNs.
https://docs.aws.amazon.com/AWSC ... mic-references.html
NEW QUESTION # 179
For most users, access to the relevant qualifying examinations may be the first, so many of the course content related to qualifying examinations are complex and arcane. According to these ignorant beginners, the DOP-C02 Exam Questions set up a series of basic course, by easy to read, with corresponding examples to explain at the same time, the AWS Certified DevOps Engineer - Professional study question let the user to be able to find in real life and corresponds to the actual use of learned knowledge, deepened the understanding of the users and memory. Because many users are first taking part in the exams, so for the exam and test time distribution of the above lack certain experience, and thus prone to the confusion in the examination place, time to grasp, eventually led to not finish the exam totally.
Examinations DOP-C02 Actual Questions: https://www.pass4surequiz.com/DOP-C02-exam-quiz.html
BONUS!!! Download part of Pass4SureQuiz DOP-C02 dumps for free: https://drive.google.com/open?id=19L2kwruhn6z8U30y5zrpFo8hUNUZq_BA
Posted at 3/8/2026 23:59:00        Only Author  2#
弊社のAPICSのCPIM-8.0試験問題集を買うかどうかまだ決めていないなら、弊社のデモをやってみよう。使用してから、あなたは弊社の商品でAPICSのCPIM-8.0試験に合格できるということを信じています。我々MogiExamの専門家たちのAPICSのCPIM-8.0試験問題集への更新と改善はあなたに試験の準備期間から成功させます。
Posted at 3/9/2026 21:47:45        Only Author  3#
This article has truly inspired me, thank you for sharing! Boost your IT knowledge with free CSDB new braindumps questions. Wishing you success in your exams!
