[General] Study PDI Tool - Reliable PDI Exam Pattern
119
General Study PDI Tool - Reliable PDI Exam Pattern
Posted at 2/23/2026 06:52:35      View126 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New PDI dumps are available on Google Drive shared by PassTestking: https://drive.google.com/open?id=13ym0nSmXgUTdrrRqjH_EOZgdYM0LR8pk
PassTestking is a real dumps provider that ensure you pass the different kind of IT exam with offering you exam dumps and learning materials. You just need to use your spare time to practice the PDI Real Dumps and remember PDI test answers skillfully, you will clear Salesforce practice exam at your first attempt.
For more info visit:PDI Exam Reference
Study PDI Tool & PassTestking - Leader in Certification Exam Materials & PDI: Platform Developer I (PDI)Our PassTestking is the most reliable backing for every PDI candidate. All study materials required in PDI exam are provided by Our PassTestking. Once you purchased our PDI exam dump, we will try our best to help you Pass PDI Exam. Additionally, our excellent after sales service contains one-year free update service and the guarantee of dump cost full refund if you fail the exam with our dump.
Salesforce Platform Developer I (PDI) Sample Questions (Q43-Q48):NEW QUESTION # 43
An Approval Process is defined in the Expense_Item__c. A business rule dictates that whenever a user changes the Status to 'Submitted' on an Expense_Report__c record, all the Expense_Item__c records related to the expense report must enter the approval process individually. Which approach should be used to ensure the business requirement is met?
  • A. Create two Process Builder, one on Expense_Report__c to mark the related Expense_Item__c as submittable and the second on Expense_Item__c to submit the records for approval.
  • B. Create a Process Builder on Expense_Report__c with a 'Submit for Approval' action type to submit all related Expense_Item__c records when the criteria is met.
  • C. Create a Process Builder on Expense_Report__c with an 'Apex' action type to submit all related Expense_Item__c records when the criteria is met.
  • D. Create a Process Builder on Expense_Report__c to mark the related Expense_Item__c as submittable and trigger on Expense_item__c to submit the records for approval.
NEW QUESTION # 44
A developer must create a DrawList class that provides capabilities defined in the Sortable and Drawable interfaces.
Which is the correct implementation?
  • A. Option D
  • B. Option A
  • C. Option B
  • D. Option C
* Interfaces in Java and Salesforce Apex:
* In Java or Apex, interfaces define a contract that classes must fulfill. They provide method signatures that any implementing class must define.
* The keyword implements is used to implement an interface.
* Classes and Inheritance:
* A class in Java/Apex cannot use extends to inherit from an interface. The extends keyword is reserved for inheriting from another class, while implements is used for interfaces.
* Multiple Interfaces:
* A class can implement multiple interfaces in both Java and Salesforce Apex. This is done by separating interface names with commas after the implements keyword.
Correct Syntax:
To create a DrawList class that implements both Sortable and Drawable interfaces, the syntax must:
* Use implements for interfaces.
* Provide implementations for all methods defined in the interfaces.
Analysis of Options:
* Option A:
* Uses implements for each interface separately, which is syntactically incorrect in Java/Apex.
* Invalid due to redundancy.
* Option B:
* Correctly uses implements for multiple interfaces separated by a comma.
* Provides implementations for both methods, sort() and draw().
* Option C and D:
* Use extends for interfaces, which is invalid. Interfaces cannot be extended by classes.
Final Implementation:
public class DrawList implements Sortable, Drawable {
public void sort() {
// Implementation of sort method
public void draw() {
// Implementation of draw method
* Apex Classes and Interfaces Documentation
* Trailhead Module on Apex Interfaces
Option B is the correct implementation as it adheres to the rules for working with interfaces in Java/Apex.
NEW QUESTION # 45
A developer must write an Apex method that will be called from a Lightning component. The method may delete an Account stored in the accountRec variable.
Which method should a developer use to ensure only users that should be able to delete Accounts can successfully perform deletions?
  • A. accuntRec, sObjectType,isDeletable()
  • B. accountRec, isDeletable()
  • C. Schema,sObjectType,Account, isDeletable ()
  • D. Account,isDeleteable
* Option B: Using Schema.sObjectType.Account.isDeletable() checks if the current user has permission to delete records of the Account object. This approach adheres to Salesforce's security model.
* Not Suitable:
* Option A: accountRec.isDeletable() is not a valid method.
* Option C: Incorrect syntax for checking permissions.
* Option D: Account.isDeletable does not exist.
NEW QUESTION # 46
Universal Containers is building a recruiting app with an Applicant object that stores information about an individual person and a Job object that represents a job. Each applicant may apply for more than one job.
What should a developer implement to represent that an applicant has applied for a job?
  • A. Master-detail field from Applicant to Job
  • B. Junction object between Applicant and Job
  • C. Formula field on Applicant that references Job
  • D. Lookup field from Applicant to Job
* A. Junction object between Applicant and Job:
* Since an Applicant can apply for multiple Jobs and each Job can have multiple Applicants, this is a many-to-many relationship.
* Salesforce requires a junction object to represent many-to-many relationships. The junction object will have two master-detail relationships: one to the Applicant object and one to the Job object.
* The junction object could be named something like JobApplication__c, which would represent the specific instance of an applicant applying for a particular job.
* Why this is the correct approach?
* A junction object allows for robust data management and reporting capabilities in a many-to- many relationship.
* This design ensures that each combination of applicant and job is captured as a unique record in the JobApplication__c junction object.
* It also allows storing additional details about the application, such as application date, status, and feedback.
Why not the other options?
* B. Lookup field from Applicant to Job:
* A lookup field creates a one-to-many relationship. While an Applicant could reference one Job, it does not support the many-to-many relationship required in this scenario.
* C. Master-detail field from Applicant to Job:
* A master-detail relationship is a one-to-many relationship, which is unsuitable for a many-to- many relationship. Additionally, you cannot have two master-detail fields on a single object to connect Applicant and Job directly.
* D. Formula field on Applicant that references Job:
* A formula field cannot establish relationships between records or represent a many-to-many relationship. It is only for computed fields.
* Creating Many-to-Many Relationships with Junction Objects
* Master-Detail and Lookup Relationship Details
NEW QUESTION # 47
A developer working on a time management application wants to make total hours for each timecard available to applications users. A timecard entry has a Master-Detail relationship to a timecard. Which approach should the developer use to accomplish this declaratively?
  • A. An Apex trigger that uses an Aggregate Query to calculate the hours for a given timecard and stores it in a custom field.
  • B. A Process Builder process that updates a field on the timecard entry is created.
  • C. A Roll-up Summary field on the Timecard Object that calculates the total hours from timecard entries for that timecard.
  • D. A visualforce page that calculates the total number of hours for a timecard and displays it on the page.
NEW QUESTION # 48
If you still desperately cram knowledge and spend a lot of precious time and energy to prepare for passing Salesforce certification PDI exam, and at the same time do not know how to choose a more effective shortcut to pass Salesforce Certification PDI Exam. Now PassTestking provide you a effective method to pass Salesforce certification PDI exam. It will play a multiplier effect to help you pass the exam.
Reliable PDI Exam Pattern: https://www.passtestking.com/Salesforce/PDI-practice-exam-dumps.html
Salesforce Study PDI Tool Sometimes, we will also launch some preferential activities to thanks our customers, This will help you evaluate your readiness to take up the Reliable PDI Exam Pattern Certification, as well as judge your understanding of the topics in Software Testing, The PDI test guide is written by lots of past materials rigorous analyses, Salesforce Study PDI Tool But the difficulty of exam questions lower the pass rate.
Traffic match criteria are configured with a class-map statement, To PDI this day, that's my username for nearly everything, Sometimes, we will also launch some preferential activities to thanks our customers.
Free PDF Quiz Salesforce - PDI - Platform Developer I (PDI) Pass-Sure Study ToolThis will help you evaluate your readiness to take up the Salesforce PDI Certification, as well as judge your understanding of the topics in Software Testing, The PDI Test Guide is written by lots of past materials rigorous analyses.
But the difficulty of exam questions lower the pass rate, If they used our PDI test braindumps they had passed exams at first shot and own the certification.
What's more, part of that PassTestking PDI dumps now are free: https://drive.google.com/open?id=13ym0nSmXgUTdrrRqjH_EOZgdYM0LR8pk
