[General] Exam Topics UiPath-ADPv1 Pdf, Certification UiPath-ADPv1 Exam
97
General Exam Topics UiPath-ADPv1 Pdf, Certification UiPath-ADPv1 Exam
Posted at 2/23/2026 07:39:07      View145 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of It-Tests UiPath-ADPv1 dumps for free: https://drive.google.com/open?id=1USwsYcJADBcQJl1B_EAU-B7wQu6FXAl_
The most advantage of our UiPath-ADPv1 exam torrent is to help you save time. It is known to us that time is very important for you. As the saying goes, an inch of time is an inch of gold; time is money. If time be of all things the most precious, wasting of time must be the greatest prodigality. We believe that you will not want to waste your time, and you must want to pass your UiPath-ADPv1 Exam in a short time, so it is necessary for you to choose our UiPath (ADPv1) Automation Developer Professional prep torrent as your study tool. If you use our products, you will just need to spend 20-30 hours to take your exam.
The UiPath-ADPv1 prep torrent we provide will cost you less time and energy. You only need relatively little time to review and prepare. After all, many people who prepare for the UiPath-ADPv1 exam, either the office workers or the students, are all busy. But the UiPath-ADPv1 test prep we provide are compiled elaborately and it makes you use less time and energy to learn and provide the UiPath-ADPv1 Study Materials of high quality and seizes the focus the UiPath-ADPv1 exam. It lets you master the most information and costs you the least time and energy.
{Online Realistic} UiPath UiPath-ADPv1 Practice Test QuestionsWe are amenable to offer help by introducing our UiPath-ADPv1 real exam materials and they can help you pass the UiPath (ADPv1) Automation Developer Professional practice exam efficiently. All knowledge is based on the real exam by the help of experts. By compiling the most important points of questions into our UiPath-ADPv1 guide prep our experts also amplify some difficult and important points. Being devoted to this area for over ten years, our experts keep the excellency of our UiPath (ADPv1) Automation Developer Professional exam question like always. They are distinguished experts in this area who can beef up your personal capacity. By cutting through the clutter of tremendous knowledge, they picked up the essence into our UiPath-ADPv1 Guide prep.
UiPath UiPath-ADPv1 Exam Syllabus Topics:
  • UiPath Studio Fundamentals: In this section, the focus is given to the understanding of Robotic Process Automation (RPA) concepts; it covers UiPath Studio and its components, Working with the UiPath user interface, project creation, management, and version control.
  • Design and Development: This section covers designing workflows using sequences, flowcharts, and state machines, building reusable components with libraries, exception handling and debugging techniques, etc.
  • Debugging and Testing: This section is about utilizing logging and debugging tools and adopting unit testing and test automation strategies.
  • UiPath Activities: In this section, the discussion is related to various UiPath activities for UI interaction, data manipulation, control flow, and more.
UiPath (ADPv1) Automation Developer Professional Sample Questions (Q32-Q37):NEW QUESTION # 32
Which of the following is an accurate example of using LINQ for querying data in a UiPath process?
  • A. Applying LINQ to find duplicates in a list of integers by writing:
    listOflntegers.FindDuplicates().ToList()
  • B. Utilizing LINQ to sort DataTable rows based on a specific column by writing:
    dataTable.OrderBy(Function(x) x.ToString).CopyToDataTable()
  • C. Using LINQ to filter a list of strings containing only "UiPath" by writing:
    listOfStrings.Where(Function(x) x = "UiPath").ToList()
  • D. Executing LINQ to merge two DataTables by writing:
    dataTable1.Merge(dataTable2).CopyToDataTable()
LINQ stands for Language-Integrated Query, which is a set of features that allows you to query data from different sources using a common syntax1. In UiPath, you can use LINQ to query data from collections, such as lists, arrays, or dictionaries, or from data tables, such as Excel or CSV files2.
Option D is an accurate example of using LINQ for querying data in a UiPath process, because it uses the Where method to filter a list of strings based on a condition, and returns the result as a new list. The condition is that the string must be equal to "UiPath", which is specified by the lambda expression Function(x) x = "UiPath". The ToList method converts the query result into a list type3.
The other options are not accurate examples of using LINQ for querying data in a UiPath process, because they either use methods that are not part of LINQ, or use LINQ for purposes other than querying data. For example:
Option A uses a custom method FindDuplicates, which is not a standard LINQ method, and does not specify a lambda expression to define the query criteria4.
Option B uses LINQ to sort data table rows, which is not a querying operation, and does not use the Field method to access the column values5.
Option C uses the Merge method, which is a data table method, not a LINQ method, and does not use any query expression at all.
1: What is LINQ? - C# | Microsoft Docs 2: LINQ - UiPath Activities 3: Enumerable.Where Method (System.Linq) | Microsoft Docs 4: How to find duplicates in a list using LINQ - Stack Overflow 5: How to use LINQ on a DataTable in Uipath - Stack Overflow : DataTable.Merge Method (System.Data) | Microsoft Docs
NEW QUESTION # 33
Suppose you have the following workflow that verifies if the text value of an element is equal to "Work Items":
The configuration for the Verify Control Attribute and Get Text activities is shown below:
The element and its selector are highlighted in the image below:
Taking into consideration that the page shown above will be present on screen at execution time, what will be the result of the Verify Control Attribute activity?
  • A. Verification will be failed because the actual value is different than expected value.
  • B. Verification will not be executed.
  • C. An exception will be thrown because there is no variable set in the Save to property of the Get text activity.
  • D. Verification will be passed.
The workflow in question uses a 'Verify Control Attribute' activity to check if the text value of a UI element is equal to "Work Items". The Get Text activity is used to retrieve the text from the specified UI element, and the result of this activity is compared against the expected value "Work Items".
From the provided information, the 'Verify Control Attribute' activity has been set up with the Expression
"Work Items" and the Operator set to Equality. The 'Get Text' activity is configured to extract the text from the UI element with the visible text "Work Items", as indicated by the selector shown in the image.
Since the actual value of the UI element's text is "Work Items" (which matches the expected value in the
'Verify Control Attribute' activity), and provided that the 'Get Text' activity successfully retrieves this value, the verification will pass. The configuration indicates that the activity should take a screenshot only if the verification fails (TakeScreenshotIfFailed is set to True), which will not be the case here.
Therefore, assuming that there are no other issues such as incorrect selectors or unexpected changes to the UI element at execution time, the result of the 'Verify Control Attribute' activity will be a pass.
UiPath Documentation: Verify Control Attribute Activity
NEW QUESTION # 34
A developer extracts a date from an email. The date will always be In the same format and always from the past. Some examples of this format are: "3 Mar 2023". "20 Nov 2021". The name of the variable where the date is saved is DateString What expression should the developer use to check If the extracted date is within the last 7 days?
  • A. DateTime Parse(DateTime Now - DateString) Days < 7
  • B. (DateTime.Now - DateTime.ParseExact(DateString. "dd MMM yyyy". Culturelnfo.lnvariantCulture)).
    Days < 7
  • C. (DateTime.Now - DateTime.ParseExact(DateStrlng, "d MMM yyyy". Culturelnfo.lnvariantCulture)).
    Days < 7
  • D. (DateTime.Now - DateTime.ParseExact(DateStnng. *dd MMM yyyyH. Culturelnfo.lnvariantCulture)).
    AddDays(-7) > 0
* The date is in the format "d MMM yyyy" (e.g., "3 Mar 2023").
* The correct expression is: (DateTime.Now - DateTime.ParseExact(DateString, "d MMM yyyy", CultureInfo.InvariantCulture)).Days < 7.
* This expression calculates the difference in days between the current date (DateTime.Now) and the parsed date (DateTime.ParseExact(DateString, "d MMM yyyy", CultureInfo.InvariantCulture)).
* It then checks if this difference is less than 7 days, which means the date is within the last 7 days.
NEW QUESTION # 35
A developer has created a variable of type List of Strings named "Users_List", and initialized it with an empty list: "Users_List = new List(Of String)".
What is printed in the log message after the following Invoke Code is executed?
  • A. System Argument Exception is thrown
  • B. Object reference not set to an instance exception is thrown
  • C. 0
  • D. 1
The screenshot shows an "Invoke Code" activity in UiPath with the following VB.NET code:
Users_List.Add("User1")
Users_List.Add("User2")
According to the given information, the "Users_List" variable is a List of Strings that has been initialized with an empty list before the Invoke Code activity is run. The code within the Invoke Code activity is adding two strings: "User1" and "User2" to the "Users_List".
The Log Message activity following the Invoke Code is attempting to log the count of items in "Users_List", which would be the number of elements contained in the list at that time.
Given the steps that have been described, after the Invoke Code activity has run, the "Users_List" will contain two elements ("User1" and "User2"). Therefore, the log message will print the count of items in the list, which is:
B:2
So the correct answer is B, as the "Users_List" will have two elements and Users_List.Count will return the number 2.
The Invoke Code activity is used to execute VB.NET or C# code within a UiPath workflow1. The activity has the following properties:
* Code: The code that is to be executed. This field supports only strings and String variables1.
* Language: The language that the code is written in. The available options are VBNet and CSharp1.
* Arguments: The parameters that can be passed to and from the code1.
In this question, the developer has created a variable of type List of Strings named "Users_List", and initialized it with an empty list: "Users_List = new List(Of String)". Then, the developer has used the Invoke Code activity to execute the following code:
Users_List.Add("User1") Users_List.Add("User2")
This code adds two items ("User1" and "User2") to the "Users_List" variable. After the Invoke Code activity, the developer has used the Log Message activity to print the count of items in the "Users_List" variable, using the expression "Users_List.Count.ToString". This expression returns the number of items in the list as a string2. Therefore, the log message will print "2", as there are two items in the list
NEW QUESTION # 36
Which command in the UiPath installation folder configures the UIPath.RemoteDebugging.Agent utility on a Windows robot to accept remote debugging requests from Studio?
  • A. UiPath-RemoteDebuqqinq.Aqent.exe enable -port -password -verbose
  • B. UiPath.RemoteDebuqqinq.Aqent.exe enable -port -username -password -verbose
  • C. UiPath.RemoteDebuqqinq.Aqent.exe start -port -password -verbose
  • D. dotnet ./UiPath.RemoteDebuqqinq.Aqent.dll enable -port -password -verbose
The command in the UiPath installation folder that configures the UIPath.RemoteDebugging.Agent utility on a Windows robot to accept remote debugging requests from Studio is UiPath-RemoteDebugging.Agent.exe enable -port -password -verbose. This command enables the remote debugging agent on the robot machine and sets the port number and the password that are required for the connection. The verbose option enables the logging of the agent activity to the console. The remote debugging agent is a utility that allows you to debug workflows on a remote robot from Studio, by using the Remote Debugging feature. This feature enables you to connect to a remote robot, run the workflow, and inspect the variables and arguments in real time. To use this feature, you need to install the remote debugging agent on the robot machine and configure it with the same port number and password that you use in Studio. References: [Remote Debugging], [Remote Debugging Agent]
NEW QUESTION # 37
Our product is revised and updated according to the change of the syllabus and the latest development situation in the theory and the practice. The UiPath-ADPv1 Exam Torrent is compiled elaborately by the experienced professionals and of high quality. The contents of UiPath-ADPv1 guide questions are easy to master and simplify the important information. It conveys more important information with less answers and questions, thus the learning is easy and efficient. The language is easy to be understood makes any learners have no obstacles.
Certification UiPath-ADPv1 Exam: https://www.it-tests.com/UiPath-ADPv1.html
P.S. Free & New UiPath-ADPv1 dumps are available on Google Drive shared by It-Tests: https://drive.google.com/open?id=1USwsYcJADBcQJl1B_EAU-B7wQu6FXAl_
