[General] Quiz CompTIA - 220-1201 - CompTIA A+ Certification Exam: Core 1 Updated Detailed
97
General Quiz CompTIA - 220-1201 - CompTIA A+ Certification Exam: Core 1 Updated Detailed
Posted at 2/23/2026 07:43:34      View147 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New 220-1201 dumps are available on Google Drive shared by DumpsFree: https://drive.google.com/open?id=1XuC1EVSMUKG-9465hXrj_GQxjLj6KWiU
Do you want to gain all these 220-1201 certification exam benefits? Looking for the quick and complete CompTIA 220-1201 exam dumps preparation way that enables you to pass the 220-1201 certification exam with good scores? If your answer is yes then you are at the right place and you do not need to go anywhere. Just download the DumpsFree 220-1201 Questions and start CompTIA 220-1201 exam preparation without wasting further time.
Our 220-1201 Exam Questions can help you pass the exam to prove your strength and increase social competitiveness. Although it is not an easy thing for somebody to pass the 220-1201 exam, but our 220-1201 exam torrent can help aggressive people to achieve their goals. This is the reason why we need to recognize the importance of getting the test CompTIA certification. More qualified certification for our future employment has the effect to be reckoned with, only to have enough qualification certifications to prove their ability, can we win over rivals in the social competition.
Quiz CompTIA - 220-1201 CThe Best Detailed AnswersAccording to our investigation, the test syllabus of the 220-1201 exam is changing every year. Some new knowledge will be added into the annual real exam. Some old knowledge will be deleted. So you must have a clear understanding of the test syllabus of the 220-1201 study engine. Now, you can directly refer to our 220-1201 study materials. Because we have been in the field for over ten years and we are professional in this career. We can always offer the most updated information to our loyal customers.
CompTIA A+ Certification Exam: Core 1 Sample Questions (Q211-Q216):NEW QUESTION # 211
A customer is upgrading an engineering workstation with multiple video cards and storage drives.
Which of the following should the customer consider first when identifying a new power supply?
  • A. Output voltage
  • B. Connector quantity
  • C. Input voltage
  • D. Wattage rating
When upgrading a system with multiple video cards and storage drives, the total power consumption increases significantly. The power supply must have a sufficient wattage rating to handle the combined load of all components to ensure system stability and prevent power-related failures.
NEW QUESTION # 212
A customer needs to install a new printer in their network. The customer reports that users had intermittent connectivity issues with previous printers. Which of the following should the technician configure on the new printer to prevent this issue?
  • A. DHCP IP address
  • B. Public IP address
  • C. Gateway IP address
  • D. Static IP address
Intermittent connectivity issues with network printers are commonly caused by changing IP addresses when using DHCP. Assigning a static IP address ensures that the printer is always reachable at the same IP address by client machines.
#Reference: "CompTIA A+ Complete Study Guide" by Quentin Docter - Chapter 4, "Printers and Multifunction Devices", page 241.
NEW QUESTION # 213
A user joins a conference call with a Bluetooth headset. Which of the following has the user created?
  • A. SAN
  • B. PAN
  • C. MAN
  • D. WAN
B). PAN (Personal Area Network):
A PAN is a network established between devices in close proximity, such as between a smartphone and a Bluetooth headset.
Bluetooth technology is specifically designed for short-range communication, making it a type of PAN.
Incorrect Options:
A). MAN (Metropolitan Area Network): A MAN covers a city or metropolitan area and is not relevant to Bluetooth connections.
C). SAN (Storage Area Network): A SAN is used for large-scale data storage, unrelated to Bluetooth connections.
D). WAN (Wide Area Network): A WAN spans large geographical areas (e.g., the internet) and is not relevant to this scenario.
Key Takeaway: Bluetooth connections, such as those between a headset and a device, create a Personal Area Network (PAN).
Reference: CompTIA A+ Core 1 Exam Objectives (220-1201), Domain 2.1 - Network types and their features.
NEW QUESTION # 214
Which of the following ports should a technician disable to increase the security of remote connectivity?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
Port 23 is used by Telnet, an unencrypted remote connection protocol that poses significant security risks. Disabling Telnet and using secure alternatives like SSH (port 22) is best practice.
NEW QUESTION # 215
Which of the following is related to the creation of a secured communication channel between workstations in different locations and is supported by credentials for authentication?
  • A. CNAME
  • B. DHCP
  • C. VLAN
  • D. VPN
A Virtual Private Network (VPN) creates an encrypted, secure tunnel across a public or untrusted network. It uses authentication credentials to ensure that only authorized users can connect, keeping data safe from interception.
NEW QUESTION # 216
Never stop challenging your limitations. If you want to dig out your potentials, just keep trying. Repeated attempts will sharpen your minds. Maybe our 220-1201 study materials are suitable for you. We strongly advise you to have a brave attempt. You will own a wonderful experience after you learning our 220-1201 Study Materials. Our study materials are different from common study materials, which can motivate you to concentrate on study.
220-1201 Reliable Test Questions: https://www.dumpsfree.com/220-1201-valid-exam.html
220-1201 Exam Questions in this CompTIA 220-1201 practice test are similar to the real test, You will be more successful with our 220-1201 braindump, As you know, our 220-1201 practice exam has a vast market and is well praised by customers, CompTIA 220-1201 Detailed Answers Of course, our company is keeping up with the world popular trend, You can also request us provide you with latest 220-1201 braindumps pdf at any time.
Adaptable Functors and Function Adapters, It was a simple toe infection, 220-1201 Exam Questions in this CompTIA 220-1201 practice test are similar to the real test.
You will be more successful with our 220-1201 braindump, As you know, our 220-1201 practice exam has a vast market and is well praised by customers, Of course, our company is keeping up with the world popular trend.
Three Formats of DumpsFree CompTIA 220-1201 Practice QuestionsYou can also request us provide you with latest 220-1201 braindumps pdf at any time.
2026 Latest DumpsFree 220-1201 PDF Dumps and 220-1201 Exam Engine Free Share: https://drive.google.com/open?id=1XuC1EVSMUKG-9465hXrj_GQxjLj6KWiU
