¡¾General¡¿
First-grade Exam CDCS Testking¨CPass CDCS First Attempt
Posted at 2/23/2026 08:19:55
View£º120
Replies£º0
BONUS!!! Download part of Pass4Test CDCS dumps for free: https://drive.google.com/open?id=1S3PWBWoDDNfGBIGDENeEG0isH739VibX
Although we have three versions of our CDCS exam braindumps: the PDF, Software and APP online, i do think the most amazing version is the APP online. This version of our CDCS study materials can be supportive to offline exercise on the condition that you practice it without mobile data. So even trifling mistakes can be solved by using our CDCS Practice Questions, as well as all careless mistakes you may make.
EXIN CDCS Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Data Centre Environmental Considerations and Efficiency: This section evaluates the proficiency of data center professionals in addressing environmental factors and promoting efficiency within data center operations. The target audience, including data center managers and engineers, will be tested on their ability to identify and implement measures that enhance energy efficiency, cooling management, and sustainable practices.
| | Topic 2 | - Data Centre Life Cycle and Standards: This section of the exam measures the skills of data center professionals and covers the various stages involved in the life cycle of a data center, from planning and design to implementation and decommissioning.
| | Topic 3 | - Designing and Implementing a Data Centre: In this module, the exam assesses the knowledge of Exin data center professionals tasked with the design and implementation of data centers. Candidates will learn the key principles of creating an efficient data center layout, including considerations for scalability, redundancy, and security.
EXIN CDCS Practice Test - The Key To Fast ExamAbout the oncoming CDCS exam, every exam candidates are wishing to utilize all intellectual and technical skills to solve the obstacles ahead of them to go as well as it possibly could. So the pending exam causes a panic among the exam candidates. The CDCS exam prepare of our website is completed by experts who has a good understanding of real exams and have many years of experience writing CDCS Study Materials. They know very well what candidates really need most when they prepare for the exam. They also understand the real exam situation very well. So they compiled CDCS exam prepare that they hope to do their utmost to help candidates pass the exam and get what job they want.
EXIN EPI Certified Data Centre Specialist Sample Questions (Q25-Q30):NEW QUESTION # 25
Given: A = attenuation in dB, R = real measured value, M = maximum acceptable value. Which formula should be used to calculate the required attenuation factor of EMF shielding material?
- A. A = 20 log (R/M)
- B. A = 10 log (M/R)
- C. A = 20 log (M/R)
- D. A = 10 log (R/M)
Attenuation is the logarithmic ratio between input and output signals. For power, we use 10 log; for voltage or current, 20 log. Since EMF shielding is measured as field strength (V/m or A/m), power relationship is proportional to the square of field. Thus the correct attenuation calculation for shielding effectiveness is:
A black text on a white background AI-generated content may be incorrect.
where:
* M = maximum permissible field strength
* R = measured field strength after shielding
This ensures the shield reduces field intensity to below allowable limits.
References: IEEE Std 299 (Shielding Effectiveness Measurement), IEC 61000-5-7 (EMC mitigation).
NEW QUESTION # 26
Which of the following statements is correct?
- A. With current decreasing, three-phase cables emit more EMF than single-phase cables
- B. With voltage increasing, single-phase cables emit more EMF than three-phase cables
- C. With voltage decreasing, three-phase cables emit more EMF than single-phase cables
- D. With current increasing, single-phase cables emit more EMF than three-phase cables
Electromagnetic field (EMF) strength around cables is primarily influenced by current, not voltage. In a single-phase system, the live and neutral conductors are separated, creating a larger magnetic loop area. This produces stronger stray EMF when current increases.
In a balanced three-phase system, the magnetic fields from the three conductors largely cancel each other out, resulting in much lower net EMF, even at higher currents.
Therefore, the correct statement is that increasing current in single-phase cables produces higher EMF compared to three-phase cables. Options B, C, and D incorrectly link EMF to voltage or incorrect current behavior.
References: IEEE Std 141 (Red Book - Power Distribution), IEC 61000-5-7 (EMF mitigation guidelines), ANSI/TIA-942-B ¡ì6.6.
NEW QUESTION # 27
When designing a data center network, your company wants to minimize the number of network switches to manage.
What type of physical cabling layout would be the best choice?
- A. ToR (Top of Rack) design
- B. It does not matter as the number of switches is not influenced by the physical cabling layout
- C. EoR (End of Row) design
- D. Star network design using coaxial cables
An End of Row (EoR) design minimizes the number of network switches, as multiple racks can share a single switch at the end of a row, reducing switch counts and simplifying management. This design centralizes network switching to fewer points, which reduces the complexity and number of switches required compared to a Top of Rack (ToR) design, where each rack typically has its own switch.
Detailed Explanation:
In EoR designs, each row has a single network switch that handles the connections for all racks within that row. This reduces the number of individual switches needed and centralizes network management, which is ideal for minimizing equipment and simplifying infrastructure in the data center.
EPI Data Center Specialist References:
EPI promotes the EoR design as a way to reduce switch counts and streamline management in data centers. This configuration allows for easier scaling and maintenance while maintaining efficient network connectivity.
NEW QUESTION # 28
A new facility requires electrical distribution of 100A to be installed in the computer room, 1 m (3 ft) above sensitive IT equipment. What type of system minimizes EMF impact?
- A. Install bus bar trunking
- B. Install single-phase power cabling
- C. Install three-phase power cabling based on a combined cable (e.g., XLPE)
- D. Install three-phase power cabling based on three individual core wires
Electromagnetic fields are generated by current-carrying conductors. To minimize stray EMF, phase conductors should be physically close and balanced. A three-phase combined cable (all phase conductors and neutral in one sheath) ensures magnetic fields cancel each other due to phase opposition.
If phases are run separately (answer B), the separation increases loop area and magnetic field leakage. Single- phase cabling (A) is even worse because current does not balance across three phases. Bus bar trunking (C) provides physical support but often separates conductors, which may worsen EMF if not specifically shielded.
Therefore, the correct solution is three-phase combined cable (often XLPE-insulated). This design reduces EMF impact to within ANSI/TIA-942 and IEEE recommendations.
References: IEEE Std 141 (Red Book - Power Distribution), ANSI/TIA-942-B ¡ì6.6.4, IEC 60364 (Wiring Systems and EMF).
NEW QUESTION # 29
What should you consider when using raised floor tiles with air deflectors or louvers?
- A. Tiles with air deflectors or louvers will reduce the cooling capacity of the tile.
- B. Tiles with air deflectors or louvers do not allow for a flexible cooling solution.
- C. Tiles with air deflectors or louvers can be very heavy.
- D. Tiles with air deflectors or louvers can only be used to cool storage equipment.
Raised floor tiles with air deflectors or louvers are typically heavier than standard tiles due to the additional materials and mechanisms used to direct airflow. The added weight can pose challenges for installation and adjustment, and consideration must be given to the floor's load capacity and ease of maintenance.
Tiles with deflectors or louvers help direct airflow, enhancing cooling efficiency by focusing cool air where needed. However, these tiles are often heavier, which can affect handling and require reinforced raised floor systems. It's essential to factor in the weight for any floor tile replacements or installations to ensure they are compatible with the raised floor's structural capacity.
EPI data center design training mentions the potential impact of heavy tiles on floor handling and load capacity. Data center operators need to plan for safe handling and load-bearing capacity when using such specialized tiles.
NEW QUESTION # 30
Our EXIN CDCS practice exam software will record all the attempts you have made in the past and display any modifications or improvements made in each attempt. This EXIN EPI Certified Data Centre Specialist (CDCS) exam simulation software enables you to track your progress and quantify how much you have improved.
CDCS Latest Study Notes: https://www.pass4test.com/CDCS.html
- New CDCS Test Bootcamp 👪 CDCS Exams Dumps 🌵 Exam CDCS Lab Questions 🎲 Search on ¡° [url]www.practicevce.com ¡± for ¡¾ CDCS ¡¿ to obtain exam materials for free download 🤰CDCS Interactive Course[/url]
- CDCS Interactive Course ☂ Exam CDCS Lab Questions 🅰 Exam CDCS Guide Materials 🏏 Open website ⇛ [url]www.pdfvce.com ⇚ and search for ¡¾ CDCS ¡¿ for free download 🖤CDCS Study Guide[/url]
- CDCS Interactive Course 🦥 New Study CDCS Questions 👏 CDCS Related Certifications 🦜 The page for free download of ⮆ CDCS ⮄ on ✔ [url]www.practicevce.com ️✔️ will open immediately 🦓CDCS New Study Notes[/url]
- EXIN CDCS Dumps- Accessible On Any Device 🐄 Search for ➥ CDCS 🡄 and download it for free on ⇛ [url]www.pdfvce.com ⇚ website 🎐New CDCS Test Testking[/url]
- CDCS VCE dumps - CDCS preparation labs - CDCS VCE files 💸 Search for ¡° CDCS ¡± on ▶ [url]www.vce4dumps.com ◀ immediately to obtain a free download 😮Braindumps CDCS Downloads[/url]
- Free PDF Quiz Unparalleled EXIN - CDCS - Exam EXIN EPI Certified Data Centre Specialist Testking 🕠 Search for ▷ CDCS ◁ and download it for free immediately on ➥ [url]www.pdfvce.com 🡄 😁CDCS Latest Test Cram[/url]
- EXIN CDCS Dumps- Accessible On Any Device 🔑 Search on { [url]www.troytecdumps.com } for ➤ CDCS ⮘ to obtain exam materials for free download 🟡New CDCS Test Notes[/url]
- CDCS Pass-Sure Dumps - CDCS Exam Dumps - CDCS Exam Simulator 😋 The page for free download of ▛ CDCS ▟ on ➡ [url]www.pdfvce.com ️⬅️ will open immediately 🙃CDCS Interactive Course[/url]
- CDCS VCE dumps - CDCS preparation labs - CDCS VCE files 🔴 Open website ⏩ [url]www.practicevce.com ⏪ and search for £¨ CDCS £© for free download 🥭CDCS Exams Dumps[/url]
- CDCS Study Guide 🍇 Test CDCS Simulator 🐌 CDCS Interactive Course 🦩 Copy URL ¡° [url]www.pdfvce.com ¡± open and search for £¨ CDCS £© to download for free 🥂CDCS Interactive Course[/url]
- Exam CDCS Lab Questions 🤺 Test CDCS Simulator 💐 CDCS Related Certifications 😂 Easily obtain ⏩ CDCS ⏪ for free download through ➡ [url]www.examcollectionpass.com ️⬅️ 🦔CDCS Latest Test Cram[/url]
- ncertclass.com, wedacareer.com, www.stes.tyc.edu.tw, softbyte.com.np, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
DOWNLOAD the newest Pass4Test CDCS PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1S3PWBWoDDNfGBIGDENeEG0isH739VibX
