[Hardware] New Microsoft AZ-104 Exam Preparation, AZ-104 Exam Discount
101
Hardware New Microsoft AZ-104 Exam Preparation, AZ-104 Exam Discount
Posted at 2/23/2026 08:26:07      View136 | Replies0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Exam-Killer AZ-104 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=16DigmkJ0Roa-0mr_-ju1n5u4au1C5aG4
One of the most important functions of our AZ-104 preparation questions are that can support almost all electronic equipment. If you want to prepare for your exam by the computer, you can buy our AZ-104 training quiz. Of course, if you prefer to study by your mobile phone, our study materials also can meet your demand. You just need to download the online version of our AZ-104 Preparation questions. We can promise that the online version will not let you down. We believe that you will benefit a lot from it if you buy our AZ-104 study materials and pass the AZ-104 exam easily.
Through all these years' experience, our AZ-104 training materials are becoming more and more prefect. Moreover, we hold considerate after-sales services and sense-and-respond tenet all these years. So if you get any questions of our AZ-104 learning guide, please get us informed. It means we will deal with your doubts with our AZ-104 practice materials 24/7 with efficiency and patience.
Help You Learn, Prepare, and Practice for AZ-104 exam successYou can get 365 days of free AZ-104 real dumps updates and free demos. Save your time and money. Start Microsoft AZ-104 exam preparation with AZ-104 actual dumps. Our firm provides real, up-to-date, and expert-verified Microsoft Azure Administrator AZ-104 Exam Questions. We make certain that consumers pass the Microsoft Azure Administrator AZ-104 certification exam on their first attempt. Furthermore, we want you to trust the Microsoft Azure Administrator AZ-104 practice questions that we created.
Microsoft Azure Administrator Sample Questions (Q213-Q218):NEW QUESTION # 213
You need to configure the alerts for VM1 and VM2 to meet the technical requirements.
Which three actions should you perform in sequence? To answer, move all actions from the list of actions to the answer area and arrange them in the correct order.
NEW QUESTION # 214
You have an Azure subscription that contains an Azure Kubernetes Service (AKS) cluster named Cluster1. Cluster1 hosts a node pool named Pool1 that has four nodes. You need to perform a coordinated upgrade of Cluster1. The solution must meet the following requirements:
* Deploy two new nodes to perform the upgrade.
* Minimize costs.
How should you complete the command
Answer below
NEW QUESTION # 215
You have an Azure subscription named Subscription1. Subscription1 contains a virtual machine named VM1.
You install and configure a web server and a DNS server on VM1.
VM1 has the effective network security rules shown in the following exhibit.
Box 1:
Rule2 blocks ports 50-60, which includes port 53, the DNS port. Internet users can reach the Web server, since it uses port 80.
Box 2:
If Rule2 is removed internet users can reach the DNS server as well.
Note: Rules are processed in priority order, with lower numbers processed before higher numbers, because lower numbers have higher priority. Once traffic matches a rule, processing stops. As a result, any rules that exist with lower priorities (higher numbers) that have the same attributes as rules with higher priorities are not processed.
https://docs.microsoft.com/en-us ... k/security-overview
NEW QUESTION # 216
You need to add VM1 and VM2 to the backend poo! of LB1. What should you do first?
  • A. Redeploy VM1 and VM2 to the same availability set.
  • B. Connect VM2 to VNET1/Subnet1.
  • C. Redeploy VM1 and VM2 to the same availability zone.
  • D. Create a new NSG and associate the NSG to VNET1/Subnet1.
NEW QUESTION # 217
You plan to create an Azure Storage account named storage1 that will contain a file share named share1.
You need to ensure that share1 can support SMB Multichannel. The solution must minimize costs.
How should you configure storage?
  • A. Premium performance with geo-redundant storage (GRS)
  • B. Standard performance with locally-redundant storage (LRS)
  • C. Standard performance with zone-redundant storage (ZRS)
  • D. Premium performance with locally-redundant storage (LRS)
According to documentation only Premium file shares (FileStorage), LRS/ZRS are supported for SMB.
https://learn.microsoft.com/en-u ... channel-performance
NEW QUESTION # 218
The Microsoft Azure Administrator (AZ-104) exam questions can help you gain the high-in-demand skills and credentials you need to pursue a rewarding career. To do this you just need to pass the Microsoft Azure Administrator (AZ-104) certification exam which is not easy to crack. You have to put in some extra effort, and time and prepare thoroughly to pass the Microsoft Azure Administrator (AZ-104) exam. For the quick, complete, and comprehensive Microsoft Azure Administrator (AZ-104) exam dumps preparation you can get help from top-notch and easy-to-use AZ-104 Questions.
AZ-104 Exam Discount: https://www.exam-killer.com/AZ-104-valid-questions.html
Microsoft New AZ-104 Exam Preparation Our company has accumulated many experiences after ten years development, Microsoft New AZ-104 Exam Preparation Our products are updated on daily basis, If you do not pass the Microsoft AZ-104 exam (Microsoft Azure Administrator) on your first attempt using our Exam-Killer testing engine, we will give you a FULL REFUND of your purchasing fee, The system can automatically send you an email which includes the installation package of the AZ-104 training material.
What we need is something in between, All these variants AZ-104 due to our customer-oriented tenets, Our company has accumulated many experiences after ten years development.
Our products are updated on daily basis, If you do not pass the Microsoft AZ-104 exam (Microsoft Azure Administrator) on your first attempt using our Exam-Killer testing engine, we will give you a FULL REFUND of your purchasing fee.
Pass Microsoft AZ-104 Exam and Get Certified with EaseThe system can automatically send you an email which includes the installation package of the AZ-104 training material, Why do you try our AZ-104 dumps free?
BTW, DOWNLOAD part of Exam-Killer AZ-104 dumps from Cloud Storage: https://drive.google.com/open?id=16DigmkJ0Roa-0mr_-ju1n5u4au1C5aG4
