[General] 最實用的H12-821_V1.0認證考古試題及參考答案
【General】 最實用的H12-821_V1.0認證考古試題及參考答案
Posted at yesterday 12:50      View:20 | Replies:0        Print      Only Author   [Copy Link] 1#
順便提一下,可以從雲存儲中下載Fast2test H12-821_V1.0考試題庫的完整版:https://drive.google.com/open?id=1J0ojFjqYcwJrRTAFZk7PAZJQZhQYpJ-O
你是可以免費下載Fast2test為你提供的部分關於Huawei H12-821_V1.0認證考試練習題及答案的作為嘗試,那樣你會更有信心地選擇我們的Fast2test的產品來準備你的Huawei H12-821_V1.0 認證考試。快將我們Fast2test的產品收入囊中吧。
您選擇我們的Fast2test來幫助你通過Huawei H12-821_V1.0 認證考試試是一個明智的選擇。你可以先線上免費下載Fast2test為你提供的關於Huawei H12-821_V1.0 認證考試練習題及答案的試用版本作為嘗試,那樣你會更有信心選擇我們Fast2test的產品來準備Huawei H12-821_V1.0 認證考試。如果你考試失敗,我們會全額退款給你。
Huawei 最新H12-821_V1.0考證和Fast2test - 保證認證成功,簡便的培訓方式眾所周知,H12-821_V1.0認證在IT認證中有很大的影響力,近年來,該認證已經成為許多成功IT公司的“進門”標準。想快速通過認證考試,可以選擇我們的Huawei H12-821_V1.0考古題。選擇我們Fast2test網站,您不僅可以通過熱門的H12-821_V1.0考試,而且還可以享受我們提供的一年免費更新服務。擁有Huawei H12-821_V1.0認證可以幫助在IT領域找工作的人獲得更好的就業機會,也將會為成功的IT事業做好鋪墊。
最新的 HCIP-Datacom H12-821_V1.0 免費考試真題 (Q1186-Q1191):問題 #1186
Which of the following parameters are not mandatory during the configuration of a BGP peer?
  • A. Peer IP address
  • B. description
  • C. as-number
  • D. password
答案:B,D
解題說明:
The mandatory parameters for BGP peer configuration are the peer IP address (peer ip-address) and AS number (as-number). A password is optional for MD5 authentication, and a description is an optional comment for reference. These are not required for establishing the peer relationship .
問題 #1187
Which of the following descriptions about Filter-Policy are correct? (Multiple choice)
  • A. In the distance vector protocol, because routing information is passed between devices, Filter-Policy can directly
  • B. Filtering In the link state routing protocol, the routing table is generated through the LSDB, so Filter- Policy essentially filters the LSA in the LSDB
  • C. Filter-Policy can be used on both OSPFv2 and OSPFv3
  • D. In the distance vector protocol, if you want to filter out the route from the upstream device to the downstream device, you need to configure filter-policy export on the downstream device.
答案:A,C
問題 #1188
In addition to a route reflector, the confederation is another method that reduces the number of IBGP connections in an AS.
Which of the following statements are true about the confederation technology? (Choose all that apply)
  • A. This technology is applicable to large-scale networks.
  • B. All member devices in a confederation need to be reconfigured.
  • C. The logical topology does not need to be changed when a confederation is used.
  • D. Special EBGP connections are established among sub-ASs in a confederation, and the sub-ASs need to be fully meshed.
答案:A,C,D
解題說明:
A is correct- Confederations arespecifically designed for large-scale BGP deploymentswhere a full IBGP mesh is impractical.
B is correct- Sub-ASs within a confederation establishEBGP-like connectionsbetween each other but behave like IBGP within the overall AS. These sub-ASsdo not require full-mesh inside the confederation, but EBGP rules are followed between sub-ASs.
C is false-Not all devices need to be reconfigured. Devices within the same sub-AS retain normal IBGP behavior and minimal changes.
D is correct- Confederation istransparent to external peers, so thelogical topology remains the samefrom outside the AS.
Reference from Huawei HCIP-Datacom-Core Technology Study Guide:
"BGP confederation divides an AS into multiple sub-ASs. EBGP-like sessions are established between sub- ASs, while reducing IBGP mesh complexity. The external AS still sees the AS as one unit." (Chapter: BGP Scalability Enhancements - Section: Confederation)
問題 #1189
BGP prefers the route with the best Origin attribute value. The Origin attribute value is: (), IGP, Incomplete.
答案:
解題說明:
EGP
問題 #1190
In an IPv4 address space, Class D addresses are used for multicast. Among Class D addresses, which of the following is the permanent group address range reserved for routing protocols?
  • A. 224.0.0.0 to 224.0.0.255
  • B. 224.0.1.0 to 231.255.255.255
  • C. 239.0.0.0 to 239.255.255.255
  • D. 232.0.0.0 to 232.255.255.255
答案:A
解題說明:
Permanent Group Addresses for Routing Protocols
* The range 224.0.0.0 to 224.0.0.255 is reserved for local network protocols, including routing protocols.
Examples include OSPF (224.0.0.5/6) and RIP (224.0.0.9).
HCIP-Datacom-Core Reference
* Reserved multicast address ranges are detailed in the multicast configuration sections.
問題 #1191
你已經看到Fast2test Huawei的H12-821_V1.0考試認證培訓資料,是時候做出選擇了,你甚至可以選擇其他的產品,不過你要知道我們Fast2test帶給你的無限大的利益,也只有Fast2test能給你100%保證成功,Fast2test能讓你有個美好的前程,讓你以後在IT行業有更寬廣的道路可以走,高效率的工作在資訊技術領域。
H12-821_V1.0考題: https://tw.fast2test.com/H12-821_V1.0-premium-file.html
本系在師生的努力之下,目前已有陳先生等四百位考生取得H12-821_V1.0證照,過多的將時間和精力花費在記錄上,只會影響我們練習H12-821_V1.0問題集的效率,Fast2testのH12-821_V1.0考古題是你成功的捷徑,順利通過H12-821_V1.0考試是每一位考生都十分期待的,因為這是開啟我們職業生涯的前提條件,對於那部分看了答案之後才能找出思路的H12-821_V1.0考題,很多時候我們並沒有進行深刻的思考,這樣的話,我們對這些考題就很難做到真正的掌握,我們的線上服務是研究資料,它包含類比訓練題,和Huawei H12-821_V1.0認證考試相關的考試練習題和答案,我們的所有產品還不定期推出折扣優惠活動,給考生提供最有效的Huawei H12-821_V1.0考試學習資料,所有考生都知道我們的Huawei H12-821_V1.0考古題產品可以幫助您快速掌握考試知識點,無需參加其它的培訓課程,就可以保證您高分通過H12-821_V1.0考試。
如何使公司重回正軌,哥,妳不是會算嗎,本系在師生的努力之下,目前已有陳先生等四百位考生取得H12-821_V1.0證照,過多的將時間和精力花費在記錄上,只會影響我們練習H12-821_V1.0問題集的效率,Fast2testのH12-821_V1.0考古題是你成功的捷徑。
高效的Huawei 最新H12-821_V1.0考證是行業領先材料&最佳的H12-821_V1.0:HCIP-Datacom-Core Technology V1.0順利通過H12-821_V1.0考試是每一位考生都十分期待的,因為這是開啟我們職業生涯的前提條件,對於那部分看了答案之後才能找出思路的H12-821_V1.0考題,很多時候我們並沒有進行深刻的思考,這樣的話,我們對這些考題就很難做到真正的掌握。
此外,這些Fast2test H12-821_V1.0考試題庫的部分內容現在是免費的:https://drive.google.com/open?id=1J0ojFjqYcwJrRTAFZk7PAZJQZhQYpJ-O
