[Hardware] CInP學習筆記 - CInP題庫更新
【Hardware】 CInP學習筆記 - CInP題庫更新
Posted at 8 hour before      View:16 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. KaoGuTi在Google Drive上分享了免費的2026 GInI CInP考試題庫:https://drive.google.com/open?id=1iNsf9abQxAYtc0pe-ssM0CYpRibMv0cP
KaoGuTi是個能夠加速你通過GInI CInP認證考試的網站。我們的GInI CInP 認證考試的考古題是KaoGuTi的專家不斷研究出來的。當你還在為通過GInI CInP 認證考試而奮鬥時,選擇KaoGuTi的GInI CInP 認證考試的最新考古題將給你的復習備考帶來很大的幫助。
手上能拿到一些實用的認證證書,無疑為自己的就業開拓了一番新的領土和創造了一些機會。CInP 是全球最大的網絡設備公司 GInI 公司的認可的初級技術認證,在整個 GInI 認證體系中處于售前規劃方向的基礎證書,有了CInP 認證你的平均年薪將不低于10萬人民幣。雖然獲取 CInP 認證需要投入額外的時間與金錢,但事實證明IT認證的投入產出是值得的,對於未來的職業發展非常有利。
一流的GInI CInP:Certified Innovation Professional (CInP)學習筆記 - 確保通過的KaoGuTi CInP題庫更新CInP考試是IT行業的當中一個新的轉捩點,你將成為IT行業的專業高端人士,隨著資訊技術的普及和進步,你們會看到有數以計百的線上資源,提供GInI的CInP考題和答案,而KaoGuTi卻遙遙領先,人們選擇KaoGuTi是因為KaoGuTi的GInI的CInP考試培訓資料真的可以給人們帶來好處,能幫助你早日實現你的夢想!
最新的 GInI Professional CInP 免費考試真題 (Q121-Q126):問題 #121
As a Project Leader, the Innovation Manager typically drives focused innovation work inside of a portfolio of projects.
Select one correct answer from the list:
  • A. Individual projects
  • B. Secret skunkworks projects that few know about
  • C. The business' innovation program
  • D. A portfolio of projects
答案:D
解題說明:
GInI'sCInP Handbookoutlines the role of an Innovation Manager as a Project Leader who oversees multiple innovation efforts, typically organized within a "portfolio of projects." This portfolio approach allows the manager to prioritize, resource, and drive focused work across various initiatives, balancing risk and reward.
Option A, "secret skunkworks projects," refers to secretive, isolated efforts, which might be part of a portfolio but isn't the typical scope of an Innovation Manager's role. Option C, "individual projects," is too narrow, as GInI emphasizes a broader oversight rather than singular focus. Option D, "the business' innovation program," is too high-level; the program encompasses the portfolio, but the manager's direct responsibility is the projects within it. The portfolio framework enables strategic management of innovation efforts, aligning with GInI's guidance on project leadership. The original answer (B) is correct and reinforced by GInI documentation.
問題 #122
In selecting new ideas in Stage 3 of the GInI InMS, the organization must make every effort possible to use real data in their decision-making, as this forces them to accept reality as it really is.
  • A. Make fiscally conservative assumptions
  • B. Accept reality as it really is
  • C. Choose whichever ideas they feel will sell the most
  • D. Fall back on statistics, which they can easily frame to their needs
答案:B
解題說明:
GInI'sCInP Handbookstresses that in InMS Stage 3, idea selection relies on "real data" (e.g., market research, prototypes) to ground decisions in evidence, forcing the organization to "accept reality as it really is"-not wishful thinking or bias. This ensures viable, impactful projects advance, aligning with GInI's data-driven ethos. "Fiscally conservative assumptions" (A) adds unnecessary caution, not GInI's intent. "Fall back on statistics" (C) suggests manipulation, against GInI's integrity. "Choose ideas that sell" (D) prioritizes intuition over evidence. Option B matches GInI's principle, aligning with the original answer, reflecting a reality-based filter that enhances innovation success-a GInI hallmark of disciplined creativity.
Reference:GInICInP Handbook, Section on InMS Stage 3 Data-Driven Selection.
問題 #123
Because "The Researcher" has a propensity to research all the possible go-to-market strategies and evaluate the supporting intelligence around those, they are usually best suited for which phase of innovation work?
  • A. The Back End
  • B. The Front End
  • C. All phases
  • D. The Mid Zone
答案:D
解題說明:
GInI'sCertified Innovation Professional (CInP) Handbookidentifies "The Researcher" as an archetype within its innovation team framework, characterized by a strong inclination toward deep analysis, data collection, and evaluation of strategic options. The question highlights their focus on researching "go-to-market strategies" and "supporting intelligence," which aligns directly with the Mid Zone of GInI's three-phase innovation process (Front End, Mid Zone, Back End). The Mid Zone, as detailed in the handbook, is where teams validate concepts, develop business cases, and assess market entry strategies-tasks requiring the Researcher's analytical prowess to sift through data, evaluate feasibility, and refine plans (e.g., market sizing, competitive analysis). The Front End (D) focuses on needfinding and ideation, where creativity trumps research depth. The Back End (B) shifts to execution (production, launch), leveraging planning over analysis.
"All phases" (C) dilutes the Researcher's specific fit, as their skills peak in the Mid Zone's structured validation. GInI's archetype mapping positions the Researcher here for their ability to bridge exploration to execution with evidence-based insights. The original answer (A) is correct, reflecting GInI's deliberate phase- specific role alignment-a nuanced design ensuring each archetype maximizes impact within the innovation lifecycle.
問題 #124
Wizard of Oz Prototypes are prototypes used to emulate the automated functionality of an artifact even though said functionality happens as a result of a person making it happen manually behind the scenes.
  • A. Looks-Like Prototypes
  • B. Works-Like Prototypes
  • C. User Experience Prototypes
  • D. Wizard of Oz Prototypes
答案:D
解題說明:
GInI'sCInP Handbookdefines "Wizard of Oz Prototypes" as simulations where a system appears automated, but a human manually operates it behind the scenes-e.g., a chatbot mimicked by a typist-to test user interaction without full development. This low-fidelity method, named after the story's deceptive wizard, validates concepts early. "User Experience Prototypes" (A) is broad, not specific. "Looks-Like Prototypes" (B) focus on appearance, not function. "Works-Like Prototypes" (D) demonstrate real mechanics, not illusions. Option C matches GInI's terminology, aligning with the original answer, embodying a clever, resource-efficient prototyping strategy-a GInI hallmark for rapid validation.
Reference:GInICInP Handbook, Section on Prototyping Types.
問題 #125
Stage 3 of the GInI InMS is focused on evaluating and selecting new ideas for conversion into Innovation Projects.
  • A. Evaluating and selecting new ideas for conversion into Innovation Projects
  • B. Focusing the organization's ideation efforts
  • C. Helping the organization feel innovative
  • D. Capturing and accumulating new ideas
答案:A
解題說明:
GInI'sCInP Handbookdefines Stage 3 of the Innovation Management System (InMS) as the evaluation and selection phase, where ideas from the Funnel (Stage 1) and refinement (Stage 2) are assessed for merit and chosen to become "Innovation Projects." This involves criteria like feasibility, value, and alignment, transitioning concepts into structured efforts. "Capturing and accumulating" (A) is Stage 1. "Focusing ideation efforts" (B) is Stage 2. "Helping the organization feel innovative" (D) is an outcome, not a focus. Option C matches GInI's description, aligning with the original answer, embodying a rigorous, decision-making process that filters creativity into actionable innovation-a critical GInI gatekeeping function.
問題 #126
突然發現,很多人對自己未來的所有計劃都有同一個開頭——等我有了錢……但是,IT認證考試不能等。如果你覺得購買 GInI 的 CInP 考試培訓資料利用它來準備考試是一場冒險,那麼整個生命就是一場冒險,走得最遠的人常常就是願意去做願意去冒險的人。而 KaoGuTi 的 CInP 考資料根據最新的考試動態變化而更新,會在第一時間更新 CInP 題庫。
CInP題庫更新: https://www.kaoguti.com/CInP_exam-pdf.html
要獲得GInI CInP題庫更新 CInP題庫更新證書,必須通過自己選擇的認證途徑上的兩次考試,GInI CInP學習筆記 您可以立即下載,並馬上投入學習,首先,我們需要對出售CInP問題集的商家有一定的了解:他們在業界是否有一定的聲譽,KaoGuTi GInI的CInP考試培訓資料是每個參加IT認證的考生們的必需品,有了這個培訓資料,他們就可以做足了充分的考前準備,也就有了足足的把握來贏得考試,許多題庫和培訓材料的供應商為考生提供保證通過CInP認證考試的題庫產品,而與所有的網站相比,我們網站的CInP考試題庫是好評最高、最受歡迎的,我們用事實說話,讓見證奇跡的時刻來證明我們所說的每一句話,KaoGuTi提供的培訓材料包括GInI CInP 認證考試的類比測試軟體和相關類比試題,練習題和答案。
妳能聽見爹在說話嗎,諸葛鏡微微頓了頓,要獲得GInI GInI Professional證書,必須通過自己選擇的認證途徑上的兩次考試,您可以立即下載,並馬上投入學習,首先,我們需要對出售CInP問題集的商家有一定的了解:他們在業界是否有一定的聲譽?
使用優秀的CInP學習筆記確保您通過您的GInI CInP考試KaoGuTi GInI的CInP考試培訓資料是每個參加IT認證的考生們的必需品,有了這個培訓資料,他們就可以做足了充分的考前準備,也就有了足足的把握來贏得考試,許多題庫和培訓材料的供應商為考生提供保證通過CInP認證考試的題庫產品,而與所有的網站相比,我們網站的CInP考試題庫是好評最高、最受歡迎的,我們用事實說話,讓見證奇跡的時刻來證明我們所說的每一句話。
