[General] Training Operations-Management Materials, Operations-Management Printable PDF
【General】 Training Operations-Management Materials, Operations-Management Printable PDF
Posted at 7 hour before      View:23 | Replies:0        Print      Only Author   [Copy Link] 1#
In your day-to-day life, things look like same all the time, but preparing for critical Operations-Management practice exam is not one of those options. About the exam ahead of you this time, our Operations-Management study braindumps will be your indispensable choices. Before you get the official one, you can estimate our quality by downloading the free demos. They are all masterpieces from processional experts and all content are accessible and easy to remember, so no need to spend a colossal time to practice on them. Just practice with our Operations-Management Exam Guide on a regular basis and desirable outcomes will be as easy as a piece of cake. On some tricky questions, you don't need to think too much. Only you memorize our questions and answers of Operations-Management study braindumps, you can pass exam simply.
In order to meet the upcoming Operations-Management exam, we believe you must be anxiously searching for relevant test materials. After all, it may be difficult to pass the exam just on your own, so we're honored you can see this message today because our Operations-Management Guide quiz can solve your problems. Since inception, our company has devoted itself to studying the proposition outlines of various examinations so as to design materials closely to the contents of these Operations-Management exams.
2026 WGU Authoritative Training Operations-Management MaterialsThere is a high demand for WGU Development certification, therefore there is an increase in the number of WGU Operations-Management exam candidates. Many resources are available on the internet to prepare for the WGU Operations Management (C215, VDC2) exam. TestSimulate is one of the best certification exam preparation material providers where you can find newly released WGU Operations-Management Dumps for your exam preparation. With years of experience in compiling top-notch relevant WGU Operations-Management dumps questions, we also offer the WGU Operations-Management practice test (online and offline) to help you get familiar with the actual exam environment.
WGU Operations Management (C215, VDC2) Sample Questions (Q14-Q19):NEW QUESTION # 14
How do just-in-time (JIT) and lean systems add value?
  • A. By reducing waste
  • B. By improving lighting
  • C. By enhancing responsibility
  • D. By increasing simplicity
Just-in-time (JIT) and lean systems add valueby reducing wasteacross all operational processes.
Lean Operations define value strictly from thecustomer's perspective. Any activity that does not add value to the product or service is considered waste (muda). JIT and lean systems systematically identify and eliminate this waste to improve efficiency, quality, and responsiveness.
Common types of waste targeted include:
* Overproduction
* Waiting time
* Excess inventory
* Unnecessary motion
* Transportation
* Defects and rework
* Overprocessing
By reducing waste, organizations achieve:
* Shorter lead times
* Lower costs
* Improved quality
* Greater flexibility
Options such as improving lighting or enhancing responsibility may support efficiency indirectly but do not define the core value mechanism of JIT and lean systems. Increasing simplicity is a result of waste reduction, not the primary method.
Operations Management emphasizes waste elimination as the foundation of sustainable operational excellence, making optionCthe correct answer.
NEW QUESTION # 15
The annual cost of goods sold for a company is $8,400,000 and the average inventory is $1,200,000.
What is the number of weeks of supply?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
  • E. 4
Weeks of supplymeasures how long inventory will last based on average usage. It is calculated using the formula:
Weeks of Supply = (Average Inventory / Annual Cost of Goods Sold) × 52
Substituting the given values:
Weeks of Supply = (1,200,000 / 8,400,000) × 52
Weeks of Supply = 0.142857 × 52
Weeks of Supply #7.43 weeks
When rounded to the nearest whole number, the answer is7 weeks.
In Operations and Supply Chain Management, weeks of supply is a key inventory performance metric because it:
* Indicates inventory efficiency
* Helps balance service levels and holding costs
* Supports cash flow management
* Enables comparison across products or firms
Too many weeks of supply signal excess inventory and high holding costs, while too few weeks increase the risk of stockouts and service failures.
Managers use this metric alongside inventory turnover to evaluate how effectively inventory supports demand while minimizing waste.
NEW QUESTION # 16
Which capacity planning measurement tells how much capacity a company is using?
  • A. Design capacity
  • B. Effective capacity
  • C. Capacity focus
  • D. Capacity utilization
Comprehensive and Detailed Explanation (#250 words):
Capacity utilizationmeasures how much of a company's available capacity is actually being used.
It is calculated as:
Capacity Utilization = Actual Output / Design or Effective Capacity
In Operations Management, capacity utilization provides insight into:
* Operational efficiency
* Resource usage
* Potential bottlenecks or underutilization
High utilization may indicate efficiency but can also lead to congestion, fatigue, and quality problems. Low utilization suggests excess capacity and higher unit costs.
The other terms describe different concepts:
* Design capacityis the maximum theoretical output
* Effective capacityaccounts for normal disruptions
* Capacity focusrefers to strategic specialization
Capacity utilization helps managers balance efficiency with flexibility, making it a core performance metric in both manufacturing and service operations.
NEW QUESTION # 17
Which role do third-party logistics providers play in the supply chain?
  • A. External distributors
  • B. Internal distributors
  • C. Tier three distributors
  • D. Tier two distributors
Third-party logistics (3PL) providers act asexternal distributorsin the supply chain.
They perform logistics functions such as:
* Transportation
* Warehousing
* Distribution
* Order fulfillment
These providers operate outside the firm but integrate closely with its operations. Organizations use 3PLs to:
* Reduce capital investment
* Increase flexibility
* Access logistics expertise
* Improve service levels
Operations Management recognizes outsourcing logistics as a strategic decision that allows firms to focus on core competencies while maintaining efficient distribution networks.
NEW QUESTION # 18
A company manufactures shoes using a quality management system. The company needs to put a process in place to measure any defects. The company would like to measure the number of defects and observe the number of occurrences to isolate the particular defect. Which quality tool should the company use to focus on correcting this particular issue?
  • A. Scatter diagram
  • B. Flowchart
  • C. Control chart
  • D. Checklist
Achecklistis the most appropriate quality tool when the objective is tocount defects and track their frequency of occurrence.
Checklists are simple yet powerful tools used tocollect structured data consistently. In this scenario, the shoe manufacturer wants to identify which defects occur most frequently (e.g., stitching errors, sole defects, size mismatches). A checklist allows inspectors to mark each occurrence systematically, enabling later analysis.
Why not the others?
* Scatter diagramsanalyze relationships between variables.
* Control chartsmonitor process stability over time.
* Flowchartsdocument process steps.
In Operations Management, checklists are often thefirst stepin defect analysis. Once data is gathered using a checklist, other tools like Pareto charts or control charts can be applied for deeper analysis.
Checklists support continuous improvement by:
* Ensuring consistency in inspections
* Reducing human error
* Providing factual data for decision-making
* Enabling root-cause analysis
They are especially useful in early-stage quality investigations where the goal isvisibility, not yet process control. By identifying dominant defects, organizations can prioritize corrective actions efficiently.
NEW QUESTION # 19
There are WGU Operations Management (C215, VDC2) (Operations-Management) exam questions provided in WGU Operations Management (C215, VDC2) (Operations-Management) PDF questions format which can be viewed on smartphones, laptops, and tablets. So, you can easily study and prepare for your WGU Operations Management (C215, VDC2) (Operations-Management) exam anywhere and anytime. You can also take a printout of these WGU PDF Questions for off-screen study.
Operations-Management Printable PDF: https://www.testsimulate.com/Operations-Management-study-materials.html
Anyway, what I want to tell you that our Operations-Management exam questions can really help you pass the exam faster, WGU Training Operations-Management Materials This may be the best chance to climb the top of your life, Just browser our websites and choose a suitable Operations-Management practice guide for you, Our Operations-Management guide torrent will be your best assistant to help you gain your certificate, WGU Purchasing Operations-Management WGU online interactive exam engine and Braindump's Operations-Management video lectures online because these are the best products right now available in the market and due to their brilliance and trust you must use If you need high quality tools for preparing yourself for the Operations-Management WGU WGU Operations Management (C215, VDC2).
Whether it is light coming through tree leaves, a paper Operations-Management bag in a subway trash can, or raindrops on a windshield, everything can form or be perceived as a pattern.
Behavior binds the structure of objects to their attributes and relationships so that objects can meet their responsibilities, Anyway, what I want to tell you that our Operations-Management Exam Questions can really help you pass the exam faster.
Pass-Sure WGU Training Operations-Management Materials Offer You The Best Printable PDF | WGU Operations Management (C215, VDC2)This may be the best chance to climb the top of your life, Just browser our websites and choose a suitable Operations-Management practice guide for you, Our Operations-Management guide torrent will be your best assistant to help you gain your certificate.
