100% Pass Splunk SPLK-2002 - Splunk Enterprise Certified Architect First-grade N
Posted at 7 hour before
BONUS!!! Download part of TorrentValid SPLK-2002 dumps for free: https://drive.google.com/open?id=17rtHYdiLyg66Yv953B8Nx1MjUb3NjTx8
Comparing to other training institution, our valid SPLK-2002 vce dumps are affordable, latest and cost-effective, which can overcome the difficulty of valid SPLK-2002 Actual Test and ensure you pass the exam. It can not only save your time and money, but also help you clear Splunk practice exam with high rate.
The SPLK-2002 Exam covers a wide range of topics, including data collection, search creation, data visualization, and user management. Candidates will be tested on their ability to configure data inputs, create knowledge objects, and optimize search performance. They will also need to demonstrate their knowledge of advanced features such as distributed search, indexer clustering, and high availability.
SPLK-2002 New Exam Bootcamp - 100% Pass Quiz SPLK-2002 Splunk Enterprise Certified Architect First-grade Vce FormatPassing the SPLK-2002 exam is your best career opportunity. The rich experience with relevant certificates is important for enterprises to open up a series of professional vacancies for your choices. Our website's SPLK-2002 learning quiz bank and learning materials look up the latest questions and answers based on the topics you choose. This choice will serve as a breakthrough of your entire career, so prepared to be amazed by high quality and accuracy rate of our SPLK-2002 Study Guide.
Passing the SPLK-2002 exam demonstrates that a professional has the expertise required to design, deploy, and manage large-scale Splunk deployments. It also shows that they are capable of optimizing Splunk performance, ensuring data security and compliance, and solving complex problems that may arise in Splunk environments.
Before taking the SPLK-2002 Certification Exam, candidates must first earn the Splunk Certified Administrator certification. This prerequisite ensures that candidates have a solid understanding of Splunk's core features and functionality. Candidates should also have experience designing and deploying Splunk environments in complex enterprise environments.
Splunk Enterprise Certified Architect Sample Questions (Q184-Q189):NEW QUESTION # 184
A multi-site indexer cluster can be configured using which of the following? (Select all that apply.)
- A. Directly edit SPLUNK_HOME/etc/system/default/server.conf
- B. Via Splunk Web.
- C. Run a Splunk edit cluster-config command from the CLI.
- D. Directly edit SPLUNK_HOME/etc./system/local/server.conf
A multi-site indexer cluster can be configured by directly editing
SPLUNK_HOME/etc/system/local/server.conf or running a splunk edit cluster-config command from the CLI.
These methods allow the administrator to specify the site attribute for each indexer node and the site_replication_factor and site_search_factor for the cluster. Configuring a multi-site indexer cluster via Splunk Web or directly editing SPLUNK_HOME/etc/system/default/server.conf are not supported methods.
For more information, see Configure the indexer cluster with server.conf in the Splunk documentation.
NEW QUESTION # 185
Which of the following will cause the greatest reduction in disk size requirements for a cluster of N indexers running Splunk Enterprise Security?
- A. Increasing the number of buckets per index.
- B. Setting the cluster search factor to N-1.
- C. Setting the cluster replication factor to N-1.
- D. Decreasing the data model acceleration range.
Decreasing the data model acceleration range will reduce the disk size requirements for a cluster of indexers running Splunk Enterprise Security. Data model acceleration creates tsidx files that consume disk space on the indexers. Reducing the acceleration range will limit the amount of data that is accelerated and thus save disk space. Setting the cluster search factor or replication factor to N-1 will not reduce the disk size requirements, but rather increase the risk of data loss. Increasing the number of buckets per index will also increase the disk size requirements, as each bucket has a minimum size. For more information, see Data model acceleration and Bucket size in the Splunk documentation.
NEW QUESTION # 186
(Which indexes.conf attribute would prevent an index from participating in an indexer cluster?)
- A. site_mappings = default_mapping
- B. available_sites = none
- C. repFactor = auto
- D. repFactor = 0
The repFactor (replication factor) attribute in the indexes.conf file determines whether an index participates in indexer clustering and how many copies of its data are replicated across peer nodes.
When repFactor is set to 0, it explicitly instructs Splunk to exclude that index from participating in the cluster replication and management process. This means:
* The index is not replicated across peer nodes.
* It will not be managed by the Cluster Manager.
* It exists only locally on the indexer where it was created.
Such indexes are typically used for local-only storage, such as _internal, _audit, or other custom indexes that store diagnostic or node-specific data.
By contrast:
* repFactor=auto allows the index to inherit the cluster-wide replication policy from the Cluster Manager.
* available_sites and site_mappings relate to multisite configurations, controlling where copies of the data are stored, but they do not remove the index from clustering.
Setting repFactor=0 is the only officially supported way to create a non-clustered index within a clustered environment.
References (Splunk Enterprise Documentation):
* indexes.conf Reference - repFactor Attribute Explanation
* Managing Non-Clustered Indexes in Clustered Deployments
* Indexer Clustering: Index Participation and Replication Policies
* Splunk Enterprise Admin Manual - Local-Only and Clustered Index Configurations
NEW QUESTION # 187
Which search head cluster component is responsible for pushing knowledge bundles to search peers, replicating configuration changes to search head cluster members, and scheduling jobs across the search head cluster?
- A. Deployer
- B. Master
- C. Captain
- D. Deployment server
The captain is the search head cluster component that is responsible for pushing knowledge bundles to search peers, replicating configuration changes to search head cluster members, and scheduling jobs across the search head cluster. The captain is elected from among the search head cluster members and performs these tasks in addition to serving search requests. The master is the indexer cluster component that is responsible for managing the replication and availability of data across the peer nodes. The deployer is the standalone instance that is responsible for distributing apps and other configurations to the search head cluster members. The deployment server is the instance that is responsible for distributing apps and other configurations to the deployment clients, such as forwarders
NEW QUESTION # 188
Which Splunk server role regulates the functioning of indexer cluster?
- A. Deployer
- B. Master Node
- C. Monitoring Console
- D. Indexer
The master node is the Splunk server role that regulates the functioning of the indexer cluster. The master node coordinates the activities of the peer nodes, such as data replication, data searchability, and data recovery. The master node also manages the cluster configuration bundle and distributes it to the peer nodes. The indexer is the Splunk server role that indexes the incoming data and makes it searchable. The deployer is the Splunk server role that distributes apps and configuration updates to the search head cluster members. The monitoring console is the Splunk server role that monitors the health and performance of the Splunk deployment. For more information, see About indexer clusters and index replication in the Splunk documentation.
NEW QUESTION # 189
Vce SPLK-2002 Format: https://www.torrentvalid.com/SPLK-2002-valid-braindumps-torrent.html
- Guaranteed SPLK-2002 Questions Answers 💞 SPLK-2002 Reliable Exam Guide 🧳 New SPLK-2002 Exam Vce 🎽 Easily obtain free download of ▛ SPLK-2002 ▟ by searching on “ [url]www.prep4sures.top ” ⚡SPLK-2002 Test Tutorials[/url]
- Exam SPLK-2002 Experience ♣ SPLK-2002 Reliable Exam Guide ↔ Latest SPLK-2002 Exam Tips 👖 Search on ➡ [url]www.pdfvce.com ️⬅️ for ➠ SPLK-2002 🠰 to obtain exam materials for free download 🎽Reliable SPLK-2002 Test Tutorial[/url]
- SPLK-2002 Study Dumps 🗨 Valid Exam SPLK-2002 Book 💲 SPLK-2002 PDF Questions 🪁 Search for ⮆ SPLK-2002 ⮄ and download it for free on ➡ [url]www.prepawaypdf.com ️⬅️ website 🌁SPLK-2002 Study Dumps[/url]
- 100% Pass 2026 Pass-Sure Splunk SPLK-2002: Splunk Enterprise Certified Architect New Exam Bootcamp 🍻 Search for ( SPLK-2002 ) on ☀ [url]www.pdfvce.com ️☀️ immediately to obtain a free download 🕔SPLK-2002 Practice Test Pdf[/url]
- 100% Pass 2026 Pass-Sure Splunk SPLK-2002: Splunk Enterprise Certified Architect New Exam Bootcamp 🔂 ➥ [url]www.torrentvce.com 🡄 is best website to obtain [ SPLK-2002 ] for free download 🤛Authorized SPLK-2002 Certification[/url]
- Training SPLK-2002 Kit 📜 SPLK-2002 Reliable Study Guide 🍮 Valid Exam SPLK-2002 Book 🎺 Open ⏩ [url]www.pdfvce.com ⏪ and search for ▶ SPLK-2002 ◀ to download exam materials for free 🦓Exam SPLK-2002 Experience[/url]
- SPLK-2002 PDF Questions 🧷 Latest SPLK-2002 Exam Tips ✋ SPLK-2002 Reliable Study Guide 📐 Download ▛ SPLK-2002 ▟ for free by simply searching on [ [url]www.prep4away.com ] 🤨Reliable SPLK-2002 Test Tutorial[/url]
- Authorized SPLK-2002 Pdf 👲 SPLK-2002 Exam Engine 📥 SPLK-2002 Reliable Study Guide 🎸 Search for ➡ SPLK-2002 ️⬅️ and easily obtain a free download on ➽ [url]www.pdfvce.com 🢪 ⚗Authorized SPLK-2002 Pdf[/url]
- Exam Dumps SPLK-2002 Free 🔵 Latest SPLK-2002 Exam Tips 🛬 Latest SPLK-2002 Exam Tips 🏞 Simply search for ➽ SPLK-2002 🢪 for free download on 「 [url]www.exam4labs.com 」 🍢SPLK-2002 Practice Test Pdf[/url]
- 100% Pass 2026 Pass-Sure Splunk SPLK-2002: Splunk Enterprise Certified Architect New Exam Bootcamp 🥭 Search on ▷ [url]www.pdfvce.com ◁ for { SPLK-2002 } to obtain exam materials for free download 🐈Reliable SPLK-2002 Test Tutorial[/url]
- 100% Pass 2026 Pass-Sure Splunk SPLK-2002: Splunk Enterprise Certified Architect New Exam Bootcamp 🕓 Open website [ [url]www.examcollectionpass.com ] and search for ➡ SPLK-2002 ️⬅️ for free download 🛂SPLK-2002 Exam Reference[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
What's more, part of that TorrentValid SPLK-2002 dumps now are free: https://drive.google.com/open?id=17rtHYdiLyg66Yv953B8Nx1MjUb3NjTx8
