[General] Salesforce Plat-Con-201 Sample Test Online | Plat-Con-201 Pdf Dumps
【General】 Salesforce Plat-Con-201 Sample Test Online | Plat-Con-201 Pdf Dumps
Posted at yesterday 15:28      View:18 | Replies:0        Print      Only Author   [Copy Link] 1#
What kind of services on the Plat-Con-201 training engine can be considered professional, you will have your own judgment. We will give you the most professional answers on the Plat-Con-201 practice engine in the first time. But I would like to say that our Plat-Con-201 Study Materials must be the most professional of the Plat-Con-201 exam simulation you have used. Our experts who compiled them are working on the subject for years.
Hence, if you want to sharpen your skills, and get the Salesforce Certified Omnistudio Consultant (Plat-Con-201) certification done within the target period, it is important to get the best Salesforce Certified Omnistudio Consultant (Plat-Con-201) exam questions. You must try PrepAwayETE Salesforce Certified Omnistudio Consultant (Plat-Con-201) practice exam that will help you get the Salesforce Plat-Con-201 certification.
Updated Salesforce Plat-Con-201 Sample Test Online | Try Free Demo before PurchaseWe at PrepAwayETE give you the techniques and resources to make sure you get the most out of your exam study. We provide preparation material for the Salesforce Certified Omnistudio Consultant exam that will guide you when you sit to study for it. Plat-Con-201 updated questions give you enough confidence to sit for the Salesforce exam.If you take enough practice tests on Plat-Con-201 Practice Exam software by PrepAwayETE, you’ll be more comfortable when you walk in on Salesforce exam day. So, go with Plat-Con-201 exam questions that are prepared under the supervision of industry experts to expand your knowledge base and successfully pass the certification exam on the first attempt.
Salesforce Certified Omnistudio Consultant Sample Questions (Q104-Q109):NEW QUESTION # 104
A consultant has a project with the following requirement: "Agents need to follow a standard customer greeti.... script in order to ensure brand consistency." Which OmniScript element should the consultant recommend to ensure the agents can see and follow these standard scripts?
  • A. Input Block
  • B. Headline
  • C. Step
  • D. Text Area
The consultant should recommend using a Headline element to ensure the agents can see and follow these standard scripts. A Headline element can display a text message with an icon and a color, such as blue for information or yellow for warning. The consultant can use a Headline element to show the customer greeting script in the OmniScript, and instruct the agents to read it aloud
NEW QUESTION # 105
A company is creating a FlexCard for agents to respond to account inquiries. The company has decided to lim actions on the card to the three most frequent and important actions users typically take.
Based on the user analysis exhibit shown below, which three actions should appear on the card?
Choose 3 answers
  • A. Request higher limit
  • B. View statements
  • C. Verify a transaction
  • D. View credit score history
  • E. Make a payment
Answer: A,C,E
Based on the user analysis exhibit, the three actions that should appear on the card are: verify a transaction, request higher limit, and make a payment. These actions have the highest frequency and importance scores among the six actions listed. The other actions, such as view credit score history, view statements, and view rewards, have lower frequency and importance scores, and can be accessed through other means
NEW QUESTION # 106
A Salesforce Omnistudio Consultant is working on a project to automate a complex business process for a client. The consultant decides to use an Omniscript to guide users through the process.
What is the first step the consultant should take when creating an Omniscript?
  • A. Deploy the script within a Selesforce application
  • B. Define the script in the Omniscript Designer.
  • C. Create a new Selesforce application for the script.
  • D. Test the script on multiple channels and devices.
* Define the script in the OmniScript Designer (D) - The first step in creating an OmniScript is to define it in the OmniScript Designer, where the consultant:
* Outlines the flow of the script (steps, inputs, actions).
* Adds UI elements (text fields, picklists, buttons).
* Configures integration points (DataRaptors, Integration Procedures).
* A. Create a new Salesforce application for the script - This is not required to build an OmniScript.
OmniScripts can be deployed within existing Salesforce applications.
* B. Deploy the script within a Salesforce application - Deployment happens after the script is built and tested, not as the first step.
* C. Test the script on multiple channels and devices - Testing is an important step after building and configuring the script.
Comprehensive and Detailed In-Depth Explanation:Why not the other options?? Salesforce OmniStudio Reference:
* OmniScript Designer Guide
* Creating OmniScripts
NEW QUESTION # 107
A company needs to create an OmniScript with three steps.
* Step 1
* Step 2
* Step 3
Enter customer details
Select a product
Display a price retrieved from a REST API
The product's price should automatically display in Step 3.
What should the consultant add to the design of the OmniScript to meet these requirements?
  • A. DataRaptor Post Action inside Step 2
  • B. Integration Procedure Action inside Step 3
  • C. Integration Procedure Action between Step 2 and Step 3
  • D. DataRaptor Post Action between Step 2 and Step 3
The consultant should add an Integration Procedure Action inside Step 3 to meet the requirements. An Integration Procedure Action can execute an Integration Procedure that invokes a REST API and retrieves the product price. The Integration Procedure Action can be configured to run automatically when Step 3 is loaded, and display the price in a field or label element
NEW QUESTION # 108
A business needs to create a FlexCard to display open cases for an account. The cases should display different depending on their priority.
* Low or Medium priority cases should display case data and an Update Account Info action.
* High priority cases should include a red border, an alert notification, and an Escalate action.
What is the most efficient way to meet these requirements?
  • A. Create two FlexCards with one card state each. Use conditions on the states to filter for priority.
  • B. Create a FlexCard with one card state. Use conditions on the fields and actions to filter for priority.
  • C. Create two FlexCards, one for Low / Medium priority cases and another for High priority cases.
  • D. Create a FlexCard with two card states. Use conditions on the state to filter for priority.
The most efficient way to meet the requirements is to create a FlexCard with two card states. A card state defines how a FlexCard displays data and actions based on certain conditions. The consultant can use conditions on the state to filter for priority, and then customize the fields and actions for each state. This way, the FlexCard can display different information and options for low/medium and high priority cases
NEW QUESTION # 109
You may find it is hard to catch up at the start of Plat-Con-201 exam certification. Now you are better to seek for some useful study material than complain about the difficulty of the Plat-Con-201 exam. Plat-Con-201 trainng practice may be your best choice. There are comprehensive content in the Plat-Con-201 simulate test which can ensure you 100% pass. Plat-Con-201 valid and helpful training will give you more confidence and courage. Just starting stuy with Plat-Con-201 dumps torrent, you will be on the way to success.
Plat-Con-201 Pdf Dumps: https://www.prepawayete.com/Salesforce/Plat-Con-201-practice-exam-dumps.html
Our system will automatically deliver the newest version of our Plat-Con-201 exam questions to your via email after you pay for them, Our Plat-Con-201 study materials are designed to help users consolidate what they have learned, will add to the instant of many training, the user can test their learning effect in time after finished the part of the learning content, have a special set of wrong topics in our Plat-Con-201 study materials, enable users to find their weak spot of knowledge in this function, iterate through constant practice, finally reach a high success rate, Salesforce Plat-Con-201 Sample Test Online How long can I use my product?
Those first screens teach everything the player needs to know: Plat-Con-201 Mario starts on the left of an empty screen, facing right, It is important to be considerate and polite when you connect.
Our system will automatically deliver the newest version of our Plat-Con-201 Exam Questions to your via email after you pay for them, Our Plat-Con-201 study materials are designed to help users consolidate what they have learned, will add to the instant of many training, the user can test their learning effect in time after finished the part of the learning content, have a special set of wrong topics in our Plat-Con-201 study materials, enable users to find their weak spot of knowledge in this function, iterate through constant practice, finally reach a high success rate.
Want to Know Your Readiness for Salesforce Plat-Con-201 Exam? Take Our Online Practice TestHow long can I use my product, While, the Plat-Con-201 exam dumps provided by PrepAwayETE site will be the best valid training material for you, Our pass-for-sure Salesforce Plat-Con-201 test torrent almost covers everything you need to help you overcome the difficulty of Plat-Con-201 actual test questions you meet.
