[General] MO-210 New Study Guide - MO-210 Latest Dumps Ebook
123
【General】 MO-210 New Study Guide - MO-210 Latest Dumps Ebook
Posted at 4 hour before      View:20 | Replies:0        Print      Only Author   [Copy Link] 1#
Once you have used our MO-210 exam training guide in a network environment, you no longer need an internet connection the next time you use it, and you can choose to use MO-210 exam training at your own right. Our MO-210 exam training do not limit the equipment, do not worry about the network, this will reduce you many learning obstacles, as long as you want to use MO-210 Test Guide, you can enter the learning state. And you will find that our MO-210 training material is the best exam material for you to pass the MO-210 exam.
A minor mistake may result you to lose chance even losing out on your MO-210 Exam. So we hold responsible tents when compiling the MO-210 learning guide. The principles of our MO-210practice materials can be expressed in words like clarity, correction and completeness. Experts expressed their meaning with clarity by knowledgeable and understandable words which cannot be misunderstood.
Prominent Features of Microsoft MO-210 Practice Test QuestionsDon't worry because "PDFDumps" is here to save you from these losses with its updated and real Microsoft MO-210 exam questions. We provide you with the latest prep material which is according to the content of Microsoft MO-210 Certification Exam and enhances your knowledge to crack the test. PDFDumps practice material is made by keeping in focus all the sections of the current syllabus.
Microsoft Excel (Microsoft 365 Apps) Sample Questions (Q30-Q35):NEW QUESTION # 30
Instructions
Exam Environment
Exam Interface and Controls
The exam panel provides access to the project task(s). Each project has an associated file in which you will perform the project tasks.
Overview:
Jelly Beans
A shop you manage sells gourmet jelly beans. You are tracking the amount of jelly beans sold each quarter and summarizing the information in aworkbook.
Task 3:
On the Chart worksheet, include the Total Profit data on the Flavor Expenses, Income and Profit chart.
See the solution in Explanation below.
To include theTotal Profitdata in your existing chart on theChartworksheet, follow these steps:
Step 1: Navigate to the Chart
* Click on theChartworksheet tab at the bottom of the Excel window.
* Click once on theFlavor Expenses, Income and Profitchart to select it. When selected, you will see the Chart DesignandFormattabs appear on the Ribbon.
Step 2: Open the Select Data Source Window
* Go to theChart Designtab.
* In theDatagroup, click on theSelect Databutton. This will open theSelect Data Sourcedialog box.
Step 3: Add the Total Profit Series
* In theLegend Entries (Series)section on the left side of the dialog box, click theAddbutton.
* AnEdit Serieswindow will appear:
* Series name:Click on theProfitsworksheet tab and select cellG3(which contains the header
"Total Profit").
* Series values:Clear any existing text in the box, then highlight the rangeG4:G23on theProfits worksheet (containing the actual profit numbers).
* ClickOKon the Edit Series window.
* ClickOKagain on the Select Data Source dialog box to apply the changes.
Final Result
The chart will now display a third set of bars (likely orange, as seen in your preview) representing theTotal Profitfor each flavor alongside the existing Expense and Income data.
NEW QUESTION # 31
Instructions
Exam Environment
Overview:
Clearance Sale
You are the administrative assistant for a retail company that is going out of business. You've been tasked to prepare a workbook for the clearance sale.
Task 3:
Configure the Sold worksheet so rows 1 through 3 remain visible as you scroll vertically.
To keep rows 1 through 3 visible while you scroll down the "Sold" worksheet, you will use theFreeze Panes feature.
Step-by-Step Solution
* Select Row 4: Click on the row number4on the far left of the screen to select the entire row.
* Note: In Excel, "Freeze Panes" freezes everythingabovethe currently selected row.
* Navigate to the View Tab: Click on theViewtab in the top Ribbon menu.
* Click Freeze Panes: In theWindowgroup, click theFreeze Panesbutton.
* Select Freeze Panes: From the drop-down menu, select the first option,Freeze Panes.
Verification
Scroll down the worksheet using your mouse or the scroll bar. You should notice that the "Clearance Sale" header and the "Item Type/Description/etc." header row (rows 1-3) stay locked at the top of the screen while the data in row 4 and below moves.
NEW QUESTION # 32
Instructions
Exam Environment
Overview:
Jelly Beans
Task 5:
Group the Profits, Costs, and Chart worksheets and change the tab color to Pink, Accent 4.
To group multiple worksheets and change their tab colors simultaneously in Microsoft Excel 365, follow these steps:
Step 1: Group the Worksheets
* Look at the worksheet tabs at the bottom of your Excel window.
* Click on the first tab,Profits.
* Hold down theCtrlkey on your keyboard.
* While holdingCtrl, click on theCoststab and then theCharttab.
* Note: You will notice all three tabs now have a white background, indicating they are grouped together.
Step 2: Change the Tab Color
* Right-clickon any of the selected (grouped) tabs.
* Hover your mouse overTab Colorin the pop-up menu.
* In the color palette that appears, locate theTheme Colorssection.
* Find and selectPink, Accent 4(this is usually the 8th color in the top row of the Theme Colors section).
Step 3: Ungroup the Worksheets
* To finish,right-clickon any of the tabs again.
* SelectUngroup Sheetsfrom the menu.
* Alternatively, you can click on any worksheet tab that is not part of the group to ungroup them.
Final Result
TheProfits,Costs, andCharttabs will now all display the samePink, Accent 4color at the bottom of your workbook.
Would you like me to help you with the next task or another project?
NEW QUESTION # 33
Instructions
Exam Environment
Overview:
Clearance Sale
Task 1:
On the Sold worksheet, insert a new column before column A.
Task 1: Insert a new column before column A
To insert a new column at the very beginning of your worksheet, follow these steps:
* Select Column A: Click directly on the letter'A'at the top of the first column to select the entire column.
* Open the Insert Menu: There are two ways to do this:
* Option A (Right-Click): Right-click anywhere on the selected column and chooseInsertfrom the context menu.
* Option B (Ribbon): On theHometab, go to theCellsgroup, click the arrow next toInsert, and selectInsert Sheet Columns.
Verification
Once completed, your original "Item Type" column (previously Column A) will shift toColumn B, and you will have a brand new, emptyColumn Aat the start of your worksheet.
NEW QUESTION # 34
Instructions
Exam Environment
Farm Feeds:
You are the assistant manager for a farm pet feed store. You are creating an inventory report.
Task 2:
Import NewFeeds.txt located in the GMetrixTemplates folder as a table on a new worksheet.
To completeTask 2: Import NewFeeds.txt as a table on a new worksheet, follow these exact steps in Microsoft Excel 365:
Step 1: Open the Import Tool
* Go to theDatatab on the top Ribbon.
* In theGet & Transform Datagroup, click onFrom Text/CSV.
Step 2: Locate the File
* A file browser window will open. Navigate to theGMetrixTemplatesfolder.
* Select the file namedNewFeeds.txt.
* ClickImport.
Step 3: Configure the Import Preview
* A preview window will appear. Excel should automatically detect the delimiter (usually a tab or comma).
* Ensure theFile OriginandDelimiterlook correct in the preview.
* Instead of clicking "Load," click thearrow next to the Load buttonand selectLoad To....
Step 4: Import as a Table on a New Worksheet
* In theImport Datadialog box that appears, select the radio button forTable.
* Under "Where do you want to put the data?", selectNew worksheet.
* ClickOK.
Final Result
Excel will create a brand new sheet (e.g., "Sheet2") and place the contents of NewFeeds.txt inside a formatted Excel Table.
NEW QUESTION # 35
A free trial of the product allows users to test the material before buying. These different formats allow MO-210 exam aspirants to practice using their preferred method. The support offered by the PDFDumps is another significant advantage for applicants. The PDFDumps MO-210 provides 24/7 support for guidance of users. Our team of professionals is highly qualified and have years of experience in the industry. They are available to answer any Microsoft MO-210 Questions that customers may have. The support team is always available to help applicants use the product.
MO-210 Latest Dumps Ebook: https://www.pdfdumps.com/MO-210-valid-exam.html
They are software, PDF and APP version of the MO-210 guide torrent: Microsoft Excel (Microsoft 365 Apps), And the pass rate of our MO-210 training guide is high as 99% to 100%, you will be able to pass the MO-210 exam with high scores, Our MO-210 VCE dumps will help you pass exams successfully, To be the salt of earth in the world and get a well-paid job with more promising future, you should pass Microsoft MO-210 exam, We will provide you preferential terms if you buy a large quantity of our MO-210 dumps VCE.
Note that self-employed individuals or consulting team members MO-210 may receive this benefit indirectly if the certification makes it easier to sell or deliver new business to customers.
has been contracted to demonstrate the development process and provide support to Simpleton's development group, They are software, PDF and APP version of the MO-210 Guide Torrent: Microsoft Excel (Microsoft 365 Apps).
HOT MO-210 New Study Guide - Microsoft Microsoft Excel (Microsoft 365 Apps) - Trustable MO-210 Latest Dumps EbookAnd the pass rate of our MO-210 training guide is high as 99% to 100%, you will be able to pass the MO-210 exam with high scores, Our MO-210 VCE dumps will help you pass exams successfully.
