[General] SD-WAN-Engineer Practice Exams & Exams SD-WAN-Engineer Torrent
127
【General】 SD-WAN-Engineer Practice Exams & Exams SD-WAN-Engineer Torrent
Posted at yesterday 17:22      View:19 | Replies:0        Print      Only Author   [Copy Link] 1#
The modern Palo Alto Networks world is changing its dynamics at a fast pace and has become so competitive. To stay updated and competitive in the market you have to learn new in-demand skills. With one Palo Alto Networks SD-WAN-Engineer exam certificate you can do this task nicely. With the Palo Alto Networks SD-WAN-Engineer Certification Exam successful candidates can validate their knowledge, increase marketability, enhance academic performance, improve reputation and increase earning power and other personal and professional benefits, etc.
Palo Alto Networks SD-WAN-Engineer Exam Syllabus Topics:
  • Troubleshooting: This domain focuses on resolving connectivity, routing, forwarding, application performance, and policy issues using co-pilot data analysis and analytics for network optimization and reporting.
  • Deployment and Configuration: This domain focuses on Prisma SD-WAN deployment procedures, site-specific settings, configuration templates for different locations, routing protocol tuning, and VRF implementation for network segmentation.
  • Operations and Monitoring: This domain addresses monitoring device statistics, controller events, alerts, WAN Clarity reports, real-time network visibility tools, and SASE-related event management.
  • Planning and Design: This domain covers SD-WAN planning fundamentals including device selection, bandwidth and licensing planning, network assessment, data center and branch configurations, security requirements, high availability, and policy design for path, security, QoS, performance, and NAT.
Topic 5
  • Unified SASE: This domain covers Prisma SD-WAN integration with Prisma Access, ADEM configuration, IoT connectivity via Device-ID, Cloud Identity Engine integration, and User
  • Group-based policy implementation.
Top SD-WAN-Engineer Practice Exams | High Pass-Rate Exams SD-WAN-Engineer Torrent: Palo Alto Networks SD-WAN Engineer 100% PassCandidates who participate in the Palo Alto Networks practice exam should first choose our latest braindumps pdf. It will help you pass test with 100% guaranteed. Besides, our SD-WAN-Engineer exam prep can help you fit the atmosphere of actual test in advance, which enable you to improve your ability with minimum time spent on SD-WAN-Engineer Dumps PDF and maximum knowledge gained.
Palo Alto Networks SD-WAN Engineer Sample Questions (Q29-Q34):NEW QUESTION # 29
When using the CloudBlade to integrate Prisma SD-WAN with Prisma Access, how does the system ensure that the IPSec tunnels between the branch ION and the Prisma Access Security Processing Node (SPN) are kept alive during periods of no user traffic?
  • A. The IPSec tunnel uses standard DPD (Dead Peer Detection) and the ION sends keepalives.
  • B. The administrator must configure a continuous ping script on a branch PC.
  • C. Prisma Access initiates the connection to the branch every 60 seconds.
  • D. The CloudBlade automatically configures the ION to send Synthetic Probes (ICMP/HTTP) across the tunnel.
Comprehensive and Detailed Explanation
The stability of VPN tunnels in the Prisma SD-WAN + Prisma Access integration relies on standard IPSec mechanisms.
Dead Peer Detection (DPD): The CloudBlade configuration automatically enables DPD on the IPSec tunnels it provisions.
Mechanism: DPD is a standard keepalive mechanism where the ION device sends periodic "R-U-THERE" messages to the Prisma Access gateway (and vice versa). If no acknowledgment is received after a specific count/timer, the ION marks the tunnel as down and attempts to re-key or switch to a backup path.
Synthetic Probes (B): While Synthetic Probes (part of ADEM or Path Quality monitoring) can be configured to measure latency/loss, the fundamental mechanism that keeps the IPSec security association (SA) active and detects link failure is DPD, not an application-layer probe.
NEW QUESTION # 30
Which implementation allows Prisma SD-WAN to improve application performance for organizations facing inconsistent user experiences across branch locations, especially due to varying device types and network conditions, by using Layer 4 and Layer 7 optimization to boost throughput?
  • A. Application acceleration
  • B. Packet duplication
  • C. WAN optimization
  • D. Forward Error Correction (FEC)
Prisma SD-WAN addresses inconsistent application performance through Application Acceleration, which encompasses a suite of features designed to mitigate the effects of latency and packet loss.1 While basic SD- WAN functionality handles path selection, Application Acceleration goes further by employing Layer 4 (TCP) and Layer 7 (Application) optimizations. These optimizations are particularly effective for organizations with diverse branch environments where network conditions are unpredictable.
At Layer 4, Prisma SD-WAN implements TCP optimization techniques such as window scaling, selective acknowledgments, and congestion control algorithms.2 These mechanisms allow the ION devices to "trick" the end hosts into sending data faster by acknowledging packets locally, effectively shielding the application from the round-trip time (RTT) delays inherent in long-distance WAN circuits. This significantly boosts throughput for bulk data transfers and legacy protocols that were not originally designed for high-latency environments.
At Layer 7, the system can perform application-specific optimizations, such as metadata caching or protocol- specific acceleration for services like SMB or HTTP.3 By reducing the number of "chatty" exchanges required to complete a transaction, Prisma SD-WAN ensures a snappy, consistent user experience regardless of whether the user is on a high-speed fiber link or a degraded cellular connection. This is distinct from Forward Error Correction (FEC) (Option C) or Packet Duplication (Option A), which focus on reconstructing lost packets rather than optimizing the protocol throughput itself. By combining these L4 and L7 techniques, Application Acceleration ensures that business-critical SaaS and data center applications perform optimally across the entire distributed enterprise.
NEW QUESTION # 31
A network design mandates segmentation at the routing level and traffic isolation across various services, such as teller cash registers, ATM traffic, guest Wi-Fi, and corporate applications. Which command can be used to validate and display the Virtual Routing and Forwarding (VRF) route leak rules?
  • A. inspect flow_browser vrf all
  • B. inspect vrf route_leak_rule all
  • C. dump vrf route_leak_rule
  • D. show interface vrf route_leak_rule all
In complex retail or banking environments, maintaining strict network segmentation is a regulatory and security requirement. Prisma SD-WAN utilizes Virtual Routing and Forwarding (VRF) to provide this isolation, ensuring that high-security traffic, such as ATM transactions or teller cash registers, remains logically separated from Guest Wi-Fi or general corporate applications. While isolation is the default state, route leaking is used to allow specific communication between these VRFs-for instance, allowing multiple isolated segments to reach a common shared service like a DNS server or a centralized security gateway.
To verify that these configurations have been correctly pushed from the Controller to the local ION device, administrators utilize the ION CLI (Command Line Interface) for deep-dive diagnostics. The command inspect vrf route_leak_rule all is the definitive tool for this purpose. Unlike "show" commands which typically provide interface status, "inspect" commands in the Prisma SD-WAN ecosystem are designed to pull real-time operational state data from the control plane's internal databases.
When executed, this command displays the specific prefix-level rules that allow routes to "leak" from one VRF table into another. It provides visibility into the source VRF, the destination VRF, and the exact network prefixes or default routes being shared. This is critical for troubleshooting "Day 2" operations; if a teller register cannot reach a shared database, the administrator can use this command to confirm if the necessary route leak rule is active and accurately reflecting the intent of the VRF Profile configured in the portal.
Without this command, verifying inter-VRF reachability would be limited to trial-and-error connectivity tests, making it an essential part of the Prisma SD-WAN engineer's toolkit.
NEW QUESTION # 32
A customer wants to deploy Prisma SD-WAN ION devices at small home offices that use consumer-grade broadband routers. These routers typically use Symmetric NAT and do not allow static port forwarding.
Which standard mechanism does Prisma SD-WAN utilize to successfully establish direct Branch-to-Branch (Dynamic) VPN tunnels through these Symmetric NAT devices?
  • A. Manual GRE Tunnels
  • B. UPnP (Universal Plug and Play)
  • C. STUN (Session Traversal Utilities for NAT)
  • D. SSL VPN encapsulation
Prisma SD-WAN utilizes STUN (Session Traversal Utilities for NAT) to facilitate NAT Traversal for its Secure Fabric overlay.
* Discovery: When an ION device connects to the internet behind a NAT router, it reaches out to the Prisma SD-WAN Controller. The controller acts as a STUN server, identifying the public IP address and port that the ION's traffic is originating from.
* Symmetric NAT Challenge: In Symmetric NAT, the mapping changes for every destination.
However, the Prisma SD-WAN architecture is designed to handle this by having the controller coordinate the connection attempt.
* Hole Punching: The controller shares the discovered public mapping information between two peer ION devices. They then simultaneously initiate traffic to each other's public IP/Port (a technique called
"UDP Hole Punching"). This tricks the intermediate NAT devices into allowing the inbound traffic, establishing a direct P2P IPSec tunnel without requiring manual port forwarding or static IPs at the edge.
NEW QUESTION # 33
A network installer is attempting to claim a new ION device using the "Claim Code" method. The device is connected to the internet, but the status in the portal remains stuck at "Claimed" and does not transition to
"Online". The installer connects a laptop to the LAN port of the ION and can successfully browse the internet, confirming the uplink is active.
What is the most likely cause of the device failing to reach the "Online" state?
  • A. The "Circuit Label" has not been applied to the WAN interface.
  • B. The device has not yet downloaded the latest software image.
  • C. The device is missing the "Site" assignment in the portal.
  • D. The upstream firewall is blocking outbound TCP port 443 or UDP port 123 (NTP).
NEW QUESTION # 34
To fit in this amazing and highly accepted exam, you must prepare for it with high-rank practice materials like our Palo Alto Networks SD-WAN Engineer SD-WAN-Engineer study materials. Our SD-WAN-Engineer exam questions are the Best choice in terms of time and money. If you are a beginner, start with the learning guide of SD-WAN-Engineer Practice Engine and our products will correct your learning problems with the help of the Palo Alto Networks SD-WAN-Engineer training braindumps.
Exams SD-WAN-Engineer Torrent: https://www.prep4pass.com/SD-WAN-Engineer_exam-braindumps.html
