Latest Test 1z0-1066-25 Simulations - 1z0-1066-25 Reliable Exam Vce
Posted at yesterday 18:33      View:19 | Replies:0        Print      Only Author   [Copy Link] 1#
As far as we know, our 1z0-1066-25 exam prep have inspired millions of exam candidates to pursuit their dreams and motivated them to learn more high-efficiently. Our 1z0-1066-25 practice materials will not let your down. To lead a respectable life, our experts made a rigorously study of professional knowledge about this exam. We can assure you the proficiency of our 1z0-1066-25 Exam Prep. So this is a definitive choice, it means our 1z0-1066-25 practice materials will help you reap the fruit of success.
Who don't want to be more successful and lead a better life? But it's not easy to become better. Our 1z0-1066-25 exam questions can give you some help. After using our 1z0-1066-25 study materials, you can pass the exam faster and you can also prove your strength. Of course, our 1z0-1066-25 Practice Braindumps can bring you more than that. You can free download the demos to take a look at the advantages of our 1z0-1066-25 training guide.
1z0-1066-25 Reliable Exam Vce | 1z0-1066-25 Exam TestOur products boost 3 versions and varied functions. The 3 versions include the PDF version, PC version, APP online version. You can use the version you like and which suits you most to learn our 1z0-1066-25 study materials. The 3 versions support different equipment and using method and boost their own merits and functions. For example, the PC version supports the computers with Window system and can stimulate the real exam. Our products also boost multiple functions which including the self-learning, self-evaluation, statistics report, timing and stimulation functions. Each function provides their own benefits to help the clients learn the 1z0-1066-25 Study Materials efficiently. For instance, the self-learning and self-evaluation functions can help the clients check their results of learning the 1z0-1066-25 study materials.
Oracle Planning and Collaboration Cloud 2025 Implementation Professional Sample Questions (Q138-Q143):NEW QUESTION # 138
You have created several infotiles based on the client requirements. You now want to group them together for display. How do you accomplish this?
  • A. First build them into a planning measure in Manage Planning Measures. Then open the planning measure on the plan by going to Open (choose area) > Choose planning measure.
  • B. First build them into an info set in Manage Infosets. Then open the info set on the plan by going to Open (choose area) > Choose info set.
  • C. No need to group them. Open them directly on the plan going to Open (choose area) > Choose Infotile.
  • D. First build them into a tile set in Manage Table, Graphs, and Analysis Sets. Then open the tile set on the plan by going to Open (choose area) > Choose tile set.
  • E. First build them into a planning group in Manage Planning Groups. Then open the planning group on the plan by going to Open (choose area) > Choose planning group.
NEW QUESTION # 139
Which three steps are required so that a supply plan can use different service-level percentages for different groupings of items when calculating safety stock?
  • A. Create a supply planning policy assignment set.
  • B. Assign the percentage on the Safety Stock tab of plan options.
  • C. Create a safety stock policy assignment set.
  • D. Create segment groups.
  • E. Execute segmentation.
Answer: A,D,E
To implement varied service levels for different item groups, first create a supply planning policy assignment set, which defines rules for assigning items to specific safety stock policies. Next, create segment groups that align items with these policies based on their characteristics. Finally, execute segmentation, which categorizes items according to the specified segments. By following these steps, you can apply different service levels to distinct item groups during safety stock calculations, as outlined in Oracle's supply planning documentation
NEW QUESTION # 140
Demand is high leading up to the Christmas holiday every year between Dec 20 and Dec 24 and not on Christmas day (Dec 25). Your customer has two demand plans. Describe the steps to model Christmas causal factor in both demand plans.
  • A. Open a demand plan and edit Christmas casual factor measure. Place value of one from Dec 20 to Dec
    24 and zero for non-impacted days including Dec 25. Causal factor changes are plan specific, so repeat the steps in the 2nd demand plan.
  • B. Open a demand plan and edit Christmas casual factor measure. Place value of one from Dec 20 to Dec
    24 and zero for non-impacted days including Dec 25. Causal factor changes in this demand plan will reflect in the 2nd demand plan also.
  • C. Use FBDI to create a new customer specific Christmas causal factor. Place value of 1 from Dec 20 to Dec 24. Causal factor changes are plan specific, so repeat the steps in the 2nd demand plan.
  • D. Use FBDI to create a new customer specific Christmas causal factor. Place value of 1 from Dec 20 to Dec 34. Causal factor upload to one demand plan will reflect in the 2nd demand plan also.
  • E. Open a demand plan and add a new customer specific Christmas causal factor. Create a table displaying the causal factor measure and relevant time period and modify as required. Causal factor changes in this demand plan will reflect in the 2nd demand plan also.
  • F. Open a demand plan and add a new customer specific Christmas causal factor. Create a table displaying the causal factor measure and relevant time period and modify as required. Causal factor changes are plan specific, so repeat the steps in the 2nd demand plan.
Answer: E
NEW QUESTION # 141
How does the Demand Fulfillment view prioritize at-risk demands?
  • A. Based on order value weighted by the number of associated recommendations required to make the demand no longer at risk
  • B. Based on the order value per customer weighted by the number of associated recommendations required to make the demand no longer at risk
  • C. Based on the number of associated recommendations required to make the demand no longer at risk
  • D. Based on order value weighted by the number of compression days required to make the demand no longer at risk
Review and Improve Your Demand Fulfillment
To improve the demand fulfillment of your plan, use the Demand Fulfillment table to review the at-risk demands in your plan and their related recommendations. You can take actions to accept recommendations from this page.
In the Demand Fulfillment UI, you can:
* View prioritized at-risk demands based on order values weighted by the number of associated recommendations.
* Take actions to accept or mark recommendations as complete.
* Review summary information provided for the current demand fulfillment position of your plan to analyze the potential for improvement based on selected at-risk demands. The information also provides an understanding of the expected demand fulfillment position based on accepted and completed recommendations.
To review and improve your demand fulfillment:
* In a Supply Planning, Planning Central, or Demand and Supply work area, select the Manage Plans task.
* On the Manage Plans page, search for and open your plan.
* In the Page Layout list, select Plan Summary.
Note that the tiles in the Plan Summary layout include a Demand at Risk in thousands tile.
* In the Demand at Risk in thousands tile, click the Select Tile bar to review the Demand at Risk Summary data.
You can review the demand at risk data through a treemap view or a table view, the treemap view is the default. To switch to the table view, click the Show Table icon.
* To review the demand at risk data:
* Using the treemap: Click an area in the treemap. Typically, you want to start with the area that has the highest demand at risk value. From the Drill To actions, click Demand Fulfillment.
* Using the table: Click the Show Table icon. In the Demand at Risk Summary table, click a cell.
Typically, you want to start with the cell that has the highest demand at risk value. From the Drill To actions, click Demand Fulfillment.
* The Demand Fulfillment UI shows the individual orders that are at-risk and their related recommendations.
Tip: You can open the Demand Fulfillment table directly without drilling from the Plan Summary. After you open a plan, click the Open button at the page level. In the Open Table, Graph, or Tile Set dialog box, search for and select the Demand Fulfillment table. In the Demand Fulfillment UI, you can search for at-risk demands by using the filter fields in the search panel.
NEW QUESTION # 142
What are two characteristics of an 'Item' organization? (Choose two.)
  • A. It does not physically of financially track material storage or movement.
  • B. It is ideal for deployments where inventory management may not be installed.
  • C. It includes parameter definition, including lot. serial number, and item sourcing rules.
  • D. It requires financial and accounting setups.
NEW QUESTION # 143
Oracle Planning and Collaboration Cloud 2025 Implementation Professional has introduced practice test (desktop and web-based) for the students so they can practice anytime in an easy way. The Oracle Planning and Collaboration Cloud 2025 Implementation Professional (1z0-1066-25) practice tests are customizable which means the students can set the time and questions according to their needs. The 1z0-1066-25 Practice Tests have unlimited tries so that the users don't make extra mistakes when giving it the next time. Candidates can access the previously given tries from the history and avoid making mistakes in the final examination.
1z0-1066-25 Reliable Exam Vce: https://www.testinsides.top/1z0-1066-25-dumps-review.html
They are valid I finally passed my 1z0-1066-25 after such a hard struggle, Let our 1z0-1066-25 real exam questions and 1z0-1066-25 test dumps vce pdf help you pass exam easily, Oracle Latest Test 1z0-1066-25 Simulations Your search ends right here, Oracle Latest Test 1z0-1066-25 Simulations The world today is in an era dominated by knowledge, Customers first are our mission, and we will try our best to help all of you to get your 1z0-1066-25 exam certification.
We long for golden sunsets, stop for red signs, and suffer from the blues, Detailed Requirements Document, They are valid I finally passed my 1z0-1066-25 after such a hard struggle.
Let our 1z0-1066-25 real exam questions and 1z0-1066-25 test dumps vce pdf help you pass exam easily, Your search ends right here, The world today is in an era dominated by knowledge.
Professional Latest Test 1z0-1066-25 Simulations by TestInsidesCustomers first are our mission, and we will try our best to help all of you to get your 1z0-1066-25 exam certification.
