[General] Pass Guaranteed Quiz 2026 Salesforce AP-212: Loyalty Management Accredited Profe
【General】 Pass Guaranteed Quiz 2026 Salesforce AP-212: Loyalty Management Accredited Profe
Posted at yesterday 19:12      View:16 | Replies:0        Print      Only Author   [Copy Link] 1#
Now they have become certified Loyalty Management Accredited Professional Certification Exam experts and pursue a rewarding career in the top world brands. You can also trust top-notch and easy-to-use Salesforce AP-212 practice test questions. The Loyalty Management Accredited Professional (AP-212) exam questions are checked and verified by experienced and qualified Loyalty Management Accredited Professional (AP-212) exam trainers. They have years of experience and knowledge to collect, design, and answer the real Loyalty Management Accredited Professional (AP-212) exam questions.
The superiority of our AP-212 practice materials is undeniable. We are superior in both content and a series of considerate services. We made the practice materials for conscience’s sake to offer help. Our AP-212 actual exam withstands the experiment of the market also. With the help from our AP-212 training engine, passing the exam will not be a fiddly thing anymore. So this is your high time to flex your muscles this time.
Frenquent AP-212 Update | 100% Free Accurate Exam Loyalty Management Accredited Professional VoucherOur website is considered to be the most professional platform offering AP-212 practice guide, and gives you the best knowledge of the AP-212 study materials. Passing the exam has never been so efficient or easy when getting help from our AP-212 Preparation engine. We can claim that once you study with our AP-212 exam questions for 20 to 30 hours, then you will be albe to pass the exam with confidence.
Salesforce Loyalty Management Accredited Professional Sample Questions (Q96-Q101):NEW QUESTION # 96
In order to view the information pertaining to a member's recent transactions and manual adjustments on the Contact record, what are the two suggestions that an IT Administrator should propose to the Member Services team? Select two
  • A. Incorporate the 'View Member Profile' component on the Contact record
  • B. Incorporate the 'Transaction Journals' related list on the Contact record
  • C. Incorporate the Member Service Manager Home Dashboard on the Contact record
  • D. Incorporate the 'Member Summary Embedded Dashboard' on the Contact record
To view information pertaining to a member's recent transactions and manual adjustments on the Contact record, an IT Administrator should propose:
* Incorporate the 'Member Summary Embedded Dashboard' on the Contact record (A): This dashboard can provide a comprehensive overview of a member's loyalty activities, including recent transactions and adjustments, directly within the context of their Contact record.
* Incorporate the 'Transaction Journals' related list on the Contact record (C): By adding this related list, the Member Services team can easily access detailed transaction and adjustment records associated with the loyalty program member directly from the Contact record, facilitating quick and informed customer service interactions.
Options B and D, involving the Member Service Manager Home Dashboard and the 'View Member Profile' component, do not directly address the need to view transactional information on the Contact record.
NEW QUESTION # 97
Using extensive Data Processing Engine jobs to modify Salesforce data at scale, which two limits should be monitored?
  • A. Data Pipeline Limits
  • B. Batch Limit in Bulk Api
  • C. Apex Governor Limits
  • D. Record Storage Limits
When using extensive Data Processing Engine (DPE) jobs to modify Salesforce data at scale, the two limits that should be monitored are:
* Option A "Record Storage Limits," as extensive data processing and modification can significantly impact the volume of data stored in Salesforce, potentially reaching storage capacity limits.
* Option C "Data Pipeline Limits," since DPE jobs involve data processing tasks that may be constrained by the limits of Salesforce's data processing capabilities and resources.
NEW QUESTION # 98
An IT Administrator has received a request from the Customer Service team to enable agents to view the Loyalty Program Member information on a Case record in Service Cloud.
What steps should the Administrator take to configure this?
  • A. On the Case Page Layout, the View Member Profile' component should be added and the required Related Lists from Loyalty Program  Member should be selected
  • B. On the Case Page Layout, the View Related Membership' action should be added to the Highlights panel and the Loyalty information to be displayed should be selected
  • C. On the Case Page Layout, the Related Record component should be added with the 'First Lookup' selected as the 'Loyalty Program 0 Member'
  • D. On the Case Page Layout, the Loyalty Program Member Related Lists are available and should be directly embedded to show the Loyalty information
To enable agents to view Loyalty Program Member information on a Case record in Service Cloud, the IT Administrator should On the Case Page Layout, add the 'View Member Profile' component and select the required Related Lists from Loyalty Program Member (B). This component allows for the display of relevant Loyalty Program Member information directly within the context of a Case record, enhancing the service agent's ability to access pertinent loyalty information while managing customer cases.
NEW QUESTION # 99
What is the recommended approach to creating a large multi-country, multi-currency, and tier-dependent Redemption Catalogue?
  • A. Create an Apex Class and implement a Redemption Catalogue engine.
  • B. Create a Loyalty Process with different rules to manage every combination
  • C. Create a Decision Tree using Flows with a leaf for every combination
  • D. Create a Decision Table and define the Redemption Catalogue as business rules.
For creating a large multi-country, multi-currency, and tier-dependent Redemption Catalogue, the recommended approach is to Create a Decision Table and define the Redemption Catalogue as business rules (C). A Decision Table allows for the efficient management of complex business rules and conditions, such as those involved in a multi-faceted Redemption Catalogue, providing a clear and structured method for defining redemption options based on various criteria like country, currency, and loyalty tier.
NEW QUESTION # 100
A sports clothing and accessories retailer is setting up a new Loyalty program. The company wants an effective way to create urgency in its Loyalty program members to return to purchase and redeem their points within a specified period. The entire points balance expires if a member's last activity, including any purchase or points redemption, reaches 18 months.
What steps should a Loyalty Consultant follow to meet the retailer's requirement when implementing the new Loyalty program?
  • A. Set up a Qualifying Points currency and apply the expiration model 'Fixed Model'
  • B. Set up a Non-Qualifying Points currency and apply the expiration model 'Fixed Model'
  • C. Set up a Qualifying Points currency and apply the expiration model 'Activity Model'
  • D. Set up a Non-Qualifying Points currency, apply the expiration model 'Activity Model'
To create urgency for Loyalty program members to return and redeem their points within a specified period, where the entire points balance expires if a member's last activity reaches 18 months, the Loyalty Consultant should:
* Set up a Non-Qualifying Points currency, apply the expiration model 'Activity Model' (C): This setup allows for the expiration of Non-Qualifying Points based on member activity, specifically if there is no purchase or points redemption activity within an 18-month period. The Activity Model is used to track the last activity date and trigger expiration based on this inactivity period.
Setting up a Non-Qualifying Points currency with a 'Fixed Model' expiration (option A), a Qualifying Points currency with either 'Activity Model' (option B) or 'Fixed Model' expiration (option D), would not meet the retailer's requirement for creating urgency based on the last activity.
Salesforce documentation on Loyalty Management would provide guidance on configuring expiration models for loyalty currencies, ensuring that program objectives, such as encouraging regular member engagement, are achieved.
NEW QUESTION # 101
Services like quick downloading within five minutes, convenient and safe payment channels made for your convenience. Even newbies will be tricky about this process. Unlike product from stores, quick browse of our AP-212 practice materials can give you the professional impression wholly. So, they are both efficient in practicing and downloading process. By the way, we also have free demo of AP-212 practice materials as freebies for your reference to make your purchase more effective.
Exam AP-212 Voucher: https://www.vce4dumps.com/AP-212-valid-torrent.html
Salesforce Frenquent AP-212 Update Dump is a place where people are allowed to leave their rubbish, And now, with Exam AP-212 Voucher Machine Learning Studio, the coding barrier to entry has been lowered, Here, we would like to recommend ITCertKey's AP-212 exam materials to you, Salesforce Frenquent AP-212 Update We can definitely ensure you that you are confident enough to participate in the IT exam and get a satisfying score, We believe you will also competent enough to cope with demanding and professorial work with competence with the help of our AP-212 exam braindumps.
Mac OS X Client General Security Practices, You Determine Latest Real AP-212 Exam What Information You Add to Each Contact Entry, Dump is a place where people are allowed to leave their rubbish.
And now, with Loyalty Management Machine Learning Studio, the coding barrier to entry has been lowered, Here, we would like to recommend ITCertKey's AP-212 Exam Materials to you.
Free PDF Quiz 2026 AP-212: Efficient Frenquent Loyalty Management Accredited Professional UpdateWe can definitely ensure you that you are confident AP-212 enough to participate in the IT exam and get a satisfying score, We believe you will also competent enough to cope with demanding and professorial work with competence with the help of our AP-212 exam braindumps.
