Latest HP HPE7-A02 Exam Guide - New HPE7-A02 Braindumps Sheet
Posted at yesterday 19:47      View:19 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that TrainingDumps HPE7-A02 dumps now are free: https://drive.google.com/open?id=1GFSnIS_KQORtkJlfSb8fZWlWHwt5n8Dd
The latest HPE7-A02 exam prep is created by our IT experts and certified trainers who are dedicated to HP braindumps pdf for a long time. All questions of our HPE7-A02 PDF VCE are written based on the real questions. Besides, we always check the updating of HPE7-A02 exam questions to make sure exam preparation smoothly.
According to personal propensity and various understanding level of exam candidates, we have three versions of HPE7-A02 study guide for your reference. They are the versions of the PDF, Software and APP online. If you visit our website on our HPE7-A02 Exam Braindumps, then you may find that there are the respective features and detailed disparities of our HPE7-A02 simulating questions. And you can free donwload the demos to have a look.
New HPE7-A02 Braindumps Sheet, HPE7-A02 Valid Test BootcampUp to now our HPE7-A02 practice materials consist of three versions, all those three basic types are favorites for supporters according to their preference and inclinations. On your way moving towards success, our HPE7-A02 preparation materials will always serves great support. As long as you have any questions on our HPE7-A02 Exam Questions, you can just contact our services, they can give you according suggestion on the first time and ensure that you can pass the HPE7-A02 exam for the best way.
HP Aruba Certified Network Security Professional Exam Sample Questions (Q81-Q86):NEW QUESTION # 81
A company uses HPE Aruba Networking ClearPass Device Insight (CPDI) (the standalone application option). In the details for a generic device cluster, you see a recommendation for "Windows 8/10" with 70% accuracy.
What does this mean?
  • A. CPDI has detected that these devices match about 70% of the system rule for defining "Windows 8/10" devices.
  • B. CPDI has grouped this cluster with similar classified devices. 70% of those classified devices are
    "Windows 8/10."
  • C. CPDI has matched these devices against several, conflicting system rules. 70% of those rules are for
  • D. CPDI has used MAC OUI to group these devices together. The average device's MAC address matches
    70% of the "Windows 8/10" OUI.
When HPE Aruba Networking ClearPass Device Insight (CPDI) shows a recommendation for "Windows 8
/10" with 70% accuracy for a generic device cluster, it means that CPDI has detected that these devices match about 70% of the system rule criteria for defining "Windows 8/10" devices. This percentage indicates the confidence level based on the observed characteristics and behavior of the devices, helping administrators understand the likelihood that these devices are indeed running Windows 8 or 10.
NEW QUESTION # 82
The security team needs you to show them information about MAC spoofing attempts detected by HPE Aruba Networking ClearPass Policy Manager (CPPM).
What should you do?
  • A. Integrate CPPM with ClearPass Device Insight (CPDI) and run a security report on CPDI.
  • B. Show the security team the CPPM Endpoint Profiler dashboard.
  • C. Export the Access Tracker records on CPPM as an XML file.
  • D. Use ClearPass Insight to run an Active Endpoint Security report.
To show the security team information about MAC spoofing attempts detected by HPE Aruba Networking ClearPass Policy Manager (CPPM), you should use ClearPass Insight to run an Active Endpoint Security report. ClearPass Insight provides comprehensive reporting capabilities that include detailed information on security incidents, such as MAC spoofing attempts. By generating this report, you can provide the security team with a clear overview of the detected spoofing activities, including the endpoints involved and the context of the events.
NEW QUESTION # 83
A company wants HPE Aruba Networking ClearPass Policy Manager (CPPM) to respond to Syslog messages from its Check Point firewall. You have added the firewall as an event source and set up an event service. However, test Syslog messages are not triggering the expected actions.
What is one CPPM setting that you should check?
  • A. The Check Point Extension is installed through ClearPass Guest.
  • B. ClearPass Device Insight integration is disabled.
  • C. Ingress Event Dictionaries for Check Point messages are enabled.
  • D. The CoA delay value is set to 0 on the server.
To ensure that HPE Aruba Networking ClearPass Policy Manager (CPPM) responds correctly to Syslog messages from a Check Point firewall, you need to check that the Ingress Event Dictionaries for Check Point messages are enabled. These dictionaries are necessary for CPPM to properly interpret and respond to the Syslog messages received from the firewall.
1.Event Dictionaries: Ingress Event Dictionaries allow CPPM to understand the specific format and content of Syslog messages from various sources, such as Check Point firewalls.
2.Message Interpretation: Without these dictionaries enabled, CPPM may not correctly interpret the Syslog messages, leading to a failure in triggering the expected actions.
3.Configuration Check: Ensuring that the dictionaries are enabled is crucial for the proper functioning of the event service and accurate response to security events.
Reference: ClearPass documentation on Syslog integration and event service setup provides information on configuring Ingress Event Dictionaries for different event sources.
NEW QUESTION # 84
A company has AOS-CX switches and HPE Aruba Networking APs, which run AOS-10 and bridge their SSIDs. Company security policies require 802.1X on all edge ports, some of which connect to APs. How should you configure the auth-mode on AOS-CX switches?
  • A. Configure all edge ports in device auth-mode.
  • B. Leave all edge ports in device auth-mode and configure client auth-mode in the AP role.
  • C. Leave all edge ports in client auth-mode and configure device auth-mode in the AP role.
  • D. Configure all edge ports in client auth-mode.
* 802.1X Authentication Modes:
* Client Auth-Mode: Requires each connected endpoint to authenticate individually using 802.1X.
* Device Auth-Mode: Allows the port to authenticate a device, such as an AP, as a whole. This mode works when the device bridges traffic (e.g., AP bridging SSID traffic).
* AP Role Configuration:
* Since the AP bridges traffic from multiple clients, you must configure the AP role to use device auth-mode.
* Meanwhile, the ports on edge switches can remain in client auth-mode to enforce 802.1X for individual client connections.
* Option Analysis:
* Option A: Correct. This ensures the AP itself authenticates with device auth-mode, while edge ports remain in client auth-mode.
* Option B: Incorrect. APs require device auth-mode for bridging, not client auth-mode.
* Option C: Incorrect. Device auth-mode on all ports would not meet the security policy for clients.
* Option D: Incorrect. Leaving all ports in device auth-mode does not meet the policy for 802.1X on edge ports.
NEW QUESTION # 85
A company needs to enforce 802.1X authentication for its Windows domain computers to HPE Aruba Networking ClearPass Policy Manager (CPPM). The company needs the computers to authenticate as both machines and users in the same session.
Which authentication method should you set up on CPPM?
  • A. EAP-TLS
  • B. EAP-TTLS
  • C. TEAP
  • D. PEAP MSCHAPv2
To enforce 802.1X authentication for Windows domain computers to HPE Aruba Networking ClearPass Policy Manager (CPPM) and have the computers authenticate as both machines and users in the same session, you should set up TEAP (Tunneled EAP) as the authentication method. TEAP supports both machine and user authentication within a single 802.1X session, making it suitable for scenarios where both types of authentication are required simultaneously.
NEW QUESTION # 86
There is no doubt that the HPE7-A02 certification can help us prove our strength and increase social competitiveness. Although it is not an easy thing for some candidates to pass the exam, but our HPE7-A02 question torrent can help aggressive people to achieve their goals. This is the reason why we need to recognize the importance of getting the test HPE7-A02 Certification. Now give me a chance to know our HPE7-A02 study tool before your payment, you can just free download the demo of our HPE7-A02 exam questions on the web.
New HPE7-A02 Braindumps Sheet: https://www.trainingdumps.com/HPE7-A02_exam-valid-dumps.html
We have the data to show that the pass rate among our customers with the help of our HPE7-A02 study materials has reached as high as 98% to 100%, which is the highest pass rate in the field, We are providing HPE7-A02 dumps with actual Aruba Certified Network Security Professional Exam exam questions and you are going to get same questions in your real HP HPE7-A02 exam, With the help of the HPE7-A02 - Aruba Certified Network Security Professional Exam Test Topics Pdf practice exam questions and preparation material offered by TrainingDumps, you can pass any HPE7-A02 - Aruba Certified Network Security Professional Exam Test Topics Pdf certifications exam in the first attempt.
The realization that home businesses can be cost efficient Many homepreneurs stress HPE7-A02 the cost efficiencies they gain by being home based, Applications by nature are coarse-grained because they encompass a large set of functionality;
Accurate Latest HPE7-A02 Exam Guide | HPE7-A02 100% Free New Braindumps SheetWe have the data to show that the pass rate among our customers with the help of our HPE7-A02 Study Materials has reached as high as 98% to 100%, which is the highest pass rate in the field.
We always hear that the effort will have a harvest, Latest HPE7-A02 Learning Materials while the realistic society maybe not, So please take this chance, opportunity seldom knocks twice.
P.S. Free & New HPE7-A02 dumps are available on Google Drive shared by TrainingDumps: https://drive.google.com/open?id=1GFSnIS_KQORtkJlfSb8fZWlWHwt5n8Dd
