[General] Palo Alto Networks NGFW-Engineer Practice Test Engine - NGFW-Engineer Braindump
【General】 Palo Alto Networks NGFW-Engineer Practice Test Engine - NGFW-Engineer Braindump
Posted at yesterday 23:02      View:20 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Palo Alto Networks NGFW-Engineer dumps are available on Google Drive shared by TestsDumps: https://drive.google.com/open?id=1geIWMbj5X6E6p56_NKgOWSw8eaTnpbMc
Our NGFW-Engineer exam questions are often in short supply. Every day, large numbers of people crowd into our website to browser our NGFW-Engineer study materials. Then they will purchase various kinds of our NGFW-Engineer learning braindumps at once. How diligent they are! As you can see, our products are absolutely popular in the market. And the pass rate of our NGFW-Engineer training guide is high as 98% to 100%. Just buy it and you will love it!
Palo Alto Networks NGFW-Engineer Exam Syllabus Topics:
  • PAN-OS Networking Configuration: This section of the exam measures the skills of Network Engineers in configuring networking components within PAN-OS. It covers interface setup across Layer 2, Layer 3, virtual wire, tunnel interfaces, and aggregate Ethernet configurations. Additionally, it includes zone creation, high availability configurations (active
  • active and active
  • passive), routing protocols, and GlobalProtect setup for portals, gateways, authentication, and tunneling. The section also addresses IPSec, quantum-resistant cryptography, and GRE tunnels.
  • PAN-OS Device Setting Configuration: This section evaluates the expertise of System Administrators in configuring device settings on PAN-OS. It includes implementing authentication roles and profiles, and configuring virtual systems with interfaces, zones, routers, and inter-VSYS security. Logging mechanisms such as Strata Logging Service and log forwarding are covered alongside software updates and certificate management for PKI integration and decryption. The section also focuses on configuring Cloud Identity Engine User-ID features and web proxy settings.
  • Integration and Automation: This section measures the skills of Automation Engineers in deploying and managing Palo Alto Networks NGFWs across various environments. It includes the installation of PA-Series, VM-Series, CN-Series, and Cloud NGFWs. The use of APIs for automation, integration with third-party services like Kubernetes and Terraform, centralized management with Panorama templates and device groups, as well as building custom dashboards and reports in Application Command Center (ACC) are key topics.
Trustable NGFW-Engineer Practice Test Engine | 100% Free NGFW-Engineer Braindump PdfThe contents of NGFW-Engineer learning questions are carefully compiled by the experts according to the content of the NGFW-Engineer examination syllabus of the calendar year. They are focused and detailed, allowing your energy to be used in important points of knowledge and to review them efficiently. In addition, NGFW-Engineer Guide engine is supplemented by a mock examination system with a time-taking function to allow users to check the gaps in the course of learning.
Palo Alto Networks Next-Generation Firewall Engineer Sample Questions (Q96-Q101):NEW QUESTION # 96
A network security engineer is reviewing the dynamic update settings for a fleet of firewalls in a financial institution that has a policy prioritizing operational stability above all else. The engineer notes that the current content update threshold is set to 24 hours.
Following the Palo Alto Networks recommended best practices for mission-critical deployments, which adjustment should be made to the threshold?
  • A. Reset to reconfirm 24 hours.
  • B. Increase to 48 hours.
  • C. Change to "download only" and schedule manual installation.
  • D. Decrease to 12 hours.
For mission-critical environments where stability is prioritized over rapid updates, Palo Alto Networks best practice is to increase the content update threshold to allow additional soak time for new releases, reducing the risk of introducing instability from newly published content updates.
NEW QUESTION # 97
An NGFW engineer is configuring multiple Panorama-managed firewalls to start sending all logs to Strata Logging Service. The Strata Logging Service instance has been provisioned, the required device certificates have been installed, and Panorama and the firewalls have been successfully onboarded to Strata Logging Service.
Which configuration task must be performed to start sending the logs to Strata Logging Service and continue forwarding them to the Panorama log collectors as well?
  • A. Select the "Enable Duplicate Logging" option in the Cloud Logging section under Device --> Setup --> Management in the appropriate templates.
  • B. Modify all active Log Forwarding profiles to select the "Cloud Logging" option in each profile match list in the appropriate device groups.
  • C. Enable the "Panorama/Cloud Logging" option in the Logging and Reporting Settings section under Device --> Setup --> Management in the appropriate templates.
  • D. Select the "Enable Cloud Logging" option in the Cloud Logging section under Device --> Setup --> Management in the appropriate templates.
To begin sending logs to Strata Logging Service while continuing to forward them to Panorama log collectors, the necessary configuration is to enable Cloud Logging. This option is configured in the Cloud Logging section under Device # Setup # Management in the appropriate templates. Once enabled, this ensures that logs are directed both to the Strata Logging Service (cloud) and to the Panorama log collectors.
NEW QUESTION # 98
To maintain security efficacy of its public cloud resources by using native tools, a company purchases Cloud NGFW credits to replicate the Panorama, PA-Series, and VM-Series devices used in physical data centers. Resources exist on AWS and Azure:
The AWS deployment is architected with AWS Transit Gateway, to which all resources connect The Azure deployment is architected with each application independently routing traffic The engineer deploying Cloud NGFW in these two cloud environments must account for the following:
Minimize changes to the two cloud environments
Scale to the demands of the applications while using the least amount of compute resources Allow the company to unify the Security policies across all protected areas Which two implementations will meet these requirements? (Choose two.)
  • A. Deploy Cloud NGFW for Azure in vNET/s, update the vNET/s routing to path traffic through the deployed NGFWs, and manage the policy with Panorama.
  • B. Deploy a VM-Series firewall in AWS in each VPC, create an IPSec tunnel between AWS and Azure, and manage the policy with Panorama.
  • C. Deploy Cloud NGFW for AWS in a centralized Security VPC, update the Transit Gateway to route all appropriate traffic through the Security VPC, and manage the policy with Panorama.
  • D. Deploy Cloud NGFW for Azure in vWAN, create a vWAN to route all appropriate traffic to the Cloud NGFW attached to the vWAN, and manage the policy with local rules.
To meet the company's requirements - minimizing changes to the cloud environments, optimizing compute resources, and unifying security policies - the best approach is to deploy Cloud NGFW solutions natively for AWS and Azure while managing policies centrally with Panorama.
In Azure, using Cloud NGFW for Azure deployed within vNETs allows traffic to be routed through security appliances efficiently without requiring a complete re-architecture. This approach aligns with Azure's existing routing mechanism while maintaining security.
In AWS, deploying Cloud NGFW for AWS in a centralized Security VPC and integrating it with AWS Transit Gateway enables traffic inspection for all connected VPCs without modifying individual workloads. This method ensures efficient scaling and minimal infrastructure changes while maintaining security consistency.
NEW QUESTION # 99
A firewall administrator needs to configure a new Palo Alto Networks firewall so that its management interface automatically obtains an IP address, netmask, and default gateway from the network. Which command should be executed in the CLI to accomplish this goal?
  • A. set deviceconfig system interface mgt mode dhcp
  • B. configure system management-interface ip dynamic
  • C. set network interface management dhcp enable
  • D. set deviceconfig system type dhcp-client
In Palo Alto Networks PAN-OS, the management interface (MGT) is distinct from the data plane interfaces.
Configuration of the management interface is handled under the deviceconfig system hierarchy within the Command Line Interface (CLI). By default, many Palo Alto Networks hardware appliances are set to a static IP address (typically 192.168.1.1), but in dynamic environments or cloud deployments, shifting to DHCP is often necessary for initial onboarding.
The correct command to enable this is set deviceconfig system type dhcp-client. When this command is executed in configuration mode, the firewall changes its management interface behavior from a static assignment to a DHCP client. Once the change is committed, the firewall will send a DHCP Discover packet out of the MGT port to obtain an IP address, subnet mask, and default gateway from a local DHCP server.
It is important to differentiate between deviceconfig (which handles system-level and management plane settings) and network (which handles data plane interfaces like Ethernet1/1). Options C and D are syntactically incorrect for PAN-OS, while Option B does not follow the standard hierarchy for system configuration. For engineers troubleshooting connectivity, verifying this setting via the command show deviceconfig system is a standard step to ensure the management plane is communicating correctly with the network infrastructure.
NEW QUESTION # 100
An organization's Security policy states that for all outbound web traffic, the TCP session to the external web server must be established by the firewall, not the user's workstation. This requires configuring user web browsers to point to the firewall. Authentication is also required.
Which solution on a PA-Series firewall meets these specific needs?
  • A. GlobalProtect with User-ID
  • B. Transparent proxy
  • C. Explicit proxy
  • D. Decryption policy with Authentication Portal
Explicit proxy requires user web browsers to be manually configured to send traffic to the firewall, and the firewall establishes the TCP session to external web servers on behalf of the client, enabling full mediation of outbound web traffic with integrated authentication support.
NEW QUESTION # 101
There are multiple choices on the versions of our NGFW-Engineer learning guide to select according to our interests and habits since we have three different versions of our NGFW-Engineer exam questions: the PDF, the Software and the APP online. The Software and APP online versions of our NGFW-Engineer preparation materials can be practiced on computers or phones. They are new developed for the reason that electronics products have been widely applied to our life and work style. The PDF version of our NGFW-Engineer Actual Exam supports printing, and you can practice with papers and take notes on it.
NGFW-Engineer Braindump Pdf: https://www.testsdumps.com/NGFW-Engineer_real-exam-dumps.html
