[General] Practice Mule-Arch-201 Test Engine | Mule-Arch-201 Actual Exams
139
【General】 Practice Mule-Arch-201 Test Engine | Mule-Arch-201 Actual Exams
Posted at 3 hour before      View:18 | Replies:0        Print      Only Author   [Copy Link] 1#
Allowing for your problems about passing the exam, our experts made all necessary points into our Mule-Arch-201 training materials, making it the most efficient way to achieve success. They can alleviate your pressure, relieve you of tremendous knowledge and master the key points with the least time. As customer-oriented company, we believe in satisfying the customers at any costs. Instead of focusing on profits, we determined to help every customer harvest desirable outcomes by our Mule-Arch-201 Training Materials. So our staff and after-sales sections are regularly interacting with customers for their further requirements and to know satisfaction levels of them.
Nowadays a lot of people start to attach importance to the demo of the study materials, because many people do not know whether the Mule-Arch-201 study materials they want to buy are useful for them or not, so providing the demo of the study materials for all people is very important for all customers. A lot of can have a good chance to learn more about the Mule-Arch-201 Study Materials that they hope to buy.
100% Pass Salesforce - Updated Practice Mule-Arch-201 Test EngineWe have applied the latest technologies to the design of our Mule-Arch-201 exam prep not only on the content but also on the displays. As a consequence you are able to keep pace with the changeable world and remain your advantages with our Mule-Arch-201 training braindumps. Besides, you can consolidate important knowledge for you personally and design customized study schedule or to-do list on a daily basis. As long as you follow with our Mule-Arch-201 Study Guide, you are doomed to achieve your success.
Salesforce Certified MuleSoft Platform Architect Sample Questions (Q122-Q127):NEW QUESTION # 122
Which layer in the API-led connectivity focuses on unlocking key systems, legacy systems, data sources etc and exposes the functionality?
  • A. System Layer
  • B. Experience Layer
  • C. Process Layer
Correct Answe r: System Layer
The APIs used in an API-led approach to connectivity fall into three categories:
System APIs - these usually access the core systems of record and provide a means of insulating the user from the complexity or any changes to the underlying systems. Once built, many users, can access data without any need to learn the underlying systems and can reuse these APIs in multiple projects.
Process APIs - These APIs interact with and shape data within a single system or across systems (breaking down data silos) and are created here without a dependence on the source systems from which that data originates, as well as the target channels through which that data is delivered.
Experience APIs - Experience APIs are the means by which data can be reconfigured so that it is most easily consumed by its intended audience, all from a common data source, rather than setting up separate point-to-point integrations for each channel. An Experience API is usually created with API-first design principles where the API is designed for the specific user experience in mind.
NEW QUESTION # 123
An organization requires several APIs to be secured with OAuth 2.0, and PingFederate has been identified as the identity provider for API client authorization, The PingFederate Client Provider is configured in access management, and the PingFederate OAuth 2.0 Token Enforcement policy is configured for the API instances required by the organization. The API instances reside in two business groups (Group A and Group B) within the Master Organization (Master Org).
What should be done to allow API consumers to access the API instances?
  • A. The API administrator should grant access to the API consumers by creating contracts in the relevant API instances in API Manager
  • B. The API administrator should configure the correct client discovery URL in both child business groups, and the API consumer should request access to the API in Ping Identity
  • C. The APL consumer should create a client application and request access to the APT in Anypoint Exchange, and the API administrator should approve the request
  • D. The APT consumer should create a client application and request access to the API in Ping Identity, and the organization's Ping Identity workflow will grant access
OAuth 2.0 and PingFederate Setup:
The organization uses PingFederate as the identity provider, integrated with Anypoint Platform for OAuth 2.0 authentication and authorization.
The PingFederate OAuth 2.0 Token Enforcement policy is applied to the API instances, requiring clients to be registered and authenticated via PingFederate.
Accessing Secured APIs:
API consumers need to register their client applications in Anypoint Exchange to request access to the secured APIs.
The API administrator then reviews and approves the access request in API Manager. This grants the client application a contract, allowing it to access the API using OAuth 2.0 tokens issued by PingFederate.
Evaluating the Options:
Option A: Configuring the client discovery URL in child business groups is not relevant to granting access; this is part of setting up PingFederate, not managing consumer access.
Option B: While creating contracts in API Manager is necessary, this option lacks the detail about the process in Anypoint Exchange, where consumers request access.
Option C (Correct Answer): API consumers must create a client application in Anypoint Exchange to request access to the API, and the API administrator then approves the request in API Manager.
Option D: The access request and approval process happens within Anypoint Platform (Exchange and API Manager), not directly in Ping Identity.
Conclusion:
Option C is the correct answer as it accurately describes the process within Anypoint Platform where API consumers request access through Exchange, and the API administrator approves it.
Refer to MuleSoft's documentation on OAuth 2.0 setup with PingFederate and managing API client access in Exchange and API Manager.
NEW QUESTION # 124
A large lending company has developed an API to unlock data from a database server and web server. The API has been deployed to Anypoint Virtual Private Cloud (VPC) on CloudHub 1.0.
The database server and web server are in the customer's secure network and are not accessible through the public internet. The database server is in the customer's AWS VPC, whereas the web server is in the customer's on-premises corporate data center.
How can access be enabled for the API to connect with the database server and the web server?
  • A. Setup a transit gateway to the customer's on-premises corporate data center through AWS VPC
  • B. Set up VPC peering with the customer's on-premises corporate data center and a VPN tunnel to AWS VPC
  • C. Set up VPC peering with AWS VPC and a VPN tunnel to the customer's on-premises corporate data center
  • D. Set up VPC peering with AWS VPC and the customer's on-premises corporate data center
Scenario Overview:
The API resides in Anypoint Virtual Private Cloud (VPC) on CloudHub 1.0, where it requires connectivity to both an AWS-hosted database server and an on-premises web server.
Both servers are isolated from the public internet: the database server is within the customer's AWS VPC, and the web server is within the customer's on-premises corporate data center.
Connectivity Requirements:
To connect to the AWS database server from the API in Anypoint VPC, VPC peering is ideal. This would allow a private network connection between the MuleSoft Anypoint VPC and the customer's AWS VPC, enabling secure, direct access to the database.
To connect to the on-premises web server, a VPN tunnel is suitable. This would establish a secure, encrypted connection from the Anypoint VPC to the customer's corporate data center, allowing secure data flow between the API and the on-premises web server.
Analysis of Options:
Option A (Correct Answer): Setting up VPC peering with AWS VPC enables private network connectivity with the database server, while a VPN tunnel to the on-premises data center allows secure access to the web server. This combination meets the requirements for secure, controlled access to both resources.
Option B: VPC peering alone would not suffice because it does not support a connection from the Anypoint VPC directly to an on-premises network. A VPN is necessary for on-premises access.
Option C: Setting up a transit gateway would provide connectivity within AWS but would not enable direct connectivity from CloudHub to the on-premises network.
Option D: VPC peering with the on-premises network is not possible because VPC peering is typically used to connect two VPCs, not a VPC with an on-premises network.
Conclusion:
Option A is the correct choice, as it provides a complete solution by using VPC peering for AWS VPC connectivity and a VPN tunnel for secure on-premises connectivity. This setup aligns with Anypoint Platform best practices for connecting Anypoint VPCs to both AWS-hosted and on-premises systems, ensuring secure, controlled access to both the database and web server.
For more detailed reference, MuleSoft documentation on Anypoint VPC peering and VPN connectivity provides additional context on best practices for setting up these connections within a hybrid network infrastructure.
NEW QUESTION # 125
An API client calls one method from an existing API implementation. The API implementation is later updated. What change to the API implementation would require the API client's invocation logic to also be updated?
  • A. When the data type of the response is changed for the method called by the API client
  • B. When a new required field is added to the method called by the API client
  • C. When a child method is added to the method called by the API client
  • D. When a new method is added to the resource used by the API client
Correct Answe r: When a new required field is added to the method called by the API client
>> Generally, the logic on API clients need to be updated when the API contract breaks.
>> When a new method or a child method is added to an API , the API client does not break as it can still continue to use its existing method. So these two options are out.
>> We are left for two more where "datatype of the response if changed" and "a new required field is added".
>> Changing the datatype of the response does break the API contract. However, the question is insisting on the "invocation" logic and not about the response handling logic. The API client can still invoke the API successfully and receive the response but the response will have a different datatype for some field.
>> Adding a new required field will break the API's invocation contract. When adding a new required field, the API contract breaks the RAML or API spec agreement that the API client/API consumer and API provider has between them. So this requires the API client invocation logic to also be updated.
NEW QUESTION # 126
What are 4 important Platform Capabilities offered by Anypoint Platform?
  • A. API Design and Development, API Deprecation, API Versioning, API Consumer Engagement
  • B. API Design and Development, API Runtime Execution and Hosting, API Versioning, API Deprecation
  • C. API Versioning, API Runtime Execution and Hosting, API Invocation, API Consumer Engagement
  • D. API Design and Development, API Runtime Execution and Hosting, API Operations and Management, API Consumer Engagement
Correct Answe r: API Design and Development, API Runtime Execution and Hosting, API Operations and Management, API Consumer Engagement
>> API Design and Development - Anypoint Studio, Anypoint Design Center, Anypoint Connectors
>> API Runtime Execution and Hosting - Mule Runtimes, CloudHub, Runtime Services
>> API Operations and Management - Anypoint API Manager, Anypoint Exchange
>> API Consumer Management - API Contracts, Public Portals, Anypoint Exchange, API Notebooks
NEW QUESTION # 127
By propagating all necessary points of knowledge available for you, our Mule-Arch-201 practice materials helped over 98 percent of former exam candidates gained successful outcomes as a result. Our Mule-Arch-201 practice materials have accuracy rate in proximity to 98 and over percent for your reference. Up to now we classify them as three versions. They are pdf, software and the most convenient one app. Each of them has their respective feature and advantage including new information that you need to know to pass the test.
Mule-Arch-201 Actual Exams: https://www.pass4surecert.com/Salesforce/Mule-Arch-201-practice-exam-dumps.html
Salesforce Practice Mule-Arch-201 Test Engine Or you are also IT person, but you do not get this kind of success, Salesforce Practice Mule-Arch-201 Test Engine A: Delivery of the goods is operated from the �Members Area�, you can try to use the version of our Mule-Arch-201 guide materials that is suitable for you, Customization features of Salesforce Certified MuleSoft Platform Architect (Mule-Arch-201) practice test software give you chance to adjust the settings of the Salesforce Certified MuleSoft Platform Architect (Mule-Arch-201) practice exams sessions, A: All purchases are activated and downloaded from your Member's Area online at Pass4sureCert Mule-Arch-201 Actual Exams.com.
Quit, quit if you can, he said to a nervous uproar of laughter, Mule-Arch-201 Soon I realized I needed to focus more on one of the teams, Or you are also IT person, but you do not get this kind of success.
Fast Download Practice Mule-Arch-201 Test Engine | Verified Mule-Arch-201 Actual Exams: Salesforce Certified MuleSoft Platform ArchitectA: Delivery of the goods is operated from the �Members Area�, you can try to use the version of our Mule-Arch-201 guide materials that is suitable for you, Customization features of Salesforce Certified MuleSoft Platform Architect (Mule-Arch-201) practice test software give you chance to adjust the settings of the Salesforce Certified MuleSoft Platform Architect (Mule-Arch-201) practice exams sessions.
A: All purchases are activated and Mule-Arch-201 Actual Exams downloaded from your Member's Area online at Pass4sureCert.com.
