[General] Exam AWS-Solutions-Architect-Associate Simulator | AWS-Solutions-Architect-Assoc
138
【General】 Exam AWS-Solutions-Architect-Associate Simulator | AWS-Solutions-Architect-Assoc
Posted at 14 hour before      View:20 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest Actual4Dumps AWS-Solutions-Architect-Associate PDF Dumps and AWS-Solutions-Architect-Associate Exam Engine Free Share: https://drive.google.com/open?id=1aKonAc8hdeRzLDElpriPE_rxyJJOZLwf
Actual4Dumps AWS-Solutions-Architect-Associate exam certification training materials is not only the foundation for you to success, but also can help you play a more effective role in the IT industry. With efforts for years, the passing rate of Actual4Dumps AWS-Solutions-Architect-Associate Certification Exam has reached as high as 100%. If you failed AWS-Solutions-Architect-Associate exam with our AWS-Solutions-Architect-Associate exam dumps, we will give a full refund unconditionally
The AWS-Solutions-Architect-Associate Certification Exam covers a broad range of topics, including AWS services and infrastructures, security and compliance, database technologies, and application deployment and management. It tests candidates' knowledge of AWS best practices, design principles, and architectures, as well as their ability to troubleshoot and optimize AWS systems.
Amazon AWS-Solutions-Architect-Associate Exam Software Makes Preparation Evaluation EasierOne of the significant advantages of our AWS-Solutions-Architect-Associate exam material is that you can spend less time to pass the exam. People are engaged in modern society. So our goal is to achieve the best learning effect in the shortest time. So our AWS-Solutions-Architect-Associate test prep will not occupy too much time. You might think that it is impossible to memorize well all knowledge. We can tell you that our AWS-Solutions-Architect-Associate Test Prep concentrate on systematic study, which means all your study is logic. Why not give us a chance to prove? Our AWS-Solutions-Architect-Associate guide question dumps will never let you down.
Amazon AWS Certified Solutions Architect - Associate (SAA-C03) Sample Questions (Q239-Q244):NEW QUESTION # 239
A company is building a serverless application to process orders from an ecommerce site. The application needs to handle bursts of traffic during peak usage hours and to maintain high availability. The orders must be processed asynchronously in the order the application receives them.
Which solution will meet these requirements?
  • A. Use an Amazon Simple Queue Service (Amazon SQS) standard queue to receive orders. Use AWS Batch jobs to process the orders.
  • B. Use an Amazon Simple Queue Service (Amazon SQS) FIFO queue to receive orders. Use an AWS Lambda function to process the orders.
  • C. Use an Amazon Simple Notification Service (Amazon SNS) topic to receive orders. Use an AWS Lambda function to process the orders.
  • D. Use an Amazon Simple Notification Service (Amazon SNS) topic to receive orders. Use AWS Batch jobs to process the orders.
Amazon SQS FIFO queuesensure that orders are processed in the exact order received and maintain message deduplication.
AWS Lambdascales automatically, handling bursts and maintaining high availability in a cost-effective manner.
Option A and D:Amazon SNS does not guarantee ordered processing.
Option C:Standard SQS queues do not guarantee order.
AWS Documentation References:
Amazon SQS FIFO Queues
NEW QUESTION # 240
A company has multiple AWS accounts with applications deployed in the us-west-2 Region Application logs are stored within Amazon S3 buckets in each account The company wants tobuild a centralized log analysis solution that uses a single S3 bucket Logs must not leave us-west-2, and the company wants to incur minimal operational overhead Which solution meets these requirements and is MOST cost-effective?
  • A. Use S3 Same-Region Replication to replicate logs from the S3 buckets to another S3 bucket in us-west-
    2 Use this S3 bucket for log analysis.
  • B. Write AWS Lambda functions in these accounts that are triggered every time logs are delivered to the S3 buckets (s3 ObjectCreated a event) Copy the logs to another S3 bucket in us-west-2. Use this S3 bucket for log analysis.
  • C. Create an S3 Lifecycle policy that copies the objects from one of the application S3 buckets to the centralized S3 bucket
  • D. Write a script that uses the PutObject API operation every day to copy the entire contents of the buckets to another S3 bucket in us-west-2 Use this S3 bucket for log analysis.
This solution meets the following requirements:
It is cost-effective, as it only charges for the storage and data transfer of the replicated objects, and does not require any additional AWS services or custom scripts. S3 Same-Region Replication (SRR) is a feature that automatically replicates objects across S3 buckets within the same AWS Region. SRR can help you aggregate logs from multiple sources to a single destination for analysis and auditing. SRR also preserves the metadata, encryption, and access control of the source objects.
It is operationally efficient, as it does not require any manual intervention or scheduling. SRR replicates objects as soon as they are uploaded to the source bucket, ensuring that the destination bucket always has the latest log data. SRR also handles any updates or deletions of the source objects, keeping the destination bucket in sync. SRR can be enabled with a few clicks in the S3 console or with a simple API call.
It is secure, as it does not allow the logs to leave the us-west-2 Region. SRR only replicates objects within the same AWS Region, ensuring that the data sovereignty and compliance requirements are met. SRR also supports encryption of the source and destination objects, using either server-side encryption with AWS KMS or S3-managed keys, or client-side encryption.
Same-Region Replication - Amazon Simple Storage Service
How do I replicate objects across S3 buckets in the same AWS Region?
Centralized Logging on AWS | AWS Solutions | AWS Solutions Library
NEW QUESTION # 241
Two Auto Scaling applications, Application A and Application B, currently run within a shared set of subnets.
A Solutions Architect wants to make sure that Application A can make requests to Application B, but Application B should be denied from making requests to Application A.
Which is the SIMPLEST solution to achieve this policy?
  • A. Migrating the applications to separate subnets from each other
  • B. Using security groups that reference the application server's IP addresses
  • C. Using security groups that reference the security groups of the other application
  • D. Using Network Access Control Lists to allow/deny traffic based on application IP addresses
https://cloud.netapp.com/blog/20 ... e-admins-view-of-th
NEW QUESTION # 242
An image hosting company uploads its large assets to Amazon S3 Standard buckets The company uses multipart upload in parallel by using S3 APIs and overwrites if the same object is uploaded again. For the first
30 days after upload, the objects will be accessed frequently. The objects will be used less frequently after 30 days, but the access patterns for each object will be inconsistent The company must optimize its S3 storage costs while maintaining high availability and resiliency of stored assets.
Which combination of actions should a solutions architect recommend to meet these requirements? (Select TWO.)
  • A. Move assets to S3 Intelligent-Tiering after 30 days.
  • B. Move assets to S3 Standard-Infrequent Access (S3 Standard-IA) after 30 days
  • C. Configure an S3 Lifecycle policy to clean up incomplete multipart uploads.
  • D. Move assets to S3 One Zone-Infrequent Access (S3 One Zone-IA) after 30 days.
  • E. Configure an S3 Lifecycle policy to clean up expired object delete markers.
S3 Intelligent-Tiering is a storage class that automatically moves data to the most cost-effective access tier based on access frequency, without performance impact, retrieval fees, or operational overhead1. It is ideal for data with unknown or changing access patterns, such as the company's assets. By moving assets to S3 Intelligent-Tiering after 30 days, the company can optimize its storage costs while maintaining high availability and resilience of stored assets.
S3 Lifecycle is a feature that enables you to manage your objects so that they are stored cost effectively throughout their lifecycle2. You can create lifecycle rules to define actions that Amazon S3 applies to a group of objects. One of the actions is to abort incomplete multipart uploads that can occur when an upload is interrupted. By configuring an S3 Lifecycle policy to clean up incomplete multipart uploads, the company can reduce its storage costs and avoid paying for parts that are not used.
Option C is incorrect because expired object delete markers are automatically deleted by Amazon S3 and do not incur any storagecosts3. Therefore, configuring an S3 Lifecycle policy to clean up expired object delete markers will not have any effect on the company's storage costs.
Option D is incorrect because S3 Standard-IA is a storage class for data that is accessed less frequently, but requires rapid access when needed1. It has a lower storage cost than S3 Standard, but it has a higher retrieval cost and a minimum storage duration charge of 30 days. Therefore, moving assets to S3 Standard-IA after 30 days may not optimize the company's storage costs if the assets are still accessed occasionally.
Option E is incorrect because S3 One Zone-IA is a storage class for data that is accessed less frequently, but requires rapid access when needed1. It has a lower storage cost than S3 Standard-IA, but it stores data in only one Availability Zone and has less resilience than other storage classes. It also has a higher retrieval cost and a minimum storage duration charge of 30 days. Therefore, moving assets to S3 One Zone-IA after 30 days may not optimize the company's storage costs if the assets are still accessed occasionally or require high availability.Reference URL: 1:https://docs.aws.amazon.com/Amaz ... torage-class-intro.
html 2: https://docs.aws.amazon.com/Amaz ... lifecycle-mgmt.html 3: https://docs.
aws.amazon.com/AmazonS3/latest/userguide/delete-or-empty-bucket.html#delete-bucket-considerations :
https://docs.aws.amazon.com/Amaz ... de/mpuoverview.html : https://aws.amazon.com
/certification/certified-solutions-architect-associate/
NEW QUESTION # 243
A user wants to use an EBS-backed Amazon EC2 instance for a temporary job. Based on the input data, the job is most likely to finish within a week. Which of the following steps should be followed to terminate the instance automatically once the job is finished?
  • A. Configure the Auto Scaling schedule activity that terminates the instance after 7 days.
  • B. Configure the CloudWatch alarm on the instance that should perform the termination action once the instance is idle.
  • C. Configure the EC2 instance with ELB to terminate the instance when it remains idle.
  • D. Configure the EC2 instance with a stop instance to terminate it.
Auto Scaling can start and stop the instance at a pre-defined time. Here, the total running time is unknown.
Thus, the user has to use the CloudWatch alarm, which monitors the CPU utilization. The user can create an alarm that is triggered when the average CPU utilization percentage has been lower than 10 percent for 24 hours, signaling that it is idle and no longer in use. When the utilization is below the threshold limit, it will terminate the instance as a part of the instance action.
http://docs.aws.amazon.com/Amazo ... ngAlarmActions.html
NEW QUESTION # 244
We will continue to pursue our passion for better performance and human-centric technology of latest AWS-Solutions-Architect-Associate quiz prep. And we guarantee you to pass the exam for we have confidence to make it with our technological strength. A good deal of researches has been made to figure out how to help different kinds of candidates to get the AWS-Solutions-Architect-Associate certification. We have made classification to those faced with various difficulties, aiming at which we adopt corresponding methods to deal with. According to the statistics shown in the feedback chart, the general pass rate for Latest AWS-Solutions-Architect-Associate Test Prep is 98%, which is far beyond that of others in this field. In recent years, our AWS-Solutions-Architect-Associate exam guide has been well received and have reached 99% pass rate with all our dedication. As one of the most authoritative question bank in the world, our study materials make assurance for your passing the AWS-Solutions-Architect-Associate exam.
AWS-Solutions-Architect-Associate Exam Simulator Free: https://www.actual4dumps.com/AWS-Solutions-Architect-Associate-study-material.html
BTW, DOWNLOAD part of Actual4Dumps AWS-Solutions-Architect-Associate dumps from Cloud Storage: https://drive.google.com/open?id=1aKonAc8hdeRzLDElpriPE_rxyJJOZLwf
