[General] Updated SalesforceOrder-Management-Administrator Exam Questions in PDF Format fo
139
【General】 Updated SalesforceOrder-Management-Administrator Exam Questions in PDF Format fo
Posted at 21 hour before      View:23 | Replies:1        Print      Only Author   [Copy Link] 1#
2026 Latest DumpExam Order-Management-Administrator PDF Dumps and Order-Management-Administrator Exam Engine Free Share: https://drive.google.com/open?id=1g3v2NgHGJx4BmIlnVS5c1JC6JERUnRxF
With our Order-Management-Administrator test prep, you don't have to worry about the complexity and tediousness of the operation. As long as you enter the learning interface of our soft test engine of Order-Management-Administrator quiz guide and start practicing on our Windows software, you will find that there are many small buttons that are designed to better assist you in your learning. When you want to correct the answer after you finish learning, the correct answer for our Order-Management-Administrator test prep is below each question, and you can correct it based on the answer. In addition, we design small buttons, which can also show or hide the Order-Management-Administrator Exam Torrent, and you can flexibly and freely choose these two modes according to your habit. In short, you will find the convenience and practicality of our Order-Management-Administrator quiz guide in the process of learning. We will also continue to innovate and improve functions to provide you with better services.
Salesforce Order-Management-Administrator Exam Syllabus Topics:
  • Advanced Topics: This topic challenges the Salesforce Order Management Administrator Consultant to diagnose and resolve configuration issues that hinder the launch or operation of Order Management processes. Proficiency includes troubleshooting integration problems and articulating how various processes interact to support successful deployments and system functionality.
  • Data Model: This topic equips the Salesforce Order Management Administrator Consultant to showcase knowledge of critical objects such as Order, Order Summary, Fulfillment Orders, and Return Orders. It involves establishing and tracing integrations with B2C Commerce or other systems, including custom attributes. Proficiency here is pivotal for ensuring seamless data flow and robust Order Management operations within complex business environments.
  • Process Automation and Integrations: This section helps the Salesforce Order Management Administrator Consultant demonstrate the capability to deliver business value by integrating Order Management with external systems using clicks rather than code. Mastery of navigation within Order Management processes, connecting nodes, and integrating systems efficiently ensures understanding of how to implement effective solutions.
  • User Experience and Customization: This section emphasizes leveraging Salesforce's Lightning UI to enhance user experiences. The Salesforce Order Management Administrator Consultant will customize experiences for users and managers through tools like the Lightning Page Editor, Report Builder, and out-of-the-box components. Success in this area ensures optimized workflows and improved operational efficiency.
Easiest and Quick Way to Crack Salesforce Order-Management-Administrator ExamOur Order-Management-Administrator study materials are written by experienced experts in the industry, so we can guarantee its quality and efficiency. The content of our Order-Management-Administrator learning guide is consistent with the proposition law all the time. We can't say it's the best reference, but we're sure it won't disappoint you. This can be borne out by the large number of buyers on our website every day. A wise man can often make the most favorable choice, I believe you are one of them. If you are not at ease before buying our Order-Management-Administrator Actual Exam, we have prepared a free trial for you. Just click on the mouse to have a look, giving you a chance to try. Perhaps this choice will have some impact on your life.
Salesforce Order Management Administrator Accredited Professional Sample Questions (Q85-Q90):NEW QUESTION # 85
Which two objects are found within Order Management?
  • A. Packing Manifest
  • B. Receipt
  • C. Cart
  • D. Payment Summary
  • E. Fulfillment Order
Answer: D,E
Two objects that are found within Order Management are:
Fulfillment Order. A Fulfillment Order is a record thatrepresents a group of products in an order that are fulfilled together from the same location. A Fulfillment Order has alookup relationship to the Order Summary object, and it contains information such as the fulfillment location, delivery method, status,etc.
Payment Summary. A Payment Summary is a record that represents a payment made for an order or part of an order. A Payment Summary has a lookup relationship to both Order Summary and Invoice objects, and it contains information such as the payment amount, method, status, etc.
Verified References: https://help.salesforce.com/s/ar ... _fulfillment_order.
htm&type=5 https://help.salesforce.com/s/ar ... nt_payment_summary.
htm&type=5
NEW QUESTION # 86
How can an administrator localize screens in the Order Management flows?
  • A. Create text localization variables in the flow
  • B. Create a copy of the flow with hard-coded text in the desired language
  • C. Add the Language Selector component at the start of the flow so users can change the language
  • D. Enable localization for the flow and modify the label's value to match the desired language
NEW QUESTION # 87
An administrator has created a new currency field on the Fulfillment Order object and wants to roll up the total to the Order Summary object. When creating a rollup field on the Order Summary object, Fulfillment Order does not appear as an option. Why is this?
  • A. The Order Summary object has reached the limit of Rollup Summary fields
  • B. Rollup Fields cannot sum Currency Fields
  • C. The Rollup Summary field must be created on the Fulfillment Order object with the Order Summary object as the parent
  • D. The Order Summary field on the Fulfillment Order object is a Lookup
The reason why Fulfillment Order does not appear as an option when creating a rollup field on the Order Summary object is that the Order Summary field on the Fulfillment Order object is a Lookup. A Lookup field is a type of custom field that creates a relationship between two objects, but does not support rollup summary fields. To create a rollup summary field, the relationship between the objects must be master-detail, which means that the child record cannot exist without its parent record. Verified Reference: https://help.salesforce.com/s/ar ... ypes.htm&type=5 https://help.salesforce.com/s/ar ... elds.htm&type=5
NEW QUESTION # 88
An administrator is encountering errors when reusing a composite APIcall to load test orders via the Workbench. What are three possible causes of this issue?
  • A. The Administratorhas logged into the wrong environment in Workbench
  • B. The administrator has duplicate Product SKUs in the JSON query
  • C. The number of subrequests in the JSON query exceeds the 20 subrequest limit
  • D. The administrator is creating multiple objects in a single JSON query
  • E. Record IDs used within the request are incorrect
Answer: B,C,E
Three possible causes of this issue are:
The administrator hasduplicate Product SKUs in the JSON query. A Product SKU is a unique identifier for a product that is used to track inventory and sales. A Product SKU must be unique within an org, and it cannot be duplicated in a composite API call. If the administrator has duplicate Product SKUs in the JSON query, it will cause an error when loading test orders via the Workbench.
The number of subrequests in the JSON query exceeds the 20 subrequest limit. A subrequest is a single HTTP request that is part of a compositeAPI call. A composite API call can contain up to 20 subrequests in a single JSON body. If the administrator has more than 20 subrequests in the JSON query, it will cause an error when loading test orders via the Workbench.
Record IDs used within the request are incorrect. A record ID is a unique identifier for a record that is used to reference and manipulate data in Salesforce. A record ID must be valid and exist in the org, and it must match the data type and format of the corresponding field. If the administrator has incorrect record IDs in the JSON query, such as using 15-character IDs instead of 18-character IDs, or using IDs from a different org, it will cause an error when loading test orders via the Workbench.
Verified References:https://developer.salesforce.com ... _rest.meta/api_rest
/resources_composite_composite.htm https://developer.salesforce.com ... _rest.meta/api_rest
/dome_composite_sobject_tree_flat.htm
NEW QUESTION # 89
Once the administrator has activated the integration between B2C Commerce and Order Management, orders being placed by customers will be sent to Order Management if the order status is set to which two values?
  • A. Drafted
  • B. Open
  • C. Created
  • D. Active
  • E. New
Answer: D,E
Once the administrator has activated the integration between B2C Commerce and Order Management, orders being placed by customers will be sent to Order Management if the order status is set to Active or New. These are the two order statuses that indicate that an order has been created or confirmed by a customer, and that it needs to be processed by Order Management. Verified Reference: https://help.salesforce.com/s/ar ... _api.htm&type=5
NEW QUESTION # 90
Immediately after you have made a purchase for our Order-Management-Administrator practice test, you can download our exam study materials to make preparations for the exams. It is universally acknowledged that time is a key factor in terms of the success of exams. The more time you spend in the preparation for Order-Management-Administrator training materials, the higher possibility you will pass the exam. And with our Order-Management-Administrator study torrent, you can make full use of those time originally spent in waiting for the delivery of exam files. There is why our Order-Management-Administrator test prep exam is well received by the general public.
Sample Order-Management-Administrator Questions Pdf: https://www.dumpexam.com/Order-Management-Administrator-valid-torrent.html
P.S. Free & New Order-Management-Administrator dumps are available on Google Drive shared by DumpExam: https://drive.google.com/open?id=1g3v2NgHGJx4BmIlnVS5c1JC6JERUnRxF
Posted at 9 hour before        Only Author  2#
This is so good, I'm liking it without a doubt. I’m offering the New L4M6 exam lab questions test that helped me advance in my career with a promotion and raise. It’s available for free today. I hope you succeed in your career!
