[General] Valid Qlik QSSA2021 Test Syllabus | Top QSSA2021 Questions
135
【General】 Valid Qlik QSSA2021 Test Syllabus | Top QSSA2021 Questions
Posted at 11 hour before      View:19 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest PDFDumps QSSA2021 PDF Dumps and QSSA2021 Exam Engine Free Share: https://drive.google.com/open?id=1GivMph-pgOEN2q7iwFFrmEOPARahhGoT
Our QSSA2021 study materials can provide you with multiple modes of experience, there are three main modes to choose from: PDF, Software and Online. Firstly, the PDF version is printable. Secondly, the Software version of QSSA2021 exam questions can simulate the real exam environment to give you exam experience more vividly. Thirdly, the online version supports all web browsers so that it can be worked on all the operating systems. And our QSSA2021 Study Materials will help you in a more relaxed learning atmosphere to pass the QSSA2021 exam.
Qlik QSSA2021 (Qlik Sense System Administrator Certification Exam - February 2021 Release) Certification Exam is a highly sought-after certification exam that tests an individual’s knowledge and expertise in managing and administering Qlik Sense, a leading data analytics and visualization platform. QSSA2021 Exam is designed for professionals who are responsible for the deployment, configuration, management, and maintenance of Qlik Sense environments, and who have a deep understanding of the platform’s architecture, security, and scalability.
Top QSSA2021 Questions - QSSA2021 Best VceStudying for attending QSSA2021 exam pays attention to the method. The good method often can bring the result with half the effort, therefore we in the examination time, and also should know some test-taking skill. The QSSA2021 quiz guide on the basis of summarizing the past years, the answers have certain rules can be found, either subjective or objective questions, we can find in the corresponding module of similar things in common. To this end, the QSSA2021 Exam Dumps have summarized some types of questions in the qualification examination to help you pass the QSSA2021 exam.
Qlik Sense System Administrator Certification Exam - February 2021 Release Sample Questions (Q158-Q163):NEW QUESTION # 158
A company has Qlik Sense streams based on departments. Users must NOT be able to access apps from streams of other departments. A user has recently moved from Sales to Marketing. The domain administrator correctly updates the user's group membership in Active Directory.
How should the system administrator confirm that the user can NO longer access the apps in the Sales stream?
  • A. In the QMC, from the Start menu, select Streams Highlight Marketing, click Edit, and then select User Access and view the audit
  • B. In the QMC, from the Start menu, select Users Highlight the user's name, click Edit, and then select User Access and view the audit
  • C. In the QMC, from the Start menu, select Streams Highlight Sales, click Edit, and then select User Access and view the audit
  • D. In the QMC, from the Start menu, select Users Highlight the user's name, click Edit, and then select Owned items and view the audit
NEW QUESTION # 159
Which two of the following options are essential when creating automated tasks in Qlik Sense? (Select two)
  • A. Setting task dependencies
  • B. Configuring multi-threaded processing for each task
  • C. Assigning load balancing rules to each task
  • D. Setting up task triggers
NEW QUESTION # 160
A domain user had access and was able to successfully log into the hub the day before. You use the same user and domain credentials to sign in to today's hub and receive this error message: "Your account is inactive.
Contact your administrator to activate it".The user is able to successfully authenticate to the Windows domain network, proxy and internet browsing. The user has not changed the password recently.
What should the system administrator investigate to determine the cause of the problem and resolve?
  • A. User properties in QMC
  • B. Security rules that may interfere with user authentication
  • C. View Windows operating system events (Event Viewer)
  • D. Proxy log files on the Qlik Sense server
NEW QUESTION # 161
What is a primary benefit of using a subscription-based license model in Qlik Sense?
  • A. Free updates for lifetime
  • B. One-time payment with unlimited usage
  • C. Flexibility to scale users based on business needs
  • D. No requirement for license allocation
NEW QUESTION # 162
A security audit revealed problems with the newly installed multi-node environment. The environment was deployed using the default settings for the central and nm nodes. All possible services have been added to the rim node.
The audit was based on the current IT security policy which states:
- All traffic between servers should be encrypted
- 2 56-bit encryption is required
- Traffic between client and server should be encrypted and trusted
- iOS devices must De supported
- Password length must be at least eight characters and include at least one number and one special character What should the system administrator deploy to meet these requirements?
  • A. A third-party trusted certificate
  • B. A web app firewall in the environment
  • C. A reverse proxy in the DMZ
  • D. A certificate with third-party VPN
NEW QUESTION # 163
In order to further strengthen your confidence to buy the QSSA2021 Training Materials of us, we offer you 100% money back guarantee in case you fail the exam. The money will be refund to your account and no extra questions will be asked. Additionally, QSSA2021 exam braindumps of us have helped many candidates pass the exam successfully with their high-quality. And we have professional technicians examine the update every day, and once we have new version, our system will send the latest version to your email automatically.
Top QSSA2021 Questions: https://www.pdfdumps.com/QSSA2021-valid-exam.html
